Home » Eclipse Projects » Remote Application Platform (RAP) » RAP, Tomcat and SSL
RAP, Tomcat and SSL [message #478764] |
Thu, 06 August 2009 18:32 |
Benjamin Wolff Messages: 136 Registered: July 2009 |
using Tomcat as container and enabling SSL leads to error, that the browser that
accesses the RAP app reports that there is mixed content, meaning that there are
some sources that are not encrypted. this causes the page to be displayed as not-secure.
there already was a topic about a similar problem in this newsgroup, but this time
this happens with firefox (3.5.2) as well as with IE 8. the ssl encryption works because
when accessing the tomcat html manager the site is correctly marked as secure and encrypted.
related qooxdoo bugs can be found here:
http://bugzilla.qooxdoo.org/show_bug.cgi?id=1021
http://bugzilla.qooxdoo.org/show_bug.cgi?id=890
http://bugzilla.qooxdoo.org/show_bug.cgi?id=710
but strange is that this problem also occures with firefox.
i don't use any absolute paths or redirects to possibly unsecure http links...
i do use .png, .gif and .jpg pictures though.
i could not track down the ressources which the browser blames to be unsafe,
maybe anyone can confirm this problem, or maybe someone has a clean ssl/tomcat environment
and could explain his setup so we can track down any differences?!
can we excluded, that RAP loads any 'unsecure' elements?!
greetings,
ben
Re: RAP, Tomcat and SSL [message #478776 is a reply to message #478764] |
Thu, 06 August 2009 19:15 |
Hello again,
i could figure out what caused this behaviour. i'm using the (gorgeous) google visualization
example from the inqle project by David Donohue.
in the file org.inqle.ui.google.widgets/src/org/inqle/ui/google/jsapi/Go ogleAPIResource.java
there is a link to the google json api (location = "http://www.google.com/jsapi";) which
is loaded during startup, thus causing the non-secure content in the browser.
to workaround this problem the location has to be changed to a secure source: location = "https://www.google.com/jsapi";
done! :)
Benjamin Wolff schrieb:
> browser that
> there are
> this time
> links...
> unsafe,
> greetings,
> ben
Re: RAP, Tomcat and SSL [message #478848 is a reply to message #478764] |
Fri, 07 August 2009 08:51 |
Stefan Messages: 316 Registered: July 2009 |
The current RAP-Version still has a problem with css background-images
in IE when running under SSL. See this bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285815
Invisible Widgets with BackgroundImage causes an unsecure content
warning in IE using SSL
Stefan.
> browser that
> there are
> this time
> links...
> unsafe,
> greetings,
> ben
Current Time: Thu Apr 25 18:55:16 GMT 2024
Powered by FUDForum. Page generated in 0.28070 seconds
