Re: SVN externals [message #48909 is a reply to message #48820] |
Wed, 08 July 2009 15:17 |
sNop Messages: 281 Registered: July 2009 |
Igor Burilo napsal(a):
> Hello sNop,
> I just checked and it works.
> Could you please describe you project structure and how you set externals
> and I'll try it then?
> Example:
> Projects/
> src/
> com/ svn:externals: ../../resources external-resources
> A.java
> resources/
Hi Igor,
thank you for your interest.
svn external is independent project in Subversion repo
It's e-shop(module) for MODx CMS which i have programmed. For every new project/e-shop
which i will create, i will create svn externals to e-shop module, so when i will do
changes in e-shop module, every project/e-shop will have actual version of this e-shop module
My project structure is:
http://img55.yfrog.com/i/svnexternals2.png/
A) is project, where i have created svn:externals. I have created svn:externals on the
trunk folder of this project, with content:
.../../snShop/trunk/assets/snShop assets/snShop
Here are SVN Propesties for http://localhost/svn/irisparfum.eu/trunk folder:
http://yfrog.com/1jsvnexternals3p
B) is project, which is svn:externals, it's e-shop module for MODx CMS
I don't have any errors when I do update through Subversive or TortoiseSVN, everything
looks that works ok, only the big red exclamation mark on the svn:externals folder doesn't
look good.
Re: SVN externals [message #49293 is a reply to message #48909] |
Mon, 13 July 2009 10:43 |
Originally posted by: jedlicka.poll.cz
Hi, I have same problem.
I resolved to switch SVN Connector - SVNKit on version 1.1.7.
But I would like If it work version 1.2.2.
Any idea?
M.
sNop napsal(a):
>> Hello sNop,
>> Example:
>> Projects/
>> src/
>> A.java
>> resources/
> Hi Igor,
> look good.
FUDForum. Page generated in 0.63566 seconds
