Home » Modeling » UML2 » Problem with Property and eDerivedStructuralFeatureID()
Re: Problem with Property and eDerivedStructuralFeatureID() [message #478277 is a reply to message #478276] |
Thu, 02 April 2009 13:02 |
Lazar Codrut-Lucian Messages: 91 Registered: July 2009 |
Member |
From my debugging I tracked down 2 references with problems.
Property.class and Parameter.operation.
Also, I noticed that for these references with problems,
in BasicEObjectImpl.eOpenUnset(EStructuralFeature),
the condition "(!FeatureMapUtil.isFeatureMap(openFeature))" is true.
Next, ExtendedMetaData.INSTANCE.getGroup(openFeature) returns null.
And on this null I get the NPE later on.
Calling unset on any other reference causes no problems, only the two
references above. Why does this happen?
Lucian
Lazar Codrut-Lucian wrote:
> I think I found the problem to this.
> XText Linker tries to unset an unsetable==false reference (the "class"
> reference of the Property, for instance).
> Lucian
>> Hello,
>> I am using UML as my metamodel for an XText grammar.
>> If my grammar is using Model, Package, Class and Operation, all is fine.
>> As soon as I use Property or Parameter, I get an error.
>> Part of the stack trace is below.
>> In that case I used Property.
>> There must be some property or some operation that is not supported and
>> that XText uses, but I don't know what to look for.
>> Thank you,
>> Lucian
>> java.lang.NullPointerException
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDerivedStructur alFeatureID(BasicEObjectImpl.java:1495)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1010)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1005)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1000)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenUnset(Basic EObjectImpl.java:1225)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicUnset(Ba sicEObjectImpl.java:1204)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicUnset(Ba sicEObjectImpl.java:1197)
>> at
>> org.eclipse.uml2.uml.internal.impl.PropertyImpl.eUnset(Prope rtyImpl.java:2271)
>> at
>> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eUnset(BasicEObj ectImpl.java:1156)
>> at org.eclipse.xtext.crossref.impl.Linker.clearReference(Linker .java:73)
>> at org.eclipse.xtext.crossref.impl.Linker.clearReferences(Linke r.java:68)
>> at
>> org.eclipse.xtext.crossref.impl.Linker.clearAllReferences(Li nker.java:188)
>> at org.eclipse.xtext.crossref.impl.Linker.linkModel(Linker.java :173)
>> at
>> org.eclipse.xtext.resource.XtextResource.doLinking(XtextReso urce.java:139)
>> at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResourc e.java:159)
>> at
>> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
Re: Problem with Property and eDerivedStructuralFeatureID() [message #478278 is a reply to message #478277] |
Thu, 02 April 2009 13:12 |
Ed Merks Messages: 33137 Registered: July 2009 |
Lucian,
Without understanding all the details, my sense is that you've passed in
a feature that's not properly a feature of the class to which you're
applying it. If that's the case, if you run with assertions enabled
(the -ea JVM flag) and are using the Galileo stream, I think you'd see
assertion failures...
> Lucian
>> Lucian
>>> Hello,
>>> Thank you,
>>> Lucian
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Ed Merks
Re: Problem with Property and eDerivedStructuralFeatureID() [message #478279 is a reply to message #478278] |
Thu, 02 April 2009 17:51 |
Member |
Here is a simple example that you could execute:
public class Test {
UMLFactory factory = UMLPackage.eINSTANCE.getUMLFactory();
Property prop = factory.createProperty();
EReference classFeature = UMLPackage.Literals.PROPERTY__CLASS;
prop.eUnset(classFeature);
It throws this exception:
Exception in thread "main" java.lang.NullPointerException
at
at
at
at
at
at
at
at
at
at org.xtext.example.Test.main(Test.java:15)
Lucian
Ed Merks wrote:
> Lucian,
>> Thanks,
>> Lucian
>>> Lucian
>>>> Hello,
>>>> fine.
>>>> Thank you,
>>>> Lucian
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Problem with Property and eDerivedStructuralFeatureID() [message #478280 is a reply to message #478279] |
Thu, 02 April 2009 18:00 |
Lucian,
There is some odd stuff associated with this particular feature. I'm
not sure why it's like this. For example, I see
public void eDynamicSet(int featureID, Object newValue) {
if (featureID == UMLPackage.PROPERTY__CLASS) {
setClass_((org.eclipse.uml2.uml.Class) newValue);
return;
super.eDynamicSet(featureID, newValue);
But there's no corresponding eDynamicUnset for that feature, so likely
that's the problem. Some UML expert needs to comment...
> public class Test {
> public static void main(String[] args) {
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Lucian
> Ed Merks wrote:
>> Lucian,
>>> Thanks,
>>> Lucian
>>>> Lucian
>>>>> Hello,
>>>>> fine.
>>>>> Thank you,
>>>>> Lucian
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Ed Merks
Re: Problem with Property and eDerivedStructuralFeatureID() [message #478283 is a reply to message #478280] |
Fri, 03 April 2009 19:09 |
james bruck Messages: 1724 Registered: July 2009 |
Ed, Lucian,
Although the 'class' feature of Property is unsettable, you should probably
not be getting a null pointer exception.
I'm getting a slightly different stack trace using the latest version of
UML2/EMF.
Ed, we seem to be getting into some trouble in
BasicEObjectImpl.eOpenUnset(). The call to getGroup() returns null and it's
all downhill from there.
Lucian, please raise a defect on UML2 and I'll have a closer look.
- James.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gr2ufn$9kq$1@build.eclipse.org...
> Lucian,
> There is some odd stuff associated with this particular feature. I'm not
> @Override
> return;
>> public class Test {
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Lucian
>> Ed Merks wrote:
>>> Lucian,
>>>> Thanks,
>>>> Lucian
>>>>> Lucian
>>>>>> Hello,
>>>>>> fine.
>>>>>> and
>>>>>> Thank you,
>>>>>> Lucian
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: Problem with Property and eDerivedStructuralFeatureID() [message #478285 is a reply to message #478283] |
Fri, 03 April 2009 19:33 |
--------------030007060001060501030602
James,
The problem seems to be that the generated eSet and eUnset both don't
handle the PROPERTY__CLASS case, although eSet and eIsSet do, though in
a way I don't recognize from the basic templates. Then eSet has a
special eDynamicSet override be eUnset doesn't. Therein I would think
lies the problem. Why the code is generated like this isn't familiar to
me...
James Bruck wrote:
> Ed, Lucian,
> UML2/EMF.
> Cheers,
> - James.
>> Lucian,
>> @Override
>> return;
>>> public class Test {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Lucian
>>> Ed Merks wrote:
>>>> Lucian,
>>>>> Thanks,
>>>>> Lucian
>>>>>> Lucian
>>>>>>> Hello,
>>>>>>> fine.
>>>>>>> and
>>>>>>> Thank you,
>>>>>>> Lucian
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
James,<br>
<br>
to me...<br>
<br>
<br>
James Bruck wrote:
<blockquote cite="mid:gr5mna$e0u$1@build.eclipse.org" type="cite">
<pre wrap="">Ed, Lucian,
UML2/EMF.
- James.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gr2ufn$9kq$1@build.eclipse.org">news:gr2ufn$9kq$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Lucian,
return;
</pre>
<pre wrap="">Here is a simple example that you could execute:
public class Test {
at
at
at
at
at
at
at
at
at
Lucian
Ed Merks wrote:
</pre>
</pre>
<pre wrap="">From my debugging I tracked down 2 references with problems.
Lucian
</pre>
<pre wrap="">I think I found the problem to this.
Lucian
</pre>
<pre wrap="">Hello,
fine.
and
Thank you,
Lucian
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------030007060001060501030602--
Ed Merks
Re: Problem with Property and eDerivedStructuralFeatureID() [message #627467 is a reply to message #478276] |
Member |
Lucian
> Lucian
>> Hello,
>> Thank you,
>> Lucian
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Problem with Property and eDerivedStructuralFeatureID() [message #627468 is a reply to message #478277] |
Lucian,
> Lucian
>> Lucian
>>> Hello,
>>> Thank you,
>>> Lucian
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Ed Merks
Re: Problem with Property and eDerivedStructuralFeatureID() [message #627469 is a reply to message #478278] |
Member |
public class Test {
at
at
at
at
at
at
at
at
at
Lucian
Ed Merks wrote:
> Lucian,
>> Thanks,
>> Lucian
>>> Lucian
>>>> Hello,
>>>> fine.
>>>> Thank you,
>>>> Lucian
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Problem with Property and eDerivedStructuralFeatureID() [message #627470 is a reply to message #478279] |
Lucian,
return;
> public class Test {
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Lucian
> Ed Merks wrote:
>> Lucian,
>>> Thanks,
>>> Lucian
>>>> Lucian
>>>>> Hello,
>>>>> fine.
>>>>> Thank you,
>>>>> Lucian
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Ed Merks
Re: Problem with Property and eDerivedStructuralFeatureID() [message #627473 is a reply to message #478280] |
Ed, Lucian,
UML2/EMF.
- James.
> Lucian,
> @Override
> return;
>> public class Test {
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Lucian
>> Ed Merks wrote:
>>> Lucian,
>>>> Thanks,
>>>> Lucian
>>>>> Lucian
>>>>>> Hello,
>>>>>> fine.
>>>>>> and
>>>>>> Thank you,
>>>>>> Lucian
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: Problem with Property and eDerivedStructuralFeatureID() [message #627475 is a reply to message #478283] |
James,
me...
James Bruck wrote:
> Ed, Lucian,
> UML2/EMF.
> Cheers,
> - James.
>> Lucian,
>> @Override
>> return;
>>> public class Test {
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Lucian
>>> Ed Merks wrote:
>>>> Lucian,
>>>>> Thanks,
>>>>> Lucian
>>>>>> Lucian
>>>>>>> Hello,
>>>>>>> fine.
>>>>>>> and
>>>>>>> Thank you,
>>>>>>> Lucian
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
<html>
<head>
</head>
James,<br>
<br>
to me...<br>
<br>
<br>
UML2/EMF.
- James.
</pre>
return;
</pre>
public class Test {
at
at
at
at
at
at
at
at
at
Lucian
Ed Merks wrote:
</pre>
</pre>
Lucian
</pre>
Lucian
</pre>
<pre wrap="">Hello,
fine.
and
Thank you,
Lucian
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Ed Merks
Current Time: Sat Apr 20 01:50:06 GMT 2024
Powered by FUDForum. Page generated in 0.05445 seconds
