Home » Modeling » UML2 » Flatten the packaging structure like in the UML2 metamodel
Re: Flatten the packaging structure like in the UML2 metamodel [message #478506 is a reply to message #478497] |
Tue, 09 June 2009 15:43 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Timothy,
There is a utility in UML2, the package merger, which we use to accomplish
this. In order to use it, though, you would need to use UML as the source of
your model instead of using Ecore directly, as there is no support for this
in EMF/Ecore.
If you take a look the source model for UML2, you'll see how the model needs
to be structured. Basically, you create an empty UML package that merges the
packages who content you want it to contain. Then, before you load/reload
your EMF model, you run the package merge utility (either progammatically or
via the sample UML editor).
Kenn
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:h0am75$hcp$1@build.eclipse.org...
> Hey all,
> i've to maintain an Ecore meta-model, with was initially created with a
> lot of packages regarding to structural aspects. But it is very cumbersome
> to have all these different Factorys, Packages and Litetals... my question
> is: Is there a built-in possibility to flatten the Ecore structure like it
> is done by the UML2 meta-model?
> I'm posting explicitly here, because you guys have already done it.
> Thanks a lot
> Timothy
Re: Flatten the packaging structure like in the UML2 metamodel [message #478513 is a reply to message #478506] |
Wed, 10 June 2009 07:17 |
Timothy Marc Messages: 547 Registered: July 2009 |
Kenn,
that sounds promising and in fact, my source model is an UML model, so i
will try the package merger... thanks so far.
Timothy
Kenn Hussey schrieb:
> Timothy,
> in EMF/Ecore.
> Kenn
>> Hey all,
>> Thanks a lot
>> Timothy
Re: Flatten the packaging structure like in the UML2 metamodel [message #627683 is a reply to message #478497] |
Timothy,
in EMF/Ecore.
Kenn
> Hey all,
> Thanks a lot
> Timothy
Re: Flatten the packaging structure like in the UML2 metamodel [message #627690 is a reply to message #478506] |
Kenn,
Timothy
> Timothy,
> in EMF/Ecore.
> Kenn
>> Hey all,
>> Thanks a lot
>> Timothy
Current Time: Wed Apr 24 23:34:40 GMT 2024
Powered by FUDForum. Page generated in 0.03122 seconds
