Home » Modeling » EMF » Multiple EMF meta-models in a single plugin
Multiple EMF meta-models in a single plugin [message #478932] |
Fri, 07 August 2009 14:37 |
drew frantz Messages: 340 Registered: July 2009 |
I have 2 different EMF meta-models I am using in the app I am building. The
EMF models were constructed from existing .xsd schemas that were used on
other projects. It seems during resource loading something does not work
correctly since once I load a model of one type, then models of the other
type cannot be loaded (Error: I get a PackageNotFoundException: e.g.,
"Package with uri.....". I read the section in the EMF faq about loading emf
meta-mdelsl from an standaloine java applicatyion, and the error I get is .
Part of the problem is that all the existing xsd used the same
xmlns=http://www.foo.bar" and therefore when I open a file of a different
type with a different extension , the Resource loader tries to create an EMF
of the wrong type. I guess what I want is an ability to make sure the
resource registry is by file extension only and nothing else, since the file
extension are indeed unique.
Is there way for the EMF resource loader to ignore the URIS and only use
file extensions?
Here is the code I use to load the model and I am manually init the
registries.
void loadFile(File file)
initRegistry();
ResourceSet myResourceSet = new ResourceSetImpl();
URI uri = file.isFile() ? URI.createFileURI(file.getAbsolutePath()):
URI.createURI(file.getAbsolutePath());
Resource resource = myResourceSet.getResource(uri, true);
EcoreUtil.resolveAll(resource);
protected void initRegistry()
CcpPackage ccp = CcpPackage.eINSTANCE;
CcePackage cce = CcePackage.eINSTANCE;
Resource.Factory.Registry registry = Resource.Factory.Registry.INSTANCE;
Map<String, Object> extensionsMap = registry.getExtensionToFactoryMap();
extensionsMap.put(CCP_EXT, new CcpResourceFactoryImpl());
extensionsMap.put(CCE_EXT, new CceResourceFactoryImpl());
Re: Multiple EMF meta-models in a single plugin [message #478934 is a reply to message #478932] |
Fri, 07 August 2009 14:42 |
Ed Merks Messages: 33137 Registered: July 2009 |
Drew,
Comments below.
> of the wrong type.
If both schemas are using a common schema that common schema should be
generated as a separate package and plugin that's reused by the other
two schemas.
It sounds like the problem is with having more than one package for the
same URI.
> file extensions?
That's generally the default already but doesn't sound like your problem.
Do you have more than one registration like this:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri="http://www.example.com/Library"
class="com.example.library.LibraryPackage"
genModel="model/Library.genmodel"/>
</extension>
for http://www.foo.bar?
> registries.
> initRegistry();
Now also that each resource set has it's own local resource factory
registry so you can register things there rather than globally to avoid
conflicts (not that I think this is your problem though).
Ed Merks
Re: Multiple EMF meta-models in a single plugin [message #478937 is a reply to message #478934] |
Fri, 07 August 2009 15:03 |
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:h5heg0$tp3$1@build.eclipse.org...
> Drew,
> Comments below.
>> The EMF models were constructed from existing .xsd schemas that were used
>> on other projects. It seems during resource loading something does not
>> work correctly since once I load a model of one type, then models of the
>> other type cannot be loaded (Error: I get a PackageNotFoundException:
>> e.g., "Package with uri.....". I read the section in the EMF faq about
>> loading emf meta-mdelsl from an standaloine java applicatyion, and the
>> error I get is . Part of the problem is that all the existing xsd used
>> the same xmlns=http://www.foo.bar" and therefore when I open a file of a
>> different type with a different extension , the Resource loader tries to
>> create an EMF of the wrong type.
> generated as a separate package and plugin that's reused by the other two
> schemas.
>> I guess what I want is an ability to make sure the resource registry is
>> by file extension only and nothing else, since the file extension are
>> indeed unique.
> same URI.
>> file extensions?
> <package
> </extension>
df> I removed those entries from plugin.xml and got same result.
df> i also tried to use the local registry on the ResourceSet
df> The only thing that seemed to work was chnaging the NS URI parameter on
the ecore model and then regenerating, unfortunealy this breaks backward
compatibility of the existing files, which I am trying to support.
>> registries.
>> initRegistry();
Re: Multiple EMF meta-models in a single plugin [message #478942 is a reply to message #478937] |
Fri, 07 August 2009 15:23 |
--------------050505070605040806070500
Drew,
Comments below.
>> Drew,
>> Comments below.
>> schemas.
>>> indeed unique.
>> same URI.
>>> file extensions?
>> <package
>> </extension>
This is just one of the symptoms of the problem. Getting rid of them
will not cure the problems.
There needs to be a single generated package for the shared schema as I
mentioned in the first comment. It's the only proper solution. So
generate a model for the schema first, and then when generating the
models for the other schemas, be sure to use the last page of the wizard
to refer to that shared model.
>>> registries.
>>> initRegistry();
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Drew,<br>
<br>
Comments below.<br>
<br>
drew wrote:
<blockquote cite="mid:h5hfn9$5b2$1@build.eclipse.org" type="cite">
<pre wrap="">"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:h5heg0$tp3$1@build.eclipse.org">news:h5heg0$tp3$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Drew,
Comments below.
drew wrote:
</pre>
<pre wrap="">I have 2 different EMF meta-models I am using in the app I am building.
the same xmlns=<a class="moz-txt-link-freetext" href="http://www.foo.bar">http://www.foo.bar</a>" and therefore when I open a file of a
</pre>
</blockquote>
<pre wrap="">If both schemas are using a common schema that common schema should be
schemas.
</pre>
<pre wrap="">I guess what I want is an ability to make sure the resource registry is
indeed unique.
</pre>
</blockquote>
<pre wrap="">It sounds like the problem is with having more than one package for the
same URI.
</pre>
<pre wrap="">Is there way for the EMF resource loader to ignore the URIS and only use
file extensions?
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">That's generally the default already but doesn't sound like your problem.
<package
uri=<a class="moz-txt-link-rfc2396E" href="http://www.example.com/Library">"http://www.example.com/Library"</a>
</extension>
</pre>
</blockquote>
<pre wrap=""><!---->df> I removed those entries from plugin.xml and got same result.
</pre>
</blockquote>
will not cure the problems.<br>
<pre wrap="">df> i also tried to use the local registry on the ResourceSet
</pre>
</blockquote>
wizard to refer to that shared model.<br>
<pre wrap="">
</pre>
<pre wrap="">for <a class="moz-txt-link-freetext" href="http://www.foo.bar">http://www.foo.bar</a>?
</pre>
<pre wrap="">Here is the code I use to load the model and I am manually init the
registries.
initRegistry();
</pre>
</blockquote>
<pre wrap="">Now also that each resource set has it's own local resource factory
</pre>
<pre wrap="">}
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------050505070605040806070500--
Ed Merks
Current Time: Fri Apr 19 16:38:52 GMT 2024
Powered by FUDForum. Page generated in 0.02143 seconds
