Home » Modeling » UML2 » Reading general XMI file
Re: Reading general XMI file [message #478617 is a reply to message #478613] |
Tue, 21 July 2009 15:07 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Tom,
I think this may be more of an EMF question regarding how to work with
ResourceSets you may want to try to post there for a more complete response.
One issue you will face will be to properly register packages with your
resource set.
Something like:
Map packageRegistry = resourceSet.getPackageRegistry();
packageRegistry.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
You will also probably need to register extensions:
Map extensionFactoryMap =
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( );
extensionFactoryMap.put(UMLResource.FILE_EXTENION,
UMLResource.Factory.INSTANCE);
The UML project also makes uses of pathmaps so you will need something like:
URIConverter.URI_MAP.put(URI.create(UMLResource.LIBRARIES_PA THMP),
umlResourcePluginURI.appendSegment("libraries").appendSegment( ""));
I would recommend downloading the UML2 examples and plugins and see how it
makes use of extensions.
There is also some example code here (scroll toward the bottom):
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
The EMF newsgroup also has many Q/A regarding ResourceSets.
- James.
"Tom" <tom@collibra.com> wrote in message
news:h3no08$7pr$1@build.eclipse.org...
> I'm new the subject of parsing an XMI file with the eclipse libraries.
> I've read the "EMF Framework Programmer's Guide" and "Getting Started with
> UML2" in the UML2 wiki. I also googled a lot, but I could not find the
> right information on how my problem is solved or even an indication if it
> can be solved.
> I have a XMI file that has nothing to do with EMF/Ecore. The file contains
> a metamodel, unlike most guides (which seem only to work with concrete
> datamodels in their xmi files). This metamodel can for instance be a class
> diagram exported from IBM's Rational Rose or Visual Paradigm. I want to
> write an application that reads the classifiers and their associations
> from this XMI file. I believe it has to be possible to transform the
> metamodel to some Ecore object-set that can be browsed in Java. Am I
> correct?
> If so, how should I configure a ResourceSet to load the XMI file in this
> way? I tried using the UMLPackage.eINSTANCE in my code but with no succes,
> because I don't seem to understand the core concepts of ResourceSets and
> how I might configure them to load any XMI file. There seem to be an
> overwhelming amount of settings for Resouces that are to my knowledge not
> covered in some tutorial.
> Ideas? Sample source code would be highly appreciated :-)
> Regards,
> Tom
Re: Reading general XMI file [message #478623 is a reply to message #478617] |
Tue, 21 July 2009 17:20 |
Tom A Messages: 8 Registered: July 2009 |
Thanks James. I will try your code suggestions and maybe also look at
the other newsgroup you suggested.
James Bruck schreef:
> Hi Tom,
> resource set.
> Something like:
> Cheers,
> - James.
>> Hi,
>> can be solved.
>> correct?
>> Regards,
>> Tom
Re: Reading general XMI file [message #478625 is a reply to message #478617] |
Wed, 22 July 2009 10:22 |
I'm having trouble finding the source code of the examples (for UML2
3.0.0). I googled for org.eclipse.uml2.examples.source, but I don't seem
to find the source code of the examples. Where have you placed the
source code ? :)
Thank you.
Tom
James Bruck wrote:
> Hi Tom,
> resource set.
> Something like:
> Cheers,
> - James.
>> Hi,
>> can be solved.
>> correct?
>> Regards,
>> Tom
Re: Reading general XMI file [message #478626 is a reply to message #478625] |
Wed, 22 July 2009 15:38 |
The source code is now jar'd up.
Download the UML2 SDK and then look for those .jars with a .source prefix
(ie. org.eclipse.uml2.examples.uml.ui.source_3.0.0xxx)
- James.
"tom" <tom@collibra.com> wrote in message
news:h46p8h$ect$1@build.eclipse.org...
> to find the source code of the examples. Where have you placed the source
> code ? :)
> Thank you.
> Regards,
> Tom
> James Bruck wrote:
>> Hi Tom,
>> response.
>> resource set.
>> Something like:
>> like:
>> it makes use of extensions.
>> Cheers,
>> - James.
>>> Hi,
>>> with UML2" in the UML2 wiki. I also googled a lot, but I could not find
>>> the right information on how my problem is solved or even an indication
>>> if it can be solved.
>>> contains a metamodel, unlike most guides (which seem only to work with
>>> concrete datamodels in their xmi files). This metamodel can for instance
>>> be a class diagram exported from IBM's Rational Rose or Visual Paradigm.
>>> I want to write an application that reads the classifiers and their
>>> associations from this XMI file. I believe it has to be possible to
>>> transform the metamodel to some Ecore object-set that can be browsed in
>>> Java. Am I correct?
>>> succes, because I don't seem to understand the core concepts of
>>> ResourceSets and how I might configure them to load any XMI file. There
>>> seem to be an overwhelming amount of settings for Resouces that are to
>>> my knowledge not covered in some tutorial.
>>> Regards,
>>> Tom
Re: Reading general XMI file [message #478631 is a reply to message #478626] |
Thu, 23 July 2009 18:25 |
Thanks James. The file
org.eclipse.uml2.examples.uml.ui.source_3.0.0.v200905041045. jar contains
Java files, but org.eclipse.uml2.examples.source_3.0.0.v200905041045.jar
doesn't. Maybe the first one will contain enough information on how to
set up the ResourceSet.
> Cheers,
> - James.
>> Hi,
>> code ? :)
>> Thank you.
>> Regards,
>> Tom
>> James Bruck wrote:
>>> Hi Tom,
>>> response.
>>> resource set.
>>> Something like:
>>> like:
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> Java. Am I correct?
>>>> Regards,
>>>> Tom
Re: Reading general XMI file [message #627796 is a reply to message #478613] |
Hi Tom,
resource set.
Something like:
- James.
> can be solved.
> correct?
> Regards,
> Tom
Re: Reading general XMI file [message #627802 is a reply to message #478617] |
> Hi Tom,
> resource set.
> Something like:
> Cheers,
> - James.
>> Hi,
>> can be solved.
>> correct?
>> Regards,
>> Tom
Re: Reading general XMI file [message #627804 is a reply to message #478617] |
source code ? :)
Thank you.
Tom
James Bruck wrote:
> Hi Tom,
> resource set.
> Something like:
> Cheers,
> - James.
>> Hi,
>> can be solved.
>> correct?
>> Regards,
>> Tom
Re: Reading general XMI file [message #627805 is a reply to message #478625] |
- James.
> code ? :)
> Thank you.
> Regards,
> Tom
> James Bruck wrote:
>> Hi Tom,
>> response.
>> resource set.
>> Something like:
>> like:
>> Cheers,
>> - James.
>>> Hi,
>>> Java. Am I correct?
>>> Regards,
>>> Tom
Re: Reading general XMI file [message #627810 is a reply to message #478626] |
> Cheers,
> - James.
>> Hi,
>> code ? :)
>> Thank you.
>> Regards,
>> Tom
>> James Bruck wrote:
>>> Hi Tom,
>>> response.
>>> resource set.
>>> Something like:
>>> like:
>>> Cheers,
>>> - James.
>>>> Hi,
>>>> Java. Am I correct?
>>>> Regards,
>>>> Tom
Current Time: Wed Apr 24 14:52:22 GMT 2024
Powered by FUDForum. Page generated in 0.05938 seconds
