Re: Need information to override the default validation function body [message #479072 is a reply to message #479006] |
Sat, 08 August 2009 20:40   |
Ed Merks Messages: 31702 Registered: July 2009 |
--------------070908000603070301070306
Yigal,
Comments below.
Yigal Spinner wrote:
> I created an eCore and assigned annotation on the EClass to generate
> the validation. (Example Class1 with Key=constrains, value=data)
> The EMF generates the generic PackageValidator.java class and has a
> method to validate the class for example:
> validateClass1_data (Class1 class1, DiagnosticChain diagnostics,
> Map<Object, Object> context);
> Is there a way to supply a generic implementation for the body of this
> method?
No.
> and not get the default implementation that does nothing.
No.
> I tried to use the generation example and merge this class with a
> class I created that only have the method I want to supply the body
> for, but it overrides all the other methods and attributes and remove
> them.
> Can you direct me to a way I can generate the body during the EMF
> Model generation?
There isn't currently a way to do that with a named constraint. You
must modify the generated validator class. There's work being done on
which might change the story:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786
> Thanks Yigal.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Yigal,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:h5id5h$lqr$1@build.eclipse.org" type="cite">I
created an eCore and assigned annotation on the EClass to generate the
<br>
<br>
<br>
<br>
method?</blockquote>
No.<br>
<blockquote cite="mid:h5id5h$lqr$1@build.eclipse.org" type="cite"> and
<br>
</blockquote>
No.<br>
<blockquote cite="mid:h5id5h$lqr$1@build.eclipse.org" type="cite"><br>
I tried to use the generation example and merge this class with a class
I created that only have the method I want to supply the body for, but
it overrides all the other methods and attributes and remove them.
<br>
<br>
Can you direct me to a way I can generate the body during the EMF Model
generation?
<br>
</blockquote>
which might change the story:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</a><br>
</blockquote>
Thanks Yigal.
<br>
</blockquote>
</body>
</html>
--------------070908000603070301070306--
Ed Merks
Re: Need information to override the default validation function body [message #479123 is a reply to message #479122] |
Sun, 09 August 2009 15:47   |
--------------090709090801040904060604
Yigal,
Did you do these steps?
http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F
> Hi Ed,
> Thanks for the reply. I copied the ValidatorClass.javajet template
> and add it to my simple plugin (I used the example to add validator
> generation that comes with the product).
> I modified the template with some changes and it built the java class.
> When I run the EMF generation it does not pick the new Jet generation
> from my plugin.
> I changed in the genmodel the flag for dynamic generation to "true"
> and put the my plugin templates directory, but that did not help either.
> How can I override the ValidatorClass.java so I can get my code in?
> Thanks
> Yigal
> Ed Merks wrote:
>> Yigal,
>> Comments below.
>>> this method?
>> No.
>> No.
>>> remove them.
>>> Model generation?
>> on which might change the story:
>>> Thanks Yigal.
<html>
<head>
</head>
Yigal,<br>
<br>
Did you do these steps?<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F"> http://wiki.eclipse.org/index.php/EMF/FAQ#What_are_Dynamic_T emplates.3F</a><br>
</blockquote>
<br>
<br>
<blockquote cite="mid:h5mq3p$bui$1@build.eclipse.org" type="cite">Hi
Ed,
<br>
Thanks for the reply. I copied the ValidatorClass.javajet template and
<br>
<br>
from my plugin.
<br>
I changed in the genmodel the flag for dynamic generation to "true" and
<br>
<br>
<br>
<br>
Yigal
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Yigal,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">I created an eCore and assigned annotation
on the EClass to generate the validation. (Example Class1 with
<br>
<br>
<br>
<br>
method?
<br>
</blockquote>
No.
<br>
<blockquote type="cite">and not get the default implementation that
does nothing.
<br>
</blockquote>
No.
<br>
<blockquote type="cite"><br>
<br>
<br>
generation?
<br>
</blockquote>
<br>
<br>
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</a>
<br>
<br>
Thanks Yigal.
<br>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090709090801040904060604--
Ed Merks
Re: Need information to override the default validation function body [message #480068 is a reply to message #480066] |
Thu, 13 August 2009 16:47  |
Yigal,
Yes, I'm trying to remember where that stuff is...
In JETEmitter's EclipseHelper.initialize method there's logic for
else if (templateURI.isPlatformPlugin())
So if the template path is a URI of the form
platform:/plugin/<plugin-id>/ then it will use the templates target java
class/file name to look up the .class in that bundle. So if you compile
the templates in a project with a JET nature then you (your clients)
will be able to load those precompiled templates.
> Hi Ed,
> Thanks for the information it was very helpful. I was able to
> override the EMF templates and run my own templates.
> I found out that the best configuration is to put the ENF override
> templates in a separate directory then my templates.
> I'm glade the newsgroup works so well to get answers, otherwise there
> no other source.
> In you answer you indicated that the dynamic architecture uses the
> *.class. But while debugging the code I did not find any evidence for
> it and the architecture recompiles the templates every time. It
> recompiles my generation templates as well even if they are in a
> separate directory.
> This is fine except it increases the generation time.
> Thanks
> Yigal.
Ed Merks
FUDForum. Page generated in 0.02913 seconds
