Update all projects [message #480102] |
Thu, 13 August 2009 20:11 |
is it possible to update all projects which are in svn without selecting
them all?
Example:
I have several projects, some in svn some not:
Project A - in svn
Project AA - not in svn
Project B - in svn
Project BB - not in svn
Project C - not svn
Project CC - in svn
To synchronize them I currently select A, B and CC via Mouse and by
holding the CTRL Key and then selecting Team -> Update
Is their the possibility to tell the system: Please update all projects
in my workspace?
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Update all projects [message #482498 is a reply to message #482378] |
Wed, 26 August 2009 19:51 |
Hi Mauro,
that is a nice and helpful idea. I'll give it a try and let you know the
result.
Best regards, Lars
Mauro Molinari wrote:
>> selecting them all?
> You may create a working set containing all the required projects, then
> issue a Team => "Synchronize with repository" on the working set.
> Mauro.
Re: Update all projects [message #482502 is a reply to message #482378] |
Wed, 26 August 2009 20:17 |
Hi Mauro,
thanks! This solved my problem.
Best regards, Lars
>> selecting them all?
> Mauro.
Re: Update all projects [message #482585 is a reply to message #480962] |
Thu, 27 August 2009 07:38 |
Originally posted by: gsdfgsd.gfsdgfsdgd.com
If you "Customize Perspective", (Window menu) and to Tool Bar Visibility
add "Team" - you get a button that can be used to Syncronize all SVN
projects. Follow the wizard through and its done.
Igor Burilo wrote:
> Hello Lars,
> There's no way to update all projects without selecting them, because Team
> actions are dependent on the resources on which they are called.
>> Hi,
>> them all?
>> Example:
>> Project A - in svn
>> Project B - in svn
>> Project C - not svn
>> Project CC - in svn
>> Is their the possibility to tell the system: Please update all projects in
>> my workspace?
>> Best regards, Lars
FUDForum. Page generated in 0.03503 seconds
