Home » Modeling » UML2 » Operations Package Export in GenModel
Re: Operations Package Export in GenModel [message #478629 is a reply to message #478627] |
Thu, 23 July 2009 13:48 |
james bruck Messages: 1724 Registered: July 2009 |
Hi John,
If possible, please attach all your bug fixes in a patch and I'll make sure
they get committed.
- James.
"John T.E. Timm" <johntimm@us.ibm.com> wrote in message
news:d41f266c50c9ac365405458eaee97c5b$1@www.eclipse.org...
> Hi James,
> I will submit a defect. I also noticed some issues with switching back and
> forth between using operations packages and not using operations packages
> between a model and subsequent derived models. More specifically, I found
> that the EOCL_ENV field does not get generated properly if you switch back
> and forth. I made some adjustments to a couple of the other templates
> (namely OperationsClass.javajet and insert.javajetinc) to ensure that
> EOCL_ENV gets generated properly.
> JT
> James Bruck wrote:
>> Hi John,
>> This does seem like a bug. Please raise a defect on UML2 and possibly
>> contribute a patch if you have one.
>> This could possibly be a candidate for the maintenance release.
>> Cheers,
>> - James.
>> news:321b6d7c3f8041ac23eb451481ec4d97$1@www.eclipse.org...
>>>I ended up customizing the manifest.mfjet template to get the required
>>>behavior. This does appear to be a shortcoming of the current
>>>implemention. If I create a model that uses operations packages and then
>>>another model which extends the first, I will get code that doesn't
>>>compile until the manifest file is manually updated.
>>> JT
>>> John T.E. Timm wrote:
>>>> Is there a way to specify in the GenModel that the Operations Package
>>>> should get exported so that it can be used by other projects that
>>>> further specialize the model and also use an Operations Package? I am
>>>> currently adding an entry to the manifest.mf file manually.
>>>> Thanks,
>>>> JT
>>>> NOTE: I originally posted this message in eclipse.model.mdt, but feel
>>>> that perhaps the UML2 newsgroup is more appropriate.
Re: Operations Package Export in GenModel [message #627808 is a reply to message #478627] |
Hi John,
they get committed.
- James.
> Hi James,
> JT
> James Bruck wrote:
>> Hi John,
>> Cheers,
>> - James.
>>> JT
>>>> Thanks,
>>>> JT
Current Time: Fri Apr 19 17:04:28 GMT 2024
Powered by FUDForum. Page generated in 0.02207 seconds
