Home » Eclipse Projects » Mylyn » Use WikiText to create PDF from Trac Wiki
Use WikiText to create PDF from Trac Wiki [message #480233] Fri, 14 August 2009 09:08 Go to next message
I heard the mylyn team is creating the Eclipse help fragments from the
online Wiki. Would it also be possible to create a PDF file from a Trac
Wiki that I have set up for our documentation?
Phil
Re: Use WikiText to create PDF from Trac Wiki [message #481422 is a reply to message #480233] Thu, 20 August 2009 17:56 Go to previous message
Philipp Kursawe wrote:
> Hello,
> Phil
Philip,
Mylyn WikiText can create XSL-FO from TracWiki. You can use this XSL-FO to go to PDF using Apache FOP, as described here:
http://greensopinion.blogspot.com/2009/04/mylyn-wikitext-pro duces-pdf.html
Also the Textile-J project provides a PDF add-on to Mylyn WikiText, which can take you directly to PDF from TracWiki:
https://textile-j.dev.java.net/builds/wikitext/index.html
David
Re: Use WikiText to create PDF from Trac Wiki [message #598812 is a reply to message #480233] Thu, 20 August 2009 17:56 Go to previous message
> Hello,
> Phil
Philip,
David
Previous Topic:MyLyn and CVS Change Sets
Next Topic:Fetching Mylyn mirror
Current Time: Sun Jul 13 07:02:15 EDT 2025
Powered by FUDForum. Page generated in 0.06166 seconds
