Home » Archived » M2M (model-to-model transformation) » [ATL] Executing ATL transformations by using ANT scripts: profiled models
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #48935 is a reply to message #48875] |
Mon, 25 June 2007 12:10 |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Bea a écrit :
> Hello,
Hello Bea,
> I am trying to execute a transformation from an ANT script whose source
> model is a stereotyped class diagram.
> A part of the script is:
> <am3.loadModel name="IN" metamodel="UML2"
> path="${inputModelsPath}FirstStereotypedClassDiagram.uml2"/ >
> I have the error:
> [am3.loadModel] Loading of model IN
> [am3.loadModel] org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
> with uri 'http:///Profile_15_E25RgN3OEdudm7Bb3-eRQg.profile.uml2' not found.
> (platform:/resource/Prueba/src/prueba/popup/actions/InputMod els/FirstStereotypedClassDiagram.uml2,
> 137, -1)
> Does anybody know if I have to load the applied Profile too?
Yes, you also have to load the "profile" model using the same way as for
another UML2 model.
> Thank you
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #49012 is a reply to message #48963] |
Mon, 25 June 2007 12:34 |
Bea a écrit :
> Thank you Hugo, but I get the same error. I have:
> <am3.loadModel name="ProIni" metamodel="UML2"
> path="${inputModelsPath}Profile.profile.uml2"/>
> And I get:
> [am3.loadModel] Loading of model ProIni
> 137, -1)
> Any idea?
By default, the model handler used by the "loadModel" task is EMF.
You may use the UML2 model handler for loading UML2 models and metamodels:
<am3.loadModel modelHandler="UML2" name="UML2" metamodel="MOF"
nsUri="http://www.eclipse.org/uml2/2.0.0/UML"/>
<am3.loadModel modelHandler="UML2" name="ProIni" metamodel="UML2"
<am3.loadModel modelHandler="UML2" name="IN" metamodel="UML2"
You can get the UML2 model handler by checking out the
"org.eclipse.m2m.atl.drivers.uml24atl" plugin from the Eclipse CVS
(see http://wiki.eclipse.org/index.php/ATL/How_Install_ATL_From_C VS/).
Note that this plugin also requires Eclipse/MDT UML2 to be installed.
> "Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> escribió en el mensaje
> news:f5obbi$1bs$1@build.eclipse.org...
>> Bea a écrit :
>>> Hello,
>> Hello Bea,
>>> I have the error:
>>> Package with uri 'http:///Profile_15_E25RgN3OEdudm7Bb3-eRQg.profile.uml2'
>>> not found.
>>> 137, -1)
>> another UML2 model.
>>> Thank you
>> Best regards,
>> Hugo
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #49219 is a reply to message #49175] |
Tue, 26 June 2007 09:18 |
Hello Bea,
Bea a écrit :
> I have checked out those two plugins. The
> org.eclipse.m2m.atl.drivers.uml24atl project has errors because it doesn't
> find some packages. I have added pluging dependencies in order not to have
> any error and I get it, but I have the same error with the UML2 model
> handler,
> Any idea?
> Thank you in advance.
I am sorry if you encountered some problems because of my yesterday's
email. I thought you were already using ATL sources instead of ATL
binaries, that's why I told you to checkout the "uml24atl" driver from
the Eclipse CVS.
In order to always get the latest version of ATL and its IDE, I advise
you to use the ATL sources instead of using the binaries versions
available from the ATL download page.
To do so, you have to follow the process described in the Wiki page "How
Install ATL From CVS". You must checkout the ATL plugins into the
workspace of a first Eclipse and then you have to launch a second
Eclipse from the first one in order to load the plugins. You can work
using ATL in the second Eclipse.
Note that you don't need to checkout the "mdr4atl" driver's plugin if
you don't need to use MDR as model handler (and I think it's the case).
You may also follow the same process for the AM3 plugins except that:
--> the repository path is "/cvsroot/technology" (instead of
"/cvsroot/modeling")
--> the plugins to checkout are in "HEAD->org.eclipse.gmt->AM3"
|-> org.eclipse.am3.core, org.eclipse.am3.tools.tge,
org.eclipse.am3.ui, org.eclipse.gmt.am3.dsls.km3,
org.eclipse.gmt.am3.tools.ant
I hope this will help you.
Hugo
> "William Piers" <william.piers@obeo.fr> escribió en el mensaje
> news:f5ork4$524$1@build.eclipse.org...
>>> Hello,
>>> do you know if I all these new projects have to be directly in the
>>> workspace or in my plug-in project?
>> They have to be directly in the workspace.
>> Bea a écrit :
>>> The thing is that following the Hugo's email, I only have to check out
>>> org.eclipse.m2m.atl.drivers.uml24atl and org.eclipse.mdt/org.eclipse.uml.
>>> And following
>>> http://wiki.eclipse.org/index.php/ATL/How_Install_ATL_From_C VS/ I don't
>>> have to do anything with these plugins.
>> Ok, sorry. I thought that you checked out mdr4atl too, which requires
>> additional libraries.
>> William Piers
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #49383 is a reply to message #49353] |
Tue, 26 June 2007 13:31 |
Bea a écrit :
> Now I only have errors in the org.eclipse.m2m.atl.drivers.uml24atl and
> org.eclipse.m2m.atl.adt.editor plugins.
> I am using the ATLBundle-20060501.
The problem is that the latest versions of ATL are not compatible with
this version of the bundle (as the ATL component has moved from the GMT
to the M2M project).
The better solution is to install a new Eclipse with only the EMF and
UML2 plugins. Then, you can launch this Eclipse and checkout the ATL &
AM3 plugins as I explained in my previous email. Finally, you can start
another Eclipse from the first one to load the ATL & AM3 plugins.
We are currently testing the latest ATL & AM3 version with the Eclipse
Europa release (i.e. Eclipse 3.3, EMF 2.3, UML2 2.1) and we don't find
any major problem for the moment. You can download these versions.
By doing that, you will have the latest version of ATL ;-)
> "Bea" <beaperez@unizar.es> escribió en el mensaje
> news:f5qo36$4pv$1@build.eclipse.org...
>> Thank you very much Hugo, but It doesn't work. When I check out the
>> plugins almost all of them have errors (they have the red cross), so when
>> I try to lunch the second Eclipse, an error window appears.
>> I am a bit lost, I would be very grateful if you could help me.
>> news:f5qlka$tth$1@build.eclipse.org...
>>> Hello Bea,
>>>> doesn't find some packages. I have added pluging dependencies in order
>>>> not to have any error and I get it, but I have the same error with the
>>>> UML2 model handler,
>>>> Any idea?
>>> the Eclipse CVS.
>>> workspace of a first Eclipse and then you have to launch a second Eclipse
>>> from the first one in order to load the plugins. You can work using ATL
>>> Note that you don't need to checkout the "mdr4atl" driver's plugin if you
>>> |-> org.eclipse.am3.core, org.eclipse.am3.tools.tge, org.eclipse.am3.ui,
>>> org.eclipse.gmt.am3.dsls.km3, org.eclipse.gmt.am3.tools.ant
>>> Best regards,
>>> Hugo
>>>>>> Hello,
>>>>>> org.eclipse.mdt/org.eclipse.uml. And following
>>>>>> don't have to do anything with these plugins.
>>>>> William Piers
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #49716 is a reply to message #49383] |
Wed, 27 June 2007 14:31 |
Originally posted by: jean-pierre.bourey.ec-lille.fr
Hi everybody,
Following your Hugo's advices, I have just installed (from scratch)
-Eclipse 3.3 (Build I20070621-1340),
-EMF 2.3 (v200706251320)
-MDT-UML2 (v200706251652)
and from CVS, the latest version of ATL and AM3 plugins.
I have written a simple transformation from Petri Nets to UML Activity
Diagrams
When I run the transformation by the menu "Run->Open Run Dialog" using the
parameters you can see on the screenshot in attached file named "run
configuration.png" , I obtain the result I expected and I can open the
result with the UML editor (screenshot in the attached file
"expectedResult.png")
But, when I use the build.xml script (see atteched file) , I can't open the
result with the UML editor. When I compare the 2 files I see
1) in the "good" result ("manual" run configuration) :
<?xml version="1.0" encoding="ISO-8859-1"?>
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
xmi:id="_28NZICS3EdyzOPBFDStLfg" name="FirstPN">
<packagedElement xmi:type="uml:Activity" xmi:id="_28NZISS3EdyzOPBFDStLfg"
name="PN_Example1">
<node xmi:type="uml:OpaqueAction" xmi:id="_28NZIiS3EdyzOPBFDStLfg" name="P2"
outgoing="_28NZKiS3EdyzOPBFDStLfg" incoming="_28NZKCS3EdyzOPBFDStLfg"/>
<node xmi:type="uml:OpaqueAction" xmi:id="_28NZIyS3EdyzOPBFDStLfg" name="P1"
outgoing="_28NZKCS3EdyzOPBFDStLfg" incoming="_28NZJyS3EdyzOPBFDStLfg"/>
<node xmi:type="uml:InitialNode" xmi:id="_28NZJCS3EdyzOPBFDStLfg"
outgoing="_28NZJSS3EdyzOPBFDStLfg"/>
<node xmi:type="uml:MergeNode" xmi:id="_28NZJiS3EdyzOPBFDStLfg" name="MG_P1"
outgoing="_28NZJyS3EdyzOPBFDStLfg" incoming="_28NZJSS3EdyzOPBFDStLfg
_28NZKiS3EdyzOPBFDStLfg"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_28NZJSS3EdyzOPBFDStLfg"
source="_28NZJCS3EdyzOPBFDStLfg" target="_28NZJiS3EdyzOPBFDStLfg"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_28NZJyS3EdyzOPBFDStLfg"
source="_28NZJiS3EdyzOPBFDStLfg" target="_28NZIyS3EdyzOPBFDStLfg"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_28NZKCS3EdyzOPBFDStLfg" name="T1"
source="_28NZIyS3EdyzOPBFDStLfg" target="_28NZIiS3EdyzOPBFDStLfg">
<weight xmi:type="uml:LiteralInteger" xmi:id="_28NZKSS3EdyzOPBFDStLfg"
name="weight of P1->T1"/>
</edge>
<edge xmi:type="uml:ControlFlow" xmi:id="_28NZKiS3EdyzOPBFDStLfg" name="T2"
source="_28NZIiS3EdyzOPBFDStLfg" target="_28NZJiS3EdyzOPBFDStLfg">
<weight xmi:type="uml:LiteralInteger" xmi:id="_28NZKyS3EdyzOPBFDStLfg"
name="weight of P2->T2"/>
</edge>
</packagedElement>
</uml:Model>
2) in the bad result (with ant script)
<uml:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" name="FirstPN">
<packagedElement xsi:type="uml:Activity" name="PN_Example1">
<node xsi:type="uml:OpaqueAction" name="P2" outgoing="//PN_Example1/T2"
incoming="//PN_Example1/T1"/>
<node xsi:type="uml:OpaqueAction" name="P1" outgoing="//PN_Example1/T1"
incoming="//PN_Example1/@edge.1"/>
<node xsi:type="uml:InitialNode" outgoing="//PN_Example1/@edge.0"/>
<node xsi:type="uml:MergeNode" name="MG_P1" outgoing="//PN_Example1/@edge.1"
incoming="//PN_Example1/@edge.0 //PN_Example1/T2"/>
<edge xsi:type="uml:ControlFlow" source="//PN_Example1/@node.2"
target="//PN_Example1/MG_P1"/>
<edge xsi:type="uml:ControlFlow" source="//PN_Example1/MG_P1"
target="//PN_Example1/P1"/>
<edge xsi:type="uml:ControlFlow" name="T1" source="//PN_Example1/P1"
target="//PN_Example1/P2">
<weight xsi:type="uml:LiteralInteger" name="weight of P1->T1"/>
</edge>
<edge xsi:type="uml:ControlFlow" name="T2" source="//PN_Example1/P2"
target="//PN_Example1/MG_P1">
<weight xsi:type="uml:LiteralInteger" name="weight of P2->T2"/>
</edge>
</packagedElement>
</uml:Model>
My questions are :
1) why are they different? (especially xmiversion and links betweens
elements)
2) how to get the same (good) result with ant script?
Subsidiary questions:
3) when I use UML2 as model handler for the UML metamodel, it works with the
configuration dialog box, but raises an exception with the ant script
3) when I try to use UML2 as model handler for the Petri net metamodel
(using PetriNetMM.uml as file), it raises an exception with both run methods
Any help will be very appreciated
best regards
jean-pierre
"Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> a
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #49747 is a reply to message #49716] |
Wed, 27 June 2007 15:20 |
Hello Jean-Pierre,
Jean-Pierre Bourey a écrit :
> Hi everybody,
> Diagrams
> name="PN_Example1">
> </edge>
> </edge>
> </packagedElement>
> </uml:Model>
> </edge>
> </edge>
> </packagedElement>
> </uml:Model>
> My questions are :
> elements)
This "good" result is obtained because the model is serialized using the
UML driver (and extractor) whereas the "bad" result is obtained because
the model is serialized using the EMF driver (and extractor).
You have to load the UML2 metamodel with the UML2 modelHandler (see
answer to your question 3) and to precise a path in the "outModel" markup:
<outModel name="OUT" model="targetUmlModel" metamodel="UML2MM"
path="/PN2UMLAD/OutputModels/${model}.uml">
and keep the call to the "saveModel" task as it is.
Doing this, it may works.
I do this
and do not see any error. Do you have checked-out the latest version of
AM3 (committed today afternoon)?
Do you still have errors with this latest version?
"PetriNetMM.uml" is a UML2 model, i.e. a model that conforms to the UML2
metamodel (which conforms to the MOF metametamodel). This is not a
metamodel, but it is possible to generate a metamodel from this UML
model: see http://www.eclipse.org/m2m/atl/usecases/UML2MOF/
Hugo
> best regards
> jean-pierre
> "Hugo Bruneliere" <Hugo.Bruneliere@univ-nantes.fr> a écrit dans le message
> de news: f5r4fg$8s3$1@build.eclipse.org...
>>>> when
>>>> mensaje
>>>>> Hello Bea,
>>>>>> UML2 model handler,
>>>>>> Any idea?
>>>>> the Eclipse CVS.
>>>>> "How
>>>>> Eclipse
>>>>> you
>>>>> org.eclipse.am3.ui,
>>>>> Best regards,
>>>>> Hugo
>>>>>>>> Hello,
>>>>>>>> out
>>>>>>> William Piers
> <project name="PN2UMLAD" default="transfo">
> <!-- Change this value if you want to use another input model -->
> <property name="model"
> value="MyFirstPetriNet"/>
> <target name="loadMetaModels">
> <!-- Load UML 2.1 metamodel-->
> <am3.loadModel modelHandler="EMF"
> name="UML2MM"
> metamodel="MOF"
> nsuri="http://www.eclipse.org/uml2/2.1.0/UML"/>
> <!-- Load PN metamodel-->
> name="PetriNetMM"
> metamodel="MOF"
> path="/PN2UMLAD/MetaModels/PetriNetMM.ecore"/>
> </target>
> <target name="transfo"
> depends="loadMetaModels">
> <am3.loadModel name="sourcePNModel"
> metamodel="PetriNetMM"
> path="/PN2UMLAD/InputModels/${model}.ecore"/>
> <am3.atl path="/PN2UMLAD/Transformations/PN2UMLAD_V3.asm">
> <inModel name="IN"
> model="sourcePNModel"/>
> <inModel name="UML2"
> model="UML2MM"/>
> <inModel name="PetriNetMM"
> model="PetriNetMM"/>
> metamodel="UML2MM"/>
> </am3.atl>
> <am3.saveModel model="targetUmlModel"
> path="/PN2UMLAD/OutputModels/${model}.uml"/>
> </target>
> </project>
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #50119 is a reply to message #49532] |
Fri, 29 June 2007 09:44 |
Bea a écrit :
> I have installed Eclipse 3.1, with EMF and UML2 1.1.1.
> I have check out ATL and AM3 as you have explained to me.
> But I get some errors in org.eclipse.m2m.atl.adt.editor and
> org.eclipse.m2m.atl.drivers.uml24atl. Perhaps I need to check out those
> plugins (ATL and AM3) from another repository?
Hello Bea,
I have submitted a bug and a patch in order to delete the dependence to
the UML2 plugin from the "uml24atl" driver:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194894
So when the patch will be integrated, it may work ;-)
But in my opinion, your problem is more a problem of upward
compatibility in UML2 than a problem with ATL.
Are your UML2 1.1 models compatible with UML2 2.0 or 2.1? I have never
testing this so I don't know, but the Eclipse/MDT project may provide
some ways to ensure this compatibility (at least converters from a
version to another)...
I think you should now try to use latest versions of Eclipse, EMF and
UML2 or you will probably encounter more problems later.
Hugo
> news:f5rlbh$5u6$1@build.eclipse.org...
>> I need org.eclipse.uml2.uml.jar and org.eclipse.core.runtime.ListenerList,
>> Does anybody know where I can find these .jar?
>> news:f5raii$3bh$1@build.eclipse.org...
>>> Nothing I get the same errors in those two packages. I am trying with
>>> Eclipse 3.1 because all my models are created in UML2 for that version. I
>>> don't know what to do. Any help?
>>> news:f5r4fg$8s3$1@build.eclipse.org...
>>>>>> when I try to lunch the second Eclipse, an error window appears.
>>>>>> mensaje news:f5qlka$tth$1@build.eclipse.org...
>>>>>>> Hello Bea,
>>>>>>>> order not to have any error and I get it, but I have the same error
>>>>>>>> with the UML2 model handler,
>>>>>>>> Any idea?
>>>>>>> from the Eclipse CVS.
>>>>>>> advise you to use the ATL sources instead of using the binaries
>>>>>>> versions available from the ATL download page.
>>>>>>> "How Install ATL From CVS". You must checkout the ATL plugins into
>>>>>>> the workspace of a first Eclipse and then you have to launch a second
>>>>>>> case).
>>>>>>> Best regards,
>>>>>>> Hugo
>>>>>>>>>> Hello,
>>>>>>>>>> out org.eclipse.m2m.atl.drivers.uml24atl and
>>>>>>>>> requires additional libraries.
>>>>>>>>> William Piers
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #51562 is a reply to message #51511] |
Mon, 09 July 2007 09:18 |
Bea a écrit :
> Hello,
Hello Bea,
> I am working now with Eclipse 3.2 and I have installed UML24ATL plugin. When
> I try to load the profile from the ant script I get the error:
> [am3.loadModel] Loading of model PRO
> [am3.loadModel] java.lang.NullPointerException
> [am3.loadModel] at
> org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModel.addReferenc edExtentsFor
> Any idea? Thank you very much in advance.
Is it possible to see your ANT script & transformation file's header?
> Bea
> news:f62k97$qe2$1@build.eclipse.org...
>> Hello Bea,
>> But in my opinion, your problem is more a problem of upward compatibility
>> testing this so I don't know, but the Eclipse/MDT project may provide some
>> ways to ensure this compatibility (at least converters from a version to
>> another)...
>> I think you should now try to use latest versions of Eclipse, EMF and UML2
>> Best regards,
>> Hugo
>>>> org.eclipse.core.runtime.ListenerList, Does anybody know where I can
>>>> find these .jar?
>>>>> I don't know what to do. Any help?
>>>>> mensaje news:f5r4fg$8s3$1@build.eclipse.org...
>>>>>>> and org.eclipse.m2m.atl.adt.editor plugins.
>>>>>> GMT to the M2M project).
>>>>>> start another Eclipse from the first one to load the ATL & AM3
>>>>>> plugins.
>>>>>>>>> Hello Bea,
>>>>>>>>>> error with the UML2 model handler,
>>>>>>>>>> Any idea?
>>>>>>>>> yesterday's email. I thought you were already using ATL sources
>>>>>>>>> instead of ATL binaries, that's why I told you to checkout the
>>>>>>>>> "uml24atl" driver from the Eclipse CVS.
>>>>>>>>> second Eclipse from the first one in order to load the plugins. You
>>>>>>>>> can work using ATL in the second Eclipse.
>>>>>>>>> if you don't need to use MDR as model handler (and I think it's the
>>>>>>>>> case).
>>>>>>>>> that:
>>>>>>>>> Best regards,
>>>>>>>>> Hugo
>>>>>>>>>>>> Hello,
>>>>>>>>>>>> the workspace or in my plug-in project?
>>>>>>>>>>>> check out org.eclipse.m2m.atl.drivers.uml24atl and
>>>>>>>>>>>> I don't have to do anything with these plugins.
>>>>>>>>>>> William Piers
Hugo
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #51988 is a reply to message #51936] |
Wed, 11 July 2007 08:23 |
Hi Bea,
Could you send us your ATL project so that we can test it on our own
Eclipse install?
Hugo
Bea a écrit :
> I have realised that if I tried to execute my ATL transformation in this
> second Eclipse I obtain the same error, then it is not the ant script.
> Any idea?
> Bea
> news:f6sv0n$j5v$1@build.eclipse.org...
>> Yes, the senteces of the ANT script are:
>> <project default="transfo">
>> <property name="projectPath" value="/Plugin/src/plugin/popup/actions/"/>
>> <property name="inputModelsPath" value="${projectPath}InputModels/"/>
>> <property name="outputModelsPath" value="${projectPath}OutputModels/"/>
>> <property name="firstTransformationPath"
>> value="${projectPath}ATLFiles/First/"/>
>> <property name="secondTransformationPath"
>> value="${projectPath}ATLFiles/Second/"/>
>> <!--Load UML 2.0 metamodel-->
>> </target>
>> <target name="transfo" depends="loadMetaModels">
>> <property name="targetModel" value="FirstTargetModel"/>
>> <property name="transformation" value="firstTransformation"/>
>> <am3.loadModel modelHandler="UML2" name="PRO" metamodel="UML2"
>> path="${inputModelsPath}Profile.profile.uml"/>
>> path="${inputModelsPath}Source.uml"/>
>> <am3.atl path="${firstTransformationPath}${transformation}.asm">
>> <inModel name="IN" model="UML2"/>
>> <inModel name="UML" model="UML2"/>
>> <inModel name="PRO" model="UML2"/>
>> <library name="strings" path="${firstTransformationPath}strings.asm" />
>> <library name="Multiplicities"
>> path="${firstTransformationPath}Multiplicities.asm" />
>> <library name="Profile" path="${firstTransformationPath}Profile.asm" />
>> <outModel name="OUT" model="firstTargetUmlModel" metamodel="UML2"/>
>> </am3.atl>
>> <am3.saveModel model="firstTargetUmlModel"
>> path="${outputModelsPath}${targetModel}.uml"/>
>> </target>
>> </project>
>> and the header of the transformation file is;
>> module firstTransformation; -- Module Template
>> create OUT : UML from IN : UML, PRO : UML;
>> news:f6suga$g7a$2@build.eclipse.org...
>>> Bea a écrit :
>>>> Hello,
>>> Hello Bea,
>>>> When I try to load the profile from the ant script I get the error:
>>>> [am3.loadModel] at
>>>> Bea
>>>> mensaje news:f62k97$qe2$1@build.eclipse.org...
>>>>>> those plugins (ATL and AM3) from another repository?
>>>>> Hello Bea,
>>>>> Best regards,
>>>>> Hugo
>>>>>>> find these .jar?
>>>>>>>> with Eclipse 3.1 because all my models are created in UML2 for that
>>>>>>>> version. I don't know what to do. Any help?
>>>>>>>>> with this version of the bundle (as the ATL component has moved
>>>>>>>>> from the GMT to the M2M project).
>>>>>>>>> and UML2 plugins. Then, you can launch this Eclipse and checkout
>>>>>>>>> the ATL & AM3 plugins as I explained in my previous email. Finally,
>>>>>>>>> you can start another Eclipse from the first one to load the ATL &
>>>>>>>>> AM3 plugins.
>>>>>>>>> Eclipse Europa release (i.e. Eclipse 3.3, EMF 2.3, UML2 2.1) and we
>>>>>>>>> don't find any major problem for the moment. You can download these
>>>>>>>>> versions.
>>>>>>>>>>> the plugins almost all of them have errors (they have the red
>>>>>>>>>>> cross), so when I try to lunch the second Eclipse, an error
>>>>>>>>>>> window appears.
>>>>>>>>>>>> Hello Bea,
>>>>>>>>>>>>> it doesn't find some packages. I have added pluging
>>>>>>>>>>>>> dependencies in order not to have any error and I get it, but I
>>>>>>>>>>>>> have the same error with the UML2 model handler,
>>>>>>>>>>>>> Any idea?
>>>>>>>>>>>> page "How Install ATL From CVS". You must checkout the ATL
>>>>>>>>>>>> plugins into the workspace of a first Eclipse and then you have
>>>>>>>>>>>> to launch a second Eclipse from the first one in order to load
>>>>>>>>>>>> the plugins. You can work using ATL in the second Eclipse.
>>>>>>>>>>>> plugin if you don't need to use MDR as model handler (and I
>>>>>>>>>>>> that:
>>>>>>>>>>>> Best regards,
>>>>>>>>>>>> Hugo
>>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>>> in the workspace or in my plug-in project?
>>>>>>>>>>>>>> William Piers
>>> Best regards,
>>> Hugo
Re: [ATL] Executing ATL transformations by using ANT scripts: profiled models [message #52068 is a reply to message #51988] |
Wed, 11 July 2007 13:48 |
Hi Bea,
We succeeded in loading your UML profile by deleting, in the "UML"
annotation from the root of the profile model, all the packages
excepting the first one (i.e. keep the "StatechartProfile" one and
delete the "StatechartProfile_XX" ones).
The information was duplicated several times and it does not seem to be
useful. Moreverer, there were some attributes whose data type was not
specified was not good (and it was the origin of the errors).
Which UML CASE tool did you produce this model with?
Hugo
Hugo Bruneliere a écrit :
> Hi Bea,
> Eclipse install?
> Best regards,
> Hugo
>> this second Eclipse I obtain the same error, then it is not the ant
>> script.
>> Any idea?
>> Bea
>>> </target>
>>> </am3.atl>
>>> </target>
>>> </project>
>>> mensaje news:f6suga$g7a$2@build.eclipse.org...
>>>> Bea a écrit :
>>>>> Hello,
>>>> Hello Bea,
>>>>> plugin. When I try to load the profile from the ant script I get
>>>>> the error:
>>>>> [am3.loadModel] at
>>>>> Bea
>>>>>> Hello Bea,
>>>>>> dependence to the UML2 plugin from the "uml24atl" driver:
>>>>>> never testing this so I don't know, but the Eclipse/MDT project
>>>>>> may provide some ways to ensure this compatibility (at least
>>>>>> converters from a version to another)...
>>>>>> and UML2 or you will probably encounter more problems later.
>>>>>> Best regards,
>>>>>> Hugo
>>>>>>>>> trying with Eclipse 3.1 because all my models are created in
>>>>>>>>> UML2 for that version. I don't know what to do. Any help?
>>>>>>>>> el mensaje news:f5r4fg$8s3$1@build.eclipse.org...
>>>>>>>>>> compatible with this version of the bundle (as the ATL
>>>>>>>>>> component has moved from the GMT to the M2M project).
>>>>>>>>>> EMF and UML2 plugins. Then, you can launch this Eclipse and
>>>>>>>>>> checkout the ATL & AM3 plugins as I explained in my previous
>>>>>>>>>> email. Finally, you can start another Eclipse from the first
>>>>>>>>>> and we don't find any major problem for the moment. You can
>>>>>>>>>>>> out the plugins almost all of them have errors (they have
>>>>>>>>>>>> the red cross), so when I try to lunch the second Eclipse,
>>>>>>>>>>>> en el mensaje news:f5qlka$tth$1@build.eclipse.org...
>>>>>>>>>>>>> Hello Bea,
>>>>>>>>>>>>>> because it doesn't find some packages. I have added
>>>>>>>>>>>>>> pluging dependencies in order not to have any error and I
>>>>>>>>>>>>>> handler,
>>>>>>>>>>>>>> Any idea?
>>>>>>>>>>>>> sources instead of ATL binaries, that's why I told you to
>>>>>>>>>>>>> checkout the "uml24atl" driver from the Eclipse CVS.
>>>>>>>>>>>>> IDE, I advise you to use the ATL sources instead of using
>>>>>>>>>>>>> the binaries versions available from the ATL download page.
>>>>>>>>>>>>> Wiki page "How Install ATL From CVS". You must checkout the
>>>>>>>>>>>>> ATL plugins into the workspace of a first Eclipse and then
>>>>>>>>>>>>> you have to launch a second Eclipse from the first one in
>>>>>>>>>>>>> order to load the plugins. You can work using ATL in the
>>>>>>>>>>>>> second Eclipse.
>>>>>>>>>>>>> except that:
>>>>>>>>>>>>> of "/cvsroot/modeling")
>>>>>>>>>>>>> Best regards,
>>>>>>>>>>>>> Hugo
>>>>>>>>>>>>>> mensaje news:f5ork4$524$1@build.eclipse.org...
>>>>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>>>>> directly in the workspace or in my plug-in project?
>>>>>>>>>>>>>>>> have to check out org.eclipse.m2m.atl.drivers.uml24atl
>>>>>>>>>>>>>>>> and org.eclipse.mdt/org.eclipse.uml. And following
>>>>>>>>>>>>>>> which requires additional libraries.
>>>>>>>>>>>>>>> William Piers
>>>> Best regards,
>>>> Hugo
Current Time: Thu Apr 25 01:09:33 GMT 2024
Powered by FUDForum. Page generated in 0.07244 seconds
