Home » Archived » M2M (model-to-model transformation) » Syntax for Math.pow() funtion in ATL
Syntax for Math.pow() funtion in ATL [message #482062] Tue, 25 August 2009 09:46 Go to next message
I wanted to some mathematical calculation in ATL.
The following code is written in java
double maxDouble = Math.pow(2, 223*8) - 1;
long maxUIntValue = Math.min((long)maxDouble, Long.MAX_VALUE);
I wanted to do same thing in ATL but i don't know how these pow() & min()
functions are defined in ATL.
venkatesh
[ATL] Re: Syntax for Math.pow() funtion in ATL [message #482143 is a reply to message #482062] Tue, 25 August 2009 13:10 Go to previous messageGo to next message
There is no pow() function in ATL, but you can do it using exp() and
log() functions, which are available in ATL, as the min() function.
Here is the list of the numerical functions in ATL:
http://wiki.eclipse.org/ATL/User_Guide#Numerical_data_type_o perations
William
venkatesh a écrit :
> min() functions are defined in ATL.
> Thanks
> venkatesh
Re: [ATL] Re: Syntax for Math.pow() funtion in ATL [message #482740 is a reply to message #482143] Thu, 27 August 2009 17:57 Go to previous messageGo to next message
Thanks for your valuable input.
venkatesh
Re: [ATL] Re: Syntax for Math.pow() funtion in ATL [message #483587 is a reply to message #482143] Wed, 02 September 2009 09:01 Go to previous messageGo to next message
Hello William ,
I have tried using exp () and log funtion instead of power and min math
funtion in java
if i give let var :Integer= 2.exp()
it's working fine
but i want 2 raise to the power 8 (2^8) how to represent
this in a exp()
there is no example to use this exp() & log() function .
can u please give me some example.
venkatesh
Re: [ATL] Re: Syntax for Math.pow() funtion in ATL [message #483620 is a reply to message #483587] Wed, 02 September 2009 11:15 Go to previous messageGo to next message
This page http://en.wikipedia.org/wiki/Exponentiation#Real_powers
indicates that you can compute pow with exp and log functions:
b^x = exp(x*log(b))
William
venkatesh a écrit :
> Hello William ,
> funtion in java
> if i give let var :Integer= 2.exp() it's working fine
> but i want 2 raise to the power 8 (2^8) how to represent this in a exp()
> Thanks
> venkatesh
Re: [ATL] Re: Syntax for Math.pow() funtion in ATL [message #483840 is a reply to message #483620] Thu, 03 September 2009 10:16 Go to previous message
Hello William,
I have given like this
from
v_left: LdmMetaModel!LDMAttribute
using{
---- syntax error
maxvalue: Real =exp(3*log(3))
but it's showing error.can u tell me how to represent this in an atl file.
thanks
venkatesh
Previous Topic:[QVTO] Integrating of QVT Editor in my RCP Application
Next Topic:[ATL] inconsistency in handling of enums in emfvm
Current Time: Thu Feb 13 03:47:50 GMT 2025
Powered by FUDForum. Page generated in 0.03515 seconds
