Error in invoking a web service [message #480390] |
Sun, 16 August 2009 16:43 |
Originally posted by: comestate.hotmail.com
I've created a simple business process the Helloworld. In this business
process I'm making a call to an external web service which I've added
using using the + plus sign for adding a partner Link.
I'm using ODE 1.1.1,Apache Tomcat 5.5, and Axis 1.4
My BPEL process looks like the following:
<!-- HelloWorld BPEL Process [Generated by the Eclipse BPEL Designer] -->
<bpel:process name="HelloWorld"
targetNamespace="http://helloWorld"
suppressJoinFailure="yes"
xmlns:tns="http://helloWorld"
xmlns:bpel="http://docs.oasis-open.org/wsbpel/2.0/process/executable"
xmlns:ns1="http://insa.stage.sncf.orchestration">
<!-- Import the client WSDL -->
<bpel:import namespace="http://insa.stage.sncf.orchestration"
location=" file:/F:/Program%20Files/Apache%20Software%20Foundation/Tomc at%205.5/webapps/GestionCandidature/WebContent/wsdl/GestionC andidature.wsdl "
importType="http://schemas.xmlsoap.org/wsdl/"></bpel:import>
<bpel:import location="HelloWorldArtifacts.wsdl"
namespace="http://helloWorld"
importType="http://schemas.xmlsoap.org/wsdl/" />
<!-- PARTNERLINKS
<!-- List of services participating in this BPEL process
<bpel:partnerLinks>
<!-- The 'client' role represents the requester of this service.
<bpel:partnerLink name="client"
partnerLinkType="tns:HelloWorld"
myRole="HelloWorldProvider"
<bpel:partnerLink name="PLGestionCandidature"
partnerLinkType="tns:PTGestionCandidature"
partnerRole="GestionCandidatureProvider"></bpel:partnerLink >
</bpel:partnerLinks>
<!-- VARIABLES
<!-- List of messages and XML documents used within this BPEL process
<bpel:variables>
<!-- Reference to the message passed as input during initiation -->
<bpel:variable name="input"
messageType="tns:HelloWorldRequestMessage"/>
Reference to the message that will be returned to the requester
<bpel:variable name="output"
messageType="tns:HelloWorldResponseMessage"/>
<bpel:variable name="inputSetPerson"
messageType="ns1:setPrenomRequest"></bpel:variable>
<bpel:variable name="outputSetPerson"
messageType="ns1:setPrenomResponse"></bpel:variable>
</bpel:variables>
<!-- ORCHESTRATION LOGIC
<!-- Set of activities coordinating the flow of messages across the
<!-- services integrated within this business process
<bpel:sequence name="main"><!-- Receive input from requester.
Note: This maps to operation defined in HelloWorld.wsdl
<bpel:receive name="receiveInput" partnerLink="client"
portType="tns:HelloWorld" operation="process" variable="input"
createInstance="yes" />
<!-- Generate reply to synchronous request -->
<bpel:assign validate="no" name="Assign1"><bpel:copy>
<bpel:from>
<bpel:literal xml:space="preserve"><impl:setPrenom
xmlns:impl="http://insa.stage.sncf.orchestration"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<impl:strPrenom></impl:strPrenom>
</impl:setPrenom>
</bpel:literal>
</bpel:from>
<bpel:to variable="inputSetPerson"
part="parameters"></bpel:to>
</bpel:copy>
<bpel:copy>
<bpel:from part="payload" variable="input">
<bpel:query
queryLanguage="urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0 "><![CDATA[tns:input]]></bpel:query>
</bpel:from>
<bpel:to part="parameters" variable="inputSetPerson">
<bpel:query
queryLanguage="urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0 "><![CDATA[ns1:strPrenom]]></bpel:query>
</bpel:to>
</bpel:copy>
</bpel:assign>
<bpel:invoke name="Invoke" partnerLink="PLGestionCandidature"
operation="setPrenom" portType="ns1:GestionCandidature"
inputVariable="inputSetPerson"
outputVariable="outputSetPerson"></bpel:invoke>
<bpel:assign validate="no" name="Assign">
<bpel:copy>
<bpel:from>
<bpel:literal
xml:space="preserve"><tns:HelloWorldResponse xmlns:tns="http://helloWorld"
<tns:result></tns:result>
</tns:HelloWorldResponse>
</bpel:literal>
</bpel:from>
<bpel:to variable="output" part="payload"></bpel:to>
</bpel:copy>
<bpel:copy>
<bpel:query
</bpel:from>
<bpel:to part="payload" variable="output">
<bpel:query
queryLanguage="urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0 "><![CDATA[tns:result]]></bpel:query>
</bpel:to>
</bpel:copy>
</bpel:assign>
<bpel:reply name="replyOutput" partnerLink="client"
portType="tns:HelloWorld" operation="process" variable="output" />
</bpel:sequence>
</bpel:process>
Afterwards I've created a simple Java application and added a new web
service client i.e the wsdl file for the BPEL process, and I try to call
my business process using the following code:
HelloWorldLocator service;
HelloWorldSOAP12BindingStub soap11Service;
service = new HelloWorldLocator();
service.setEndpointAddress(new QName("HelloWorldSOAP12port_http"),
"http://localhost:8080/ode/processes/HelloWorld");
soap11Service = new HelloWorldSOAP12BindingStub(new
URL("http://localhost:8080/ode/processes/HelloWorld"),service);
HelloWorldRequest inpart = new HelloWorldRequest();
inpart.setInput("Hello World");
HelloWorldResponse response = soap11Service.process(inpart);
And I'm getting the following error in Eclipse console:
DEBUG - GeronimoLog.debug(66) | Received request message for
HelloWorld.{http://helloWorld}process
DEBUG - GeronimoLog.debug(66) | Starting transaction.
DEBUG - GeronimoLog.debug(66) | Routed: svcQname
{http://helloWorld}HelloWorldProcessService -->
[BpelProcess[{http://helloWorld}HelloWorld-30]]
DEBUG - GeronimoLog.debug(66) | ODE routed to operation Operation:
name=process
style=REQUEST_RESPONSE,1
Input: name=null
Message: name={http://helloWorld}HelloWorldRequestMessage
Part: name=payload
elementName={http://helloWorld}HelloWorldRequest
Output: name=null
Message: name={http://helloWorld}HelloWorldResponseMessage
Part: name=payload
elementName={http://helloWorld}HelloWorldResponse from service
DEBUG - GeronimoLog.debug(66) | SET MEX property isTwoWay = true
DEBUG - GeronimoLog.debug(66) | Invoking ODE using MEX
{MyRoleMex#hqejbhcnphr4inch259dcx [Client hqejbhcnphr4inch259dcw] calling
{http://helloWorld}HelloWorldProcessService.process(...)}
DEBUG - GeronimoLog.debug(66) | Message content: <?xml version="1.0"
encoding="UTF-8"?>
<message><payload><HelloWorldRequest xmlns="http://helloWorld"
xmlns:soapenv="http://www.w3.org/2003/05/soap-envelope"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><input
xmlns="http://helloWorld">Hello
World</input></HelloWorldRequest></payload></message>
DEBUG - GeronimoLog.debug(66) | invoke() EPR= null ==>
DEBUG - GeronimoLog.debug(66) | Commiting ODE MEX
DEBUG - GeronimoLog.debug(66) | Commiting transaction.
DEBUG - GeronimoLog.debug(66) | handleWorkEvent: InvokeInternal event for
mexid hqejbhcnphr4inch259dcx
DEBUG - GeronimoLog.debug(66) | >>
handleWorkEvent(jobData={type=INVOKE_INTERNAL,
mexid=hqejbhcnphr4inch259dcx, pid={http://helloWorld}HelloWorld-30})
DEBUG - GeronimoLog.debug(66) | InvokeInternal event for mexid
DEBUG - GeronimoLog.debug(66) | GET MEX property
org.apache.ode.bpel.myRoleSessionId = null
org.apache.ode.bpel.partnerRoleSessionId = null
DEBUG - GeronimoLog.debug(66) | INPUTMSG: client.process: MSG RCVD keys=[]
mySessionId=null partnerSessionId=null
DEBUG - GeronimoLog.debug(66) | INPUTMSG: client.process: routing failed,
CREATING NEW INSTANCE
DEBUG - GeronimoLog.debug(66) | BpelRuntimeContextImpl created for
instance 7801. INDEXED STATE={}
DEBUG - GeronimoLog.debug(66) | SELECT: PickResponseChannel#9: USING
CORRELATOR client.process
DEBUG - GeronimoLog.debug(66) | SELECT: PickResponseChannel#9: CHECKING
for NEW INSTANCE match
DEBUG - GeronimoLog.debug(66) | INPUTMSGMATCH: Changing process instance
state from ready to active
DEBUG - GeronimoLog.debug(66) | SELECT: PickResponseChannel#9: FOUND match
for NEW instance mexRef={MyRoleMex#hqejbhcnphr4inch259dcx [Client
DEBUG - GeronimoLog.debug(66) | INVOKING PARTNER:
partnerLink={PartnerLinkInstance
partnerLinkDecl=OPartnerLink#21,scopeInstanceId=7851}, op=setPrenom
channel=InvokeResponseChannel#20)
DEBUG - GeronimoLog.debug(66) | INVOKE PARTNER (SEP): sessionId=null
DEBUG - GeronimoLog.debug(66) | SET MEX property activityId = 37
DEBUG - GeronimoLog.debug(66) | Invoking in a p2p interaction, partnerrole
{PartnerRoleMex#hqejbhcnphr4inch259dd2 [PID
{http://helloWorld}HelloWorld-30] calling null.setPrenom(...)} - myrole
{MyRoleMex#hqejbhcnphr4inch259dd3 [Client hqejbhcnphr4inch259dd2] calling
{http://helloWorld}HelloWorldProcessService.setPrenom(...)}
DEBUG - GeronimoLog.debug(66) | Setting myRoleMex session ids for p2p
interaction, mySession null - partnerSess null
ERROR - GeronimoLog.error(108) | Method "run" in class
"org.apache.ode.bpel.runtime.INVOKE" threw an unexpected exception.
at
org.apache.ode.bpel.engine.MyRoleMessageExchangeImpl.invoke( MyRoleMessageExchangeImpl.java:144)
at
org.apache.ode.bpel.engine.BpelRuntimeContextImpl.invoke(Bpe lRuntimeContextImpl.java:766)
at org.apache.ode.bpel.runtime.INVOKE.run(INVOKE.java:100)
at sun.reflect.GeneratedMethodAccessor53.invoke(Unknown Source)
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.apache.ode.jacob.vpu.JacobVPU$JacobThreadImpl.run(JacobV PU.java:451)
at org.apache.ode.jacob.vpu.JacobVPU.execute(JacobVPU.java:139)
at
org.apache.ode.bpel.engine.BpelRuntimeContextImpl.execute(Bp elRuntimeContextImpl.java:870)
at
org.apache.ode.bpel.engine.PartnerLinkMyRoleImpl.invokeNewIn stance(PartnerLinkMyRoleImpl.java:206)
at
org.apache.ode.bpel.engine.BpelProcess.invokeProcess(BpelPro cess.java:237)
at
org.apache.ode.bpel.engine.BpelProcess.handleWorkEvent(BpelP rocess.java:408)
at
org.apache.ode.bpel.engine.BpelEngineImpl.onScheduledJob(Bpe lEngineImpl.java:439)
at
org.apache.ode.bpel.engine.BpelServerImpl.onScheduledJob(Bpe lServerImpl.java:441)
at
org.apache.ode.scheduler.simple.SimpleScheduler$4$1.call(Sim pleScheduler.java:411)
at
org.apache.ode.scheduler.simple.SimpleScheduler$4$1.call(Sim pleScheduler.java:405)
at
org.apache.ode.scheduler.simple.SimpleScheduler.execTransact ion(SimpleScheduler.java:218)
at
org.apache.ode.scheduler.simple.SimpleScheduler$4.call(Simpl eScheduler.java:404)
at
org.apache.ode.scheduler.simple.SimpleScheduler$4.call(Simpl eScheduler.java:401)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.jav a:269)
at java.util.concurrent.FutureTask.run(FutureTask.java:123)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:650)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:675)
at java.lang.Thread.run(Thread.java:595)
The wsdl file for the invoked web service is the following:
<wsdl:definitions targetNamespace="http://insa.stage.sncf.orchestration"
xmlns:apachesoap="http://xml.apache.org/xml-soap"
xmlns:intf="http://insa.stage.sncf.orchestration"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:wsdlsoap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<!--WSDL created by Apache Axis version: 1.4
Built on Apr 22, 2006 (06:55:48 PDT)-->
<wsdl:types>
<schema elementFormDefault="qualified"
xmlns="http://www.w3.org/2001/XMLSchema">
<element name="setPrenom">
<complexType>
<sequence>
<element name="strPrenom" type="xsd:string"/>
</sequence>
</complexType>
</element>
<element name="setPrenomResponse">
<complexType>
<sequence>
<element name="setPrenomReturn" type="xsd:string"/>
</sequence>
</complexType>
</element>
</schema>
</wsdl:types>
<wsdl:message name="setPrenomResponse">
<wsdl:part element="impl:setPrenomResponse" name="parameters"/>
</wsdl:message>
<wsdl:message name="setPrenomRequest">
<wsdl:part element="impl:setPrenom" name="parameters"/>
</wsdl:message>
<wsdl:portType name="GestionCandidature">
<wsdl:operation name="setPrenom">
<wsdl:input message="impl:setPrenomRequest"
name="setPrenomRequest"/>
<wsdl:output message="impl:setPrenomResponse"
name="setPrenomResponse"/>
</wsdl:operation>
</wsdl:portType>
<wsdl:binding name="GestionCandidatureSoapBinding"
type="impl:GestionCandidature">
<wsdlsoap:binding style="document"
transport="http://schemas.xmlsoap.org/soap/http"/>
<wsdlsoap:operation soapAction=""/>
<wsdl:input name="setPrenomRequest">
<wsdlsoap:body use="literal"/>
</wsdl:input>
<wsdl:output name="setPrenomResponse">
</wsdl:output>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="GestionCandidatureService">
<wsdl:port binding="impl:GestionCandidatureSoapBinding"
<wsdlsoap:address
location=" http://localhost:8080/GestionCandidature/services/GestionCan didature"/>
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
Any Help why I'm not able to invoke properly my business process.
FUDForum. Page generated in 0.03215 seconds
