Home » Archived » M2M (model-to-model transformation) » [ATL] internal error occurred
[ATL] internal error occurred [message #479858] Wed, 12 August 2009 14:12 Go to next message
Hi everyone!
Here is the problem. I have the following rule that results in an
exception when I run the transformation.
rule Model2Model{
from model: psc!Model
to agent: Agent!Model()
do {
agent.message <- thisModule.NewMessage();
Eclipse stops with the following message:
An internal error occurred during: "Launching psc2agnt".
java.lang.ArrayIndexOutOfBoundsException: -1
at
org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:437)
at
org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:387)
at
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:197)
at
org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:162)
at
org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:135)
at
org.eclipse.m2m.atl.core.service.LauncherService.launch(Laun cherService.java:135)
at
org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDel egate.launch(AtlLaunchConfigurationDelegate.java:222)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
This problem occured the first time when I added 'agent.message <-
thisModule.NewMessage();' to the imperative code block. When I comment
that line out everything works fine.
I'm using Eclipse 3.5.0 with the latest ATL version. Is that a known bug
or am I doing something wrong?
Thanks for your time!
Re: [ATL] internal error occurred [message #480016 is a reply to message #479858] Thu, 13 August 2009 09:24 Go to previous messageGo to next message
--------------000801010109010207090301
Why don't you use the declarative part of your matched rule to do this?
E.g.:
rule Model2Model{
message <- this.NewMessage()
Even it doesn't solve your problem, using declarative syntax is more in
ATL philosophy ;-)
It seems you're using EMFVM, could you try to execute your
transformation with the regular one? Maybe, the problem comes from the
EMF VM.
Otherwise could you detail NewMessage()?
Freddy.
Adalbert Gorecki a
Re: [ATL] internal error occurred [message #480148 is a reply to message #480016] Fri, 14 August 2009 03:21 Go to previous messageGo to next message
Hi Freddy,
Thanks for your answer!
I tried it with declarative syntax in the first place, but when I try
this...
rule Model2Model{
message <-thisModule.NewMessage()
... I get this error message in the console:
Operation not found:
OUT!<unnamed> :Agent!Model.__resolve__(org.eclipse.m2m.atl.engine.emfvm.li b.ASMModule)
at __applyModel2Model(psc2agnt.atl[7:3-7:36])
local variables: self=thisModule,
link=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@ab702f,
model=IN!<unnamed>:psc!Model, agent=OUT!<unnamed>:Agent!Model
at __exec__(psc2agnt.atl)
e=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@ab702f
at main(psc2agnt.atl)
I'm not really sure what this message means. :/
By the way, the called rule is very simple and looks like this:
rule NewMessage(){
to m: Agent!Message()
Adalbert
Re: [ATL] internal error occurred [message #480181 is a reply to message #480148] Fri, 14 August 2009 05:37 Go to previous messageGo to next message
--------------020603060801040604030706
Hi Adalbert,
I advised you to rewrite your rules like this:
rule Model2Model{
from
model: psc!Model
to
agent: Agent!Model(
message <- Sequence {m}
m: Agent!Message()
Normally it should work :)
Freddy.
Adalbert Gorecki a
Re: [ATL] internal error occurred [message #480186 is a reply to message #480181] Fri, 14 August 2009 05:52 Go to previous messageGo to next message
--------------080801050404070006070102
In fact as I don't know your metamodel and the cardinality of 'message'
reference, so maybe the good answer is the following:
rule Model2Model{
from
model: psc!Model
to
agent: Agent!Model(
message <- m
m: Agent!Message()
Freddy.
Freddy Allilaire a
Re: [ATL] internal error occurred [message #480337 is a reply to message #480186] Sat, 15 August 2009 07:18 Go to previous message
Ok, now I got it. This finally works:
rule Model2Model{
to agntModel: Agent!Model(
message <- m,
agent <- agnt
m: Agent!Message(),
agnt: Agent!Agent()
I just forgot some commas!
Did I already mention that I am new to ATL? ;P
Thanks for your help, Freddy!
Previous Topic:[ATL] Lazy Rules and ResolveTemp
Next Topic:[ATL] Little bug in string convertion with ATL 3.0.0
Current Time: Sun Nov 09 15:19:51 EST 2025
Powered by FUDForum. Page generated in 0.03980 seconds
