Home » Archived » XML Schema Definition (XSD) » Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema"
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #48628 is a reply to message #48597] |
Fri, 02 July 2004 14:47 |
No real name Messages: 121 Registered: July 2009 |
I forgot to mention, the error message appears in the "Problems" view.
When importing the schema, the EMF model wizard reports, "Specify a
valid XML Schema and try loading again".
Thanks, chris
Chris Giblin wrote:
> I receive the mentioned error message when importing a schema file to
> create a new EMF model. The error refers to an import statement.
> My versions:
> Eclipse Version: 3.0.0 Build id: 200406251208
> Eclipse Modeling Framework (EMF) Version: 2.0.0 Build id: 200406280827
> XML Schema Infoset Model (XSD) Version: 2.0.0 Build id: 200406280827
> When I open the main schema file in WSAD, no errors are reported. The
> schema is displayed correctly, including the imported schema elements.
> This suggests the schema is syntactically OK.
> Help?
> Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #48662 is a reply to message #48628] |
Fri, 02 July 2004 15:09 |
Dear Chris,
You fell victim to the infamous Sun Crimson XML parser problem.
http://fullmoon.torolab.ibm.com/tools/emf/scripts/downloads- xerces.php
Yourself
Chris Giblin wrote:
> Thanks, chris
> Chris Giblin wrote:
>> Hi,
>> My versions:
>> Help?
>> Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #589578 is a reply to message #48597] |
Thanks, chris
Chris Giblin wrote:
> My versions:
> Help?
> Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #589587 is a reply to message #48628] |
Dear Chris,
Yourself
Chris Giblin wrote:
> Thanks, chris
> Chris Giblin wrote:
>> Hi,
>> My versions:
>> Help?
>> Thanks, chris
Current Time: Fri Mar 29 07:01:57 GMT 2024
Powered by FUDForum. Page generated in 0.10332 seconds
