Re: Facing problems in model tranformation [message #481026 is a reply to message #479961] |
Wed, 19 August 2009 11:27 |
Fabien Giquel Messages: 147 Registered: July 2009 |
hello,
here is a way (but not the official and the more simple one) i found to
have the configuration working without 'org.eclipse.gmt.tcs.dsls'
(a more simple way would be to retrieve 'org.eclipse.gmt.tcs.dsls' or
equivalent).
- unsatisfied dependency from 'org.eclipse.gmt.am3.dsls.km3' to
'org.eclipse.gmt.tcs.dsls' : make optional this dependency (see post from
Marcos from Nov 20 2008)
- on "org.eclipse.gmt.weaver" project, add "parser_src" to the build path
(in order to avoid "KM3_ANTLR3Lexer" ClassNotFound.
- fix KM3_ANTLR3Lexer and KM3_ANTLR3Parser compile errors in replacing
usage of org.eclipse.gmt.tcs.injector.TCSRuntime with
org.eclipse.gmt.tcs.injector.TCSInjector
- in WeaverResourceUtil, line 301, set back the direct .class access :
params.put("lexerClass", KM3_ANTLR3Lexer.class);
params.put("parserClass", KM3_ANTLR3Parser.class);
(dynamic access failed in ClassNotFound without 'org.eclipse.gmt.tcs.dsls'
installed)
Fabien.
Fabien GIQUEL
R&D Engineer
Mia-Software
rue Nina Simone
44000 NANTES
FUDForum. Page generated in 0.03283 seconds
