Home » Modeling » Modeling (top-level project) » Help: Advice on GUI Designer to choose?
Re: Help: Advice on GUI Designer to choose? [message #478946 is a reply to message #478936] |
Fri, 07 August 2009 15:28 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------080208050205040802080505
Content-Type: text/plain; charset=UTF-8; format=flowed
Lou,
It really depends on what type of application you're trying to build.
Things like the Visual Editor Project or the Web Tools Project might be
useful. Also, you might well have a model for your data, e.g,. a schema
and could generate a complete application from that:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html
LouArnold wrote:
> Haha, OK. Wrong forum. Thanks for helping, anyway. I guess we'll see
> about the RAP project later.
> I just wanted to ask what to start the prototype with SWT or Swing to
> make migration easier. Perhaps if you can direct me to the proper
> forum, I'll ask there.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Lou,<br>
<br>
schema and could generate a complete application from that:<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html</a><br>
</blockquote>
<br>
LouArnold wrote:
<blockquote cite="mid:h5hfnq$5cm$1@build.eclipse.org" type="cite">Haha,
OK. Wrong forum. Thanks for helping, anyway. I guess we'll see about
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------080208050205040802080505--
Ed Merks
Re: Help: Advice on GUI Designer to choose? [message #479094 is a reply to message #478951] |
Sun, 09 August 2009 04:14 |
Originally posted by: n.n.nnn
On Fri, 07 Aug 2009 11:58:27 -0400, LouArnold wrote:
> Krzysztof Kowalczyk wrote on Fri, 07 August 2009 11:48
> I think this answered it. I will try VE, but if things get sticky then,
> perhaps Netbeans is better.
Netbeans means Swing and Matisse which may or may not be better. SWT is
cool (and better IMHO) though it is changing in e4 so who knows. They
are going declarative and CSS and Javascript and such things.
If you stay with SWT, forget VE, buy SWT Designer from instantiations.com.
My opinion.
Re: Help: Advice on GUI Designer to choose? [message #496793 is a reply to message #479159] |
Wed, 11 November 2009 11:38 |
Yves YANG Messages: 688 Registered: July 2009 |
Soyatec has published the first version of XWT Designer for technical
preview, and has decided to contribute it in eclipse. The integration of
this GUI Design in e4 is on going. If everything goes well, it will be in e4
1.0M3.
Definitively, PMF addresses the Modeling UI in large terms (not only UI ,
but also data binding and scenario),
So, keep turn.
Best regards
Yves YANG
"Krzysztof Kowalczyk" <kowalczyk.krzysztof@gmail.com> wrote in message
news:h5nhrf$s68$1@build.eclipse.org...
> I mentioned Netbeans, as in database application one can use Swing
> Application Framework https://appframework.dev.java.net/ and JPA and
> Netbeans generate and handle such things well out of the box. In Eclipse
> it would take much effort to gather proper knowledge about beans binding,
> SWT, JFace, JPA and find good plugins to support that.
>> SWT is cool (and better IMHO) though it is changing in e4 so who knows.
>> They
> It is not "changing", it is "growing". e4 allows for deklarative SWT (XWT)
> and for styling controls with CSS. But you don't have to use it! The old
> way works like always did.
> I am (not yet ;) ) fun of XWT / XAML, but declarative UI has strong
> advantages in many use cases IMO.
> Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #617748 is a reply to message #617747] |
Fri, 07 August 2009 14:44 |
Lou,
Comments below.
LouArnold wrote:
> I'm a bit confused by your response. I don't want to develop graphical
> editors.
Then you won't be interested in GMF. :-P
> I want to use one that is already developed.
Like VE.
> Did I ask in the wrong forum?
Yes, I think so. :-P
> Is SWT appropriate if I move the project on to become a web
> application with jFaces, servlets and Tomcat?
Things like the RAP project support web access to an SWT-based
application. The Eclipse 4.0 (e4) work is also targeting the web...
Ed Merks
Re: Help: Advice on GUI Designer to choose? [message #617750 is a reply to message #617749] |
Lou,
<html>
<head>
</head>
Lou,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
Ed Merks
Re: Help: Advice on GUI Designer to choose? [message #617752 is a reply to message #478949] |
Fri, 07 August 2009 15:58 |
Lou Arnold Messages: 20 Registered: August 2009 |
Junior Member |
> You are not sure what technology you want to use, but want to create a
> prototype? Sound like a case for http://www.eclipse.org/pmf/ But it is
> "not there yet" and I don't think that you want it, but still it is
> "modelling" newsgroup ;)
> You can try to install http://www.eclipse.org/vep/
> (http://wiki.eclipse.org/VE/Update) it support SWT and Swing.
> VE news group: eclipse.tools.ve
> Most likely you will have some problems (installation or usage), so you
> would like to check commercials tools (both support SWT and Swing, there
> are some free non-commercial versions):
> http://www.instantiations.com/windowbuilder/
> or http://www.cloudgarden.com/jigloo/
> Actually if you are not sure what to use, probably
> http://www.netbeans.org/kb/docs/java/gui-db.html fit your needs best.
> Krzysztof Kowalczyk
I think this answered it. I will try VE, but if things get sticky then, perhaps Netbeans is better.
Thanks very much.
Re: Help: Advice on GUI Designer to choose? [message #617754 is a reply to message #617752] |
My opinion.
Re: Help: Advice on GUI Designer to choose? [message #618458 is a reply to message #479159] |
1.0M3.
So, keep turn.
Best regards
Yves YANG
>> They
> Krzysztof Kowalczyk
Current Time: Thu Apr 25 19:27:53 GMT 2024
Powered by FUDForum. Page generated in 0.05814 seconds
