Home » Modeling » UML2 » UML2 editor exception on stereotype application
UML2 editor exception on stereotype application [message #478609] Wed, 15 July 2009 13:25 Go to next message
Esteban Dugueperoux is currently offline Esteban DugueperouxFriend
--------------000008060104000403090000
I use a predefined profile definition written with MagicDraw (see
attached files), I have a uml model (see attached test.uml).
When I try to apply "serviceCRUD" stereotype to a uml Class I have a NPE
on
org.eclipse.uml2.uml.edit.providers.StereotypeApplicationIte mProvider.getPropertyDescriptors(StereotypeApplicationItemPr ovider.java:139
with uml2 from ganymede, with galileo release I have a NPE on
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:814
Is it my profil definition that is incorrect, if right what is incorrect?
Thanks in advance.
Content-Type: text/xml;
name="test.uml"
Content-Disposition: inline;
filename="test.uml"
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:PersistenceProfil="http:///schemas/PersistenceProfil/_k-vKAGGNEd6noqTSfbYfzw/0" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xsi:schemaLocation="http:///schemas/PersistenceProfil/_k-vKAGGNEd6noqTSfbYfzw/0 ../../../com.miasoftware.miastudio.mapping.model/model/persi stenceProfile/Persistence_Profil1.profile.uml#_lNyUUWGNEd6no qTSfbYfzw ">
<uml:Model xmi:id="_8qLEAEFhEd6SvejbCXXp4A" name="Model">
<elementImport xmi:id="_8qLEAUFhEd6SvejbCXXp4A">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Boolea n"/>
</elementImport>
<elementImport xmi:id="_8qnv8EFhEd6SvejbCXXp4A" alias="">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</elementImport>
<elementImport xmi:id="_8qnv8UFhEd6SvejbCXXp4A">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Unlimi tedNatural"/>
</elementImport>
<elementImport xmi:id="_8qnv8kFhEd6SvejbCXXp4A">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
</elementImport>
<packagedElement xmi:type="uml:Package" xmi:id="_tOZKEEIzEd69ocq2JytHEA" name="business">
<packagedElement xmi:type="uml:Class" xmi:id="_ABzHIEFiEd6SvejbCXXp4A" name="Person">
<ownedAttribute xmi:id="_n1-jMEnvEd6JxJdzuWWlww" name="id" visibility="public" aggregation="composite">
<type xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
</ownedAttribute>
<ownedAttribute xmi:id="_w3QvcEGJEd6tBdxq2mzFhQ" name="name">
<type xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</ownedAttribute>
<ownedAttribute xmi:id="_cu0rAUlfEd6F7ooXUTzWYA" name="job" type="_0emIcEleEd6F7ooXUTzWYA" association="_cuzc4ElfEd6F7ooXUTzWYA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_cu0rA0lfEd6F7ooXUTzWYA" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_cu0rAklfEd6F7ooXUTzWYA" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_zZSGMEleEd6F7ooXUTzWYA" name="Company">
<ownedAttribute xmi:id="_p5aakEnvEd6JxJdzuWWlww" name="id" aggregation="composite">
</ownedAttribute>
<ownedAttribute xmi:id="_FsILcElfEd6F7ooXUTzWYA" name="name" aggregation="composite">
</ownedAttribute>
<ownedAttribute xmi:id="_cHu10ElfEd6F7ooXUTzWYA" name="job" type="_0emIcEleEd6F7ooXUTzWYA" aggregation="composite" association="_cHuOwElfEd6F7ooXUTzWYA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_cHvc4UlfEd6F7ooXUTzWYA" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_cHvc4ElfEd6F7ooXUTzWYA" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_0emIcEleEd6F7ooXUTzWYA" name="Job">
<ownedAttribute xmi:id="_lMZR0EnvEd6JxJdzuWWlww" name="id" aggregation="composite">
</ownedAttribute>
<ownedAttribute xmi:id="_QlKxkElfEd6F7ooXUTzWYA" name="salary" aggregation="composite">
</ownedAttribute>
<ownedAttribute xmi:id="_cbpN4EnvEd6JxJdzuWWlww" name="title" aggregation="composite">
</ownedAttribute>
<ownedAttribute xmi:id="_cuzc4UlfEd6F7ooXUTzWYA" name="employee" type="_ABzHIEFiEd6SvejbCXXp4A" association="_cuzc4ElfEd6F7ooXUTzWYA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_cu0rAElfEd6F7ooXUTzWYA" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_cu0D8ElfEd6F7ooXUTzWYA" value="1"/>
</ownedAttribute>
<ownedAttribute xmi:id="_cHvc4klfEd6F7ooXUTzWYA" name="employer" type="_zZSGMEleEd6F7ooXUTzWYA" association="_cHuOwElfEd6F7ooXUTzWYA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_cHwD8UlfEd6F7ooXUTzWYA" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_cHwD8ElfEd6F7ooXUTzWYA" value="1"/>
</ownedAttribute>
<ownedAttribute xmi:id="_ddu_cElfEd6F7ooXUTzWYA" name="boss" type="_0emIcEleEd6F7ooXUTzWYA" association="_ddtxUElfEd6F7ooXUTzWYA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_ddu_cklfEd6F7ooXUTzWYA" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_ddu_cUlfEd6F7ooXUTzWYA"/>
</ownedAttribute>
<ownedAttribute xmi:id="_ddtxUUlfEd6F7ooXUTzWYA" name="worker" type="_0emIcEleEd6F7ooXUTzWYA" association="_ddtxUElfEd6F7ooXUTzWYA">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_dduYYUlfEd6F7ooXUTzWYA" value="*"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_dduYYElfEd6F7ooXUTzWYA" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Association" xmi:id="_cHuOwElfEd6F7ooXUTzWYA" name="CompanyJob" memberEnd="_cHu10ElfEd6F7ooXUTzWYA _cHvc4klfEd6F7ooXUTzWYA"/>
<packagedElement xmi:type="uml:Association" xmi:id="_cuzc4ElfEd6F7ooXUTzWYA" name="PersonJob" memberEnd="_cuzc4UlfEd6F7ooXUTzWYA _cu0rAUlfEd6F7ooXUTzWYA"/>
<packagedElement xmi:type="uml:Association" xmi:id="_ddtxUElfEd6F7ooXUTzWYA" name="BossWorker" memberEnd="_ddtxUUlfEd6F7ooXUTzWYA _ddu_cElfEd6F7ooXUTzWYA"/>
<packagedElement xmi:type="uml:Package" xmi:id="_hauN0HE9Ed6Z0fEfv32RaQ" name="businessVO">
<packagedElement xmi:type="uml:Class" xmi:id="_hauN0nE9Ed6Z0fEfv32RaQ" name="PersonSalaryVO" clientDependency="_ha3XwXE9Ed6Z0fEfv32RaQ _hbBIwXE9Ed6Z0fEfv32RaQ _hbUDsXE9Ed6Z0fEfv32RaQ">
<ownedAttribute xmi:id="_hbBIwnE9Ed6Z0fEfv32RaQ" name="personId" clientDependency="_hbK5wXE9Ed6Z0fEfv32RaQ">
</ownedAttribute>
<ownedAttribute xmi:id="_hcDqkHE9Ed6Z0fEfv32RaQ" name="personName" clientDependency="_hcDqknE9Ed6Z0fEfv32RaQ">
</ownedAttribute>
<ownedAttribute xmi:id="_hcDqk3E9Ed6Z0fEfv32RaQ" name="jobSalary" clientDependency="_hcNbkXE9Ed6Z0fEfv32RaQ">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Dependency" xmi:id="_ha3XwXE9Ed6Z0fEfv32RaQ" supplier="_ABzHIEFiEd6SvejbCXXp4A" client="_hauN0nE9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hbBIwXE9Ed6Z0fEfv32RaQ" supplier="_0emIcEleEd6F7ooXUTzWYA" client="_hauN0nE9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hbK5wXE9Ed6Z0fEfv32RaQ" supplier="_n1-jMEnvEd6JxJdzuWWlww" client="_hbBIwnE9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Class" xmi:id="_hbK5wnE9Ed6Z0fEfv32RaQ" name="PersonSalaryVOIdentifier"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hbUDsXE9Ed6Z0fEfv32RaQ" supplier="_hbK5wnE9Ed6Z0fEfv32RaQ" client="_hauN0nE9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hcDqknE9Ed6Z0fEfv32RaQ" supplier="_w3QvcEGJEd6tBdxq2mzFhQ" client="_hcDqkHE9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hcNbkXE9Ed6Z0fEfv32RaQ" supplier="_QlKxkElfEd6F7ooXUTzWYA" client="_hcDqk3E9Ed6Z0fEfv32RaQ"/>
</packagedElement>
<packagedElement xmi:type="uml:Package" xmi:id="_hauN0XE9Ed6Z0fEfv32RaQ" name="businessService">
<packagedElement xmi:type="uml:Class" xmi:id="_hbUDs3E9Ed6Z0fEfv32RaQ" name="PersonSalaryService" clientDependency="_hbUDtHE9Ed6Z0fEfv32RaQ _hbd0sXE9Ed6Z0fEfv32RaQ _hbd0snE9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hbUDtHE9Ed6Z0fEfv32RaQ" supplier="_ABzHIEFiEd6SvejbCXXp4A" client="_hbUDs3E9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hbd0sXE9Ed6Z0fEfv32RaQ" supplier="_0emIcEleEd6F7ooXUTzWYA" client="_hbUDs3E9Ed6Z0fEfv32RaQ"/>
<packagedElement xmi:type="uml:Dependency" xmi:id="_hbd0snE9Ed6Z0fEfv32RaQ" supplier="_hauN0nE9Ed6Z0fEfv32RaQ" client="_hbUDs3E9Ed6Z0fEfv32RaQ"/>
</packagedElement>
</packagedElement>
<packagedElement xmi:type="uml:Package" xmi:id="_3hS2cF_xEd6eObMch8Zy6g" name="useCases">
<packagedElement xmi:type="uml:Component" xmi:id="_iIeCQF_yEd6eObMch8Zy6g" name="RHManager"/>
<packagedElement xmi:type="uml:Actor" xmi:id="_mASoYF_yEd6eObMch8Zy6g" name="DRH"/>
</packagedElement>
<profileApplication xmi:id="_Yp2lMHEpEd6ZpuywBV8xTA">
<eAnnotations xmi:id="_YqAWMHEpEd6ZpuywBV8xTA" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href=" ../../../com.miasoftware.miastudio.mapping.model/model/persi stenceProfile/Persistence_Profil1.profile.uml#_lNyUUWGNEd6no qTSfbYfzw "/>
</eAnnotations>
<appliedProfile href=" ../../../com.miasoftware.miastudio.mapping.model/model/persi stenceProfile/Persistence_Profil1.profile.uml#_15_0_1_ffd038 2_1205508097408_209189_98 "/>
</profileApplication>
</uml:Model>
<PersistenceProfil:entity xmi:id="_Zp7iIHEpEd6ZpuywBV8xTA" base_Class="_ABzHIEFiEd6SvejbCXXp4A"/>
<PersistenceProfil:entity xmi:id="_a17bMHEpEd6ZpuywBV8xTA" base_Class="_zZSGMEleEd6F7ooXUTzWYA"/>
<PersistenceProfil:entity xmi:id="_b2dEEHEpEd6ZpuywBV8xTA" base_Class="_0emIcEleEd6F7ooXUTzWYA"/>
<PersistenceProfil:field xmi:id="_d-gVsHEpEd6ZpuywBV8xTA" base_Property="_n1-jMEnvEd6JxJdzuWWlww" key="true"/>
<PersistenceProfil:field xmi:id="_enoyQHEpEd6ZpuywBV8xTA" base_Property="_w3QvcEGJEd6tBdxq2mzFhQ"/>
<PersistenceProfil:field xmi:id="_fhADMHEpEd6ZpuywBV8xTA" base_Property="_p5aakEnvEd6JxJdzuWWlww" key="true"/>
<PersistenceProfil:field xmi:id="_gUtYEHEpEd6ZpuywBV8xTA" base_Property="_FsILcElfEd6F7ooXUTzWYA"/>
<PersistenceProfil:field xmi:id="_hKNcsHEpEd6ZpuywBV8xTA" base_Property="_lMZR0EnvEd6JxJdzuWWlww" key="true"/>
<PersistenceProfil:field xmi:id="_iFOTcHEpEd6ZpuywBV8xTA" base_Property="_QlKxkElfEd6F7ooXUTzWYA"/>
<PersistenceProfil:field xmi:id="_i2GWwHEpEd6ZpuywBV8xTA" base_Property="_cbpN4EnvEd6JxJdzuWWlww"/>
<PersistenceProfil:valueObject xmi:id="_ha3XwHE9Ed6Z0fEfv32RaQ" base_Class="_hauN0nE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:masterEntity xmi:id="_hbBIwHE9Ed6Z0fEfv32RaQ" base_Dependency="_ha3XwXE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:valueObjectProperty xmi:id="_hbBIw3E9Ed6Z0fEfv32RaQ" base_Property="_hbBIwnE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:field xmi:id="_hbK5wHE9Ed6Z0fEfv32RaQ" base_Property="_hbBIwnE9Ed6Z0fEfv32RaQ" key="true"/>
<PersistenceProfil:valueObjectIdentifier xmi:id="_hbUDsHE9Ed6Z0fEfv32RaQ" base_Class="_hbK5wnE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:valueObjectIdentifier xmi:id="_hbUDsnE9Ed6Z0fEfv32RaQ" base_Dependency="_hbUDsXE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:masterEntity xmi:id="_hbd0sHE9Ed6Z0fEfv32RaQ" base_Dependency="_hbUDtHE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:valueObject xmi:id="_hbd0s3E9Ed6Z0fEfv32RaQ" base_Dependency="_hbd0snE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:valueObjectProperty xmi:id="_hcDqkXE9Ed6Z0fEfv32RaQ" base_Property="_hcDqkHE9Ed6Z0fEfv32RaQ"/>
<PersistenceProfil:valueObjectProperty xmi:id="_hcNbkHE9Ed6Z0fEfv32RaQ" base_Property="_hcDqk3E9Ed6Z0fEfv32RaQ"/>
</xmi:XMI>
Content-Type: application/octet-stream;
name="persistence.rar"
filename="persistence.rar"
UmFyIRoHAM+QcwAADQAAAAAAAAB3+XSgkFgA50EAAE5CAwACW0CNdOl82Tod MzMAIAAAAFVN
TF9TdGFuZGFyZF9Qcm9maWxlLlZhbGlkYXRpb25fUHJvZmlsZS5wcm9maWxl LnVtbADwqmM+
ECGQzMzRVVQaHb9+1Xfg6rN7rlb33lOMkEAEnOZrN1JMmPJmpI5I5IsmVqqV L0FNqRJpxJNz
0V37xynYKbSiTsBJFBopJkohNHM1rHqRssogX4BfoFgEegkT4bf+Eq/LSKbc cSYJv+F342vy
/8+lqzQ6ILl2xb5f8fg34GvwoQctW3WscvHg3t9n67z34f+fn/+//n5fc1j8 f48/loJ/uLni
eBsIHoHLd/EePg/Jevc347+/dq8kFqn4Ldrj6u5x4NzQVd8fl76/PXQ+Xz6j wfNxXNEaabBe
biV0HexiXb1PGbBm+L+nF5vHz4SxMWPtTvKiDl6FlhK7v6PI79L40vM29R4P R5Kx+W38vZxV
6nvr/b577Wbqfnp8dir+lyn8/Tct17FmAP+I+yJ8fke4A9Hup2bFZUP6rqkb kh6rvF9geqCr
buQdoNcI4hOa7AoOsStdIfE3/Inls3w+frdV8Ef1/dpPA11O/7fP5r6u2Pxy Re81urNhfoD1
OlxDJ92S3K1LKUngiEuLgj1Gl2upeDmy/pGL//FKz6HeT22tHr1DZ5I5LFfR iLXp8AfnKJVK
CuqVvfGDn8BNtoUPyGFvxy9EUbniX/x+FJtukalXdI04d4fwM+Yj53WiYDSI 42487hT8KHLT
tDMlzxKoZejYZwv2bWrdaCz64K8FwT5h5ek1H4uf5dIPCoqDFaDw8uOu8r9d 3PFdRExikxYX
bfPcqwSWcBlgMYFq4nb0HVZIBvfXmHoSp/n4+T006vxp8cH4aENxxFjANEAu Pj2+vyzQ5DEH
9yQdP00sAREMkLvHZxNXbGF4LmkIzycvPa0SJtB5uKAUu1j7//zY5ay8B6+R QgVqFzNMVu6i
cA660Ur9I5XHHsPYN+G/oRd82PXEDTs6EWv54NSVNaCpz8cl6LqpebHLXt4H 0fePOP4NyXp2
qH7507nKKxOLqJA1iB5vuy5buRdPcDVp6oNq9O992w/BQ+v5b684mTzoVfs/ DQiDqhypZzDP
Xz2YO0nVk07KnaA0lJqk9VptEeMCO4Z3qXivtHpHbfM+ceIWMPnFeuc9W9i1 7EP1g6evg0gO
RJL9EINVLl2wfwriGrD0Efj1xlnvqzb+eD+Lss5a2jOyZMoFTVTQuiKL/Fzj N9k0mdSj3ghm
IY7gq4Cpk/pFaZUmVTVH71KePClEp118mHaigmKXsGG9VInyCWUkB7/j7gzR C0C139IW21Zm
xA0Mk9bGnz4i7iS8u5flwR5uUlmt1eALHA3SnpCgTH9pzfhvyaLmsn8Vufmx pC2j4te2VeuY
39TOgqh+HjGLN65TsYk5ZOj15O6xg9GARZAOWC7oC8qW2PGzf0kLsgx1Yv9G Cfy38w26JnKx
b7AhK8ONq5Yqc95H2rapK7TqVPvjosKhGNJNJEHf6CvkT+nuAg7dIMQvIJJJ YvpWg+mwF0dc
x+efEXdSjTv+yao8G7lb2e5O6oKAfWUCgTkafPZvCwy8+Zo9zNM2+ySJ1Sgi xa5rMGAct7+k
T42Ssig1R/eNfop43KYon5Kpagos9sH8nh9NQafasr+P1LrxDdb11Irpik6X 3mUytQbUVc95
qP++pnusNXFJNJ6frX7wZMnimaNgp8KOtgjMtuPr0Q9aXJxBcUXWVHPumZ5p Im99qWq4efks
cfJZH/97x27Nu5/t6ZCuTXOmTyi0NaahXR/jI1uMLF9orwvet8U1rg8R5yT0 LDjC247W2zwd
eUuyULivRC+0gDzWhgMkz/k1jGhXt7QM+5KIWLjTYukl59t441Jw09DyOS0F ryEDJscAe/gJ
Yo9xUJ20DQbFoLEanrK1Sddbwp1xHJQqAsEC1+HAGT8KP+/GggJ8NUwjKca+ 0DP/gQLEzjr7
lJPEcJSIaUKgfjwQ2vxohk/G0Hv4CfEmuri5Gxs940QA7j7zQIraWcFHKshb WQyrIe/wi2ke
dQiWJTYNq13u90jFGhvO0iFO2PK4CyrBw2v9+e6Ya1oPPTxf2OiD3duwuOkT F1NnrzvlQcak
0L3yI11NaGOsLgb73XmF8EOkcGoSKRSNydMXyhbcu0LDva8mtkTAVO/q86zF 5tRLrG6Npuga
kSaPP57msmSZrXa57Ud1hSG2LOj0TSTAPjB9cO2q1L7kzWc0kNrYN/XERzZB O8trmt3L2eIk
ptbKPRrCvnwVssjq0tY2wY86ekZpaMWN7ktU0y1jbNnz+T2eHz8P6eTzcSfy 8EULKtmO0tH3
tRp7mP3Ncxo2EosFImdpx683l8Xr8Pr8vkVHn09qEPBivqXKdz6zQhfhT6Kf p76In940I7GR
VbyZK9Y0IhrMnqyPKQ2ul1tsVtaceQOXqTkbvAFDV2xx1CJ78rfz5YK2Vpg7 gKHhVq4XdwAm
FR4h+1bJaLqWuCS7RDm6oJrQUYxE5wn1YU764VbGIDzjWCjRoMLGvp5eoMpK H5AFvTGbNGIi
G1GooXMLnd6p+/GG9B8ZyQQrzFnBXgp6JFw2g1PE+LVTi0edPfRO08NJKIDF nB84UoxEw2pi
t4K8QzTiYWL2nRrf1edizgecKUYiYet+W/oLi5Iui+gtft3u10HVnGvyaRX3 nijTuDxH7D2t
vaqYyPJy9x8oftM48hN0NbyzuFSNuIRJEvv5wE6Aoxwaki/AQy1Mho/qkciC wXI4gzdDpDHa
xgFTssFlAFoDuWOwVNPDyQdJH/zQp8fHcg41R/+9KtsWf26pwEjRS7dWxl48 kBeRnMdADdAU
Y4vI0R/Rz8wuR9Nq4tCVrKdb7eWyltugreimpzwSOWXA1OMWGIkdOftjtaHt eK8tMq1Ys/Ob
mXLElvyWnhZxcX4ynINrBy8o0+DjwCSI4BeSaa40O5D8SUX/nRAibzuViIh1 84k6KmsUR/ei
mdxx3qKTjY0BYZjrd/lZPldm7rbriESHy5OWOQ5mmwTaNP5gJ9ApRgaRZ6Iq oD0bJxopRgXR
qfQBvpam0qiwvQ4mYQytNJiNDS+gEfVgmXRElCyZIrDTtSndQoeh9QI+s3nc rERD+rH+yIjC
hijSwG3jQ8nJ8ozx2jGBOo8uXlincVAJ4dP6gJ9gpRgaRZ6IqoD0bdFIpRgX RqfYBvtam0qi
wvQ4mSIzhWsZB0J+Gj9gIam5lyxJQsmSKz7RjmcBPI57QENTedysREP6s7qU QLuEkv6wl/l5
PlOCxdNHQjw+XJywnrlcMhOw6bQCNhSjA0izjBcgLRs/iilGBdGo2AzdqbSq LC9DiZIjQw+2
R1ChpNgQSbmXLElCyZIrDZWtNLAv9EgEEm87lYiIf1ePfr2heqo16qNkDZSp nyfK7MBU0FhT
tDXcthXrW4VI6GeQBHApRgaRZ6IqoD0e02UUowLo1HAGctTaVRYXocTLEYrw t/CFDScAgs3M
uWJKFkyxWadwJEw9AtEBysCdznIiH9U8V8joR2AHF9V4UMS/yMvynWhtskhF oa3ljdeKN+FO
SJTOUBDBRjg0iyjCqgKNcp8ijHBdGoYBjWptKosL0OHliNhAa3PahR79EwEH m5lyxJQseWKy
a9EFrmhg1/nnAg83ncrERD+qGtyk2IlO4KgQsoUy5fkNi1nixfFcoa3lRcrj rxUQWRKYzgI6
FHRBbvFTDGCtgKYNG9y6YKX9EE5GpddAZ21NpTs4tbiUuZjMnOpwrDExUtug Q9NzJs5IziUt
ZpbRipgsMS9Sy8BDzAnaxEP/SlLBW0rFsAHiiw+uyhSzk+Sl4QdmcMP3/Lk5 V53E0+4iHodN
4BHwpaIL95KWtAUkB9u+y2YqWdEE7+o+Az9qbSn5xahxMkRXHm3cJutzBSy+ BG9NzJoiQnGp
Yyzp8ETbrNq/z94CN6bzs85DwsUbB9PV3FsNOi1CjQdjlfEgX4l8Q4A80M+E enbwLA1sjTDU
NUg1pQTckUQqLvWTv3GmxWWIR3xoCouArP2uh4rHX3Pr5PpzXILqlKX0gq8+ Kaot3oRrg+pM
VMXSDr6Yn5GmNq5bkJNTOcTcGnL+/auH7r+WO7OK/bieOHiVivYVhrLoQjG+ Tr5WiOtF6wam
nFzzN35PLkTlJjJ+fR4Q6+mImSInh/VZp8vHzihF/PJPQ/Lfi4Ha5apbrfX8 xYovBiGtJJnw
K/msJP+CLBMXwXBNQu+DRkI9auLYu6JmSkOuLBXWr/z3+1LJopNU9M2A8YXo +5SGlmC+N785
rZt8Pj82znh+jwgLiIRTjE4j2c3ZqQaGk4iCnSXUupXPo8LHPD8QUo5Eoc+0 ZftQ8AlJpdfC
4XADPDT0T0hVWkMXCjUVaxzA7zxAN4g1pETH9yO70hc9Q12XQw8fs4dTxCS4 7rxAR4+DZ5Qo
5ETyO50plO3juyijOIUrxDUnXXGjCxPRWRv9AxKtc17657ucJCdy4/5+AAx6 RRR1NOSyM1YR
tonZ5iz6+kYbYqvwqWWLqEcbSBR6USZyedsiJ4HZ2ue7e/an0LcdnnXnpGTT UW6Vd94XiUNI
DI4XCoviQov0uk/g3UYUI7EyscFm3Ux/Z5tdGxe5MnDyYZK3ZIeJ6AG9Aa0n Kv+2Hk9wXBXW
33zAnZced6AI9Aa0nI3dR6eeUTMuBz8GatnHeLwwIVozotSTpm3DZ7u+BoAN DzKu+KkDwmcf
4ZafPp5j3DJT5ZQSPdvCbYbwRdREF5rFs0Ugzm8IGwYVOzRYhUq2eIYcgkiT vhtALwkmYq6Y
k5Gk9VPT4ebKH8lD5waZIL+KedOtd5D/jQq4znqYBVwnhL1Y/bg8C9c54JMj T9PAA/posEXt
As5OjVUMXpp47hUvQXIdd5+k+cgvhNEHiX7ipW57N7TjPkMRkBCmONVPGQhn 8VrGJKrkrOLA
Bq7HljClrJIpfP/1kkjCMD0A1h/zXyTb/bknYsoeMxxNKXhiJ9sW6nwgqopa B9Enkw9XABPq
ogMsESBPy3+2jWYaPB17HA8+PEzWCG/9Wb3/z82Sj09THZyPURAyxbossIi0 ftQp0HP1sk0P
1gOsGsLCYoonW0J4GD1slVL6wHWCKHe6mhTd02sRYqcShtVK08NH0QomLPxU +OSNqHExXEZx
UUDLEcjk+yC1zWRoJHFY4+VOB0GgLPrVgKGl7+Rua1jv8xoND2IY8NgJCJ7j YfWry+hzZpiu
v+V2JOmwOFPSZUvxARxSg0Huy7mSpDPIfFgP1mkOi5lGosKeeQaI1fuPlvFd SRrsoRqexkqh
fZRm0iSxfyhGbGkW7h3hRR1kQm5TF/YlD/QvaMq+xmR9zItsJk+skYm5lecD t+NC2vkZ39RI
1LFR8ZG/JW4yMSBmm3sFhh/rUyMxNwtjlq2eccp+LJbifax3D97Zia9GLRht wWogc53SjUxL
5XGM296C0RFP2slnK9pJtIssF3eTbpqIjPDxUzHSlljbayFSHuAr3TczFYE9 1uFPURfLhJ19
tEOZrbGU7vFBeZKML3Mdm0903MrWLC/uzYIl0mPlZD0zGjTu4AV1NiVpkjBo skyaiACwWoc2
33nG3ATedfaMIXckgDJMtogRRABYt0btwxsd5kI4OX8AV/AALBbulffgQukF 6FRUOO7Ax5MZ
RI9aAqbmaLAvPJGY+Z1584Ii6/P5c44inMlGV72PQu/eACxaw7srjhitAngL xHOtvp4jUzRl
+9kmWe8AFguQ6nbdaBRUNTn5WYvy/ljmT/yAURYQ7xwnXOjBzc8qfH/IFfyA CwXIyjOGwuLD
1FdqhUp8bHkyk8j9NksydMAFgYnnQwccDhW0KKlH1xeh2LJlIyabHoXlMAc5 ZQ7t0VYLZUKW
vK3unXvMkYNRkmQ1AAWCZDmQcS3HUI+1l9NRjmP1AAWLBG7eaFPO0hFvudVk mT1QAWC6HLNh
LsPhRt1092raAmqACwLocykdfIk9V3aNtD6wEVpuZWsVm3EYRjtKojc8bQGV mSZHWABYLt0o
wn38ONkS5+d2UKyACoAAWBhDmJ6qq7Qi7pSq2+flZVZKwARAACxYI3Z3epS3 BPMpGM4651RE
KaMxNcCq4AZwt3WzEFf69Cf3NYVauyVMFcAFgThc3XiilhQopM6d3xU2TZhn jAjjABYsEbxp
0/UIg7U8qSXxoK4wBzhdPIycz41Wqmp/SbcsKvyMcy7kABYt0bt14x8HQjA5 8gFcgALBduqh
bnK+Rwf6OjNsAVYAHODCGx95OVbcxCtY6Bi/f+IPoz7cKWGPQu7AUY5aI2mW B33GyuhL99z+
DJMr+AUY4XQ4eWIxzDQaRO5da3PQvfgBXwm5mKwJ/2ruXMX/GJPNtRO2/x27 NnKzlxQzrpKv
ixO5eviBGclUMJjD9rhBig7jkhgyoryLuXrL8p8XTc0c43B0tP39f4gR8Q62 mLtGZphTRq5/
ltlGoB20J6UI1bLJU4WQ62mADcPcvemE7L3L4siIkXcwfdmWI/GyBlkk2kgW Bb+s9zCCSLuB
NOi/Lxo1LT6rWKZa6jsfZk2zDtARamBsUcr4dimB8Ujo4+HjMzPflueVQT2m Szn2pgaxHC6d
FKWGL7zeN50Xf91BCJsLsv3lVBdZJlPKBHKFGMWW0zKHh+8br3MKGTl4Vcnj YBflArlmBlEc
LocBMRiuD22cfGK0pEPMe8qJozfWwKthRjgpOtGI/gnWC6ZnneqeyKPF3a2y 0Yttj0Oa2FGO
We00Y2aB2xXMFTxL7nzMkyrmCjHC6HDyxGbF5dOtjxHb+TzMlTFzTczJYFL7 aQqewlMcotFw
8Ta1k2vkx2Yn5BRjlhtRGHlgdrrHzJvIenjQs/kBXyJN5Fs4XbjRh5IjPtFf cVmbThyLjJUv
3JuZksCl9rK0czpm6Tpcc6czAzujSUPDZsslGTcY7MbcChpC2h2eaB+vwM8M vTyZjboFXaM2
kWWC6HCzRGbecaS4coruEKswkw0Kp4lEjrJUz3ZuZosC060ZY4pvOK/EpR/p xrRpKzMRl3mO
zK3goaQtodplgczWAtOITcLneZJlt4KMcLocPLEYWIh8cq4bhL+XzslTTzzc zRYFr7XjXMcr
WNgr+CpwQdiuylupw9TZKMfnY7MnzhQ0hZI2aoHI5ScceeMQb58p5Ix+i+V0 UZnIt2wunYZS
6XHEWkU/UFcpZ8Z+hiizjKugCOgKUYs0bXJA7zb427bbIWFz+YFfMKUYLkNr 4ruR71ifcGxf
0WNpt3ntMkyX5gR8wpRiuRtckDicU0WGZbUuXduviZGPfQCvoFKME6GkXp0Z to74q6SCxBPr
WmF5rlutz1WU/0foxzIvoHW0xZI2OeBxzOomayT0p3XsKfUCvrRm0iqwWw4G SIzrSUn+CYOm
0luakdE3DSO/raAn6zMzTQBf+y2/zVeku0Yp15b+GrZ7DvrI7f3/YBvsAegS KOTsOH5RXcVT
b6qV7tC56v7MdRt9pQYDJiz25h+MNQMjyL+FhN3danlQjWgKaYRgegGveSkz uImv4C8dCbYu
H42gfQjkNAU0RjSYZwinxil2fCZmlaFgYds2x6lnbYRp+gW/eKPTCZXXOl2e bysbZJoTYD5w
0nCjyIdMS3N3o8CMlVCQCcoQT2R3FHKMIVOZY4meUerZ8t30QfNko8SMdnmI AnbLqGyOYitM
0E8UeDjJNCcAeIM0PThsczan46uaD7eVWl/ysyTR3AIcAfOX/eJow8HFemYp PLIPSVkmkFAd
YNZ9GlYGY3aqcnEF6bjJ7suKxzQi9Oct+8jQzOZKZ3LanZk7tov0jAUYCM4a oenip0rAu9pU
b5eVWSa5kGkGAgwDxF53kaMLqDaaQp5W0FOgo4EZw1nDSxcY77w5NY4qgcup MoT924MhwR7Q
EnYRq2gEs+UfTuBPtr9hLdkNny5PCC3qe7hOJMe6uVH7siQx1ju9J0BO2ByL Ir5m0tMbzU8a
8MdhKdAdYNP7ZWukWJBiO+bE7+KF9dJe8xa12eAmIk5w5G4RajmjDYH0pGxp wL7rd/Xi+VhX
sZPCnL+u8BDwUNIXaM7SCmjXzfLd+/E3i7SjCH59ks879GbyJZy/3DdrLpRN y3ayRIhJJkbm
7kyhH4vgY/NzMM4Jw/vexAp2nXx/U2VUjJdq4BkbwEb0xNfjFhDs80DuYC8d 1CdnjfGbvXyt
4k2kWWC6Frii+8Z99Kyk22sdU6QEUpuZYsWqN3ifIMb33Z5Y6pUgKpTcyvOF s8jKjOGbMmL5
9qZIct7wsYyXe8IALFgjd4pxrCaFPzwcEO94QJ3vCRgSKZgsnYZI6V4psbDa c3BL7zW2MoL2
94gH3vFMTKIxaI2uSB3jDWLzSE3PFSfveICd7xEm0iywXd5VCnqIjODcieZC JMsCSZg4Dd7x
gTiMm5mKwJzrRjONNDg9SfG66N1aDzm2MHEN7x2gGxFIoaQtEbPNA5OoyS+F nkjG/RkmV/oF
GOF0OHliM20LrrfQjQ5H6MlTD+k3MxWBO+2keV4Bj8bxiQo+1LztN7yAPiKm JlcYsNqIwskD
v4RO0dCdnhedpveQCcRhJtIssF240YWaI2Eh8OcL250YP6slS5+tFgSM5gSn YjAGvAnFWkCd
chUTgb/wyUXn6sdl//UKUYrIdrlgfA8VJ4Yfnj3S1vcDJMi4ApRgu3Gi8yRG eGYulz8vxU/y
6x2zCUSOslS1wTczRYFp1owSjf7YfG+R5pwJJtTJc7vfsx2YL9goxywRtMsD 9c262iXJ5UkX
9r5X7Em0iywXQ4eWIxDECGwRd1IxfKyVMflm5miwLX23qB1OFPPpwXQff2vl OF3vKA+IqYmY
Riy2ojHyQO480+nC/iWdm7d1ZN6Yov/3ZJkP7hSjBMhsMTBhHZ5t11NQ2RZ+ YqfNiA5azJMg
/cCP3CjHLFG0ywOUYIIlI29PJfR/lkmUf5CjHC6HDyxGdwq80lJ8/udy2f5t AT/mbmYrAnOx
GG4Vorw2EycHs9BpqJwM81yBmoxfMx6Fd5go6Qs9qIxskEHOUw6JpURPOvvf MBXmJNpGFwv3
GjIyzIEuf9HbdFff+cCvOwDNVgUnYjKxwnK2LiFxyuN35icD1excusqq+vOx 2Y7ZNHAuoLHa
iMjJBBRnitJgcs6qFh6AK9FGbSHrBNC243TmF/XDrmQUeFFSeLNNlmQegCJL o1XkZYQ7XJBD
b410GpVy7OoyHhArhClHCedZkWN0ezTaTw1pEm+ppvPas2tB9OGuyTJeECOE KOkLNG0ywQLC
OZ8qJnjkGs3vSyTLfSFHSBfuJsPyxHEbBoOUM3/p3y2Gem0BMo0abyAEYWx1 wqsnqXUps1bF
kHupspfR6mPT0vUFHSFcjaZYIwgdWS81udbYV6mSZB6go6QJ9xIunTGG3OvW EeSoaaiyDF2N
pqbbHYjz3pRJj62SpslGjRWQBTOtGkLE4OKzz2Np5KXpqLIP1YxmYgb3hZSN j1sdmb9YUdIW
kO0ywRgbZmjol2eTyr4mSZdxBR0gXw4eWI+ApGeGXu1QsJxo5OJkqluKbmnL hbDhvPmdOekL
FcXI3s7oqyv2Mk1LZ9GiOlBSdaoF87eOEXFsOilJq+oshAV3nqM+4Tve9jHV CewKOkLdG0yw
Q680Vs4TPOrMPbCV7aM2kYXC+HDyxHJgGMpyGYnBAnWx9ONUJ7QK2fRoHpQt 3TJq8L8dxkwz
E4I+fm5kFSeSP3Mk1nZ9GhmlBv+03jH57jI8t4x0j1Ze70v0aO6iR+UGhyUj d33jECxjHMUZ
nIvB4px8EELbUjvGIz/Kf7FiOR88PF/0b1Fju4rZdGj+mLu/maYU0aq3y8Ec aRLcoRm0WSpx
2XRo3pgA3DeMTphOivGKvSO8YXuzJUfhvbHo0dR5d7+JuZasB/9ZvGGSSLxh X50he+7xDLZa
Z2b2n7/DHojv8TE1yMWF/YjA7zRx/JEYbTqD+bLPC6zT3slnA98wNYjhb3+2 xpiMQfzHPJaT
IioiyBJd/aAmN732mTI5MDMo4Kzqx8peOIzX4F1EuBLZ9rIw/5Y7NpsujUnT Fhf2uSBxrzx1
LpQbnjeyVvMjRqTvB19MF240YmSIzpnHl8tA+4s58e9TAnEZNzNc4LzrRivt j4g1hwJLSMTe
0rjSKYEbLo1A0pV7TRf5YGcwkRt0eRnlcaPUArZdGo+mC7cSL/LEZ9ofGwYN +l+6WYSoBVSb
mZLArC2ClfHRJTgeFh8BS5NuZ9cN6qA+9VmJmkYt9qIy8sD9a6nNHQ5PGkn1 WSZbsujUvTBb
fw8sRnDNqiKXdKMmsyVM1abmY5wUnUjIOdpoe/LsI9Y4nFdPbiMesx2ZKsFC OWyNmqBjJoJO
KwcWbCHnijGgZJlWy6NTtMFt/CzRGGuIB/JOK0G66SlAyVM0BJtI+sDE7EZb oixhc2AlccWx
NZ3mSjBrsdmJrzEyyMVm1EYWSB3m3k+PP8k8cDDq4FbLo1Q0wW7jRhZIjCdi NZCJzFLboZiu
MCuObmZLArOtF+PjPg62k9hTHCVOYrXbGCVmw6NXEeTjmBmMctNpox8sDmGw /ZE5idL7jyMk
yrkCjHC2HDyxGcFXEqY5LMl4FJj2Mw5AK2XRq7pgUnWjGeaeS0TdWJj1+c/i w6RsbDHZjrAU
Y5aQ7TLA40SDFTDJr7lYZJlVgKMcLYcPLEbAWmnzIR4cn4MlTFsujVjTApfb SuHcT45sTNr+
GVq79bQwncEKbFfJ5jNmSjQ+DHZl/gFGOX0O1yQO4OZcFPhgsngjP+LJMz+I UtELNxozskRX
T4xGiQp/dNJd+LJU1/GbmYLArfbHnR8xGlIdVUg+EuwrW1cJfLIEWZiZZGLD aiMHJA4zwXhy
ShlnldBxZZJk9kKUYLtxoxMsRjlKN1LBSboZk7QFWpuZksCkLW611DhRxn7b cTM7K5tXGvO0
x2YW0FDSFgjZ5oHHMHqmd6WeNvv+UCuWjNpFVgtnYZMRsw+OaMhFPVMq+PDT OuAJ5QI5ZiZX
GLVG1yQPikxUGJCp5XNGWwK2XRohpgunYZY5jXH8esK8mZq9tTI8zvW2OZNs ujQzSlftQyXJ
Aw+b+59CnjqBl3uYCd7ZdGhWlC2dNzLicKBxviraS7taT5C7Xwlv5gI2XRoB piyh2eaBzmHy
rvvklr/P7uhDTIyD5AVsujP7ShNPS4vFfzusdvvnCTdiw5Jgf/PD4/NS8Vu3 iopyPUPjvS/R
oxqJLJQZ3JiXk9xgOxZhkzmSdbnslLTZWDEtwCJRozZkxasNFHr8uihXXhzX tRZF76jG7Rbk
6Jq4yXWhcYU+3QB3d+XjI2M4fxGJs8c3Xe9dZKl6UaM/JMGu62YfXn743ind OtZ963cZKOy6
x2Ym6RAyxaIsjdam4aN5yHLvMkyi8BGcHYWEXpF9yGhRQc7zJVYSjRo7Jg1v vTjrx3yLWsV+
jLR287HZ2ufpzlrDZEIPYJyfNnLDlc7JMp5wHWB2FhGn0NNJS9nhc2No1D/j xc/n4GOqxiDW
+9D6CoupTbXjP6mxrDH1HOpFWigRPSrTBkg0C57ypZhDNEV5xGtzI8Uh+RkG W+gB1gdvsL49
qqNp84BkLekdqKCfRaAZYNZz1CpjbeHSv8+Z+kNTntNr61eBiiyUc3oIA/DK DWe7K5ho39LA
7pQjCrrpVtEJM6jLOECuG1M5Fu2F39vqFla0IaPnl8rMyNFIyS80bTyW+mUG iSYl5HULPZby
jIdZsfaXZxrhShuvK7aCsXeLnqXcQN5XknozelZnL12RR6JgzjhE8STIx/Sx 2a70gOsC6NXD
HbkFYmftgUqzq3bNv/tkqQ/SBHq4GKPaxZ94tlTpzuJ1FBPs/DqaHkepkqOf UwjCNAHb7C2U
76V0z7U7rdGQr1Mmh3esB1g1ny4HHxwqNOt3P5vMlHX62Opn9YDrFnDZDRNG x7Vifbhy/WyT
J+IB1gdhYSDMUOVCIDnxMlVfxAOsGsL066+8v3pl//MlHVxMdnW9gD5yy7yZ 1Su4Ak8tyHL9
gFewCM4OoYRFZOoU18sLn7AK9oDrBqh7MYhn1rgaK1joZKOz2sdnX9vTnLVF mLSOPZQr5ocv
2gV7gIzg6hhwUg1F1Cjg5+4CvcA6waoenx8mbDa1x+Fq3WZKO33MdnaogOsW sNkY52h7hLfd
Rl0WSZTRAdYHYWF4hk+CvV95DnRZKrH+AHWDWF6KdWUwWK5yr775b5X8Mdnb /gB1i1hs2jnH
y9Yv7rqJ/+GSZT7wHWB2Fhxmj6zr6RGoXT3slVj7wIzhrC9OtPpsXFFdTFap /Rko7fex2dv+
QHWLWGybxXm6gZhe66ih/lkmU/yA6wOwsOMzrHEKedRQfyyVWFMB84aT5R14 Q6g5Vrt9WVWx
dMCKYDrFmiy6sUrOK4jTk8jPqYFVAHWDWfJn5h8BBjq13v+/CVUAioA6xZos jEbTm/MaLupg
pqMkyeqA6wOwsJk+qxwYmyy5geS2ptmSOurRAmqwjUNANYXoayGwNpe8raoy e10KrHoi9YB1
i1RZEH2IBPoU86o1rAVWAdYNf7d2H8uj9R8/XBIvXRqkaGJ2H3AA6xKbdulV M004tewoybet
QMdmigAfOWXeVDhHUKuZCivRKY6/CTom4GSzQ1wHWB1DCOUXM2T1pewuNcCq 4DrBqh6cwZob
tSS7St6zXY7M/xgOsWaLIdQTbrSE/upHXxskyfjAdYHYWF07hQltoHPjZKq/ kAdYNYXohHBp
mw9p57Rt61yMdnW5AHWLPvFHW8d05Dpn3oy+RkmT2AHWB2FhcfJgj6aYRC52 GSqvsAOsGsL0
Ux8AVgD5tGoZbDHZ1/gA6xZosh8dIJR7ZV3Ujq+DJMm+AD5wcnBdKNjHeIUc o3E8kdPwZKq3
4gOsGsL1hF85zJwPX2jSwfix2dX4gOsWaLIawvH6hU86uj+LJM/sgOsGqHcf bxkcfT0atg1g
y7bU2QIsgJ2y17z1y+lGy7bZ91MFllkmU2gHWB3drBbg1Jwpxu0YI27C52qI E2mEahoBrPpH
aLxofpNm2pbai0BHKwqIx2y028jrGYSVXpFHI29Dl8rJMn5QHWB2FhGpCR8x RhG34XPlZKq+
2AnbDWF6fwr1JRP3b2nZX22x2dm2A6xa94o7W3XE+09sk86oxtgVzMc0HOGq HrHK6/ga3r3+
r2bbHwOESKbHND5gHWLdFkORxox0Kd+QEhC5gK+QDrBqh6HDFh9KY/O/Jx92 5TJND+QEfIB1
i3RZDMMIZpCnl27l8kFXAHWDVD0/1CfHLaYq3iD2ZJoVwCLgDrFsiyM3hZ9t C3XV6NxkmVXQ
HWB2cFK4IbqG0tIE78O+b6u0QJusI1DQDWF6T66hs/sSS/Nko6brHd0N4B4i x7yYKnB0LtIR
t1I57zJMjvAOsDsLCU2FU66ezwud5kqq+cB1g1hd3nxpsytj3yY67Ot/hko7 edjs6/OAnbLd
Fkcwv3F5C3V2jZzgV0IHWB1DC9hRsyYmzyw7x6AK6L46waz5R3j7MrB8dxcX nlP/NlI7Ohjs
7Ul93/MpLS/ZYKNR/GhW6u0bfmBXzYxlCwO32E5hRKNohxoHP5slVh9AJiDX +34hcPKt2HFZ
Hz/mGcmxnCih/XSbsL3f4J6Qwjd9Alts9/dilvOPnaxeQnto+ZdNILMdTN9Q HWLZFk8QrfXo
hyedXZfVkqfvqA6waz6pS5TNPOAomEO9by4qdMg0f6gR9gHWLtFkfFbi1JCp 51dt9kFfYB1g
1Q9dYV4dVr8Xn5svW03PBsg0T7ARJfeA7KS4hshoT5Tq9zE077LBNMk0NoB8 4aT5NCHJAYRE
th8vNqtNYuxmhtAQ2A6xcos+tPg4zD2XWqC9DPRSbApsB1g1n2aKNMtGaUTO aJ7ebmAxsCJL
7wPpQXHeJoeE3SvL+7pWFrIBRAHWDVD0V9/CjfTFsFMauICqx9X36RUY5obg DrFx3kqIIn0N
tEcOhzcApwCM4azgfbDuFXHzLe8g26x5PpRJWyX2AUB1gdnyjwMLhDfdQotF aw5GBLjIz1nJ
FdjWChKA6xdos3HTqoxj08keZWSaOYB1g1hYRrFMUwY6oR9p6pbZPJeZkqoz AOsEMOcYck4+
NMdhJgVrdWqWdIxMk184CdsIf6Rqltyez9EgfR5zAzvigwH1uoup2CY+esH+ GrZi1NmyStYz
gNJfeH1JyW35lk4Z1MEDRpXyD+zFEOc5nrX4+ThdS/mTZOFtX5QU0ek7Hoks l94UcnBTf2vk
4U00RWzEFK8PkIBTMLaPfg7a1Kir27lq77LemRryUcXaIETKffpirYDNDqoM GqaeoSw0uEav
rufALVJ0+joFPcE1FWMVEoT5X0lMkxPa1fnTF77BYCdUWT7RTKrenCD8Kic6 847K/PUQJemx
u0YLdyMCbI94m+olLO68KFdoVTvZ0VOx6waNp/eJ/3XQRsCa4ZCPQkHOjUJy fc7q13ewrdTK
qgEejSX3inykL88x7UTGPylfvFXlIeUND3ivxbRfmhrfeLQSTbRZ6Se8XCUh pI2nx8BpL7xe
JSPe/t33jAd1E1sZK3lsuBMRFNyZjzYnvGIQka8oJjf7994yHdRcGoJmlN5U r9w5CQhoscbG
NPTWI/fnp73+dWQhjvj7cnzdgrrZVvJfvJlYOXoJQgo4dnPNw+vNB4vtwjaE SHT3gEm/vH2j
hfDcxw8R98+zbp2VWFG2bR03Vhxw2RqUgGkvvKwlI+w5WWJo0YlWxnMLMFYl IB+iS+8lOUkz
OlWLli6JjTj6+cv+/rdHhAfo8LGnqrEfCxaXXUt3O1wYRxItrm1rZIWEpu6P EHJ7snJIpnzb
TnfXh4L4OK4NCnI2mBs+qkjOHdBIeadSLIk3nR4gF6JT7w7O6KhGj+W/2xLm c8ziFDLBbvaF
RASHYMD8uu2u9V/0+Jhzw5L7wpJCR0wnhd3sI2/w0uzwm0s77aWwdGSFrFn4 +OEDOC6NRkPZ
uNs8ptymoaGwL90u18DkJp3jAT9ApaBGd2abqqu81bAcmraL6xXNYG6m/AzZ 8062ldh8jNI/
QBv0DWlIJSA1DVVdxK0cWhsHPtRtDudlRyy/YLpJFQjEkd8kxMO0Qb7+RzLS Ad0jpl0vDw7M
g9NW39TSef022CW2dma8gDeSSmvyEpNmlB7ffpMw2gWEfayDM3YpfPq94Cb7 vUvJ8wyGzU7r
o8gEfrMDjI5Jd/07PVxWwm06dfzLySYX/1ogRaCusRDAp0s1RRmcFY0Oy3SG Xak+3ptshds6
KP9WKpl4ApaJSQ+zj7GgML9Q40+torT2BFHwMc0PgCnoklCyqis8MVDt9qpg b+twMdQH+wU9
EiIWHGSlodccMPgJjfcjbZ8bXVJJINo2fI0Zn7MVlw/YKWiBu4tjt62RXsFV bTpwlI9MELXl
AjyhSjEkhkyxWOKr4w9r+TEaWOhk/cKUYkkUlRhi21w+gNeXzY6q/X3I1NdU OvTgX9eZfXmi
Lk/y9G/xJNoxrJZEv2AjyhSjF0jXXHyYp+RmE5nN49XH1yAip/HWpw24lUsN bWj6o4VOn7LI
robbPzZ2qX92KnY/cNaTlZ/cWqvVl642NEbhgfEherxuszBHb+4Ef54JtKvH Jnv9S93UXSul
N1dJ9+XNX/+aID/5tMUbM5HTFTBuSo94+yix0226c1sirDqPHzBRjkMy6xBj bK1zuNrvrpVE
+1NlPokPGKpc81qGusEvfz9p1u154YdIpeO4l9GCVo+LbN0uo23yuzsFPmYr rP84UYxTI9md
VPEFPAccvMTsxohXnY6q+S6QH5ESXf7ArrIrOtmX9AT0nF5jsvfo4EAREP/U GAePtD8Ud4tu
ajIWAqW6PwUeT0TCfZHInZ7B/aXr6dgfvSdwQX/M409IbB7SJiykahzhYq+n hCjGATvWwdEb
aQPbUZidh2jWyFwsVd5JdG8siCW/+msVe0cB2Mmy0X1tei/PCSTY+IF8uFR2 PMRFZNN8m2KU
++Cu0Cv9Ueg4904B910G2qDWT+IMKmdH+65sv08Xpgf6XydNOn0vP9Nep0vB 4qkDis+EwQff
FRHhEI4g6T1ekzoeDBw7U6TVg8VQ4gqB2wjTOjiBvpeN01nOl8/TWr9MFUO3 38V5E18ciQHr
4Yfq3/CIR3puBxA6HasEFDtj6qvo4rVumoQPDYcPQdMBA7FzRBwi61DNc+Um 6+Ks8EPiuHDx
+mnV6W2wmuMOuo4IYJrjHMyJrlhimjiBoOw848jxVCYBiHAiR/UWuiRAKs6i YU6RHD1MJTMT
bRxVa6a7vTUDtCsTbyYrVnb/DlYJr/f53ESJPU4EcP1+mtT6TudOUXBINqGa 5MspgxErEhkY
vtkRKQCbRNf7mNXRw7B0mOEjClQ6PDwcVT9JSBIxhIRE11TEUd69cOGv9s/4 gieKCeg2r8VI
FiVYv250GaIw1TE/9XJvDJK5k5w6kHLyeE4YeiwJkqH+MBGdK4lBeMnn3ImZ cI+icAPAVPCc
GdhQaT0dvBCj8EuWUNses4GXDRcP08Appie4pBc4M23CpQlPL4ZL1RoYchgT gSph0eUIJFwJ
4A8kQSMFH9XhgZr4wEJFupn+ONJ/JwY5D8IYlP35+4qqevNp+8QVIMMDOzT+ JhmXDB50z36k
CusCGQ86qGG66o949SK/aMfiiSYxzPfkf+qJKEYsj/byeE4P2dUVCeSRTb6I oVUiAdCGMbg9
Bwy6iDmUgwvwI69TTFDLQdTO4K8ktjtJLOriAfSOpTpHjGCRPOHbSH4/wnhp igPSH09LI0k3
MioqFyCeIi0GkxT/ChZzblR7x/j/r9ME57SdtUdT5fuXigvYZ5eO7/q7T5+a n0Ydgu/G9b5v
9RdiBf66M/3WPj1lOkO2MXpNn+nVeDjsV8Tw3Kb4fxOcHl/WSMJPoAbhDWlS 22RM+SV53etD
CjbVxyLbJQyahg+kBPSFKMRCDXh1kFUjlGv4zhBH+/aGF6gG9QUowC970MPR 2tpSNtsG1niQ
vUA3rClGCVH9EfStQZPlV2fbVlhQv+/9PT0h76Hv4fyPSA3qAKMttQ3xtqFQ jvk24EsmoY3r
AT1hSjEWg4w91yjw02yqO1fvuIBuIKeiAqLjR2qbKNtsG1NxQuIBvYFKMEqP 6PZI6MjL+EnH
G05goZHQxqwruTIRqmX6yt2LuehRRNWsVAkxc9bWSubioQ7ub6pkTQnyVs7Q qluBhgjymuEY
VLnodVcyaCiP8ZvrsCR4qJW2OV87X8c0PFSqED08WH0WMT7gJfVXN9HCBgEY 5Pw8PO9Oeg25
mtqKiY5KFw40tQ+2sv1AP5CCSqCc4le/FQ4Ym7GKjAporUMU8e4kMVLEymjV KY/6Zcv1E24x
UYDJHRt5LDg6IpQQxfiAW9pPynzpIvPSMxbYUtMaaFKZLK7WGiLixrqZN8n0 lt+OHwwm4/tt
bbhg9Ayaqocr9NP2GFmmqJ/U9XUy1pa5xo+sCqMe8ln5GhX1RZR00xcpVSTC BhE/pOZPyDJm
NCPNUypskMPU08NxUmIhlWTPSImYAmT5IGldHiP1EtLLipiAzbDkTywtL77q WqweSfyEElob
qJZyRZ23U8cSpVRU3ayf5FoVFqDS3Cj0+ung5KYcJJi06JlfbeT1986aVQP7 nktyYxcIP6Wl
Qa2kwd0yeSFpTGCKCohJo0jeWl5GVQCk01BvajSBlYtpm0h+sBuIAoyOpDfG 26Rmfu26TNIP
sAT2BSjESg18fBIbSxSGTmkEebv33tAb2hSjAKi40NvHEjb7Bt3U0L2gN7gp RglR/RKLes+O
d/kbY6JzyXyJpBruqX+1VLhnyJfJqXpkiBX21MjxKhh5S1avXSvdcbSzwi5o CKW3JZPTp/UL
MC2iKldTRiLlpehgfoqJOiDU0ucRxxLp9gUwLuvZXz4lb+8pq+fTwTKc5Bz5 Y5JhSAIydHrK
ZqR/J2GKuXmSqdsLrqV1UDamdY6nW0K/h5LUMl2pNq6zUCCq+LVCKaSUO6p7 TV1NiTdA6nRM
VXOCBTyvsKpoEggT+TrcMVUl8dUT3Hku4FL15qKdbj6moxRCpdTKvsFsEI4r gjyZlRGU7jh+
Kd9JTDIA/kqHgejiEVNUO1Aiqr5yng2ngqkFT9mR8N108g7TVFgfvQh6aVPQ Tqh01dL4JEUi
w9nDpdsld5Iktuq6O6EPK4LgcITsCvsrJluSFCgrT84ZmTioLqp/VUOlnkM/ mHAR5rX4EClc
49Bm+y/DpcwCEzS3Vkdr8Fv9ilSz3ulUIbyviuKd+VdTOSqOZq6RMTKUp6B5 ej1VQ6UIV1kZ
fTtw9jBGQcB+QRXWVTA67apLxj4+mo2n1NrRFPRGCqmXQj6iyGZI8qfmp7oZ QoyTUa1+U8F9
VQRkRCnuwkykZfVSKJEwuWo1zK5xMKVcxHU1S3OBN9Gpphc+QylUBFKnqddT bA44owUeTdVF
jMYc7UT8J1Ri5VAamLDeb7Ie4l8oHxi3VyGiISowjPMbWoLn+7P/X/fv+6Qs O3TfXSB6BW5U
6DSljSUFyUQWSo3hWpUHkod21OOQaTi2lPaZSSYaYglC+PO1WlVRcZPLDS6F U2+gRX1A0rkE
oGayVV7iqkcpp6GVVMDFIIPS1IqYBQsCkn+7cWlRKhVuBXFKpz9KpxlVKghM QB+EMZ0/c4lE
M88laIRVMNFe0TIu/VTaTtJSXNtJRJDGeup0iwESkES6WqD6qqGTHCspFml0 mCtKS5gXKqUy
DlVJDlIlw4PU0lRWSkXbgSrxbzVaA9ApZtQKkSn1VxrUeTyJkpaH1MFj1VUP C6gyKc34sAqi
MdSx6Pqc49eopgEEssrsKHmh6YMJqrUYegv5AyGNaekiVlVVb1VVVTykJh/s ipQHjJWcvmT8
gavJTL8MB4A0oiTJLlTl2LVTGpUi4qeaqnCZlltptZ6rNOqsZqjSZX9rVVkq lyZHDeTZXDh7
AG9oBRmxlDfG244qO6dxCsjX9wCe4KUYiUFONdRgA3R8YRbT4dgyd+uHCiA1 EOvpQFRcaG3Y
bRt9g26RiFRAb+ApRglR/R7KUSYuCHbVoS0h9/6enp6f9+/7pR76Hv/SGB7g GogFGbGUZcnw
Qx1W72V1g9/ww3DtNNZ+mlI+ZYXkSTGkeY4IVM3GIzo/himFzTWfzpgrnzgh 13obvHxP21W6
s81ktPvYZvPvACOSO0jetHFwBG12PFUPo96Bv5ACOFaPaJDurj6Gs3WOEhN+ /kBP5DWkRKzB
+36Xr5Rv7IhjBWhxBXKeQZIYm+7xCfkZp/8gNT4JgMcYA9pv23UQ1iwRBTDs BAile2bEXjV9
dH32CPvoUkwFgp0QFp2pnIr2wa/tuIvelx5fkUo+mx5Y1PysLvNGcUIr9CSD ZIUj9NhXxrVO
CbTJVgaZuPIchFWNjx5p1OuuwUikSf+SY8gMhAfUAaoFbtDnt7BXHVxGI22+ c4QaYYTmVGNe
s7V4JsLKxJX8DVxWHG74aS0U1/oVaID1ZvO5WIiee3Z97Tryy439Ih3sOHOq iNzkHYAKDUf2
Raal+Lkpitv4Rilcu8ljmkSjeqAlaTz85QS8kUf9vbPD6yAh2Aq4pbnYYdKE v90HWuDysxUx
la1Nw+jk3I0ymybZwnu4lF60ym8uXILazHTGwcDGFrOR8kQaZds3NOHbNPa0 3l1ppwfYeqR0
76FE1qZsoWd2hxfXlq8lzHXKMhOEDDp2kDAMdjlEzkLjrw33mpev/UkRBTG7 sRqFuvQ8eP6z
Q8UHJT6MIXKHhkuyHwSDLFp2ddgGS6Qv9/de2v8EWcwsZRX39uI+soCFcGgS NomXYAUV2OyV
V7TGlWXJHvdH9IDhRrA7NWCA7frsuOUcI578YTcCZGcHmmSyQ3euA3GHS7ks d2G6xCWzja45
cDbFAjqffN0QkuNp4wI4w6XckfPo2cfW7A4iMeRnFeZciTq7M2WO+Vq7eMBu Rgm6xi/nArsi
Fjaqu3TgINc8EKZbzLYSY4LkAiS60N5USE+zg8c43HrumV4LoCX9RLnzw/VT +PtuyTC+bkAa
wwjfNEuEZuUUkwgidvm7qL8V+zkMlKHPsARYAPRJBD5145HnBzQRvJxA6k6v vLkJBkZutgBv
gAeiWyM3MJe3zblFwV951qXbmi1I+sc234AHoEfPw2wwoGnHzh2OVGolkB6L F76yQ2j4AN8Q
E0CyRmxCZv99QdFLD6LdbvI+VQ6udedW3TIlp83xAiS61LpUSH9pfW7jXZS8 hDeyO8OS54sW
ConDc5uSmMUB39O/0sLbgUfWyesOrCrIVtMTCDMsBDUZvXtqr8Ntrth3HDlH rssWrCbNphh7
2yahxMsSjtDYjN55Ey91R2WPVhVpiTme2SH9RQpnpNLJLCOp/4a5wahQ54ND LaSleLEPZsr6
Qf9ZJbaYdV4yXWkzIiI2NB3q+tFdwundVq53Dfcti6ecSkEKjBdrwwYrLvJd aGEiJfdjLfl6
aw2PLVlg60O7/Ucl9DP5QI5ZvPqiIbd1DGzbh09aND5iDs1VW0+ufUfW2qSL V6h7KfHLjMeU
BrYciSEr/azNdcWg7KmMeTIaXu3q2BEl1ocScjf6mvOyk6crYk/AhOdiDTw5 Lw+rw4LxWHwR
axbgIwZndDx27g50nsad27Q/6VbCL/uRL47bDoE/NLjfu6J3ZV9Gl6+LPAbE 02OUvgfVoKuH
vpt3L3YZ47doTm8ltQZIi75mLQJua1Mg80pObu3HVGJOreYteba4t0+/gHCp 4VLsla3Mx6Eh
8uBgyi9ojZzsAS0aijlSZJgjhB4pjJYrXs7Z3Y5U9g63aFXYDUfkA3yClpyg Rm8KfOuz+tm3
89rmpRFwiRQitQqXsCPyvkXApacjUZ5KTUVw+2PhwWLsz45MdKTr9+KTkXlY g9GNeh4aiZp1
XAJZoLW6LgC9Eo1oCdyTMjNEUGwrkYjPtUHI+iw59NT6uFH2poD5MMUyXojy 16GJehZgp3et
xOwdXmsdJY7HqeYVMnlqXoXuQecqxDCvyeJCnD3iPQkhVSUy66x20C7MJKY4 kyQyn8t9eS7v
mzyebfU2MNIlpQVcabHKTOPhrYLDD0vYYLgESjWwB3ZESdIRm3LeXD4/MTwN a3cuB2Lvh0TX
EzHrngt1bPhujk5V/6zoyf+/Bn57vBLQ8Ptp/MhDh9indphurpavSnQQ6qyJ 9fGjiKzTXJGl
vusVxk3tmlm0pQMtLjigbK0OO2g74AMdFKD5MyXHw2bIpR4KFfLvu/LHKr87 EQn3eS3z2U4r
zZdBxEiStaUlZKb7eAjnDr6UNJ7pXIp/+1Eqg2+AfTr2pHSnQ1Lt5L+mVZjr M7wdfSkRtNKp
2rgGt7869u4Jtv/VCvQ//+r8Gfvfn3RfcO+p9/H8chs9D/tN2sNtfQs5F0Wn iEpyHofelJcM
26Yro+jocewAU5Xj21nzAqkuSRMjzsVsBkutS6Tkjuykm5ari+rDPj7gthYb RrWyFS+uL+cC
OjgYcoixGzlczxA+gvUAzw7KyVMY3MeSd7ifFW/1kWOjz4hMVwszdWTuZjoA boDmyAmkZqRS
ZRo2nLId00mLjMehUusuV0Mc0aS61TZORsLphUX6cn1s8vD/5PmhP7dZ07Aa N8wG+YU9MTSP
7mYsh96mJXH0TL3mz875H0CnpiNhcTEeOPkRXfVWx8V5Vvl5eSC5YTmlwofr ct2qHmgp15Ia
H9AGlGtRLuSXZjzXG6ywdLpTyfNLo6fNTY/HT5aA9ZoWMgf0Kdasm8/PHTke Xo03WukTqaXn
zXklNfjkbJTD/qx6MN9ZhIZohZPemt53X1tV5YmcdKNtJhzXztGW3Wz9/X+g ESjW4n3ZEbS3
V2s4bD56JfiXTolkdPlhjaOLJc48tYe5NauYm73SNh74p116RW4a+oCfbZZX NMTmvsPbtgai
j5OWyDjywVtPq1Xdv/7FY1mWjT9qICbKkc0xNw9dW/3O8PMr/ASP2r2Ae63/ 80f50ff8VUKa
f3Yusv5yPrPdyFcP6+j40WV/gO50/+KyXfziLGK+QiRUga7KWk6VfR9fGLg7 WF8bwlDGeF4w
yIQ+6A3i+FYxGL/ixbGB84MUNV/ixfyLLGN/i4r7meOPG7c0yYRB18is2l0V PjigNED1wd8x
0m4z4h07Qcs7bEl7J7wfth/xhf7cmG9xFORSgd3Mmwxn/xhSZODo/4vDfx7e jGddHLw6X0/2
LXz4yvsWWVw97/LxhoyhVGjn0Q6OrYjPyimD5od8vKqpKMBiv48XNbu8rWpA DKtLlfY2WwxB
tBoS/u6zYIktyIC5W6nthiNRDQl11R+wxIIGhIq782aIJJYBUku8S2GJU1nT aa6K/YYkkh6u
sqIxHRctSaI0ltv8jolkEyKTOw+XQ+T3tBoy2tZdgiNIUXcvuRb2GJMgmLyW 0vGwQ+TZZENX
bUTYYjSABpX2uzsERXJrMW0109CP/V7ehDVru2NuVX2zU+e9yW7g2b7VD0pi WRiNMswiGWQM
9cquFsmES5pI3o3vmw+bQ/x8Wfj2vxWip7PD++laiuTDsHnGISZ7ObHu6qv0 P2U7mO+9I9Kb
mQpFPtSV6bIY5E82SxSPB1/PzQ/OjZ8fq1VBVy/DkumlVanGZO94fzy6IZFU ZTNxI/LLaR0+
45pbRq0j7/lv68uR5T7iyf5CGh+//6hy8XSgkEQANyQAAIEaAQACoQX+jOl8 2TodMx8AIAAA
AFBlcnNpc3RlbmNlX1Byb2ZpbDEucHJvZmlsZS51bWwA8OyeORAhkQzMzVVA Fh1/flVzwc1N
VW5rdVI2OjBnRNvW5Tka0+PenHHtuOOa1UqjQI6EzGUUoik5HPGufnvU54a/ MeURgKR6vrsA
pFIApEtlJacVNRIEEZd5l5eX0fZgBwzxC/8JX999izESCLBHReYCTne+n9dy 5Y9km/et7t3+
nyO9xz5LEl2Ldjt3dvDvR939fnX8n0/8/+//Xe4cZvo8u/uy27kljHK39E3+ 93HZgES7e+gc
/D/VwcG99Hd7t6L1SbkPc3dzb4vf28O3pIu7+H2eLu6HXYhxTJyUD9OI7mAu W969IdBx9lxs
cce7u0XTZ6GKjaagj23gX3OJ7vo+zx4Hlmtx43WXYLLnGWZZY3H1vYTkWggc W4xSONs4Yx1b
LLM09i7DuCp/lKzN7gCBc1NFscU4n4MV7sclzzSS4uL2gVnKvN0KXZmqEeWL Hek7927u428A
Rle5asXPJ7fR6PD4fJtRpxb+f3eeW1/eX9v0yXXt3h34pNVtQZhBjiyNg88F Bf4PbvAgGmL6
NrywxeuHbk+TBp9M2pUQFnQDl29Hm8XJVGm9693anU92z6/n9n9u/Usp3XCI eMcl/9a0wU2E
JFX13MjGLcSSb9ZYo/c59iNyaIIOt4/cpc6O4l6brWN/OoRe0quzEYmgQoe4 jEqLLyn/k7vM
q95+Df4YuDJrDc/rJCP7JWIE5Fb+cgj7/DNFahy42aUd5AoxTRQ5ckd7Arm7 +mH/VmoujlO6
KKyqd9wO+muF9QtfqiG/5YwUUTmWt7tZa7XkG9/J/v27XDwN9dMu/wQ2rknk HFsJBngysQl7
PSIP5rNBq2hZwNZuuUI6bBRRjP+LEHd7u6LCv4FiD9700VrhyEXcmd7VGIfp 8M2CSpKF4ldV
AjiLL7jk/J0qkfp9M35fwyDtzoWqXI9Y/iSE9K5m9L023slCnvTmjPUDsFiT +GmfBXvbdizD
7t23+xOfdrWYJn8PTNglvoUzDUvQKffsvvJbM/huTflbIUu02EqT9RGQDGvr SlH9+snPzMTY
YPSviSc/QPbIUo/u2Nuef308N1kD9luKTVVIesJOR1xx3DMIsofw/CbL6l7I Uh/x4Zs/m1/8
abBzkEza5BtUUg/xuTYLiVusRhuHPDmIcRslSDpIJ7f3cgm/we3siCfz1B7B Umh02D7Nvb/P
h1ViPD6cGCCjq2MDEBSYH5x9yaZh3Js/m2ntOxNkuR6opLa8M2CgfS48iypi nU4sRBsmK4te
mf9D4WcTtTR473MsF3tgGs2tNgu3sdorZZJV2WhHxXeDrhB0WnnBYsh8napB WnDT7f7dq0E6
ZhtL6/r7asOIntOhT+0nt7bIXj0zEH1ydM9tsYsxPw3OD72nDJ47eRwVCz9V 1Wiec3bmau71
yijTsX/zuUWD7VqcaZjKIqPycNy52+U8m8tMx9ihD6mOf32DQHSTZKuLPu/C STW1d4dznVzk
0zBn6211OSbk2fNg8ySZWxDgz+JC1WUJTAoZ/m+yfTSq9z6s6cPrh9knz8O9 HmPk1MkvTbn5
o5LknHfPgN71BX2x7CX4K9zUTDLprjcarnIS3pt56ZtnSVlf+Tu9QTfsvR6J R82Us1UtUVql
6xFdH2Pow7E6FPPKTZS6yeZ25vZ372Y6K2duux5wnRqJ1u1C2/4bomXY+Ebb mjPF79tr8sfO
DVMIe3Nf1QLUlfGOJswPBt/OOvqmmfV/Csi4+GQb0Yax4JMgd2MUfsgNa0Kh 9g4PfVNHRk6H
2ScHq3dVFifV1fg+SIOqB+Bxdl8f1eLn3ncEzbm9n2gUF7MdActQuwVLremw obkwIW7WdAkW
9yafdsvIU64/K+FLeJgSwfpwox3FkGKJzZWYCW5vZ2+Yve30fl4ej0CjrTF/ 8vT1Ypg+JUx1
a30LswIHqRPO/lufxFi98LFu/k90ikn9g6K1oAk9c2D9c0fnorv92/DdvQxE k47BamvL65sE
+6zE+GqQt10RQbs3pXznnr0y3/By2qx11MlvTbvzSQx/bdue3XADK5NHet7m 9ckrgDXY7Pe5
6Zvb9fm9HgC2fn4ZjfJbi9ptLBaipqqL1+Ga/BoxiRLqJx6DFC3Kxo3p6u9A unHw72VOIBEe
jrv/oe0a69q+DNszVAPR2U6CLuBfyxjX6nOStX6Zc7tQ69VSupL1Z0u81vNo Ws2I71VFp8Rd
npbjNn4m1RTbGgAYeIQmfAZV1TD/c3Jr+xAF4EJGHjDlYVsqCbFgKxc3tqAc qGcjNz3psI25
Nus+kONTwibk1/wpKwG+JViZ6BbIMHNr4soWAnj432W9s7Z+Vp6u1PZ5iorv R4Te3OpBgh30
9J3AxTIn7KiMLvUmGtEyTfeWtDodTD+YEh90YgEON3116bB7uzRy5u3u+mbJ Nj4Gt3TR6H6S
WvPq/ZSgJT3Va97+FodcdQIZqy+tJTqqHNkQz+9/HuykucrHWKu97ePuXbxb m9lG4OVEGr+D
JgRLZ02SOjucPQQELL/R9hEbPb/JfwerchJAQtPZ+za+7v/Z9vg2vH5y9Xc5 Dp3BR/5Wc99u
XfmVl6OvG9v5TbeaD2HcZe6hrp4/F9Xm7/m8W0dc/LzDd3Llu1vw7/t+Ar/+ UPsh8vXFg/+q
hv1+wke1ck3ArNzj/5wEkSbpevQw9ap4NgrfCBne3f0u5LeSIs6YqvupVhq3 VcU/Ok1uOH2W
72Qy3cBlCJMi/sGjprEPJoJbpS6P3A+pqg5fCh/BzWBJINpN2vYBsGjvd3mo C19DAy/LL2oN
SwPGL41LgsCiroP6tQvSbc5v+vd3OS/ae3OyjFpAAt198Z89A5kvHv5QMjdr M6Cr5MfrGaWx
mfsGdrAaXBmlvbt2OEMtcVAS1xZx/n8P1eCxv0aO8utO5/t/L9e//x5Yd/GH 3fvLDmu+bHn5
cd+Auru8hSiJG2E5XrGVy7w3ouG4foyDgSth93/kN0uvyPg3whz/Y3gTuHFw brjDaTbfuBQS
hpZyLvawk7u9EoVzMN/wbGTnSPWxFHl8aldkRNj6zXg53gk3Y6jYwdpw1Lxx a2AXN58Nig4e
9KFClYj3IT9m3dt2MW5hAkKHhIrjC97v8jpP5xS2M8gp/vj5u8OjSd7lK+dV Qjr+oPeMfy5v
sh/y+3ItlPthVe9w75Uqkr60p5UTY3462LbdK1qTMCxuGpgQzEjw8XM0wPeO SFWMBxSbGN7T
CEu2Ma7DlH6lVMs/+Q8X4p3AQNah6kNan2imtTUlrUP3aay6xbWqAzI0UPVC 1jggS1lyZWvL
dOOTtb+AbRbrRtFoaQNaxRVNa8gKXmtkGAU1sHJW1stNIWtkbS01skaRNbJS ra1Qg7wNcIq2
prhFUrTXDI0ia4R1kbXanTrWxFhc1AWVyNbEztqhanGu0/gramT7Xaz9HatT DGu1EVf2q1GV
bWqEFxxrtDgY1iiwoay6yNriBfla4np6xPzDaRNGIay4IGuJdJHiFtYZ3EDW 2kYpcjXHOpWu
N4qgNQosLjXGERPNcblPtRoz8kI0Tgcac/AwkjTqNqY1xrz8kWahnfLwBLEc 7GLOFtI5SRW1
RIa2qIESVrkcz8ASe/OxybTzXIPVA1yP00WR7PwP0lCQeqIvyQdStrkCc20k CYZGvl4LU1o7
4TUqezL9q/Ffjvn1McRI0nbVA20M1B1jjXIjPwLK2s6ktT2BHlnckk9h+353 K1QNcrtJxweD
9NTJYG2ZTUaUXQPl+SqpqZKLxETuVWfgF1J3oSnWSOIihHKX4XBG1yobaDP7 TVJOyI62vlp1
rBaNtgk9/A5TvEapV5+AXHOzuW1n6NhXmzqWMkVtRe0prBHc7ff6/Nl7zpYF EWHZ6Sylyom/
/K+xaLLDsfRY3utA98tHhlDG18PDQzBD0PC1Bg+8WFkOKBS4yf/B5C6DEHUe RwEYc61MIvm3
xQ4T793HNZv5gyvxhJqksiIx8nwSMQOilQHATmzZgH7Nx8H7mMTpPuUGzZHM fIjRQlXd3EL4
fZB0wgjsg3uBvRRaR82AyxYrDlG34DKrFqSQm9IVoKHvI/Vo7SwnZwO9x7OA DrQWCKnlQniK
I/FkbRBivHbsPHnxAIhkJCbZthIwNp6o4DGUUBZ++Ke+TeWgmvlVwoN40pQu E3GflKFGKoMJ
VVgaQCwEEwPwczHeAkSIJ46KmvioshPg3xZZ0jWEOsNxO8aBY3zqGL0JCvIl dK7ZGAWVwTrx
kOcgRM3zvlhkNJ4qTA0YRslYSK0v4AqnD+BQcoSAufj3EcKtGsia7aNEQoR2 RtOEZHSrm8wu
QLISmheR0ofpMJQcERdKFILBqwkHCxUzzfg+j8fs8Xf/H9N3f9Zy5Pm8H/yS GP8QCT/lJwXv
ruCOb478fDxo0sNJw7+F/Vv2+CG3v/iIxp3uI+7d/6e2tr8TnbpMWXuPty40 gFq+fe5QXb8d
6amAt7gA7QQqZDGjLk7N7ubeOmVSXKHi4Rd3h8X9eeCZ55ATUQTXa/UHM++e +kjc6oEBTLTD
y33uWhqj3WARux0fUMxiYtjUrmgxgMelsAPa1WwegXW1kzkWzpAaKg4auEnw 7e3vybdKmwHC
N7dyKbBB6uHemN8u4d+cgejSpHou3ClgJI/JCYt1q162Xp4Dek4ybwq6Wy7x jSPQH/xCWF28
I1Y7MFxDjUub/50w+L1vf13dYEE6nkzDnZeL70IKuvjIWeKHPxbmqxIl1HU4 G69kuU0CUsSu
zqCbUqgNGlA6tUAUq+0PxuFHnY9PGFmepKHpwLmC49I33sm7Z9QuwCvADzU4 EmbTSvC03yCW
v1kPlm5w1q6SpZRv1PORpheYlKXickMUx3BWs8ovamO26YvKexI44eErqIds z1n2CGJKYiAO
00ZcFhxoMzO7fBiV+/fv9vv9fbns2f37/VABpU8+H9P5/J1vSKy0cc6ASJ/C cOBjZsnSK1Jd
nFZgXJ0vB3Woyc6+Iy1YpgU5lrCDsQ9vpOe/fv3+33+vtz2bP79/qfP+qshI 3g1JL9sVPUMx
paKv5KcE3VLrZOsmAW9Kqmlt5pNj7IMRi5nJb1nn/VJ2dQhjkzdb31T4ys6H 41g1ye/yOsLu
FRGReBM6gwTba4akJXnSMHzzIEhNAzohT2XHADtSVuf379+/2+/19uezZ/fv zXarISN4NNME
28ydiMm1aTonmqlRmylZL9t6VVNLbzPXj8KJCK+s576k6peeW4VolT95WfNJ Nd817a1PbkVk
wLTZXkbeQ40W7PM8hdYl/iX2pyf5wVwy3ONfGcawBUD3b6e3v379/t9/r7c9 mz+/fmu1bISN
3/JTFD4tucanp4K2TobMVlRmyVdL6N6Famlt35DY+8pDy5kjrGe45Ds9ApwH xb/Zs9vU2PwV
uyIzWO9S32cRAwFJxjxFlmC3iyIjY1zYvWx49Y3Pd+/B6t2iJ4y2xerJYP+s b27w75e6GBYW
DHRcVjBu28mfu//cGMtjbw67xW/f5PJFfg7/20eQE5OHGbGO77N32yF5HZnV 7hucEOJdwfy3
vat4+k6LZH1rgGHkB41YCIYErUU9oqv87ce/AY1JgHwy0pTUme6cladggZLq kiu1mB5I85qj
EFg5SmFPdieOSb2uSIwBJpIsvaLgObpW+QB5JEU5o84UsyyU+CUn9TUU4mYC uU6ACIJRIPTo
5wPFnjAMI6QANkp8kde/TP9QwUz3cJwVAOlpRdNRwUTuZAAb7WXJRYaimzlH NuymTQ/wFgpw
TiEb9ID8JahbpcmWEoU+0o68vlSxAe2j9qI50y0goMqidGigMsyEULTJhbTP OMxRGA6wTgNY
hYmglh2GAWlEyrImyxnwQXznCmuUqXRBcRQTEZz7jxz/Q4JS9qF8gDaWUkIR u5+SuaiM/AcV
WXtRT0wKQ5sigoHDW2lEaynzYDmyDQVRThwSPTUgmDsK2spgBKm0kKDSaxfi dFFTIbRJJLgC
AXG2emdpZAssaCIJAnAN0pzxAS3CVzUrhWghzzbq0TVWnPwHNlivK4p7CnGB VrWc+Io/2Lmk
EcZ0SQz9URz1lAA8AVmNzPwOn+RGA2MsYEVCfMBmCMVFUmgADLgMiU8kVkep pE7BNFUkZ+AH
R055cFAUJJ8FqxgaG0hPkiyLk9GTWlLoGopGqUwAxhpwBZFqaADkE2A+jHPo TyzPRQhBLaSl
1NPJPo5DvTkYYA8LHWjvitH7Q/chcFFQ2uCarnb7/X7809rIEzDLNZiDxfoM BTQU76Jnx+Yh
NoEH5AaZB5DgBNuJOcsgiKa8YYGcBwApuxKaXwRP7TFIoSn0ymsBkEk4Ge3E vGAzoN7KAQ98
2dhAAKDIThjOx+yH3CTbDjlulUGK0YGTYeIEFZEU8K66T85EBPwinLw5vajy C9BzvoK0WAky
fGCORnzrTpQRkUJO+83g9DxEpBtUkpMeZVO3rROz4HCtitw6GK7Wigzx18Zj xoAOjyRJJ5JO
ELHY8el0wQ8V3J/W88QNqtRExlAOUR/AE2MhuMELwDwr3aLoA/HdMG1UbW4A L0ZuMXyr2x4v
aWSBhdw+XCIPlhc+I8jhVKQDFAsikWUGioLxANBQSyP9GAFKJJbsYAMqxtTe DUkCGxU9Q8J1
dkDUuebql1snVlL29Oqmlt5z3MpQNBAIdcnwlJ2Vk3gcK0bOzQA2ptXHbXmb Wc28JCM0oBzR
8cZZqyM+cAN8pT9ORcSS1z3fv81i31WAOeYgBe3JzQBaiyusgClVEDea8/xC 0WZxmGEGgv7N
AFKTAjLNhrk6ewfQgAMCDiD+UrgFetDxp8sxrdEhO3RnO9h0S19ME3GYBcsn WsD2jBX08DRO
f0Hmg4d/pdp5KDyO8O64y/eBwyk9IfVYOAbkZnpSy0IuHiB8EAf4gjJLjUoi eo31Thv9pxLC
AlFIPI2ZDo443CgmX3y5j7QQWyjzwMPmGUV4eKZXKxqDgHkFAZDQqUZdBBKV pZ0Hzbpz+SZS
f0l++TJB3qaXQP8A4ymhV60VCEMsotDai0LBbeIvUJx1RQOBZR8IAx48nIBh LQ/Mbxw2Ag4i
nfoCI8UBEF6YGScpPN7EZ4PUFZZ2CAAsmM86sLQASjAlJGFCmvwlL+iGFjLQ 0ZAY5wYER5y8
SVFFlAELxE1KTyYc4TdUpzbBzIQB54jmdWRFVdchTVanitTCwkb2pDJUhofi P8dIponpJEVf
35h1JXCjJRwcCg37Si6oRF8ZhQbyCTuOOMViQSLyijYiV8fgKjEBMFZ2QwDd 04o2Rw5+8wfA
e0CiWhp4DiLjyd9ZW1gWRPYk8pIcKxA0SFCXBIdfEFV2E4kF4JgUeTxqKKbE a0lZVuSVRn6A
C8IUAVKUb5RnvZAPij4ISiXCvgCFoyqKWfnxGqEwrzQsgaAzyxlSDITxJTKN MCnpnxD5RNAN
a1U5R1AFxIiTRGqjR+bxaMeBsdK+sooBJaBZnAh40BPl/RWcz0IspJ5WsLep JWZ6IwFdZIAF
HXERsjUcbiYXcE9SFj1QYgk9EdHkmCIUI6dZrfGDCSWqQ76jLTAqoF+wuAow IWFqlMuxmpIL
u7RFIrUFacSXNoUQlf5T6qB01SXyWOMKSCjIkk0nmiZhpcTCupVGVpgRTEFn Yix1MUVTUFSE
wFyCWohLBwWjr7TpYE1rJMVorhSSSC+WhVo7VDFJ18mGMUBmMUhhiDcUzfWW ONUJSfAtfEYP
sqErAC+I8VJYJaEUxHTZDwUBT0wfqUr5VnfjE+RsIJONPYxzwJL2rSixdEzF FTTzRijHPHCW
iWHDWPMMsLMvjDv3mHzAik8doCjYKM4DLRY5YwEEbiU8LTLr0B5s9IR0kWRZ Wa7EBtbFppxP
R2qNJrphNfYtGJPmI2O0y+I/FynUstLMtT5aUteSWlY2FUiI2LElo8TRodJH rpzS8Js+BKlE
nKNhXNOlew6wpdApeIYeXCte6d0Ybp2jzV4LZQEZXmHnd7UFOLRWcSecSJMO jDQ+V2kPWGnT
xb2IpxgJZB/K44pYSgPLBOUVrywatGPGlsX0uG0WLS+hYlTGgCavUB3g6MdT JTh+LmHnyMMZ
sUS0fyBaVJuS6BclKCuaY6TcolHYyX5QYeoVYoyqqGgB2OIXdD4E1k0xk8pY fMC5UCTtHQ23
J7aEIvzON6kawtHndMEZUwnzRu6g0XkNp+bUIna5zOto8IAd9oN4nAbTaExh MYn3zV8B5LSL
WBEtZIVmKCoTekdAEfPHjfNXYK4SUDZhrcBz+mgB4LUEeeAzJ8BAb7Ye4P28 c9K07Om/aIrB
q3ru3N4eXyeGbCVYlNvBqReLYqeoemOKIyowTdUutk6sgw3p1U0tvNJsLzh2 lqTPhM9oxmAI
/b8HZs35U3FPVm40nXJeeBDjmQ+yO/cc04KjNmy89Jgw1b7hKYLwd7raHkup wgBFrz6svWAW
5Wbiodjed5WPl4D0fYtQqE65U+Slgd927d5vyUxY93/2oA7fA/JVOiSerfkq 6vTP8c/ADw7E
JDDayxx18rHPVdx4uxlNX8kgEF7Kwp/x4U1d5wWCV6+a6Tm30DkFfXF6reXk KkWOAXT8P66x
dlVtF1tdjnbgYJ1bAk+ysCdSg5lWjm7katj3Xi6IvgDcNDCGjq+64hAaS50N 2liHKN7v83ix
X5W9/bLE9/NWj8HcfTxH++tXpVEBfHl6fHQIdUNRXZmoMCTzNymex70nhh6J 8nAwMxRe7VGR
PVDbu0Xe5soYuD3f5GHXkvdHzDdlHF4G7FFw73u/c2tBPgbH88wMGjenrV59 W3zfvUurCahl
UMGYsbRv1125fnY9678A+XCH8S8UL1kTW89um7kr2tCEF+bR+Z7Q88D0ISmm 2V9vJekeQSxS
Zs5OR8xrF6dVAXx28pShk5mIedcKRJH/aXc1vsa9VL7nEDM4EPDA/Zw3P8SB +CmE0ihjpa0l
eHRKNDJlBKYhsoMnFkovnzOipo9jkvZHuyzBbAms98JEHWcWVVB3x5e8tA/Y cpH/IIHtHc79
sfFRxKUJLOM0uFipg52r0/z4akWxLDb4CatcFuTRxZD39wAg0mtXa1LStw9T cvZ3tDczxXzg
WeidNd6xSXxroQOQCWNn8NlqSqE7SNs4OFv4KQc/dD3sdSlKh34TmZxIzA8/ xaSRnsef/vx9
LKtUSoO19fm7/n2rHj2vPY+/v8b6PNx/JHt/NYKIywK3+wKPisbXjLptr8PF 5/u2vJ92EcV/
36Plo5nn+0cjy+bIbivaHq8Hf8nGYCxTbbWVgqqQvjthwpLhYysJefgZOlc/ dL9sdRJUGIsk
bqRoOjAlV3YCGkz9UN7r0lvbulDa7vCHDF3Wrtqlpv4Gw5UwfPvosgsQUkDN gsN3edukVApA
6LsFpLSFGFJ5+6nTpBSfp90s/vaqC8gLhKkuIcWP4vBp+aiIDKI8lt3bEfy6 ESFRofTA/mKC
LKttEhsdk9Mq3qCHeiT31YPNVRAZvBppmY1hcwJbsasJm7JHmqlRmylYLrt6 VVNLbzSbBkLi
cl04nrHyw7ynZD0BZAimfvazdZn0O6+efhkXcLffssDVQS+aXntNus099Hp8 5jwh1x2Bqdnu
mjWzZXysiMHwGPAMhBrqESIf6p2UgKYPMS6x6nQ3hcZgizzEZD2ILFPN5rfH Sj1eg4Kpggs/
uWCAe7vc7nFWOaPlGITH7v3d/6vHteTv/ZtZfOTie0zj3Ukn/6VEodVur6zA c3gZ6YMVzy3W
p+xq2NjBM1ajNk61nW3o1iaW3jObIFwJdTMoG4POdlrcY8V86J+6rt3T7a1d 3qGsNh6C0pTV
kSS6iAtqkGxPGiWgXSAmXHedHQ/6RtDh5+39gTy+XFGYcZPqo83cd0u3m3U0 OaYwh07hk76j
8cXaFauxW0NeoS3e1y0jdbQ6hWIck7862N4L3ry63r6TG63nV6aepG0OgbGB wQNhlqH8GA0D
tA8+kbjfUPT93W7xAtPvG01raaYPC4gmcheg4ew9VOk3ZRamyJ05hYpBeT/0 dR/PjfLWrsZk
TXWsbvtCmQJJgE0VPr112jZetqM3U5ivGusla9dFvPrk6tu1JsEvQh1YNLOs GSXLaCBQz7x1
q6i2N+jd3pnwidGK3VRRxtebv8v1qdHGxhllljH1LPed1PXxjWMInSb3F25a M1Uw+9nFBcIC
lIV/Gmfz2tzNAs9e5s6xRk1NNXdHRjG3T28NxWH+7/wTqFzd2ynayzcqXDoq J5czhv5QM0wX
nLOAP5kaARIt8ZhBY+nodGv6vv/EoRi2vSXCcYNOUPpeyBhIsC+g3/pawVyG qgGlEJtKYTGT
pt/8HvJlfy8OtBNHBjDOntDf/J7yTwIADIZRKqPlGppRpt/9GztdAahsYR0r gjp9jVljoung
dGgJnXFe/uBdQLdRwHn2Vz643/r9lnjd/qKa9it/tPc2MlKdYDX1C4A0x1fY Bupw9uRHXEUl
qG+Waxpt9C+s97BLdyLi0I0rcNHH8jgT6z05V++/bvGKpBryUz0OyhQ3p4bt j/b8+HAf8aAF
nRyC+0RFi9u5+goHhKfby24WM/fvSadtxq2+mDoY3isI+anEQ3SVBoIjZwAF oGHI6oaQ+wfl
6jazVGt2jcUJ3RjU9PrV12WxWt9bUSq1w5mFvpWumpYs/fWudcnBt15TWsDX az1L11a1y5To
hzM8l89Xj4O3rt+VDa1u/VrVWuZFl7DlPkO3PsLejbBXNcxoKHP4LqG+VTCy LY0ouGvtNRNT
aj9Fv13bwDr5xCC+GPVTicHrrwF/pjANou5q+udlAX2vIeAWgWQzCRwLSZ6a 3frXrTEuu34n
69mnREYMkEBh6H+zpaCmz9lXeSjcoVJY5d+DpbUk6K7dzV1aKqAexHU1eqY3 eaFLDiAS+GCG
vwItla6ojdTmsj9fVbqsGffXU9enFt00DWFZ1Mg6ydUaB1eVhiWT3foAhvp2 DljUPoJP0M/X
UMT8ECJh9L7HoD06rV+gJnvjJR542FK3zASHs/ayh1+9nMZJDQzI7kUJ4mYQ UFJ9ZZOVbDt0
0oO95RFl8HnPAeg+0h2dF9Bb/e0VQLYXmRlkC4BzH5/OKaOiV+36T3R6dZRr Us02XQ4pBZTk
Mn6zMkBW836Ej+9omyFsTiZeXYKuDmI56Js213nIq1hBtWuTdnqmKkrfoRjV +hg+eru2XgnC
5b/Y2KvSFlJZ2eg0huPz/1u95+G1eEobwlpUkl2eEVhpK39Ne+0JGsQrRWrH qD2BQySYhX53
3/43v0xcRkaUnnOtf9Y0G1l4QA9ElhnIGKVoqA2ek07lpd75cfk0++Uj7Idu 3F4N+Hmb7B80
A7lE55Gq74XfXIKl7kdneo8AZ2SrZyPruRDVfvj769iQa1RjVIkDQpWGBbLB FXLsNlq2ojYz
YV65EfV7IJvOrU3dSRHvKasKy7sVgwmhfY4x1zs4DmrfonnqH0Wt1nSvwkul ofGuos2bE7Lb
c0Fwu9aBnEi/iht0zLaIU0bTKUvqf5mVZbCGktEwwOUCQH8UGkK9QbVW1HIs +pAgrlzx1q47
ZesqI3Ur8SWutsq7Hm3n1qeepW2fIiQSgGE9aNsuW/YZw6p6e76qvTV1TU3f 8lLzI0ZKlghq
6swbMVaiN2+vNTCainDqZeDOa8JzDudbLw5zqIiGBXZy8FR1rqy72ekjvzEv pT2nBBWPeWzF
WonxI3IqJ36mXlzml9IxTOkinBguS5haHCwtuK7Jjeq36aU9N9N4dYiYSMLB MosKZZYnmOKu
d9NLtg9vOA4qIHsdaZNFOJ0PA8P1+qTHcafWscp6sCzIiSjzNKP5cRZMwNO7 /P8IVlmggwPY
m3d+8NQTRSXLknzxW8hOOe8fhEMEDCLxeCL/lLCcdGp0TWMrGsffR5/q8+8B jUYbfd+5AaBe
Lvx5UpPRaXGn235n8M6nSj8Qq3s/b/5mYHbGThxsyqjph6Pd+9Hj4W5oeKZK RXfuUfw6gePk
8f1clacqBdxLjwGtIK5Z+4tz76pPx/nFR8hbbo6mECX3t3NWG9q5Qf4n8FQV bHMgfHfq7AOA
Omz9+B8mcaYvjLEEo5kH72B5M36oe111qtUe28tLWMp4MDJsardbsV7ZWVD6 J7XyJw1x7TXt
q286uTr1I9r5TW0yVPtTsE2A5TqP267zIsbrZ7V0f1Eor/qQFquSV8wurzVL GcFDcniUMbA7
2DklfNteWuVrLBVca5SQr4QNxrS4PH0BQpyE4O32c0b6S07dvo7gLHRdOPDW b7zUv4Ro50hc
qNHeev/qTRnpcLTeJ0ic2zdch59CHhdHA5Pdq46jNWVki9nY7Rqu+pqdjSfV AHVmQVBXHaKw
0osh9L2CZ0S4iBxLrf1dJadu7r7gG6nMMbH33GNmdIXG+ugrRrTH3SLe+9sf NIm1tz0TXA++
B/CfBc1RN5bzefiPl/80kj1//0A7kHSgkDsA5AMAAOMPAAACfg9lvul82Tod MxYAIAAAAFBl
cnNpc3RlbmNlX1Byb2ZpbC51bWwA8AnGQAwZTQyRE81BW99S38PEb67hKnSE BXu4s27MtGZd
4hWWbu35UqCVAm5OnZUAy8/9alLtBCUDnQQLDM0MsvEs9QKp9HG+cp1R+Zpu n2cba+40mm0u
J+rb8Ob1/JxtDIWAzTzv7VEqoqiBXcDzDTuGPXu32+pep6/3/P8uaQzVn++u 2hL80tqdVKIC
HnTWQ14/ihhfsoomwYiuEqvOYc3Bhjz5cCIPaO22mitlzFXKpM1JiElEuq7N AvVpENCTSaXW
69ZMLWDogJluQPMtNlpgdEzMjusSI/iPntL9PT8LTFZ17/e26zf7mfnlRFrj /S2fgvkBegW2
nzFmD46jMoUTRtSs2t/4879ZyDbTCqRZlG9qIqIeKszhzqewEhmtv58aoBH4 7oWUYJAwOhtq
0v1Oi/R8gDP0G38K7JN6AqAayCHMDFZ63mCtzG00xpdLmBpCVWVrV88JRJSO qRxSt4mo10jg
Wh0ahyRvI0XK+807DoCeFhDHyYPjpMLbc0RBDTEhi0ntRvV5kL2975TTP1Dm Do1M2FYuTuJn
aEGeTFIQe3FAVnQB34cThJbYlsR1W/47PZ2W7V2X83PJI6rbV+AkHfPYIVRH WIkfII+CN/8J
kJc++Dv3b0v+bGGLTZXCuw7gP0BmpTSviAixiKA3hm1pBQjMeQYhCpOoBUhr TchFO1Xr2V0+
/O85FU1tr5QRucPwBV111QRitYVENNVPMLgkARF95jviwQwPHKIHPlAxQw0E bQ1VP425Ax+G
PFelpg36oSCwoMFkg6FtfAkYEEleZByRBSRg2zYIGtJGhY8hLJ0Ez1BiIakl PyFNVqA6OnPj
tNueNs3vEdrh7Xr0N3sffboluyyEljiZwbLLAlF04ymJZYS4rFdXOjjlhJew OwvvwLcTxoqc
YlorZEBzqatuROgZ7HBgLxuLSmShJwV0F9gzCG2krzZNLNqlLU671yXoXNDK woxEJRN33r39
ROjspVHbpbZrElsMVjWiPjJbxd6dszN6+nFG+PEehmudBSsC3D6WFk7FauJM J6mGTxevoTkD
M93TFy/S6af5IeZiYTfW6amO70Y4vNAPiCN5Y89rHeUUsBjiOudoaqqyy4Y5 +ROxyL1eb8K/
pJw4AC//IfljmsDFskZ4zprZldNQ841kwwiCGGmrX5A7ff+Fc0fS1N3OeuvO fejy4YE4slfQ
862yTrAlnwKy1dIOjtOsuG8lW5HOx7/xznV0XZDc+M0LxzvnMPt7njFeci3e AH/FFnw0MaIp
93c/73f7PWSY/lnmg90XYWcs9o2rqfcpv9gSF8hij+09M87pQXv2PqRqBo/9 cH3/5BIsdKCQ
aQATIAAAdGEBAAI5zIED6XzZOh0zRAAgAAAAVU1MX1N0YW5kYXJkX1Byb2Zp bGUuTWFnaWNE
cmF3X1Byb2ZpbGUuRFNMX0N1c3RvbWl6YXRpb24ucHJvZmlsZS51bWwA8AnG QBAhkMyNFVWA
Fh2/f2q9+DlZuq5+HKrWRtNPpzk3rdTWZNTc3zJMmQkwyZWqp0QGEMh04dEm TX3rlRMIddp9
AMG2RNtQhMlVKgDE0ru1fSrXQ0j4hf+Eq/EQYwGmeI8/hig93/X5rVZnYzat 1LFf/PsR9qHs
mM16FijUr08O5+b+f2W9n+v3////t3Gap7vrxcMwvrnlwvaiSgmCvb9wdfD+ q5cs+7c3LdDq
ZrT/bYrU/DtU8Oss0NwO73H8utk1dvge3tSblQkEESL4zW5h/bKJbuT8prL3 a/Cb8ffdxFkY
qf3PuNgC7MTtJW9zVkO4x1sfFFadwce/RUr2PxzTaXT0Uv77dxB6c+KfTqUP han9vJasUqlV
kmw15NW9++twE3M1+YxnSF/ENWpZtstjJkUpFGgW5vlkz3Z3cDFdiH142i9q Hg7nPxfG+rdT
3OA78bFCXEJmf4Yq8avVz1tX6pjUEwAnYmhV5Rn2qLDsu9ufv8/Rsu+oDC2A tKfAmz2Ab9Mm
boSH3O9q2cJUo5s2EUWE2OllBBJBEPgmkkigmomrmnYEJRYPuRUA3OvPrBUc BEZmkRLFGJss
VaxRZq8rNJm0B/ASZhCD1Q7pgng2CgAszvV8tdxvp29ALtlPgFqyX27F21QZ Na53aDChaGR2
4z4TlA3O6yExNmx+7f5J9Drn02fZqU3WJsZyCahA8u/Py8MpM/LMXJlLpVPz CT9nEMpK/fVy
MW6mNDNqEEnfr5vtURhEvaVCcFqxds8Yde2/o7XVOfTgJNMtPGOW4Q4hFQDf Rqi8O8sRYQwk
Nf2bmoD3xqXMgU+rqg3Oih1zD18qRROmct2qzbNZwijDeIp8szhr47VMdc5i PZhd0PsRNZ+i
qpQSvs44ZFGbZOwiOzuAl75dtdmjv5vaxUEM87pEeiiucDLVBL884jI9FFdA 5IGo2ecEyPRR
T5vdW6bGgIVL3fu7j9F83R3b+zUR4+vARs2Ru+s4nwN/e5OkF1D5HUayiQlk VQ9cNTTEiuxB
MWm3LV2hcydT6v8sz76ZhCJZ1++qRaKrqL31v+cfOafl6yqYlwmiEwh29IK3 gmarY7cP/jNj
XDpAyQu2bOf5fsjplGKEnME3RVVPUBCjQm3+MYHO01CC7kIQY8knET1TW6/G uTb2UO1U6btx
ry6IpGbHWyE0s13ETeZn8+MamaEb+GRCeX6fEI9pvUbS3wGcqszZhIIpdb1s 93aBEP1oisSi
90RSobIaUfqOPFVxcL1AHXr1UZ0Ev0alv1yTCJR0+0UqV6sY2eIGuZZm8Yku LMT3atz6NVde
c6L1ACzPlySmUOxVza19mGz/aKVV0H7pnte4Q3qACLBZn2aTGLVj5vavdzWN r3CXzclYien1
8au1qnxSsC3m+xxKMW1S+R21mbNJLFKr+nMGyw6JN/0fprPqfFKkbbsTL3/z eq1cCDEUqlO7
adgmHkRpXot6Tnii0c6dPITcZotwbja5HzzZVL0611mo44bZku8xSV6Zxma3 8Kk+nkgrW/VS
SEUTSsYGvesiY378UrCylzerHq5Qu3OLHe7tSkc7HYe7ZhrlCLdYeqx26I/t O6ma/HYubwPU
WG0fX1oyJ5UCX/xdqUOspNu4EBwil/r1gFQilZt3LNRAF3901evlZZKoEv2b AXQV01WSr/7X
r6IOUYpWRWBURU+NSuyWO+a0139fX20YuFs5CmaePfd6yuJyjWJeodWPXXNy BVapQVgmY16n
4usyw0D0YSuKVHut85vVPyDTan96hnQtMjwvLiO8Megw55v3dkl+mGC471G1 +4sk4YYlfDXR
QYXXWTD0Eoser9zZra6FTZ1iRzVA+iVyzItcZZ4zdpsgUXhWmGfjXcGS+SYJ 5pEc+VKRYKIp
EOEwgTYTXXGkNVBbCGBDwpDGVJJbycmcUhEGIyc5zpsSMRODVTTENZUaaTAE qURVYRPSjinw
E5+S7Tinc+uz2hiUf1jgVWnW1hFdrosO2VfZhm3jx+JthWdrJHssz88rkeqK U92XU8uBttEa
rkuqd5XjK5dBYSQkUF2BrpDBdiC589Ljer187jEvdQvEMr9WwtOJJRUikVMd 6t2tX9fElJ/T
tZFKd63x2KPnzd7zOO2VIpUDSqVQsbsEiu3kT7PLLCobN2zVll9+DYdhFVQE JdLDUmFlFlRK
MKpiPTLn7zifrHk0D71ietxYdHTRhE4dIiwbGBWU71VD1kjrr9fWo0l7rJf7 HDKv0FuqeUau
sl/UhkXDXpWDZGjrIcnnjGCLC1JdAS4I0iQVVGkmmsquowEMZw8OoquYwxrE zubBXelu7j8T
XupEDDOq+/51ibj2cmdBL92iAdVKurMkISbrZ7ghtVFjGR7LzRnnJnc1wlWW 83t8NazYtXNA
DRjOT4TLUb75mi5nCl8bGFX/uLmgF5APJhc6q08tdQVnscW/zb3F8vhv/GaX 5e3PSredrEHw
eaQUeKHtm1lRqZY+xtJe35EHPx4f45d7l4d9sOOTSo/21anTan2u6WCJ95/Z P5NkiR/yBSEj
El3NnOoAYZ18ZdxWdnGYyzmqaZ2S1iTXLwEw4lJzlnE9zxM7WwyTwdawGHQ3 bka8Qmq4eoOL
YK/fAyO5IYnO6V7tryYViYsUTIRIYAqNaosmm4/JrISliQTyZLYnSUw1e+lN bns0zKfN4CCz
ZQcFBFi9waKxbl+D4he4Ct9IQc/fGhRTqcrNJFAE698CIsIiglxqBFScqaXg IJjCwijhtAtj
Mp/MdTleYj0ZFjYZzl9ZMmqWwKqF+sQamg1xoUk6nM8xIoAl7EWXorDESlxj RKumHp6FPmZQ
ec6nF85HjISr3wFCU5YtFFSIQ+8LFNg0khqL5O1cAuDPQSi2nocqaFGOpxHO R43E+SlLzvOL
yt8zec9GTedAtG+h7MK87mTzb9CCfQmCaCkaPOXvzX5yn3ri6WBQVXRSYUQG X0xHfXTYogD2
DnuTznqYjYSGZ9E46qL5xPehiBtYDpZGvHPCxY0dkCMeTtgcRoxb2VLeRPNx UxOW79KmZG4y
allOqk6dGGa5oNl5kPouacOdKoYbg/sggScG5RN1uINtxnLUoN1WDz16pbam zR457cO6fqiY
fC7SwLO0F0kytyAwlwHUerXzkm/7M4bsBd/rH0JomsL6mqFEYFh+UzW1i7mg tD/rNxanWF+d
ipZqiWmgoANg8/tUtKS51iEHJDbSFc2LloK5qqus6qSXKvAi0vhAYsljLEaT hSdV50HVhF0G
p/JuNl/99bNdm0VCUX4eg7okdBHowLF7MMKy0L4jQvw/Y7sMPtOaGziu1ko2 7G2GNdsqyZYQ
KgvrNNWZOrC+x1df/sSaFHKTKxNK4aZXcscC9Lj3XMquq
Re: UML2 editor exception on stereotype application [message #478610 is a reply to message #478609] Thu, 16 July 2009 09:39 Go to previous messageGo to next message
Uhm in fact my uml profile definition is not valid, but uml2 editor
should notice it instead of throw an exception rigth?
Re: UML2 editor exception on stereotype application [message #478611 is a reply to message #478610] Thu, 16 July 2009 09:42 Go to previous messageGo to next message
Maybe even to do a validation before application and stop application by
notifying user of no valid profile.
Re: UML2 editor exception on stereotype application [message #478612 is a reply to message #478611] Thu, 16 July 2009 13:09 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn HusseyFriend
Esteban,
How exactly is your profile invalid, and what kind of check are you
suggesting that UML2 use to determine whether a definition is valid?
Note that UML2 is intended as a framework upon which tools can be built
rather than a complete application; I would expect the suggested level
of error handling to be something that a complete UML2-based application
(but not the samples provided by UML2) would do...
Kenn
Re: UML2 editor exception on stereotype application [message #478615 is a reply to message #478612] Fri, 17 July 2009 15:06 Go to previous messageGo to next message
Hi Kenn,
My invalid profile definition had a stereotype inheritance :
"service" stereotype with a "base_Class" private property,
two child stereotypes also with private property "base_Class".
With property visibility set to protected on "service" stereotype and
without "base_Class" properties on childs stereotypes, my profile is
valid. Like MagicDraw default properties are privates.
P.S. : I don't consider a NPE handling be a feature to complete
UML2-based application.
Thanks.
Re: UML2 editor exception on stereotype application [message #478618 is a reply to message #478615] Tue, 21 July 2009 15:09 Go to previous message
james bruck is currently offline james bruckFriend
Hi Esteban,
Please raise a defect on UML2 and it will be looked into.
- James.
"Esteban DUGUEPEROUX" <dugueperoux.esteban@free.fr> wrote in message
news:h3q41h$fpn$1@build.eclipse.org...
> Hi Kenn,
> Thanks.
Re: UML2 editor exception on stereotype application [message #627789 is a reply to message #478609] Thu, 16 July 2009 09:39 Go to previous message
Re: UML2 editor exception on stereotype application [message #627790 is a reply to message #478610] Thu, 16 July 2009 09:42 Go to previous message
Re: UML2 editor exception on stereotype application [message #627791 is a reply to message #478611] Thu, 16 July 2009 13:09 Go to previous message
Esteban,
Kenn
Re: UML2 editor exception on stereotype application [message #627794 is a reply to message #478612] Fri, 17 July 2009 15:06 Go to previous message
Hi Kenn,
Thanks.
Re: UML2 editor exception on stereotype application [message #627797 is a reply to message #478615] Tue, 21 July 2009 15:09 Go to previous message
Hi Esteban,
- James.
> Hi Kenn,
> Thanks.
Previous Topic:Operations Package Export in GenModel
Next Topic:static profile definition?
Current Time: Tue Apr 16 13:04:38 GMT 2024
Powered by FUDForum. Page generated in 0.26430 seconds
