Home » Eclipse Projects » Plugin Development Environment (PDE) » Access restriction: The type XX is not accessible
Access restriction: The type XX is not accessible [message #479772] Wed, 12 August 2009 13:25 Go to next message
Lars Vogel is currently offline Lars VogelFriend
in several of my plugin projects I receive the errors message:
Access restriction: The type XX is not accessible due to restriction on
required project XX
XX is located in plugin A in package b and package b is exported
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Planning Plug-in
Bundle-SymbolicName: A
Bundle-Version: 1.0.0
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: b
I'm not aware of any other way to define a access restriction. The
following tips describes how to turn of the check ;-) but I would like to
solve the root cause.
http://lkamal.blogspot.com/2008/09/eclipse-access-restrictio n-on-library.html
Any advice what this could be causing?
Best regards, Lars
Re: Access restriction: The type XX is not accessible [message #479801 is a reply to message #479772] Wed, 12 August 2009 14:32 Go to previous messageGo to next message
Michael Sullivan is currently offline Michael SullivanFriend
Member
I've seen the same problem, but was content to simply turn the error down
to a warning :)
I just assumed it was a legacy, pre-OSGi Eclipse thing.
Re: Access restriction: The type XX is not accessible [message #479835 is a reply to message #479801] Wed, 12 August 2009 16:27 Go to previous message
Hi Michael,
I believe that there must be a better solution, as far as I know the
export statement is the only restriction.
Best regards, Lars
> down to a warning :)
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Access restriction: The type XX is not accessible [message #600613 is a reply to message #479772] Wed, 12 August 2009 14:32 Go to previous message
Member
to a warning :)
Re: Access restriction: The type XX is not accessible [message #600644 is a reply to message #479801] Wed, 12 August 2009 16:27 Go to previous message
Hi Michael,
Best regards, Lars
Previous Topic:Line Separator in Menubar
Next Topic:Set Selection of the Package Explorer
Current Time: Sat Sep 24 20:57:12 GMT 2022
Powered by FUDForum. Page generated in 0.02068 seconds
