Home » Eclipse Projects » Plugin Development Environment (PDE) » Versioning on dependent features?
Re: Versioning on dependent features? [message #48832 is a reply to message #48674] |
Mon, 02 March 2009 19:54 |
Originally posted by: eclipse-news.rizzoweb.com
On 2/27/2009 6:24 PM, Zhongyu Zhang wrote:
> We are trying to determine feature version dynamically. Suppose we have
> a feature A which depends on feature 1, feature 2, feature 3. When we
> make some changes and increase version number differently in feature 1,
> feature 2 and feature 3 while feature A has not changed. What is the
> recommended way to set version number in feature A? Should it be set to
> the highest version number in feature 1, 2, 3 or just keep its old
> version number unchanged?
If feature A strictly needs any of the newer versions of 1, 2, or 3 then
you HAVE to make that explicit, which means a change to feature A which
means its version number must be updated. But remember that each feature
can have independent numbers, though - there is no requirement that
feature A's version correspond to any of the numbers for 1, 2 or 3.
Also remember that just because 1, 2, and 3 change does not necessarily
mean A has to change. If A can live with the older of 1, 2, and 3 then
you can keep A unchanged. Only if it *includes* 1, 2, or 3 would it be
forced to change just because one of those changed. Remember that
"dependency" and "inclusion" are two different concepts.
Hope this helps,
Eric
Re: Versioning on dependent features? [message #50052 is a reply to message #48832] |
Tue, 10 March 2009 19:19 |
Andrew Niefer Messages: 990 Registered: July 2009 |
PDE/Build has support for suffixes on feature versions.
See
http://help.eclipse.org/ganymede/topic/org.eclipse.pde.doc.u ser/tasks/pde_version_qualifiers.htm
It auto-generates a suffix for your feature version based on the
versions of the things included in your feature. This is why you see
versions like:
org.eclipse.rcp_3.5.0.v20090307-9RA-FqhFsGOCx-Zfc1bnHHHC
the "-9RA-FqhFsGOCx-Zfc1bnHHHC" is actually an autogenerated suffix.
-Andrew
>> Hi,
> Hope this helps,
> Eric
Re: Versioning on dependent features? [message #592595 is a reply to message #48674] |
Eric Rizzo Messages: 3070 Registered: July 2009 |
Hope this helps,
Eric
Re: Versioning on dependent features? [message #593084 is a reply to message #48832] |
See
versions like:
-Andrew
>> Hi,
> Hope this helps,
> Eric
Current Time: Fri Apr 19 08:09:41 GMT 2024
Powered by FUDForum. Page generated in 0.31015 seconds
