Home » Modeling » UML2 » UML middleweight extension:making unnessecary elements invisible
Re: UML middleweight extension:making unnessecary elements invisible [message #478039 is a reply to message #478038] |
Mon, 01 December 2008 21:48   |
james bruck Messages: 1724 Registered: July 2009 |
Hi Deepak,
Can you explain a bit further what you mean by "if I run my extended model,
I see unessecary elements...".
Do you mean that in an editor, if you try to change the type of an element,
for example, that you will have the option of choosing uml::Class etc.
If that is the case, you can try to customize the ItemProviders for your
custom solution.
- James.
"Deepak" <dee_n@gmx.de> wrote in message
news:gh13ig$qkj$1@build.eclipse.org...
> Hello,
> I am modeling an UML-specific DSL using the middleweight concept.
> Mainly, I want to create a specific version of the Activity diagram ( with
> OCL, less variety of elements...).
> If I run my extended UML-Metamodel, I will also see unnessecary/unrelated
> elements like Statemachine, Class and so on.
> Is it possible to narrow down the selectable elements to those which are
> based on the extended UML-Metamodel ?
> With regards,
> Deepak
Re: UML middleweight extension:making unnessecary elements invisible [message #478040 is a reply to message #478039] |
Tue, 02 December 2008 15:08  |
Deepak Messages: 53 Registered: July 2009 |
Member |
--------------010403090506090009090800
Hi James,
I attached the screenshot to clarify what I mean.
The children of my extended Activity node should be CallOperationAction,
Control Flow, Object Flow and so on. But certainly not StateMachine,
Substitution,Generalization etc. These elements should not be selectable
when I want to add new elements to the Activity node.
Anyway, I will have a look on the ItemProviders.
Deepak
James Bruck schrieb:
> Hi Deepak,
> custom solution.
> - James.
>> Hello,
>> With regards,
>> Deepak
Content-Type: image/jpeg;
name="extendedActivity.jpg"
Content-Disposition: inline;
filename="extendedActivity.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQH/wAAR
CAHeAf8DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+nHUtVh8HeK/C40P4i2fj nwj4oS20S/0f
xx8RP2f7b4heH/FDa1cadHJ4fsfAd7oFh4msmtL7QbzVdBs4td1tbHUra+02 6i1S0k8La171
a9W+h/mtcB8Lte8M+MLX44aZ410vXZE8Qav4T8FeIdH8Ra7qTatJ4TX4IfDj VbzwNrN5p3jD
xKbvw7B4l8a+PtQGgR+K/EGiJd+LvEssF3ff27qNzexGHw34Y+KXhPw14Luf Ei6T4h8AfEbX
detPEPjbxl438/UfC/iL4VWGgXFnP421/wAQ3OkfZbbxd4giuItHmsINU+1w PqsV5JpmlNZf
iHD/AIo5VheOM24PhXxeMoYjivMMny2jjs3qZjmWWTwuNxGWzpxni8JDE4rB V8ThVmEKeMx0
8TluGxNXCwni1hKSr/oWO4TxlXI8Hms6KoV6eSYbMMVWoYGnh8DjIVsHRzCM 5exxDhh8RTo1
pYRujhXSxdejTrSWH+sTVHzC7/bR/Z5sPjRr/wABb7xH44svHHhTxx4Q+GPi nXbv4IfHS2+C
/hr4k/EHwp4I8ZeAvh7r/wC0hN8Nk/Z40bxx430j4mfDez8IeE9R+KNtr3iX xX8QfBHgPRtP
vfHHivQfDt/9UV+O/jL9kP8AaGvPjh+1L8a01vxx4q+Fd/8AtwfAL9pDSf2O odS+Bej+C/2m
PCnwJ/ZX/ZBsvD3jLwt8Rrjw1a/Fv4afHDwJ+0n8FdP8W+AvDvjX40+Bvgv8 T9W/Z/0H4V/F
DQvAvwr+NPif44aZ852H7Afxqs/2jP2gviXr+l/tiDx34q1z9t3XtW+P3wK+ In/BP/4VTeOv
g18aND+N+nfAL4P/AAc+M0vgG1/bv+IPxU+FHhbx98D/AA/8Pfhj+1l8Svhd +yr8Hvix8FdI
8d+FfiXdeBP2d/2ePC3jT99u725Xva/lffr+npazf56f0KUV/PX4A/Yv8beF fDXw1n+LP/BO
P4V/GH9nDw3rn7RtjYfsYeA/gx+wp8P/AIh6t4l8aWH7KOmfBL9qj9p34M3f xx0j9gTxH+0Z
4T0T4M/tI+A/E3xd+BfxMs78+BfjR8Oo/h58G/hno3jr4x/DH4Q7nhH9mT9s /wCFnw20j9n7
x18LfHH7RHjj4mftUf8ABJ/9oX4j/tReE/ih8KdY+G2jf8MoaD/wTY8E/tD6 n8TtV+NnxU+G
37Q/ifxxqGr/ALF/xW+Ien3vhX4N+P8A/hMNB8b/AA9ubjWk8cav408K+Cjm f8r28+1+3fT8
wP34or8B/hz+wNc/B79m3/gnr4W+Jv7En/DWHhP4bfsr3vhn9qP9lm71b4Bf FvXtQ/bG8TeA
v2UNF8K/HbX4/wBqb4u+Ffgp45/4UT4M+C3xj/Z88IeLdP8AilrPif4T/Dbx 74I+EHwD8N/8
KDOsWfgnuP2e/wBiT4t+Bf2+tf8Ajt400P44XXiiT44ftN+P/E/x0/t39iPQ Pgv8Q/gX8T9S
+LB+B3wX/wCE08I/CvVP+Cj/AMb/APhV/g7xr8E/Df8Awor9ofxb4I/Z5+Hn iv4L/wDCTfDj
xrrfhf4A/s2+CvHRzPT3Xra++l7eXT9OgH6aeIf2q/g94d+LFv8ABQt8VPFP js654Y8Ma03w
y/Z6/aD+L3gXwJ4l8Xw6Tf6J4e+Kvxa+Ffwv8Y/Cj4Qa4dA8Q+GvGer6T8Uv GvhC/wDDXw88
VeE/iP4lt9J8CeKfD/iLUvVPiF8SPBfwr0Gw8T+PdZ/sHQ9U8cfDH4b2N9/Z 2q6p5/jT4yfE
nwn8Ifhvo32bRrHUbyL/AISP4ieOPC3h7+0ZrePStI/tT+1tevtL0Oy1HU7T 4D+Mfw3+Ieq/
tRaR4g+A3wB/aM+GPjtvip8Ctc8bftPWnx28C+GP2P8A4h/Dzw/rHw9k+Orf Eb9nDw9+07f6
z8Uvip4r/Zw0fxZ+zP4J+IvxG/Yy8QeOtD8Y6d8J20jx/wCCfAnwx+HvxY8B flf8Mf8Aglt8
atO+GfiPw/8AED4U/FT4ieMLLQ/2br79qaw+LGsf8E/7D4T/ALefjr4Kftb/ ALMP7QXxS1Pw
TofwV+GXh/4mftQa58UfDfwQ+OGifDn4vf8ABUn4qfDv4h6FN8brTRfH1tJc ftBftIeP/hSn
KS+zffVXt5X6v5admB/UJRXD/DHTtK0j4bfD3SdB+G//AApvQ9L8D+E9O0b4 Q/YfBel/8Kr0
qy0GwttO+G/9mfDfWfEfw707/hB7OKHwx9h8BeIde8F2n9l/Z/C2s6pocdjf T9xVgFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFc34k/1ngj/ALLF8Cv/ AFdHgKukrm/E
n+s8Ef8AZYvgV/6ujwFSls/R/kB6r+2Z4o8S6b4f+Cngjwt4i13wtcfFj9o/ 4N+AvEuqaNq1
/wCDGn+Hd/4rtLn4haHH8TbW40ceBNd8QeGbe80vwq+l+K/DXjvxPrs9r4X+ G8+peL9S0/Sr
r5H1/wCBfxS1P9oPRPBnw/8AiZpPijx58Mo5vjb8UvGPxi+I2heLrTx3q2p+ JLrWPhv4J8Gf
s6t4g+ITfs9W2mwpb+F3+P3h/wCHXhbxDpekG81HQoPiJ4gvtVa//Q34/wDw Y/4Xd4S8N6Na
+JP+ET8Q+BviZ8Ovi74N1q40f/hItGh8Y/DHxPZeKfD0Hibw7Hqvh++13wzd XtmtvrOl6V4m
8L6pc2shFj4g02VRKfPYPgh8dLD4iar8Q9O+O/w9ju9S8X/FXVpLS6/Zq8MP e3vgXxD4F0jw
58HPhhr/AIs0vxxo3i/WNC+FHi/SY/HviTWYdb0vxF8T5RZ+GE1DwJoWm2sY 9DEUcjzrhHG8
NZpWwkMNmOCzWjjcPXp5jTrVMVOWHq5fi6GNy3DTq061FU+bL+atGOEzXDYP MKrjLDYOrhPI
X1/CZzRzPD0q9SeHxGBnh6lKeFlTjRiqkcVRqUMXXhBwm5f7S4wcq2Dq18LT uq2IhX5r/gnn
ezan+yp8PtT1ExnxFf3HiGTxYNKs9NsPBQ8S2ut3mnagPhtB4UsdN+Gdz4DK WVu+j6/8JLWT
4feMbptR8aWeq+Ite8Q+IfEmr/HXw/8A2iv2hz+zx+yf/wAFJde+M3iDxJ4J /bB8QfsLW+rf
sU3vhD4Saf8ABr4R/D3/AIKB/Fv4I/CH4fQ/C/4naL8OdO/aDuvjB8CZPjf4 C8U+PviF8Tfi
Z8RPhn8d5/C/xk0jwv8AAH9nm2+Lnwsuf2ZP0/8AgD8HdG/Z++DPw5+C/h/V dT13SPh14as/
DtprGsLax6jqRgaSe4vLiKyhgtoPPup53ht4kf7PbmKB57qSN7mXz/wz+xt+ zx4Q+Mtz8dtB
8HeILfxs/iDxZ4z0nQ734p/FvWfg14J+IXj+DWbf4g/FT4X/ALOmteOtQ/Z8 +E3xg+IMfivx
63j74vfDL4YeEviZ42n+KnxkuvFHivVrn4y/FObxf4U8Dk2VzqZdw9hlhMhw VSphcnwydeSo
5bRnKGDg5YmdXFTaoKHNPFVa2JnJuWIrVaznUl6dKtjcRSpV8yqe1zCrSp1M bUtTXPipQi67
tSjCkl7RysqUIUktKcIQ5Yr84Phl/wAFrPAnxL8OfB7UrH4RfYvEHxc+H/8A wTY8RWnhn/hP
tYuf7J8d/ts/FP8AYt8J/Hr4df2zN8KrCyv/APhjz4Zf8FHf2Fvi3/wl0sem 6P8AtB/8L/8A
+EC8GQeFPEHwq+MFz4G5/Sv+CyXxC8Mfs8fB347fHj9krw/4Uuf2rf2YPhv+ 0z+yh4K+BPxw
+Jn7SWo+JdO+J3xb/Y9+BmjeDvjhY6b+yT8PfiJ4A8QWvxE/by/Z0aXTv2ff hh+1z4q1vwra
fGW68HeD/E3jbwZ8OPh98Z/1f0b9lz4E+H/+Fcf2R4G+yf8ACpP2gPjV+1H8 Pv8AipvGNx/w
j/x2/aI/4X7/AMLi8c/6V4hm/tX/AITD/hqD46f8Uzrf9peDvD//AAnH/FLe HtE/4Rnwf/wj
/n93+wV+yde+BPg/8Nrj4U/8Ul+z/wDs/wA37MXwUtoPHXxJtNY+GXwi/tj4 C+JtKtPCPiy1
8Yw+LdK+IHg/xb+y/wDAHxt8OvjZDrn/AAuz4ZeO/hf4d8c/D34heGfFv9oa zeyaHyB8L/8A
gpB+0J8bf+ED+Gfw+/Ys/wCEX/aa8V/8L78R3XhH9pTxr+0x+yv8CdT+Fn7P X/DMsHjDx/8A
DD4i/GL9hHRf2mvGv9oa1+2B8HfB2g2fjD9iP4VeHNT8Y+Df2jLC18azaL8M fh94i+Nvy/J+
0v8AGXw5/wAEzf8AghT4lvP2if2n/AWr/tNeH/2XvDP7Qfxj+BHwbg/a6/af 8aadqn/BL39o
P486jc6X4I8V/s9ftc+JPGfiDxX8ZPhj4F1/x/4ssfhB4s8VQeH4vFOu6prO i6Q3iHX7X9P7
n/gnX+yrP4V0bw1b6B8YNF1fRvEHibxMfjD4W/ar/au8H/tQeI9R8Zad4T0X xVbeP/2uvCvx
s0f9qP4meH9f0P4dfCjQNU8J/ET4v+KPCt14f+CvwI0KTRjpHwL+EVn4L9g8 M/sufAnwd4O/
Zc8AeHPA39neEv2Lv+Ee/wCGaNJ/4Sbxjef8K1/4RX4E+Of2aNB/0+/8Q3Wp +MfsHwS+JXjX
wV/xX974q+1f21/wkd79o8W6dpOvWAB8f/sW/ti+O/iZa/si+APHtn/wnn/D S/7P/wC2h+0n
8Mvj5PcaP4b1j4hfs4/AH9o79n/4ffsp/E3xd8PPD/hjR9FsfiB+1N+zL+05 8JPjv8RbXTdL
+Edr8PfHY8ReFo/gb8PP7XPw9+Gf5g/A/wD4LK/Em7j8a+MPDPwH+IHxb+IH 7WvxA+HP7Qnw
w+D2oat+1j8U/An7P/wTt/8AglR/wR7+LHxE8B6Zrf7Jn7G37ZPxasfsPxa/ bJ0bUdCW2/Zm
8D/CLxNrHiL4peMfFnjvwB8QNb8KeDfih+33jX9hH9mfxx9tln8L/EDwPqd3 8QPH/wAS4fEf
wR+P/wC0J+zv4x0TxH8W/wDhHL34wab4S8a/AX4p/Dfxb4K+H/xl8W+EfDvx W+Mvwn8I61on
ws+Lfx201P2gPiL4N8TfG24u/H9x5/pH/BL/APYs8L+DtE8E+BPh18QPhbZe G/8AhFoNC8T/
AAd/aS/ad+DfxT0zR/CHwJ+Bf7NmmeEbX40/C34x+EfjAvw/1H4P/syfs96H 4w+HTeOW8CfE
DxH8G/h78SfHnh3xJ8TfDen+MIgDz/8AbO+L3xd8W/sWfs8/Gv4KfED9oD9j Txb8W/2gP+Cc
umappep/Df4J2/xs8JeBP2vf2nfgL8CPH/wt+KXgD47/AAw+O3hLwd8QPB3h L47arqGoafp+
lNrHhL4u+B9CtbrXdb8JWfinwt4t+QP2pv8AgqV+0d4J/ZY/as+Kmn/Bj4f/ AAg8P3H/AA9Z
/Z7/AGRvjP4N+N118YPinbftHfsB/Dr9uTxHpHjz4sfATx7+zR4H+GXgz4f6 /ZfsNfFLxXpr
aZ8XvjpdW3iO9+GngzXfAmt+H/FHi/xP4J/V/wCMn7G37PHx0+DXgH9nzxj4 O8QeGvg38LPE
Hwv8TfDrwL8Dfin8W/2ZtO8G6j8E57K++D9toF5+zh46+FOr2Hh/4YavpPh7 xF4E8JxaiPCv
hfxV4R8EeK9H0a08SeB/COqaKan+xf8Aswa94V8PeBfEfwg8P+KfBPhj4wft B/HfTvB3iy98
QeKvCt58TP2q9O/aG0f9oPVPE3h7xFrGp6R4z8P/ABN0j9q34/6XrPgDxfZ6 58PbPTviHc2O
ieFtLttA8KRaCAfAHx7/AOCo3xz/AGdfiF4c+DPin9iPxB8UfjJ4b+D/AIY+ Pf7QXgz9l65/
bC/ad07QPh78RPiZ8Z/A/wAM/Dn7P3i34R/8E+Ne0j4h/GDxTpHwD8e6jP4Y /atT9g74ZweK
r/wj4Y8OfGfxd4bX4lfEP4Yev+BP+ChPjvxHar4/8Yfs0/8ACuv2f4/2/wDx 5+wRc/FjUPjL
o/iPWJNY8MftHftCfsi+E/jJpnw08M+Cr/Wrr4f/ABK/aa8HfszfAjQtF1HV NG8d6B47+O/x
S8U+MfDegfs//s96N8c/jv7BrP8AwTr/AGVfEuneE9L8U6B8YPFtt4Y8P3Pg zWJfF37Vf7V3
irUfjP8AD248VeJvGMXwr/ap1jxD8bNS1f8AbF+D+lav438e2fh34Q/tW33x l+Gfhjwr8Q/i
L4F8OeFNL8E+P/GPh7W/YL79lz4E6j8Cfi7+zReeBvO+CXx3/wCGi/8Aha3g r/hJvGMf/CVf
8NZeMfiJ4/8A2gP+Kji8Qp4t0P8A4T7xb8V/H+rf8U5r2j/8Ir/b/wBg8Ff8 I5pml6LZacAf
mB8Z/wDgsra/Cn4E/DP9pLSvgP8A8LC+GXij4f8AxQ/aZ8caN4K1b9o74gfF Pwt+w7pvjHxR
c/s2/tNWXhn4J/sbfGLwL4E/4ax+Avg7X/jB4A8J/trfFL9iTwl4W8R6Z4k+ FPiv4tRXvwv+
OPiz4U+gfDv9pf4p/Df9hj4gfEu21b/hOfibr3/BT/8Aae/ZW8Ba/wDFK/8A EfjLR/Bn/C6v
+C3PxU/Yp+Emua7pUevaP4g8W/D/APZ/8P8AjvwnqWmfCXRvGXgL/hIPAnw7 0/4TeGfHXwws
rzTfFfhr6/8A2l/2Ef2Z/wBrn+1v+F2+F/iBdf8ACT/D+/8AhP48/wCFX/H/ APaE/Z7/AOFq
/Cy//t7b8NPjP/wz38U/hd/wun4f6T/wl/jn/hF/BvxX/wCEx8OeEP8AhYvx M/4RXTdG/wCF
leO/+Eh9f0D4A/Brw58M/G/wZs/h74f1L4U/EvxB8cvE3xB+H3iyGfxz4V8a aj+0p8QvHfxT
+OVt4m0nxrca/bax4f8AiL42+JnjrUdZ8J3yTeFYNO8Q3PhjS9G0/wALW9jo tqAfIHinWPjf
+x1B4A8K2fxv+MH7dvxk/as+MGl/BT4FeGf2rNd/Zq+A/wAM/BHirwj8Gvjv +0L4z1DxB8S/
2Sf2JvDHinw14f1v4U/Bjx0BdX3wi+Ouo6l8QtF+GXhXS9K+H/hvxN478faV 8wXn/BWz4pta
/Hzxdon7Kfw/vfhl+xT+z/4j+On7aesap+054j0nx34b/wCFS/tHft3fs3/H nwt+y74ItP2Y
tb8P/tBf8I/4g/4J8/GHxF8I9b+LHxF/ZS/4Wlo/in4aweMtI+C17qviiPwh 9v23/BPL9m6L
wrrPhK+v/wBp/wAT22qeIPDPizS/Evjv9vD9un4h/Ez4ceKvCuneLNCsfE3w N+L/AI6/aO8R
fFb9nzxBq/hbx5418D+N9Z+BvjP4eaj8R/h74q1/4efEG58T+CdUvNAl6C0/ YK/ZOsvAnxg+
G1v8Kf8Aikv2gP2f4f2YvjXbT+OviTd6x8TfhF/bHx68TaraeLvFl14xm8W6 r8QPGHi39qD4
/eNviL8bJtc/4XZ8TfHfxQ8ReOfiF8QvE3i3+z9ZsgD84P2kP+CmPx9bVvi3 8Nfgn4F+D/wn
+JPw6/af/ZW+Gfw88B/Hf4y+NPhn+1B8Y/CviH/gpd+yz+yV448dap+zn4z/ AGQ/FOkaD+xB
8fNI+IfxA8L+AP24Pgl8Rv2jNOtvD+v+Fr/QPCuj/HaHxb8OPhH9P6Z+3z8U 7a6/bOtPiF+z
58P/AIdWX7GX/CE/DjXPHF3+0D4j8W+BPi5+1P8AFP8AZx/ZZ+NPw2+AXwf0 rwT+zzrvx68W
f2z46/aKm+D82s2/wFHxF8V6xd/AWH4A/BX49fE340eOfg58APoDU/2Ef2Z/ EGsfFLxF4u8L
/EDx94g+LP8AaH9pa78Sfj/+0J8StY+G/wDaXjvQvilJ/wAM1an49+KfiK9/ ZE+w/E3wf8Ov
iLoP/DK0/wAG/wDhGvHfwi+CPi7w7/ZfiD4IfCTUPBnQWX7G37PFn8Pfih8M X8HeINW8N/GX
xB4B8Z/EbUvE3xT+Lfi34ha98QvhX8M/g38Jfhr8VLb4ueJ/HWr/ABW8O/GD wH4W/Z8+DOq+
E/i94Y8aaN8TNC+JngDRvjVp3iu3+Mj3/jy8APyAH/BZ74ha94g8H6d4e/Zu 8Qab8ZLHxB4w
+Aniz4G+PfHfxM+BvwavPjL4x/ag/wCCO/wk+GHiPUvEPx9/YK8D/th2Ph/R vAf/AAU88HeK
4/E+sfs+fCGCzn0r4t+HYvgx8efDeufA748aD9AeFf24P2uPiH+3n8HP2a9H +FHwf8Oav4C8
P/tbeFP20/hpN8eNb1T4Z6XqPgF/+CUXxZ8B/F74A/GST9lOL4k/F/xB4M+B P7c8WnW/wr8Y
/Df9mPwr4n+IXiz4heH/ABD4zbSPht8OfiN4q+n/AAx/wS//AGLPCusW/iaL 4dfEDxV4tg+I
Fn8UpPG3xS/aS/ad+MvjvUfHeneO/wBjr4k6bruu+Ofi38Y/Gvi3xF/Zni39 gD9kK50zTNe1
nUdH07R/g1p/hOy0+Dwl4q8e6H4q9g1X9jb9njVviZdfGYeDvEGg/FbUPjBp /wAcdU+IPgn4
p/Fv4feKtZ8aWfw9+CnwsvtF1zVvAvjrw7c638H/ABd4J/Zw+A+nfEn9nrVn vPgF8VNR+E3g
bxP8Sfhp4r8U6DZ60gB9P0UUUAFFFFABRRRQAUUUUAFFFFAH5Ca78PfBHi6+ g1Pxj8DfEniv
UbezjsIdQ8R/sxfFDXb2GyikuJ47OK61T4W3M8dpHcXVzPHbpIsKTXE8qoHl kLdL4Q8OeDPA
Zvz4M+CvjPwh/agthqX/AAiv7M/xS0D+0fsXn/Yvt/8AZXw0s/tf2T7Xd/Zf tHmfZ/tVx5Wz
z5d3WfFL/goB8EvhT4nvdE+MH7c37C/7K2r3Gq+N4/Dvwy/aI8TeGNF+IV74 W8E/Erxt8KU8
axt4k/aO+FV1q+g+KvEXw88R3emXlh4MttP0+eG+8LrqWuX/AIev9Wu/uL4T eNLzx94JtvEG
oxWSahb+IfHPhS+n02K4tdO1O88A+OvEngO512wsLu5vrrSbLxDP4bfXLXQ7 nU9YuNDg1GPS
Jtc1uSybVr3FZXltHFPMoZblyx6nJTxsMJRWMVSpTlTm3ifYxquU6anTnKNR 80HKLbg1fpeY
Y2eH+pvGYuWF5UlhniKrw/LCUZxXsOd00ozUZpcitJKSSaR8V/8ACSSf9CR8 Yv8AwxXxo/8A
mCo/4SST/oSPjF/4Yr40f/MFWp8ftT+BHhb4sfGz4jfH3wt4H8QeE/hp+zj8 FfEMl34w8I6P
4vu9PguvHv7SEU2neGdP1LT9QvLvXvE17Y6Xo+k6DosT6r4o119G0XT7W+1K ewtm8c/Y2+MX
hjxx/wAKS+L3wbGheAPA/wC0b4kuPA/xS/Zy0rTbE6J8J/if4U+CfjTxhrw0 u70pdBtYfElh
q3w5t9PXxHaeFdI0z4neAPEWjeMZNP1HTp/AWraXyPMOIVhqWbR4cVfIZZ9P I8RmGHzKLxGD
vjMTl1DHVsHicJhaVShLGUcPCvSwuOxGIw9HGUq3squlOfXHA4edKvJYupCp Rw1OsvaYSSw1
WvPD0sW8JDEUq1WaqrDzqSjOpQhSc6cadSdJ1qTl6f8A8JJJ/wBCR8Yv/DFf Gj/5gqP+Ekk/
6Ej4xf8AhivjR/8AMFX07+0J+078Iv2X9H8B6z8W7v4gf8XQ+IC/C34e+H/h b8E/jZ+0B478
YeO/+EE8d/E6bQtC+HHwB+HvxN+IF79i+H/wy8eeLNT1OPwz/Y+laP4Z1C51 LULT/R1m+X/C
f/BQfwX4l+Lfx9fTo/EHjL9nz4U/swfsifGTRb34V/An4+/E/wCPo+IXx0/a H/bd+AfxT8A+
K/gf8PvCXi74yWniD4W+JP2ZvDHhjxn8L3+DOi/Ez4J+NLD4vad8ZrLSZPC+ rad4H9j27/lX
3s8sf/wkkn/QkfGL/wAMV8aP/mCo/wCEkk/6Ej4xf+GK+NH/AMwVeO/F7/gs J8Ivh/8A8NMS
eCPhz8QPitZfA79gDUP24PCOs6J4K+Nlh4c8Uax4W/4betviL8APjp4mg+B+ ueH/ANi/4geA
fEH7F2seAtXsP2kNS8LeO5fin4i8U/CSP4XxfE34U+IvCep+v+Bv+CgXwp8B /DP4bSftJ/FH
xBqnxE1/w/rnjPx74q8N/sE/tofs6+Ffhf8AD1fiF428K6D8VP2jfhF8TdM+ L/jb9hj4Py23
gzxRb2Hxe/a9+IngL4Z+PtO+GHxV+K/hLxXB8O/CfigeDj27/lX3sB//AAkk n/QkfGL/AMMV
8aP/AJgqP+Ekk/6Ej4xf+GK+NH/zBVu6v/wVA/Ys0z+249P+IvxA8e3vh39o DxT+yrqujfB3
9m39p344+I4v2jvA3/C9Lnxx8F7Xwz8HPg5468Qan8QPBXh/9nL4pePfGGga Zpt5deF/hZF8
Pfi3rosPhl8avgt4s+IHoHhb9vX9k7xn4c1fxZ4d+K32vw/pHxA+Bfw7j1C6 8C/EnSP+Eluv
2nvinonwU/Zv+IHw+tdY8HWF78Tv2f8A49/E3XoPDPwd/ae+HVt4p/Zx+JH9 keMNZ8I/FTV/
D/gPxvqvh89u/wCVfewPIv8AhJJP+hI+MX/hivjR/wDMFR/wkkn/AEJHxi/8 MV8aP/mCpnjf
/god8M/g9+0P8aPB/wAZfFXh/wAJ/A7wX4g/Z7/Zu+HPiTT/AAd8QvEXxC8b /t5+PfhJ8dP2
o/iV+zXpXhzwvaeI9c8aeIJ/2XLX9ljxb8FNJ8H+BGf4ofEz4u3XwP8Ah94k +Jnxx1Sw+E/h
n2Cf9vX9k6w8d+LvAeufFb/hE/8AhCP+Fiwa38TfHPgX4k+A/wBnG61j4O6P 4i8QfGHwj4V/
as8ZeDtD/Zl8efED4Q6L4I+JOpfFf4deBvi34i8d/DW1+EPxtk8beHdC/wCF J/FgeDj27/lX
3sDyL/hJJP8AoSPjF/4Yr40f/MFR/wAJJJ/0JHxi/wDDFfGj/wCYKu9uf+Ch v7N1n4V0bxRe
WH7T9rc+I/EHibQPD3w3uf2D/wBumD4+67B4L07wnqPjHxvo37Ncv7OK/tB6 p8H/AAnJ498C
6D4m+OVj8Mp/g1oPjTxp4T8Bap47tfG3iPR/D956Bpn7aH7MGveFfEPjrw58 X/D/AIp8E+GP
jB+z58CNR8Y+E7LxB4q8K3nxM/ar079nnWP2fNL8M+IfDuj6npHjPw/8TdI/ at+AGqaN4/8A
CF5rnw9s9O+Idtfa34p0u20DxXLoJ7d/yr72B4F/wkkn/QkfGL/wxXxo/wDm Co/4SST/AKEj
4xf+GK+NH/zBVu+HP+CoH7Fnjn4WeAPjN8NPiL8QPjB4F+Kv22f4aN8Ef2bf 2nfjb4x8e6Po
nhzwV4g8ZeLvCXwx+E/wc8ZfE3Xvh/8ADC9+Ing34c/GX4i6b4QuPAnwV+O2 tJ+zr8WPEXg3
49WWpfDiz9g8M/tk/s8eL/jLc/AnQfGPiC48bJ4g8WeDNJ1y9+Fnxb0b4NeN viF4Ag1m4+IP
wr+F/wC0XrXgXT/2fPiz8YPh9H4U8er4++EPwy+J/i34meCZ/hX8ZLXxR4U0 m5+DXxTh8IHt
3/KvvYHgX/CSSf8AQkfGL/wxXxo/+YKj/hJJP+hI+MX/AIYr40f/ADBV8O+D v+Cw3xT8WfEn
4efCbSvCf7AGneIPjt8P/DP7QH7NupftK/t5eI/2NtY/aK+BP7Tf7WP7Wnw0 /Yki+CPwmb9m
f9pzxn4/+IHjf9nL4KfBT4l/EnRbrUvCPjHQvHfx20HwbqHwp8EeIGuPBujf f/7Sn/BRf4E/
AT4J/tDfEXQ9R/4WR8TfgN8P/wBrbxTN8BY7Txj4V8d3/iP9j74Rah8YPiFp Hje0uPA+t+IP
g/8AD+98P3Hw2n0f46eOfCMPws17R/j7+zf4i8E6340sv2kPgDD8Tj27/lX3 sDC/4SST/oSP
jF/4Yr40f/MFR/wkkn/QkfGL/wAMV8aP/mCrvdZ/4KKfsq+GtO8J6p4p1/4w eErbxP4fufGe
sReLv2VP2rvCuo/Bj4e2/irxN4Oi+Kn7VOj+Ifgnpur/ALHXwf1XV/BHj288 O/F79q2x+DXw
z8T+Ffh58RfHXhzxXqngnwB4x8Q6IaB/wUb/AGPde8VeN/C9x8TfEHgi2+H3 iD45eE9f+JHx
e+DPxz+B/wAArzxV+zTqPjvTvjz4Z8GftKfGP4a+Bf2fPiR4g+Fsfwr+K+ve K9G+HfxN8U6j
Z+C/hR8VPHsdtN4J+G3jfxBoJ7d/yr72BwX/AAkkn/QkfGL/AMMV8aP/AJgq P+Ekk/6Ej4xf
+GK+NH/zBV554T/4KpfCnWPj78ffCWv6T8YPC3wp+Gnwf/ZE1n4eaH4p/Yx/ bQ8DftQfEz4y
/Hzxp+27b+OPCfgD9nPxn8INK+O3xo8P6B8Nv2Y9C8d6Xc/CD4H69BoHh/w9 8d/GHiXxNqHh
b4eeLZvh0ftlf8FWfgh8C/2R/jV8avgvrHiD4p/Fbw1+zB8bfjX8PPB2hfs7 ftK/FjTvBXir
4e6J8SdH8N6f+134e+FfgKXxJ+yh4fX4yfDHxz8MfG9r+0rqvwC1HQvFXwn+ O/gvVNV8NeKf
gn8VovAx7d/yr72B6H/wkkn/AEJHxi/8MV8aP/mCo/4SST/oSPjF/wCGK+NH /wAwVbv/AA3P
/wAZ2f8ADJ3/AAq7/i0v/JH/APhpb/hNv+b7P+FO/wDDWP8Awx3/AMKb/wCE R/4SX/kyX/jJ
b/hoP/hI/wDhTv8AzRv+0/8AhbX/ABTlef8AxC/4Kt/s/wDhW6+CeoeC/CH7 QHxX+H/xX/aA
tPglc/ELwR+yt+1/rmj6jo+ufs4/tO/H7wn8V/2b4fDP7Onib/htf4f+I/8A hnFNKj8Vfsv3
Xj7wJp3gTx9o/wAa77xynw/TRrjxUe3f8q+9gdH/AMJJJ/0JHxi/8MV8aP8A 5gqP+Ekk/wCh
I+MX/hivjR/8wVd74V/b+/Z41DwX+0v4x8W+PfD+h237I3h/42fEn48N4Z0v 4t+K9O8DfBr4
Q/H39rX4Enxtc3WrfCLwVq/iHxBNq/7GHxwi8WeBvAnh7xjP4e8VeDNZ0fwf rnxO8E6l8Nvi
f8S/n/Rv+CtfwQsPi3+0J8PvihoviDw14J/Z9+D/AMT/AI1+Jfjb8OPAP7Sv xn+Gek+Ffgn+
0P8A8FB/gn8X9P8Aidr+hfs06HpHwb8QeANI/YJ1rWltfGWrDTvit8QvFniD 4Wfs7ar8arbw
PoHxA+J57d/yr72B6H/wkkn/AEJHxi/8MV8aP/mCo/4SST/oSPjF/wCGK+NH /wAwVd7+19+1
5p3wT+Gf7SOg/Ci98P8AiT9rH4cfB/4T6z8J/hf4s0HxVL4V8S/GX9r74hfE H9nb9hnwn4m1
qzl8NaGPD/xs/aj8D3Hwy1m5j8e+G4PA+nRXPij4ieJvhx4OubLxkPzg+Kn/ AAXO/wCFYfAn
9trx/P8Asu/2r8bf2Y/2gPjl8O/g1+z/AP8AC7fsP/DTPwJ+A3jH9q7RfFv7 Rf8AwtZPhHqH
hL4M48Jf8E9f+ChfjX/hUXiqy1/xif8Ahln/AIRzTL7WNT+N/wAEZfGp7d/y r72B9xf8JJJ/
0JHxi/8ADFfGj/5gqP8AhJJP+hI+MX/hivjR/wDMFX07o37UfwJ8Qf8ACuP7 I8c/a/8Ahbf7
QHxq/Zc+H3/FM+Mbf/hIPjt+zv8A8L9/4XF4G/0rw9D/AGV/wh//AAy/8dP+ Km1v+zfB3iD/
AIQf/ilvEOt/8JN4P/4SDx/xX+3X8M/h1+1x8RP2XPiZpXiDwTpHgL9mD4Yf tQXnx2uvDfxC
1T4NaB4V8X63+1na+Ok+NfxP0v4f3Hwb/Zs8P/D/AMN/stXHiTSvGnxv+LHh DTviZP4s1Dw5
4QsX1fwTfLrB7d/yr72BwX/CSSf9CR8Yv/DFfGj/AOYKsTWNbe8vfAlufC3x K00SfGL4GZvd
f+E/xO8M6RDs+MvgR/8AS9b8Q+EdL0ey8zb5UH2y+g+03MkNpb+bdXEEMnrF t/wUU/ZVn8K6
z4luNf8AjBour6N4g8M+GR8HvFP7Kn7V3g/9qDxHqPjLTvFmteFbnwB+yL4q +Cej/tR/Ezw/
r+h/Dr4r6/pfiz4d/CDxR4VuvD/wV+O+ux6ydI+BfxdvPBfjuhftyeC/2j/H Xxw+B+j/AA8+
MHhPV/gX+0F+x2ml+IfFnwV+Pvhfwr4u8F+PdK/YT/aDsb7xN4r8dfB3wV4J +Evxg025/aSi
8H6z+y/4x8Wt8fdE07wbc+O/EPgvRdI1S807w6e2b05Vrpu+oH3Z8YfjB4a+ CvhfTfEniOx1
3WZ/EHjDwj8PfCXhrwzbWFxr3izx1471u28PeE/DGly61qeheHNOudX1W7it 11TxR4h8P+Hb
Bd0+qazYwrvPyh8VP26/h7p/xd8Rfs3eDdci074geHdb+GOj+NPG882l6vov hPTviR4ktPDl
xH4c07w9D471u4+IWlXN7Y6Lav8AEDwT4f8AhT4X8XeIfCUXj/xV5mteHfCH jToP26v+JX4a
+APjjUf9I8H/AA+/ar+AniXx1bap/ovgrR/DCeOLC0u/iP411uz/ALO1fw7p nwqkuIvG9hrB
8UaH4RttW0y0HxCs/FHhB9R8O33jum/ET9nex/a9+PHiHxB8WvhT4i8F/HHw 5rn7Pfjfwn4v
t9f08eHfHH7JvgbWvGnxj8Na3HrfhK9+H/iPwDYfDLx/PqfxA8Wa/wCKvDfh zw1c2sXhF4PE
uo6reR6T6eO4XrZ3wZm0Mpr5hg88xeT5xLLszwVKtiKeCx+DxmVNU8RTpU+a FKGVPMcRiJ06
2ErqhW58FmFDHww8sN5UM3WBzvCrFLDTwFLHYCOJw9eUKc6+GxGHxic6UpzS lOWNWFo004Vo
e0g1Ww86Dqe1+0v2b/i5d/HD4Q+FviNd2OnRNrMMkSaz4fXWYvCPi02Oy1u/ E/g208Vafonj
Ww8N3mope2VtZeMfD+javBeaffCwbxJ4YPh/xr4n5Twz+2T+zx4v+Mtz8CdB 8Y+ILjxsniDx
Z4M0nXL34WfFvRvg142+IXgCDWbj4g/Cv4X/ALReteBdP/Z8+LPxg+H0fhTx 6vj74Q/DL4n+
LfiZ4Jn+FfxktfFHhTSbn4NfFOHwhxv/AATz0XWdE/Y6+CMWt6Tqfhi51Pw1 Pr1r4I1CwutO
t/AGla5qt/qWk+C9Bg1eJ/FUnhnQ7C4gi0C78baz4r8Y3mnSQ3Ou+LdfuZBf P8ZfD/8AZ1/a
HH7PH7J//BNrXvgz4g8N+Cf2PvEH7C1xq37a174v+EmofBr4ufD3/gn58W/g j8Xvh9N8L/hj
ovxG1H9oO1+MHx2k+CHgLwt4++HvxN+Gfw7+GfwIn8UfGTV/C/x+/aGtvhH8 LLb9pvxf7KxG
Rt5Lis0nneJymU8uxGb1KFLCzzKtg5PD1MbLDUZ1aVB4idN1PYwrYhU1JQ+s 4lp16npU8XDM
KdPHU8KsFTxlOGKhhIzlVWGjXiqkaKqTjCU/ZqSjzyp0nK1/ZUr+zj+z1Ffz g/Bn/gmN+1j4
M8OfsseE/EvjT7T4f8I/ED9kL9mr4maf/wAI58Nof+Ea/ZO/4JFfFP4VfGv9 iP43farDx9dX
us/8Lr+Jv7Lnx18Tf8K28P3Nz8Sfhv8A8PjP7G+LevfErw//AME9vB2leIPI LX/gkx8b/h5+
x7+x58I/gB8CvD/7O/iTUv8AgnB8PPA3/BRrS/gGP2avB3ir4+fG/wCGnxz/ AOCYfjrxf8Nv
iFY65Dq/wO/ae+MHxE+B3w8/4KE/CX4fa5+0RpvxD/Zq17Ufi98Q/Afxz8ba H8G/j943vPFI
Wf1O18QD/goP+zxZ/s1fsp/tS+IY/jBpPgn9s3w/8MtZ+Bngvwz8Cfi38cvj Lr2o/FT4IeIP
2iNE8J3Pwq/Zp8JfGrxSfEGjfCnwf4x8SeLLnR7XWfCuhQeFNZeXxNNbJZ3N 5+QHw3/4J8+J
vhr4V+FUnxJ/YQ+MH7XP7J2j+IP2oLq0/wCCffxruv8Aglz4m8VfDj4hfE/T v2ObL4S/GvT/
ANmbwMP2X/8AgmF8F/D/AIEb4GftcW9rpXwL+InxL+JlnqP7Wmq/FebUL7xj +09+0/4S+Dn1
B4e/Yp/aYv8A9jL/AIIZfBK21/4gfs+fE39kT/hRX/DQ/jz4W6r+z34i8d/A 7/hBv+CW37Tn
7Pfij+wl+LnhT41fB/xz9s+MHj3wn8KNT/sbwN8S/N0fxhqHirwz9hstJPjv w6Afr98Lfil4
E+NHgTQviT8Ntd/4SDwl4g/tOC2uZ9M1jw/rGlax4f1jUPDPizwj4u8J+JtP 0fxb4E+IHgTx
bo+ueCfiL8OvG2h+H/Hfw58d+H/EXgbxz4d8P+LfD+s6NY8/8NPjX4V+KnjT 9oXwL4e0/wAQ
Wer/ALNfxg0X4KeOrjWbXTrfTtW8Va98Avgf+0ZZ6h4TmsdV1G5vvD8fgn4/ eDtLubrWLPQd
RTxVpviaxi0qbSLPS9c1n8ofhp8Dv2mP2WPGP7N3xLm/Zt+IH7R2tfAH4f8A 7ffwJ+Lc/wAE
fHH7PekeMf2lPin+2v8AHb9kv9rXxB+3H4S8NfHX42fA34f/AA5+H/xU+IHw o+MGpfGX4I3f
jLw54j+Avx28eJ8J/gL4B+Ln7Mvhnw18eb78oPAf/BJj9rSz+C3wV8MftA/A r4weMfht4K8P
/CvTfGX7OfwUH/BMP46eKte+Leh/8Er/APgjx+zl4Z+LeofD/wD4KJQ/ET9j y88P/Bbx5+yf
+2d8Gbrx7p2o6b+0PoWo+OdKf4OR678Cfi98UPEF4Af1PftL/tO/CL9kT4Wa t8a/jpd/EDSP
hl4d+3z+KfE3gD4J/Gz44/8ACH6PpHhzXvFmt+LvGujfAv4e/EjxB4M+H/h/ w/4a1fUPEfxF
8U6VpHgTw75Vna634isL3V9Itr7f+Enxx8F/GrTo9U8HaL8YNGtpPD+m+Jli +Lf7PXx9+AOo
jTtW8VePfB1rbSaP8dvhp8ONXi8QRav8OPEN5qXhOWxTxVo3hXUfAXjrWNGs fBPxU+GHiHxh
8gftC/s8fGXxP/wSI+OH7J2jjxB8T/2g/EP/AATg+Jf7PGljxZ8XIPiX4q+I fxl1b9mTWvht
YjxN8ePHXhf4NW3j/wAQeLfG1xF/bPxc8Y+CvhTB4q1HULnxl4h8L+Bo7+80 nS/mD9rP9gPx
H+03/wAFJ/hT8Rfib+z38P8A43/si23/AAyB/wALJ0/4pWfws8beBNR/4U38 Bf8Agu1oWuf2
78LfHN/fXviL/hD/AIm/td/spz6ZnwjqW7WPG2n+IvD/ANph8A+NtT8IgH7f Vz/izxZ4V8Be
FfE3jrx14m8P+C/BPgvw/rPizxj4x8Wazp3hzwr4T8K+HNOudY8Q+JvE3iHW Lmz0jQfD+haR
Z3mqazrOqXlrp2l6da3N9fXMFtBLKv8ALFqX/BMX9ru9+Cfwb8H+Jvhh8QIv At5+z/8A8E0/
iZ+3P8HfhJrH7FHj3x3+1b+2T4d+EX/BQrwf+2x4o8S/D39rl/HP7GX7Qf7Q GrfHL4l/sM/G
L46/Gf8Aaktb+x+LWj/BXw/8Qvh98UPHPx6+B3wktdK/V7wZ+xl8TB/wTg+F f7OumTeIPD/x
E+GHxg+EP7Q3w68JfH7x18Pdf1G0g+AH7b/hT9sr4P8A7PnxC8U/s4fCjwl8 G/g14fuPDfgD
wj8BJvD37OHwn+IHwa/ZD8Kz2/gr4F6Z+0V8O/g/4Rv/AIkAH3B8C/2lvh1+ 0R/wlP8AwgHh
z9oDw/8A8If/AGJ/a3/C9P2Tv2p/2X/tf/CQf2v9g/4Rb/hpf4N/CT/hOPs/ 9iXn9t/8IV/w
kH/CM+dpH/CSf2V/wkGg/wBpe/1+QP7Sg+NH7Xvg74YL48/4JwftAXHwl+DX 7QGg+P8A46fs
l/HTxN+wL4u/4bL+Fmt/An9oz4eaR4K8LeDtE/bD+JH7P/jX/hTX7QHi74Cf tCa34c/aa8ef
CTw5Z/8ACt9I8d/C+98a/FrwP4W8Mt8AH/glj8Xdc+HX7bnjnxF+y98P7349 RfsAa74f/wCC
YOqa3P8ABPU/in+yD8Xbj9qf/grR8d/2cfgV8C/H51+/sv2YviB+yf8ADL4+ fsQfDbSPEvwi
8baJ8E/ht4j+H/hbQ/gX8W/FHgX4P6N4p0oA/o9+JfxS8CfB/wAOab4s+Iuu /wDCO+H9X+IH
wn+Fun6h/Zmsav8AaPHfxx+Kfg34KfC3Qvsuhafqd7F/wlHxN+IHhHwz/ac9 tFo+if2v/bPi
LUNI8P2Gp6rZegV/ND8WP+Cc/wAVvid8UP2vr+D9kLw/8R/ht40+MHw++MPx B8Zftg/D39i/
xH+1x+1Lp3w1/wCCiv7N37T+rfsufs+/H34WfFjXo/iH+xB4p/Z8+AfjP4a/ CL4Bf8FD/DHw
c8VfDTW7r9mj4c6/8Yp/gTZ614b/AGV/oDQP2HPGmh+B/wDgo78RPh1+yd4f +HHjH9orxB8C
/AHwd+DHjBPgF4un8HfsLS/sS/8ABPX4PftJ/Aj4LfCa+8afEr9i/wCHHxgv NO+Dnxg+FHhj
wt4uji/Zu+L3xl+CP7Nlv+0fqnxK/ZO+HHw31fTQD9vrnxNp1r4q0bwdLbeI G1fXfD/ibxNY
3lt4T8VXnhWDTvCeo+E9L1S21nx1Z6NP4J8OeILq58aaPL4Z8J+IfEOl+KvG mnWfizWPB2ja
7pHgLx1feHOf1L4peBNI+Kfg34Kahrv2f4m/ED4f/Ev4peEfDP8AZmsS/wBr +BPg/wCI/hP4
T+Iuu/2zBp8vh+w/4R3xB8cfhbp/9manqtlrGr/8JR9q0LT9TstE8RXOkfyh eDv+CWP7UXiW
+0DwN4h/Ze+IEv7LGkftALB4d+DX7S8//BO3SP8AhH/2cfEX7ZP/AAbu/HD4 m+EdW+BP7Gev
2P7Ivh34f+MJv2RP+CgvxJv/AIdfCnwTYWvjP+yNe1z4h+HdX+M/xxil+JH3 /wCGf+CeF18M
/wBuzwx8Trn9in4f/EP9kX4L/tAfFzQP2RvhD4P0P9nEeHP2VbX48/B3/gkh 4r0j9qr4O/Cv
x74s8FeDPgx8P/hX+0b+y7+2f4g+IQ+Eq2f7RyfFP4p3XxH+GXwX+IsPxW8X +M4AD9/qKKKA
CiiigAooooAKKKKACiiigAooooA+RNY/Z3+J0Wp66vgX436b4Y8K6v4k8V+K LbQta+Gl74m1
Kx1Dxv4k1Txj4jhl1zT/AIleE7W8sz4j13Vn0iNdAs57DSHsdPvLjVb21uNX v/ePhV4Aj+GH
gXSfBy6tPr1xaXfiHWdU1i4to7H+0de8XeJNX8X+Irq1sI5bn+ztMk13XdR/ sjTZr3U7rT9L
FnZXmravdwT6nd+h0VtOvVqQVOck4xaaShCLuk4ptxipSdm9ZNvVvciNOEZO UVaUt3eT89m2
l8kj8U/+Cln7H3xK/aL+JEPi7wh8PPiJ4ku/BPww8EXPwy8QaN4w8E3/AMLY PH2j+IfjJJ4p
0X4p/CTx5473Xmn3Hh/xN4ZS28a/DX4TeKPiGLHUtX0SaP4heG47/wCFHiLx f/gnv+yj8bND
+M/wt/ai+Ifwa+LPgvxh8RtZ1zxP8Qnv9X8L/DD4a+CvAWsfC34rJ4c0DWPh Fp/xB0T4peKP
idH4v8XaBZ+ILT4sfDbX9G8G6ze+JrzwsbvWU1j4zfET+hSuT8BW/wBk8C+C 7X7N9i+zeE/D
lv8AY/sP9mfZPJ0ezj+zf2b/AMIv4I/s7yNvlfYf+EL8IfZNn2f/AIRfQPL/ ALJtPQhn2a08
onkccZVWFqVnVVTlofWKeGlVVWvl8K7oOqsHiJKjGpCM4z9jS9h7R0pyid6x tdYaWGUv3baX
W6jKHLOClfmUZOEJuKai5Rd04ycX8Wft0fBz9o74r+Lf2Etc/Zm1X4f+FfFv wW/a/wDEXxS8
WePvil4Huvij4E8A+BNR/Yd/bR+Ddzruu/C/RvjT8AfFvjz+1/Fvxc8H+BtM 0zwd8SdO1jQ9
Y8X6f421HT9W8JeFfE1lJ8gat/wRv+32vjrUrn42/D/xt4g+I/8AwgHi3x78 P/jX+zf/AMLV
/ZO+J3xTtv2jv+Cj37TnxbT4yfs4SfGjwze/FD9n/WPib/wUg8WeMvgF8EdZ +LNt4j+AnxJ/
Z9/Zy+Jfib4y/HTxB4J1KPXv22u7u1sLW5vr65t7Kysrea7vLy7mjtrW0tba Npri5ubiZkhg
t4IUeWaaV0jijRndlVSR+ePgz/gof8MfFH7Svin4XXGreFtN+C0mi6NpHws+ OdxrVlb+DviB
8VLG4Wbxl4a03xPNqX9iXunajaeI/DuleAriCG1g1nX/AAj42js9X12PX/Bt u3n0sPWrqrKl
TlNUYc8+VN2jdLot9W0t2oyavZnhY/NsuyypgqWOxdHDTzDEfVsLGrUhB1Kv K5aKUk+RS9nT
lNJxjVrUITcXVjf438E/8EZ/FXw6/Z4+OnwA8D/tDfB/wfpH7VX7MH7UP7L/ AMe7fwj+yVqP
hn4e6B4V+MPxb/b0+N/wRf8AZW+GekftK21t8A/D/wAC/G37f3xD0TxF4L8Z +I/jzp3xM+Gf
gD4deEPCV98ENXtNc8X6x9f/ALWX7B/ir9orxV8brzwh8avD/wANvBP7Xn7M Hhz9jL9rjw94
k+Eeo/EjxVr/AMAvC2o/H+XTJv2cvGOmfFr4aaR8D/jBJpH7VPxvsb/x18TP Av7S3gufUR8K
tUt/hRaW3gjxdo/xP+i/2vv+TdviH/3KX/qc+Ga/mO+B/wC1la/Gfwr4P+I2 pfBH4t/BP4Uf
ETwl4D8WeAPil8ZvEf7OGmeFfF//AAtPUfCWmfDHwzp2n+Av2gPiF43sfFvj +58a6JB4Y0bX
/CGjfbNRmTw7Nc23im+0bQtT6MNg1iIObquD55RUfZuekYwbk2pJRXvpa6ef bsnUcHblvonv
bdtWtZ32P6BvBv7DH/CJf8M4/wDF0f7Q/wCGf/2//wBtT9uf/kSfsn/CW/8A DYH/AA31/wAW
u/5G65/sH/hXf/Dcf/I7f8Tr/hLf+FX/APIo+Gf+E1/4pLz/APZ2/wCCe3jv 9mfw58PNN+HX
7S32HxB4J/ZA/wCCVn7HWoeJv+FNaPc/8JH4E/4J2/FP4ueLPilef2NrvjXX rLSP+GsPhl8Z
vF3wk+zwSXesfAr7T/wnvh3xP428QQ6ZbaX+M3i39qr4E+BfjL4D+Bfiv4i+ EtD8b/ET/hMN
N0D+1PF3g7TNOHjvwjP8D/J+El5/aXiKz1cfFvxlpH7QXw/8U+BfAVlpF9rP iHwrNfa2kdtb
SaJ/bR8fv2mPAn7On/Cvf+Ex0nxbr3/CfeLYdFvP+EMsNG1T/hW3gSz+z/8A CdftA/FT+1Ne
0P8A4Q79nf4Q/wBpeHv+Fv8AxWl+2aN4A/4Szwp/bES/29Y+Z0PLILmbxK91 pS/dfC3ZpP8A
eaaSX3k+2enuPXbX/wC1P2Z+FH7HXjvxJ8RdN/aG+K15/wAK3+Jumf8ABT/9 o79sXXvBNnb6
P4o8OeL/AAJ4f/ZY+OP/AAS8/Zos/Dl9pPie5m8E/wDCbfsi237P/wC0H41u Na1PxnrC/FOX
x/4el8MfD+y8S2HhD4W+QaP/AMEe/h74Y+Mvxl+J2g6H+xBqlt8RfEH7W/xG 0nXPiZ/wTt+G
fxM/aH8S/EL9sKD4u3HxB8IftN/tGa18SrXV/jf+zBp2r/Hbx7pVn8Gfhl4L /Zq+Jmt/CTQP
hb8FfFH7RWseCdG+KcPxn/MX44ftVfAn9n3TvGH/AAsD4i+EofG/hH4SePPj XD8HbHxd4Oj+
MvjLwJ8O/Cvi3xhr+oeBfh7rfiLRdX8Q50jwL4r+x3SfZtGM+h6p9t1WxttM 1K6s9fwV+0f8
FfiLr2n6R4G+Jfw78Xaf4h0jw9qXgnxT4X+Jvww8TaD8QbzXrz4y2s2geC7f w9401TxPq2r6
FB8BviVqOqTS+HLPQb2z8M+Jk8M634h1DwB8T7HwOf2ZG/L9aXN29mr6+Xtf 6uu6D2ztfk0/
xf8AA8z9Q/hf/wAE2PjZ8Cf+ED+Inwc/al+H+j/HrwZ/wvvwrplj48+Anxd+ JH7G3w2+Cf7Q
H/DMr678Ev2Zf2X9Q/bM0r4m/s8fD/wXe/se/BbWPhf4G0r9rDxb8IvhtfeJ fj3pPgf4UeH/
AAL47+Fvgv4E8/4e/wCCTnir4TeFfAnwK+An7Sfh/wAO/suaT8YP+CePxr+I fhL4vfAjUfip
8ffFfir/AIJ4ad+xr4P8D6f4M+OHgz44/BP4d+AfD/xC+Hf7CnwS0zxXa65+ zh8SNR0/xprP
xU8XaRqqaH4m8JeBPh9+THxI/bb/AGd/hL4q8P6D48+IHhLQfD+veLdO8Cz/ ABMvviN8JLP4
e+FPFV5p37Ss93pfjq/v/iHaeIPBv9j+IP2WfiH8PLy+17w3Z6dqHxNvNL8B +G7zXvEGg/Ey
0+H30RbeP/Al5/Y32Pxr4Suv+Ej8W+JvAHh77N4k0af+3vHfgv8A4Sz/AITH wVo3lXrf2p4t
8J/8ID46/wCEm8N2Pn6zoP8Awhfiz+1LK1/4RzWPsYssi20sUm1a69nrra3/ AC92d1Z7O+gn
Xa3hv/e/+1P0+8J/sDfFP4NfCz9g7SP2f/2g/h/4f+Nv7D/7IDfsU2XxB+MX 7P3iP4q/Cz4k
fCzxB4c/ZstfH+v3Xwd8FftDfBHxb4V+IGreLf2UfhTrfg/VYvjp4g8OeEfD mofELwtrXhTx
zqfiDw54w8FeAap/wTJ8R/s1+O/2i/2tP2VvAn7IHxB+PWkf8NoftKfs5WPi D9jX4WaR+1j8
Sv2p/wBoXR/jN4zsPhh8df26fEnxMsr3W/2f7j4m/GDxF4Z8NaD8OvB37M/x F0L4baR8JPh5
4u/aM1fwL4T+KsXxm+lv+Cef/NXv+5A/93Wv0orz8RS9hWnS5ufk5fety35o xltd2te272ub
QlzRUrWvfTfZteXY/KDwX/wT9+Pv7NfirwVefsXftOfB/wAC+CfCP7EH7HP7 EMnh79qD9ljx
p+0f4q1Lwr+xXqP7QEvw78cJ4x+FH7Wf7JGkWPiDxPpHx81Ox8aac3gW9064 1Hw7Y6pobaJb
Xtxo8PoHxW/4J/6j8bdR/aSvviH8ffED237Yfwf+KX7Kn7Qej+F/AHhXQ9Om /ZH1nwr8YPD3
wG8AfCOXULnxBq/w/wDjB8ANX+MHjjx0PjT4t1T4qaJ8VfFXxk/aIs/Gfwij 8E6t+yr4O/Y3
/R+isSj8Yfj3/wAEntR/aj+IXhz4zftA+I/2IPiv8ZNc+D/hj4CfGPxn8Rv+ CcPhX4vadofw
98A/Ez4z+OPBHiP9i3wl8efj/wDFzSP2ZPjANI+O/ivTvHvif4xP+2N8M/iD 4q8HfCPxPqHw
Y03w34P1/wCHnjfv/in/AMErfCvxn+AWhfs5+OvjD4gh8Ep+0/8A8FH/AI+e MdU8J+E9O0bx
VrfhX/gop4L/AOCivgXxD8PfDN9rGs+JtI8K+IPhfpH/AAUAvLjRviDqmh+M 9O8S6j8K7aa+
+Hmk23jKWz8Mfq/RQB+IPxh/4JOfFP8Aae8d+KfjH+1Z8av2QPjn8TYv+GZ/ +FY+C/EH7APi
PU/2TrT/AIZ40f8Abs8LL/wvX9nj4j/tm/FDxB8bv7c8P/t+/E3VfDX/AAj/ AMafg1/wgfxJ
+H/wk8cD/hKLLQPEHhTxSeOv+CRnjuL4E/Fr4Kfs9fH79n/4FWX7Tf7IGufs dftG2Vv+w7o6
/Cyw8Cap4x/ap8fabefsm/Bv4HfHz9nHw/8As9/8I74g/bT+O2n2lv8AEjVf 2mNY8ReHNO+E
N1488T+Lvib4c+K/xQ+OP7fUUAfkD/w6C+HX/CY/8Lt/4Xp+0B/w01/w3/8A 8Nz/APC3f+F9
/tT/APCHf8l2+3f8Ku/4Z0/4aS/4UV/yYX/xre/4Tb/hDv8AkhP+kf8ACI/2 L/xbut/wh/wT
9+PvgL4Sfs6/Cjwx+058HzbfsF+IPhzc/sE6zr37LHjTUp/CfhXwH+zx8Zv2 RZ9G/a8s9P8A
2s9Ej/aY8Qaz+z58ZNRji8TfBm4/Y007S/jLotl8RH8J6n4JuZ/g8v6v0UAf mBB/wTG8CXN9
8BtS8T+NP+Ejvfgz+1/+1r+0rqc//COaxpH/AAm3gT9pj9snxL/wUC0L4I+X p/j5YfDf/Crv
2uvCH7HXxb/4WTbx6prHjb/hk/8A4QK80HQfhl8dfil4Mueg/Zw/YP8AFX7M fxz8U/F3wP8A
Grw/rOkfGHxB8b7n49+EvFfwj1G71HX/AAr4w/bC/bi/bK+COjfCHxTpHxa0 W2+FviD4a+Nv
27fiH4V+Knibxn4V+NWnfGjwr4P8GHwl4T+A2rjXL/Vf0fooA/EH4G/sFeO/ h9+yx+xp8E4P
hT/wgVl8SP2v/wBnf9pX9sHwpZ+OtH8QeI/2Z/An7K/w60j4qfsj/BHw54z1 Dxjrvh/4nf8A
DNniD9jv/gnp/wAE/PGvxJ8K6N4h1j9oX4WeDPH/AMd9T0Hw18TfiX4r+L3h P3/xb/wTG8Ce
L/2Z/wBof4Kah40x8TfjR8P/APgrB8LfCPxx/wCEc1j/AItb4E/4Kt/tCeL/ ANoX4i6F/wAK
0g8fW3h/xv8A8IT4gufhbp/9p6nqulax4k/4VZ9q0LUPh1ZeN/EWir+n9FAH wB8G/wBlz+x/
27P2sf2sfEPgb/hDf7d/4Rz4d/CL/ipv+Eh/4Tv/AISv4O/s0/8ADRf7Rf8A oPiGX/hGP+Fs
f8KE/Zc/Zp/4VF4m8OQ/8IJ/wwJ/wuTwNfW3/DVHxE/tjz/xp/wT28d/FHR/ Feh/FT9pb/hN
P+Gl/wBgDwt+wR+3j4sX4NaP4b8d/GnR/A/gT9ofRtB+Mn7Pdz4e8a2Pw/8A 2Y/iBrHxA/am
+L3jnx3oviv4bftJeBNW0ceA/BPgzw38PP8AhGda8TeL/wBP6KAPxB03/gkF /Yfws8ZeGPC2
k/8ABMDwD8QPF/xA+Gniy11P4T/8Eq/+FLfCzwH/AMKo8OfFjT/B/wATvhpo Xwd/bI8B/tNe
CP2v9C1r4va3ceDf2odI/bFT/hUPhzSdNs/gX8LPhd8QNc+IXxS8b+++D/2R PFX7Kg18eHvj
v4g+K3wp+JfxC/Yq1vx1F8ctC1Hxz+0r4p+Pvwwf9jD9luz+LGv/ALRdj438 O+G9b8P+Lvg3
+zh4O1bx34N1j4D3/jTX/jf4h8b/ABJi+MOn+FtW0v4W6H+oNeO/HP8A5ErR P+yxfs7/APrQ
Hwypx3XqvzA9irE8R+I9G8J6Nea/r959h0yx+zrJItvdXt1cXV7dQWGm6Zpm m2EF1qesa1rG
p3VnpOhaFpNne6xrusXtjpGkWN7qd7a2s3yn+2Z4o8S6b4f+Cngjwt4i13wt cfFj9o/4N+Av
EuqaNq1/4Maf4d3/AIrtLn4haHH8TbW40ceBNd8QeGbe80vwq+l+K/DXjvxP rs9r4X+G8+pe
L9S0/Srr46+Pnxn+Jnxw/af+C3wz+E+leFvDejfD/wDaN+Kvwzn1f4gX0OvR +MPiV8I/gjo3
x8ntR4Kn8E+ItH8CaVdRQ6P4U8L/ABy0fWdc+KHgyLxD4yvNC8F2lvNdad4n 6MyyfiJ8N4/N
+HsDQzXMcPlec5pQy+tXp4ZToZRSVSpNSrVaKxFaty4mOEwcKlBYuvh1hpY3 CRqVcVhOWjmW
WwzOjgswrzwtGpi8Bg5YiNOVX99j58kItQjN0oU+alKtWlGXsqdX2io1WoU6 36/6bqWna1p2
n6xo+oWWraRq1la6lpeqabdQX+nalp19BHdWOoaffWsktteWV5bSxXFrdW0s kFxBJHNDI8bq
xu18c/sG2Ov6b+zZ4UsPGelX+g/ELT9b8YaR8SdBl0S38OaFofj7QfEuo6B4 k0jwbouh6Xo3
gC38Lafd6WLa21D4YaevgjxLqkereLI9Q17xJrviPxDqvxP8P/2iv2hz+zx+ yf8A8FJde+M3
iDxJ4J/bB8QfsLW+rfsU3vhD4Saf8GvhH8Pf+Cgfxb+CPwh+H0Pwv+J2i/Dn Tv2g7r4wfAmT
43+AvFPj74hfE34mfET4Z/Hefwv8ZNI8L/AH9nm2+Lnwsuf2ZPOwkMzhhqEM 6wdHLs3jShHM
sDQxVLHUcJjVFLEYeljKDlQxUKVXmhGvh51cPUS5qFavScK0+yc8NUlKeCrT xGEm3LDVqlKd
CdWjLWnOdGoo1KUpRabp1IwqQelSnTmpQj+z1FfiD8Mv+C1ngT4l+HPg9qVj 8IvsXiD4ufD/
AP4JseIrTwz/AMJ9rFz/AGT47/bZ+Kf7FvhP49fDr+2ZvhVYWV//AMMefDL/ AIKO/sLfFv8A
4S6WPTdH/aD/AOF//wDCBeDIPCniD4VfGC58Dc/pX/BZL4heGP2ePg78dvjx +yV4f8KXP7Vv
7MHw3/aZ/ZQ8FfAn44fEz9pLUfEunfE74t/se/AzRvB3xwsdN/ZJ+HvxE8Ae ILX4ift5fs6N
Lp37Pvww/a58Va34VtPjLdeDvB/ibxt4M+HHw++M/QSfu9RX5A/C/wD4KQft CfG3/hA/hn8P
v2LP+EX/AGmvFf8AwvvxHdeEf2lPGv7TH7K/wJ1P4Wfs9f8ADMsHjDx/8MPi L8Yv2EdF/aa8
a/2hrX7YHwd8HaDZ+MP2I/hV4c1Pxj4N/aMsLXxrNovwx+H3iL42/L8n7S/x l8Of8Ezf+CFP
iW8/aJ/af8Bav+014f8A2XvDP7Qfxj+BHwbg/a6/af8AGmnap/wS9/aD+POo 3Ol+CPFf7PX7
XPiTxn4g8V/GT4Y+Bdf8f+LLH4QeLPFUHh+LxTruqazoukN4h1+1AP6HqK/M D9i39sXx38TL
X9kXwB49s/8AhPP+Gl/2f/20P2k/hl8fJ7jR/DesfEL9nH4A/tHfs/8Aw+/Z T+Jvi74eeH/D
Gj6LY/ED9qb9mX9pz4SfHf4i2um6X8I7X4e+Ox4i8LR/A34ef2ufh78M/wAw fgf/AMFlfiTd
x+NfGHhn4D/ED4t/ED9rX4gfDn9oT4YfB7UNW/ax+KfgT9n/AOCdv/wSo/4I 9/Fj4ieA9M1v
9kz9jb9sn4tWP2H4tftk6NqOhLbfszeB/hF4m1jxF8UvGPizx34A+IGt+FPB vxQAP6faK/MD
9pD4vfF34r+GP+CY9t8JPiB+0B+xd/w2j+0Bp+mfEJJ/hv8ABOz/AGjvAPgS 8/4J9/tf/tQQ
/C3xd4L+P3ww+P3w/wDAfxA0j4gfCPwHo3xF0+TwnrWsaHdaL4i8M6brtv8A aLi+c/Zs/bF8
d337WPjD9gT4k2f/AAsbxb8Hv+GhtPuf2kp7jR/CmsfEbR/gf8Nv+CZHxW8J 6n4u+FvhnwxZ
+EtP+IHiXwl/wUo0Pwv8Rdd8E6j4V8Car47+CHiL4g+Bvhb8OfCXxh0b4P8A wXAP0/or8Yf2
aP8AgrH4q/aL+Bnxd/aBuP2bPD/wk+Hfww+D/wCz74k0rxJ43+O+o6/p3xK+ Pv7U/wCx7+x9
+1H8Ff2cvAnhz4Y/A7x18ZPEHiC98SftTw/BbX7/AEP4Qaz408R+Kp/gbafs 6fCr9or4ifGX
xp8J/gN5/wDAT/gpX+0r+1H+1x+z/wDDD4d/Bbw/4FttD8P/ALZPhT9sP4R/ FjxB8b/hDp2h
6j8Ktb/4JZePPB3xe+D2pfG79iH4c/tLeOPEHhH4LftqSWuifCv4r/An9k3w r8QfFXjHxk1x
4z1LwT4N+Enxa8bgH7vUV+IP7MH/AAVK8d/E34J/AL4tz/Bj+3/gl/xrr+Bv x8+Knjn43aP/
AMNHWX7R37e3wi/Y98Z/Dy68K/CH4ffs0eBvgl8Vfh/p+p/twfAGP4r/ABNh 8e/sx3Vldf8A
C7dS+Hv7Nn9meBPh74U+Jvv/AOxD+3z8U/2l/wDhmz/hdP7Pnw/+Cf8Aw2N+ yBdftrfs8f8A
Cr/2gfEfx8z8LPDv/DO//CaaB8Z/+Er/AGef2dv+Fd/ECw/4ar+Dn/CL6V4H /wCFxeHPEn2f
4mf2r4r8I/8ACJ+Fv+FhgH6f0V+cHwPn+N/7WXiDWv2hR+1D8YPgZ8O/AX7T /wC0L8FNC/Zo
+E/hH9mrVPh74y8K/sgftQfEv9njX9Q+MPjr4v8A7P3xR+MmveIPjh4k+Eni rxNrd18IvH3w
K07wL8M/Fng34aeFdKf4ieAfEv7QHxV+YNR/4K2fFO1+HXwU8f2n7Kfw/uf+ G0fh/wDAr4xf
sLaTcftOeI7P/hMfhZ8cP2p/2JP2aLG6/ayv4v2Yr3/hmr4geH/+HgPwF8a3 fg/4P2f7Ynhy
/wD7F+L3hyH4hW//AAifgzXviUAft9RX4w/Er/gqn8QvhZBq/g3xv+z/APB/ 4efFb4afGDxf
8JP2gfiT8Wf2lPiZ4G/4J1fBrUdB+DX7OPx38KR+I/28NP8A2PPFtz4S8QfF rwT+1p8HNF+F
Wm/Hn9nb4B+FfHHxQ8PfG74X6B491DxT4W+Dtt+0Bz/wy/b5/bJ0Tw5otr4j /Z8+H/x+1P45
/wDBT/8Abr/Yp/Zo1vRP2gbH4e+I7jw58Fvin/wUj1fQdf8Ajp4Wv/2edA8J fC/4f/BTwl+y
N4K+Hur6r4A8YftB/FPxx8LH8U/GKz8KeM/jboek/Av4tgH7fUV+EP7aP/BX yf4Da3+0x4B0
r4Z+INZ8E+HPg/8AtZWPwb/aM+Cl78ZZ57v4+/s1fsj/ABr/AGjfH/gvUPiB 8Yf2EdX/AGD/
AA74g8B3/wCz58avhpdJ4L/aF/bC8aeD/jL4L0rwz8Tv2X7q20r45+H/AIPc /wDtTf8ABUr9
o7wT+yx+1Z8VNP8Agx8P/hB4fuP+HrP7Pf7I3xn8G/G66+MHxTtv2jv2A/h1 +3J4j0jx58WP
gJ49/Zo8D/DLwZ8P9fsv2Gvil4r01tM+L3x0urbxHe/DTwZrvgTW/D/ijxf4 n8EgH7/UV5/8
LdS+Ker+BNC1D41+Dfh/8P8A4m3H9p/8JN4R+FvxL8R/GDwJpHlaxqEGjf2F 8RfFnwn+B3iD
xF9v8PxaVqep/wBofC3wv/ZGsXuoaFa/23ZaZbeItX9AoAKKKKACiiigAooo oAKKKKACiiig
Ark7fwF4FtPs32XwX4TtvsX2H7H9n8OaPD9k/sz/AIRf+zfs3l2a+R/Z3/CE eC/sPlbPsn/C
IeF/s/l/2BpP2TrKKTSe6T9Un+Y7tbNo888R/CT4XeLvBWufDjxL8PPBms+A vEtvp1tr3hC9
8N6S/h/VI9HtdIsdEa60xbVbVrjQrXw94fh0K7WNbrRF0DQzpc1o2kac1t+Z nhj/AIJo6Mvx
48TeHPGsdx4i/Y08N6Fofib4WfDnUfE2s3d1eeNNYuPs9/4L8VaodcfxRr/h D4dP4dvdctLL
X5PsXiK0+IXhrSL7UvEg8N+MbW+/Xaiumhiq+GhUp0ZuEaiasvsN2TnT/kqO KcHNa8sn1UXH
xczyDKs3r4TE4/Cwr1cJUhOLdl7eFOTqU8NirK+IwkMR7PFLDzbpuvSg5KVO VanV+Wf2pNF0
fw3+y94t8O+HdJ0zQfD+g6Z4E0XQ9D0WwtdL0fRdH0vxf4UsdM0nSdMsYoLL TtM06yggs7Cw
s4IbW0tYYre3ijijRB/IF+y5+yf8WfgT+z5P8B1/ZY/YG8I6hq/wO8BfCf4h fEvw14r8S+Nb
P4469oOmaR4E17xf8cfheP2WfhDP8RNIufDGufEjx1deEdb+K15eeL9eu2+G t54w8Laf4/17
4qeFf7kdY0XR/EOnXGj6/pOma5pN55P2vS9YsLXU9Ouvs88V1B9osr2Ke2n8 i5ghuIfNiby5
4Ypk2yRow4f/AIUx8Hv+iUfDX/whfC//AMq63w2LhRi1OM5z55y5k47VIwUk 3JN3fJdtNN33
PTdJJRjBRhCEYxjFK0YqF+WMVGyUUrJJKyS0tZH8gHw+/Zu+LPwk8X/AnWfD knw78b6f8FtI
+M3wTuNQ8SeKfEvhTxf8QPhN8evG3wH+J3in9oHx5qlj4B8ZQeIv2ntO8T/C PV4PiHoLrZeG
v2jfG3ivXvjrqPxN+C2oeJLr4T6P03xZ/wCCfnxZ/bh+PPivTdO+JvxQ0L4f 3n7JHiz4M6b4
I+Dl98BNI17UPDnxZ8ZSwftTN4y1L45fCzxVDDpHjDRdG/Zk0jwffeEPFdn4 n0W88NeMp9Pt
dAW+utS1z+tn/hTHwe/6JR8Nf/CF8L//ACrr54+MHgzwf4Q1/Vv+ET8J+GvD H9ofsp/tTfb/
APhHdC0vRft32S9+CX2X7Z/Ztrbfafs32m5+z+dv8n7RP5e3zZN27x1OpH2U Kcouco2cpXir
KMdVFxbSilo3uk73EqTTu2nZPbfv6b+XV+Vv5v8ASf8Aglj/AMFNtU+FHx5+ CvxM+H/w88Uf
8NjfCQWfx9+O9j8VvA+m+KvAPxl1r9i74a/sv+ML7wL8FNO0nSfCXxP8JX/i 34U2HxCs9Uu/
ib8Cp007xxqnh6DwLpX/AAhun3PizrvFv/BMn/goZ8SPEfxO+NGs/A74efD3 423Pwk/Zz/4U
pZeGvjv4Y8b+HPBnx2/Zt+Kn7VnjXSv+Eg8f3WifDrxafhJ8U/CXxo8M/DP4 uf8ACJ+F9D8Y
+IfhX43+O3wvtvs2majp/iTxL9beRB/zxi/79p/hR5EH/PGL/v2n+FeisHX6 4mD9aDbu7639
te6c5tO97yv0jy7ewXZdPtPpby8vwVrXZ8N3P/BHf9tH4cfFTwB8UPgz8KtK 8X/8KY8JfAGD
wrofxY+Mnw/8NeI/jH478E+HP+CgPgn4veL/AIxfEnwraeLP7J8W+Pf+G2U+ Mmt/EbTvAPjb
WfiV8VNE8ZWXifw74Y/4S8eObP6I8J/8Evf2lvDn7R/ib4pS/DHWLn4ZW/8A bPj/AOGHw5b4
hfCebRvBfx2+LlrbeHfjv4107wg3iSDw/wCHPtXh/wAF6PrvgfxJ4e1BfGM/ jv8AaV/bf1Px
je6lZfGO1gteQ/aO/aV+Hn7L+m/C3WfiFoXirUNI+Kfxd0T4SQ6r4W0zQ7vT fAn9o+FPGnjz
xB8TfiRfa3r3h+18MfCL4b+B/h94s8Z/Ezxokuo/8If4U0bUPEV7pr6Rp2pX lkav+1R+z/4Q
n+K3/CzviD4L+DWkfCP4u6J8Edb8VfGDxX4K+HnhTXfHviD4L/Dz476bp/hP XPEHiG2tdT87
wP8AEbT8Wl3/AGbrMmpeH/Ff2fSZtI0qHWL6Vh6kW4/WqS5ZJtOg7Rk1zLV1 uqV7N29yLsnc
PYJ9trP3ne2j7evrfz0/Z39lfwh8Zfgf/wAJ3/wlnwJ8e6h/wlH/AAjH2D/h HfE/wTu/J/sX
/hIftX2z+0vi3pPl+Z/a1t9n8n7Rv2T+Z5W2PzPrn/hZvjX/AKN3+MX/AIO/ 2f8A/wCfnX4D
f8J18PP7Z/4Rz/hMfBf/AAkP/CX/APCvv7B/4SHQ/wC2f+E9/wCEC/4Wp/wh H9l/bPt3/CX/
APCsP+Lj/wDCNeR/bP8AwgX/ABWH2L/hHv8AiY1yHi74z/Dzwz4C8MeP9Kuo viLY/EX+xbb4
P6N8NZ9D8Uaz8atZ8UaNc+IvCmi/C6UarZeHte/t7w9ZX3ilvE95r+leAvC3 gLSvEPxP8eeL
vCfww8J+LPGeh41ctdWcqtTEw5nbmtSaXuqMdlW3Ssrb3t3KjScUkrWXm+ru +nm/w76f0Uf8
LN8a/wDRu/xi/wDB3+z/AP8Az86P+Fm+Nf8Ao3f4xf8Ag7/Z/wD/AJ+dfyma 1+3L4D+HPj34
beE/2kPBsX7IGkfEnwh8bfEWleIP2nPi1+z34S87UvhBrP7P2m2OjaRN4D+K fxL8D6r/AMJt
a/GzXb2wiufiFpHivTP+FXa+83gy90jVLPW7b0XVf2oPBGh/HTU/hBrllofh 3QfCvw5+OfxC
8efE3xB478C2mg+DrL4IaR+yd4m1N9bsNP1bVp/C+kXnhf8AanstY1K9+JV5 8O9e0Cy8EzeI
F8J6x4A8Z+EPHN/j/ZlPW+JirSjFp0ZpqUknFNOqmrp7tJd2tbPlfl0W762/ u+f9a2/pu/4W
b41/6N3+MX/g7/Z//wDn50f8LN8a/wDRu/xi/wDB3+z/AP8Az86/mp/Z6/aO +Hn7Ss/xsvvh
jqfgvxf4H+E/xds/hXonxD8B+NND8feFPiF5nwX+DvxV1LXtK1fw/E+kWn9j av8AFPUPAd9p
dpquu+TqXg68vLjUba6vptE0j6L8iD/njF/37T/CqjlCkk44iLTvZqlKzs7O 377VXvZ7Oya0
Yckv7v3vy8vX8O+n7l/8LN8a/wDRu/xi/wDB3+z/AP8Az86P+Fm+Nf8Ao3f4 xf8Ag7/Z/wD/
AJ+dfhp5EH/PGL/v2n+FHkQf88Yv+/af4VX9jf8AT+P/AIKl/wDLvX+no+SX 9373/l6/09P3
L/4Wb41/6N3+MX/g7/Z//wDn50f8LN8a/wDRu/xi/wDB3+z/AP8Az86/DTyI P+eMX/ftP8KP
Ig/54xf9+0/wo/sb/p/H/wAFS/8Al3r/AE9Dkl/d+9/5ev8AT0/cv/hZvjX/ AKN3+MX/AIO/
2f8A/wCfnR/ws3xr/wBG7/GL/wAHf7P/AP8APzr8NPIg/wCeMX/ftP8ACjyI P+eMX/ftP8KP
7G/6fx/8FS/+Xev9PQ5Jf3fvf+Xr/T0/cv8A4Wb41/6N3+MX/g7/AGf/AP5+ dH/CzfGv/Ru/
xi/8Hf7P/wD8/Ovw08iD/njF/wB+0/wo8iD/AJ4xf9+0/wAKP7G/6fx/8FS/ +Xev9PQ5Jf3f
vf8Al6/09P3L/wCFm+Nf+jd/jF/4O/2f/wD5+dH/AAs3xr/0bv8AGL/wd/s/ /wDz86/DTyIP
+eMX/ftP8KPIg/54xf8AftP8KP7G/wCn8f8AwVL/AOXev9PQ5Jf3fvf+Xr/T 0/cv/hZvjX/o
3f4xf+Dv9n//AOfnXm3xU8deKNZ0Hwzpuo/Bn4leE7O5+MX7P3na/r+qfB+5 0iw8n47/AA4n
j+1w+Fvit4l15/tUsSWUH2HRL3bc3ML3X2azW4u4Pwg/aB+JsHwK+Avxt+N3 /CNxeKf+FOfC
L4k/FT/hGP7QTRP+Ej/4V74N1rxd/YP9tf2bq/8AZH9r/wBkf2f/AGp/ZOqf 2f8AaPtf9nXv
k/ZpYv2Fv2pfgl+2TofwA+O3wI8Qx674S174xfCSx1LTryG2sfFngXxXZ/EP wXNrngPx3osF
zeHQPF+gi9tWvLNLu803U9NvdK8TeGdV1/whr/h/xBquVTLI0lJvERc4U51V D2bTlGCu7N1X
10bs7aNrUThJfy7X3fS1+n9ad9P6Hfj/APBj/hd3hLw3o1r4k/4RPxD4G+Jn w6+Lvg3WrjR/
+Ei0aHxj8MfE9l4p8PQeJvDseq+H77XfDN1e2a2+s6XpXibwvqlzayEWPiDT ZVEp8XuP2XPi
JN8Z4vjm3xL+C974403xf8W9W0DXtZ/ZM8CX3i/TfA3ij4bDwR8IvhjL8R7P xdpXxCfQ/hdr
dzrPivxTrOl+JNE8RfFO11q78GDUPAvhrdby/bVfnB+0t8d7zWPiV4R8E/Bf 9oPxf8PZPhV8
Ufh54W/aQv8AwT4W8GeK/CWkp8Vte8P2vg/4feMNS8V/AD4ynT/H3iWytdXg 8NnQPEXgLRPB
kms2H/C29b0y88d/CC31fz8TxVX4byPNMwxGIjRyfKcvzDEY+rPLaOPjh8Jj I0cNXjOpLB4m
eHp4ut9Vw0a9adDB4XEVKWIxGJwdKNXFU+P+ysPmGOwtKNKVTG4vE4Wnh4Qx dTDyq1sPKdWl
KMI4ijGrKhD2tWUIRqVqtKE6cKdZuNKX2B8Afg7o37P3wZ+HPwX8P6rqeu6R 8OvDVn4dtNY1
hbWPUdSMDST3F5cRWUMFtB591PO8NvEj/Z7cxQPPdSRvcy+f+Gf2Nv2ePCHx lufjtoPg7xBb
+Nn8QeLPGek6He/FP4t6z8GvBPxC8fwazb/EH4qfC/8AZ01rx1qH7Pnwm+MH xBj8V+PW8ffF
74ZfDDwl8TPG0/xU+Ml14o8V6tc/GX4pzeL+0/Z6+J2sfGH4TeFPH+taNb6Z c65p9rcQalpd
tr1j4X8YWctna3EHjLwVYeMNN0HxxZeEtcM7tpEPjDw7o+pP5E9zpMvijwjP 4b8c+KfK/wBn
v9uj9n/9qDx348+G3wkg/aA/4S34X7oPiFbfFL9jv9r/APZ/0fwfrH9j+BPE 0PhHXfFnx++B
fwy8JWXxAvfCXxN8B+NtM+HUmuf8J3qvgTxNp/jnTfDt34S+0azD5+EzmnxH hqGf0qtWvTzq
lHNYV61GVCrXjj19aVadKcIODq+19ppFQakpU7wcW+yeC/s2csvcI0vqL+qe zhJTjTWH/dKm
pJyvyKHLq3JNWlaSaPQNG/Zc+BPh/wD4Vx/ZHgb7J/wqT9oD41ftR/D7/ipv GNx/wj/x2/aI
/wCF+/8AC4vHP+leIZv7V/4TD/hqD46f8Uzrf9peDvD/APwnH/FLeHtE/wCE Z8H/APCP+f3f
7BX7J174E+D/AMNrj4U/8Ul+z/8As/zfsxfBS2g8dfEm01j4ZfCL+2PgL4m0 q08I+LLXxjD4
t0r4geD/ABb+y/8AAHxt8OvjZDrn/C7Phl47+F/h3xz8PfiF4Z8W/wBoaze/ X9FdBJ8QXP8A
wTr/AGVZ/CujeGrfQPjBour6N4g8TeJj8YfC37Vf7V3g/wDag8R6j4y07wno viq28f8A7XXh
X42aP+1H8TPD+v6H8OvhRoGqeE/iJ8X/ABR4VuvD/wAFfgRoUmjHSPgX8IrP wX7B4Z/Zc+BP
g7wd+y54A8OeBv7O8JfsXf8ACPf8M0aT/wAJN4xvP+Fa/wDCK/Anxz+zRoP+ n3/iG61Pxj9g
+CXxK8a+Cv8Aiv73xV9q/tr/AISO9+0eLdO0nXrDf+Gnxr8K/FTxp+0L4F8P af4gs9X/AGa/
jBovwU8dXGs2unW+nat4q174BfA/9oyz1DwnNY6rqNzfeH4/BPx+8HaXc3Ws Weg6inirTfE1
jFpU2kWel65rPQeDfil4E+IHiP4s+E/COu/2v4g+B3xA034W/FLT/wCzNYsP +EX8d6v8LPhp
8a9P0L7Vqen2Vlrf2j4ZfGD4deJv7T8O3Or6PF/wkX9jT6hF4g0jXdK0wA8A 8a/sI/sz+OPt
ss/hf4geB9Tu/iB4/wDiXD4j+CPx/wD2hP2d/GOieI/i3/wjl78YNN8JeNfg L8U/hv4t8FfD
/wCMvi3wj4d+K3xl+E/hHWtE+Fnxb+O2mp+0B8RfBvib423F34/uPP8ASP8A gl/+xZ4X8HaJ
4J8CfDr4gfC2y8N/8ItBoXif4O/tJftO/Bv4p6Zo/hD4E/Av9mzTPCNr8afh b8Y/CPxgX4f6
j8H/ANmT9nvQ/GHw6bxy3gT4geI/g38PfiT488O+JPib4b0/xhF9f/Fn4peB Pgd8LPiX8a/i
lrv/AAi/wy+D/wAP/GXxS+Ivib+zNY1v/hHfAnw/8Oal4s8Xa7/Y3h3T9X8Q av8A2R4f0jUN
Q/szQtK1PWL/AOz/AGXTNPvb2WC2l8g+En7YXwQ+Nmox6F4Hb4wWfikeINN0 DUfA/wASf2Z/
2lfgr8QvDUGveFfHvi3wx438bfDz4zfCTwD428B/B/xjbfC74h+GvA3xy8Z6 BoPwa8cfEzwf
rnwg8JeO9Z+K1m/gwgB8WP2Nv2ePjH8Pfg98LPEPg7xB4L8E/s9+INE8TfAz TvgD8U/i3+y5
qPwj1Hw58M/GXwZ0S2+Hvif9mnx18JvFPhTw/p/wp+IPjH4fQ+E9H1q18Kt4 V1y40mXRpLaC
zS25/wARfsI/sz+IvAnw6+H8fhf4geDLL4Vf8Jd/whvjT4SfH/8AaE+CXxsi /wCFkaxB4p+L
H/CS/tD/AAe+Kfgb49ePf+F1eOrPTfif8df+E9+JHiX/AIXj8XdF8P8Axe+L f/CZfE3w/oni
uw+v68A+A37SHgT9oi18Z3PgnR/iBpX/AAgnxA+L/wAOtZfxd4I1jR9Hu9Y+ C/7R3x3/AGX/
ABNP4d8aW0epfD/xN9r+IH7O/jnWYPDuh+LL7x34Z8Cax8OvE3xJ8I+BP+Fj eE7HUgDz/wAD
fsFfsnfDX4J+Kv2ePBHwp/sD4S+Mf+FUT6roEHjr4k3WsWGsfAj4RfBL4G/B Txd4R8d6h4xu
/iB4A+IHwm+H/wCzh8DT8OviL4E8UeHPHfg7x38NfDvxc0DxFYfFqO68b3XP +Av+Cdf7Kvw0
1HTfEPhLQPjBB42034wSfHGX4o65+1X+1d4x+MviHxpdeFfhJ4J1jRfHPxo8 Y/GzXvit8Q/g
/wCKfC3wD+B+j+Nv2evHfjHxH8AvHMHwh+G0vjD4aa5c+C/D0+n/AG/RQB8Q eDP+Ccn7Hvw8
1H4V3ngv4ZeIPD+kfBzw/wDCHQPCHw+svjN8c2+DWqT/AAA8K+FPBXwQ8b/F D4G3HxKm+Dfx
w+MHwo8N/D74Y2PgH45fGrwL8QPjL4Yn+Efwb1TSvHdtq/wf+Gd94V9g+HH7 LnwJ+En/AAoL
/hX3gb/hH/8Ahl/9n/Wf2XPgX/xU3jHVf+EH+BPiD/hSv9r+Bv8Aid+IdS/4 Sb7X/wAM7/B3
/ipvGH/CQeMbf/hD/wDRfEMP/CQeKf7b9/ooA+YPE37HvwQ8T/GW2+PRX4we EPiIPEHhPxZr
qfCf9pj9pX4K/D34h+KvBMGjadoHib4w/Bn4QfFvwP8ABv42eIB4b8NeFfAm t6z8XfAXjbUf
FXwz8H+Dfhd4qudZ+HfhDw14Y0vz/wAP/wDBOT9j3w1Osun/AAy8QXltpviD 4Y6/4H0TxJ8Z
vjn4x8K/BiD4OfGX4cfH/wCHngj9nLwh4t+JWt+Fv2Z/g/o3xW+Dfwd8Q3/w N/Z+0f4a/Brx
Pp3wh+FXg7xX4E1zwT8OPBnhzRPt+igD5A+IX7CP7M/xR8R+MPEfjLwv8QLr /hZXxAuviX8W
PCWifH/9oTwd8LPjT4jv/hZ8HfgjqWm/HT4NeDfinoHwl+N/w/1X4S/Ab4ae ANX+E/xY8FeM
fhZq3hyw8U2epeDbr/hZXxLfxf0Glfsbfs8aH8TLX4taV4O8QWfinS/jBqHx +8PaVH8U/i23
wz8HfGXXvh78a/hj4x+IXgP4Ky+OpPg34A8QfEnw3+0X8atS+Lc3gvwHoUHx e+IXj3Uvi58T
rfxZ8VrPR/Gmm/T9FAHwB8TP+CX/AOxZ8YPEfijxB8Qvh18QNZsvF/8Awuef V/hzZ/tJftO+
G/gTb6x+0V8LPih8Gfjp4u8Ofs6+FvjHovwF8G/ED4q+Bfjb8Yl8a/EXwf8A DjQvHet+Mfij
4/8AiddeIm+JvizW/F977Bqf7F/7MGveFfD3gXxH8IPD/inwT4Y+MH7Qfx30 7wd4svfEHirw
refEz9qvTv2htH/aD1TxN4e8RaxqekeM/D/xN0j9q34/6XrPgDxfZ658PbPT viHc2OieFtLt
tA8KRaD9P0UAef8Awt+Gnhz4P+BNC+HXhPUviBq/h/w7/af9n6h8Uvix8U/j j47uP7X1jUNd
uv7d+KXxr8ZfED4m+KPKvdTuYNM/4Sbxdq/9iaPFp/h3RvsHh/SNK0yy9Aoo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAr5T/aC/5D91/wBmp/tXf+lvwLr6 srwvxro+neIf
jR4I0DWLf7ZpOufAr9oLR9UtPOnt/tWnan4r/Z8sr638+1lguYPPtp5YvOt5 oZ492+GWORVc
XTajOMntF3dt7LUT1TXdM/Euiv03/wCFK/DL/ozr4z/+HM+HX/0TVH/Clfhl /wBGdfGf/wAO
Z8Ov/omq+h/tbD/8+63/AJS/+W+v9PTX2j/lX/gX/A9f6en4e/Hz4I/8Lq8Q /s8/2lp/hDXf
A/w5+LvjLxd8TvCvjO0/tPTfGHgLxf8AstftH/AjUPDEWh3Gk6rpHiD+0tX+ Muif2zoviD7D
o154Uh8Redc3N1HaaPqn5oaF/wAE8P2kdA8Tax8QfEnizSPi94o0n4jfFrQP Btrb/tgftT/s
z+MPF/wS8R/CT9iz4R/Dn4i/GT9oX4L+DdS8f+IfjpFoP7GGj3vxf8BR+E9R +F3xB8cfEnVv
iHpviXw3P4M8O+Fbz+vH/hSvwy/6M6+M/wD4cz4df/RNUf8AClfhl/0Z18Z/ /DmfDr/6JqsZ
5hhJu8qda/Mpf8ubXSgldOo07cqsmmt/5mLn/u+fxPy8vL8PNn8tdj/wT08Y eAotYuPhV470
jQdQ8AfDn4P+LP2edHs9c8ceG/h7p/7VXw1+G3wd+EF9e+MdAvpPiH410f4F 6j8Kf2VPgt8I
bFLH4meN/jU3wc/aB/bj+HXiL4ha9p/xT8PXmm/Uepfsx/8ACH/B/wDZh8Ef B/V/tfiH9i7/
AIQ29+C0XxKv8aN44/4Qn4IeM/2e38NfFHW/C+gJfaX/AMJd8MPH/iuyXxv4 T8NT/wDCD+Pb
nw98QT8PvH3h7w3qXwn8Yfvj/wAKV+GX/RnXxn/8OZ8Ov/omqP8AhSvwy/6M 6+M//hzPh1/9
E1Qswwcb2pVlft7LT3lJNfvdGmlb/BHzDn/ur7/T+75fgvl+B3hHwJ8evFfx 6+F/xu+LvhP4
RfD/AP4V/wDCL9pD4V3Phj4cfFrxl8Wv7S/4W14y/ZO8XeEdeg1rxP8AA/4L +R5H/Cl/H2n+
I9Lk0mT+zfM8H3emajrv9u61beFPzo+GH/BMj49eBdN+H0uoeLfhFeav8M/C HwevdNsbPXvG
X9m+JPHvwO8Kf8EcrzRPDV9qs3gGO68PeEPG3jj/AIJvfE7w7qvje30bxFrP g3wp488B+M7T
4feMtXXxB4D0n+wj/hSvwy/6M6+M/wD4cz4df/RNUf8AClfhl/0Z18Z//Dmf Dr/6JqlLH4Se
soYhu9270U22oJvSoltBbJbebsc/93/yb08vL8PNn4S/s0fD74t+EtU/aM8b fGbRvhz4Z8Uf
HL46ab8TrDwv8MfH3ib4maD4f0HRv2efgF8FLW0u/F3ir4X/AAg1C+1e+1H4 Qaprtxbw+DLe
ysbLV9PtI9Qv54riRfqOv03/AOFK/DL/AKM6+M//AIcz4df/AETVH/Clfhl/ 0Z18Z/8Aw5nw
6/8Aomq1jmuHirclZ6ttv2N227tu1RLdvZJbaLoe0f8AL+Pp/d9f6en5kUV+ m/8AwpX4Zf8A
RnXxn/8ADmfDr/6Jqj/hSvwy/wCjOvjP/wCHM+HX/wBE1Vf2th/+fdb/AMpf /LfX+no/aP8A
lX/gX/A9f6en5kUV+m//AApX4Zf9GdfGf/w5nw6/+iao/wCFK/DL/ozr4z/+ HM+HX/0TVH9r
Yf8A591v/KX/AMt9f6eh7R/yr/wL/gev9PT8yKK/Tf8A4Ur8Mv8Aozr4z/8A hzPh1/8ARNUf
8KV+GX/RnXxn/wDDmfDr/wCiao/tbD/8+63/AJS/+W+v9PQ9o/5V/wCBf8D1 /p6fmRRX6b/8
KV+GX/RnXxn/APDmfDr/AOiao/4Ur8Mv+jOvjP8A+HM+HX/0TVH9rYf/AJ91 v/KX/wAt9f6e
h7R/yr/wL/gev9PT8yKK/Tf/AIUr8Mv+jOvjP/4cz4df/RNUf8KV+GX/AEZ1 8Z//AA5nw6/+
iao/tbD/APPut/5S/wDlvr/T0PaP+Vf+Bf8AA9f6en5BfGH4Y6D8bPhJ8Uvg z4qu9X0/wv8A
Fz4c+N/hj4kv/D9xZWmvWWg+PfDOp+FdYu9EutS0/VtPttXttO1a4m024v8A S9Ssob1IZLrT
7yBZLeTqP2ZvhH8NvgMf2dfhB8IPB+keAvht4C+Jfwc0Twr4V0SOVbLTrJfi j4buriaa4upr
nUNW1fVtQubzWPEHiDWLzUNe8Sa9qGpeINf1LUta1K/v7j9Vf+FK/DL/AKM6 +M//AIcz4df/
AETVcz4m+GHgXw6/gnWNG/Zr+JvgDUrP4xfAn7N4t8Q+OfBesaPpP2j40+Ab Wb7Zp2k/HTxl
qFz9vgnl0y3+z+G9R8m6vYJ5fscEUl/a5Vcyw9SFSKp1FOdKdJSap6cyaSuq jajd3dk72Wjd
rJzbT91aq2/e3l/Vl8vpH40an8VNd1nRPgx8OvD/AIy8NWXxN8G/Ej/hIf2k /D+qeELe1+BL
6VoC2vhq/wBK0DxDp/iCXxl451rxXrGhQaP4budI0jSR4eh8U+JB4nW98Mro 97+f2pftbWOg
fEr4Nfs8+DvBGneJ/glrviz4ifs+/tBeIP2gLW88TfEjxzceB9Z/Yr/Zq8Oe IPiFcTeJbzx9
pWq+OfEH7S+ieGpZPi38HfHniz4wm3+Gus6zpnwy/Z0+KE37Tngr9h6+eNZ8 S/ss6p4s0X4g
anffBLxR8R/hzqHxQj8I+ILODwd4x+J/hjxBpN74S+D/AMYNK8DHS4dX8cQe K4tW1nwD8JfH
eg+FIm8Q3Ot614L+HWsWM2qatoGi3PPhsxy3DYTEPNMupVstoYHGvGTlU9nh 2p4bFupi8fUr
OUIRo0nT5akpwwmCpYWpilhKleVapLzK2ExVTEU5YXFzhialeh7GPKnOMY1a HLRw8YJOXNP2
nMlF18RKvGjLERpRhBdJ8AvjRoP7QXwp8K/Fbw5pWr6LpviW3uQ2nasLO6W3 v9Ou5tO1IaL4
k0S61Pwh488MtfW07eG/iJ4A13xL8P8Axxo5tPEfg7xJrWh39pey/mJ+0J+y H+0P8R/hJ/wV
X8IeFbLxB4ek/aU/bf8A2ZPjJ4Ni8J698JLjxV8Y/wBmr4afs8f8E1PB37RP gHwzo/xQi8Uf
Bu98QfF/w3+z1+0T8ANG+F/7UWiaf8EPiVqOpW3hz48WUP7PnjnWvEN5+uXg fxR4G8YeF9N1
v4beIvCfinwXuv8AR9H1fwPq2j634X3+GdTvPDWqaXpuoaDcXWk7vD+saRqH h+/sbWbOk6np
l5pVxFb3VlPBF1leZWnRq1atTDU3Sw9SpOdCm6ntvZ0pScqcPa2XtOWDS52k 5W5nqzspRqQp
041pqpVjCMalRQ5FOaSUpcibUeZ3fKtFeySWh/KFqH/BKH40TfCzX5fAf7OP xAi1PwJ+yB/w
Va1f9jLw58ffEn7Auj/FP9lf9sn4seHP+Cd1l+yZrfwV8Ffse+DPhN+yl+xr 8QL/AOKXwB+P
fxW+HHin9mXWvE9j4N8R6xrP7QHxQ+OngT42/Hvxd4A8KdB8Tf2SPA/ww/4K K+GPhR42/wCC
ZHh/9rj9lx/D/wC3945/ZC/ZK8DeCP2JdZ+Gfwp+Gd18L/8Agg7ovi34k/Db 4R/tJ/F74OfB
b4R+H1/aWtv2nI9c0Pw7caF8QtW+IXxU8bfES08E6tofxM8UeN7/APqdorM0 P5Yrv/gnV+2Y
nwW1P4QftR/CfxB+1j4W1L4wfBLx/wDE7xJ8JtK/4J/ftKfH34qfHP4U/wDB K/8A4JxfstaZ
8d/Dj/8ABWTSNZ+BL/B/VviT8K/21dC+Kvinxr4a8Lfthaz40m+COv8AgrS7 f4U+MfjBdasf
D/8A4JvftVD9mr43+Hvip8A/EF9+2h+0X8H/APgnh4x+Ln7YmjeIf2UfH/xl 8YfC/wCCHwQ/
4JnfC79tT/gn14s+KPxn8UeLdX+Jvxg+OWr/ALKX7SGsW3gT4v8Ag74hf8E6 vjVB8SfDMXx+
+NcmneO/iT4d0b+p2igD8IfBH7D/AMVvCv8AwSI/4KH/ALMHw8+Gfxg8O+Kf 2g/g/wDta6H+
z18BfjX4q/Yv8O+KvDGo/Ez9mS0+F2geBtP8BfsW+BfhL+w5+zb4f8a/FzTf EnjK18E/CnxJ
408K6pqPjzVfj78VPiTpHxW+LvxO8CfDz4g/an/4J4/tY/HXwB8W7z4H/sxf tAeCfD/iv4f/
ABK8DeHfhl+2J+1J8Nvj/wDtTzeO7n/gmB/wWc+A8/irU/2gPF37V37UN7L+ z/4y+Jv7Z37L
Hwz+D/wovv2m7nR/hl8Rbn9oP4pJ8EvhH4f8b/EX4s/FL+r2igD8Afjj/wAE 8LrwH8dtVtfg
Z+xT8P8Axb/wTr0z/hkv4i/E/wDYP+Duh/s4+BfhZ+09470fwd/wU9+HHxeg tf2c/iB4s+FP
7OXin4geFvGfxW/4J0/Gvxh4i+OeoeBNH8U+HP2cvh9qvg/xd41+Kv7P/wAN /A1p8gfs8/8A
BJ74i+IPjZ8Ev+F4fsGfD/w3+yLbftAax4/1z9nT4pW37LHjbwJ8N/hYvxd/ 4OX/AIifDbwV
rvwi8E+PPiT8Mrr/AIVtZft7fsPf2Z4c8A/8Jf4c8Nax420//hEr25h+Fvjm +8Gf1e0UAfxh
f8FAfgdY/Ar9n/8AaH+FH7Vv7Nvw/wDj54g+PP7P/wC3J+zp/wAEnvgtqnjj 9jbxV47/AGZ/
GOkftf8A/BQTVfgxffsu/Bz4+fGzwL4z0z/hNf2cv2jf+Ccngb4R/Dv9gPwr 8X/jtpej/AL4
a/BLXPhF4L8QfDT9n/wP4j/s9oooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACvHdb/AOTgPhl/2R345/8Aqa/s717FXjut /wDJwHwy/wCy
O/HP/wBTX9nemt/lL8mB7FXn1x8Vfh1F4Cl+KFp4v0fXvACIzQ+J/CM7eNNP 1Jxq39gC10T/
AIRKPWrjX9Qk17/iSQabokGoahcax/xK4LaS+/cV4X8WPGT698RpPhJ4psJ9 H8CW/h+DxJda
NeFFl+Olk0tvbanYQ3MRmspfhX4QvbzTtL+I3hVLk+KPFetavomiePdH8N/B /WdMtP2gPnrx
nqOkfDu1nmPjTx34uXUPHXinxt8I/gLjwW9p4l+NPi7xj4m+IWnCzs9L8L6f 4u8bNonjzxU3
iHRdN1zXbnwp4JttF0rxp4gtTceDofFml/h/FHjRlWRZ7jsiw9NVK2Dhicul KvQxCrwz2Twr
wlSeDlLC1quTU4TrwlLCyr5hmmJlQWAw9LL5Usyxf2eXcI1sXhKGJqyqJ13R xMYUeWVOWAca
vtIRxCVWnHGyapy/e+zwuDpKp9ZqyxMauFw/6R+H9e0fxVoOieJ/D1/Bquge I9I03XtD1S23
/ZtS0fWLOHUNMv7fzFSTyLyyuILiLeiP5ci7lVsga9fnN8X08V/Bvxd/wSG+ FOgeKdZ0fSpv
2ptQ+Enjuw8Oa5rOn6L448LeDv8Agl5+3v4gtPDviS1S5gPibwxB43+H3g7x nY6R4hivLWLx
N4U8MeIjbLrehabeWvx1o3x9/bQ8R/8ABR/9qn9lD4E/GH4P+DdI1L4wfHT4 jxeIf2jfg78V
v2lNO8F+FfgX+xB/wQxi0f4Y/Crwd4O/aj/ZstvAXh/xL42/bO+J/wAR/EjL rOtadP4qmv8A
UrXw/b6v4o8Q6xdfsuBniqmCwdTHU6dHG1MLh54ylRcnSpYqVKEsRTpOd5un Cq5xg5tycUub
W58jiFRjXrRw8pzoRq1FQnUSU50VOSpymo+6pyhyuSjopN20P3eor+aHxh+2 b8ff+CgX7PHw
n+Onh6H4P/BP9nzw1+2//wAEH7bx18EdZ8C+NPix8ZfFfir4+/Fv/glH+2pZ 6z4T/aLsfiv8
KvBPgXw/4Nuf2svB3w6ufDOsfsxfELUfE8Hwn8TeKovFnhqT4p6X4e+FX3/+ xV+2b8ffjb4q
/ZTvPi7D8H7vwT+3x+xB4w/bw+DPh74ceBfGngnxV+zl4V8I6j+yXK/wV+J3 jHxP8V/iTpH7
SPiDUtI/bJ8K2K/Fzwr4F/Zm06y1H4R+INUPwlvLb4p6do/wt6jI/V+ivwB+ FF94x+HvgjTf
2pvCnxd/aA8Y/tD/ABU/4K//ALRv7LjfC/x/+0X8dvi78LPiZ8Cbr/grh8cf gJ488DeCv2Zf
HfxE8TfDfwP/AMM2/sceC/FP7QPhzxN+zx4L+GvjH4Z+HP2Yr3xb408Q6p+z xYftCeA/iF8w
T/t5fthftX/B/wDZ01z4/wD7Pvh/4S/Bv9p34wf8Epf2sf2fL65vPgZ4R8Va L4V/4ev/APBM
6807wVo2l+FP24P2lvit+094fk8LfHzw5N4m+P8Arf7Of7D2nfD/AFHw34Tt /F/wYsPEn7Q/
h7wL8KgD+p2iv5Yr7/got/wUV/aH+A3wi8Uap8PPD/7K2kftaeIP+Cdfx8/Z X+Ieof8ACr9H
1Hwl4V+In/BST/gnh4Mufh7qvgf4Uf8ABRX4n/Hb9tH4P+Jfht+1DY6D8a/i DefDL/gnZp3/
AAitja+AvHXw88M6v+1Lo3hL4S/b+pft1ft2aL+1jrPwstvgt8P/ABv8BfgB +0B+yh+yL+0P
8YoNG+Dvwj8CeMvin+0D8Nv2YPGHij4neEfiF8XP+ChmkfE34M/2De/tYeE1 +HX7LWjfsi/t
jeI/irrHhTw78KvDP7Sdz46+N5uvgkAft9RRRQAUUUUAFFFeAftY+P8A4p/C j9lj9pb4pfAv
wV/wsr42/DX9n/4yeP8A4O/Dr/hHPEfjH/hPvin4O+HXiPxF8PvBX/CI+D73 TvFvir/hKvFu
naRoX/COeFtQsPEeufb/AOzNEvbXU7q1nQA9/or8Qf2nPhBa/Cj9l3wj+0P+ yj+1n+0B40+L
Xxr/AGgP+Canh3wz+0T8Rf2tf2jv2hPgn4+0f4+/8FEv2OrPWfiLB+z74T+P vgH9mVPh/wDF
fRdcuB4i8I/sy+F/gF4E1z4ReMfF3wj+Fs/w2+EvjS50FPP/ANoL4xftT/E2 1+OPw6+LV1+z
/c/DL9lP/gp//wAEWPgXbeKfh14P+Ivhfx38Wvin4r/aO/4I5ftD+LPFM/hT xN8QvG3h/wCE
3w/8J+IPjH49g8O6JH4u+LniPxxo/jrwj4d1LV/AF78ANZ8aftQAH7/UV+QP wn/bo/ai8Zft
9fFj4KeI/wBhL9r/AMLfDKw/Z/8A2K/EFn4Z8SeIv+Cdsv8AwpLWPit8aP21 PCfj/wCOvj/W
fBX7aPiXxB4g+H/jPw/8N/BWn2fhrwBqvxW8d6L/AMKO8a3Vn8JPDt74p8OX PxV3/wBhD4K6
Jd/GX4l/tM/Cz4k/tP3n7NP/AAj958Hf2dtL+Kf7ZX7XH7T/AMPf2mfCurwf C/x14q/bCs7H
9qL42/FS20nw+njbRta+DX7Mmq/D7wv4N07xd8M/D/xM/aF0n4kftAfBb9qX 4D3nwsAP1frx
345/8iVon/ZYv2d//WgPhlXsVeO/HP8A5ErRP+yxfs7/APrQHwypx3XqvzAz P2if2hvh3+zJ
8N7j4lfEjUY7PTX1Ww8OaHYG90zTrjxB4m1VLqaw0azvNZvNP0u2c2dhqOqX t1fXsEFlpGl6
lenzWtlgl/Pe7+LHww+ON94X8P8Awi8beHPF/wAd9K+M/wAQ/GvgDRovip+x x420XXLXSfjd
perWg1Tw34b8WfaNO0DWvhpq+teOvCvxM8JfDjWf2jPhZ8NPh1461fxDd+KP i/qF14E+Pv1f
+3l+x9of7bnwBv8A4P6nrcXhvWdN8S6N488E65eWM2raNZeL/D8GpWNtD4i0 aC80+fVNB1bR
9a1vQ9Ritr61vrFNTXWNNlGpabaK352f8E7f+CQWrfss/HKz/aA+KeqfD6Dx H4O0nxBpXgHw
r8Ltc8T+KrF7/wAVaRNoGr+J/E/izxP4O+Ht0y2ugX+r6NpXhGx8KzWi3GpT eIL/AMRXlxBp
mmaZ9euHfDziDw+z7C8RZniqeb1o4un/AGVThWhLGuNKnPKPq2Kw9ehXw8YY xe3nisPJYjCV
6Ea7nSVLD+1+Jxeccc5bxplUMoyfCYnIpPBynmdStFPBL2s1mkq1GdOpTqVP qzUKVCslSxMJ
qlTU5TxHs/1b/Zb8Bav8OPg1oXhnxFpOu6L4ittU8TLrVprcXgPS47u6s/EG oaPa+I9B8H/C
vUtT+Gfw+8NeM9K0zT/Gej+CPCE5fR4fEDS+NbjV/iZeeN9f1b8p9A/aH+N/ 7IMH/BR34u/G
r9pz9p/9snw3+y9+0/8AAv8AY/8Agr8GfFnw3/Zq0+DxJ4q/aV+DX/BPXxP8 OPFPiZ/2RP2K
fDPxx1jxBY/HH9rTVfCusy/DHwr8TNRtvg1cXJ8F/s1fGb4yaP4a07xJ+71e AeIP2XPgT4o0
f466Frfgb7TZftI/EDw18WPi3PB4m8Y6drGp/FPwT4E+Enw68BfEvwj4i03x DZ+IPhT8QPh5
4f8AgN8HtQ+HXjL4T6n4J8R/D/x38PfDvxS8G6lonxNtpPF0vwmBwGCyvB4X Lstw1PBYDBUK
eGweEpzrVIYfD0YqFKkqmIq1sRV5IJJ1cRWrYirK9SvWq1ZTnL7qtWrYirUr 4ipKtXrTlUq1
ZKEZVKkneUnGnCnShd6qFOEKcFaNOEIJRX5Qaj/wWL+LeheFbXxR4n/Yc8Qe ELb4ffB/9tL9
o79owfETxX+0P8D57P4BfsRad+yV4q+IHi/9kzwr+0b+xP8ABf4rftF+IPE3 hb9rHTtB8KaR
8Zvhl+x34LvPjL8KPif4CT4lTeCbPw/8Xde9gsP+ChX7U/i347Wf7JXw9/ZK /Z/1P9prwl/w
0J/wvTTfGX7ZnxF8JfAnwl/wpLwd+wH8S9I/4VP8WNE/Yg8dfED4sf8ACZfD /wD4KJ/B2fUv
+Ew+A3wS/wCES8Y+EviX4atf+Et0XTPC3jLxb9Pj/gnJ+x7L4V8UeEtV+GXi DxTbePPg/wDt
D/Aj4g+JfHPxm+Ofj74mfEf4Z/tV6d8I9C+OWl/En4v+NfiVr3xW+IfiDxT4 W+AfwV8D6H4/
8aeM9c+IXw4+Hvwu8E/Dz4Y+KfB3gnQLHQIvP/i5/wAEyfgh8Xf2oNE/aSvP E3xg8AXMnh/4
9SfEnRfgp8ff2lfgD4q+JnxM+Mvh/wDYY+H2k+PdQ+KfwH+OXwx8U6L4f8Ff Cn9hjwL4Iuvh
JYw3Hw98aajqOlfEDVNNsfG3hI6t4i6zM+APhT/wVO8Qah4R/aN+O3wg8K+I Pjfc/Hr9p/4D
+Pf2f/2efidqn7UGq/ELwN+zV47/AOCS3/BNz46+JNS8P/Dr9jT9lb/goV8R NA8P+BviJ8cP
DTfEePQvhhY/BDw98TPjk11r/wAW7Hxt8QvB+mfEvoPhb/wVn+Ker/Db9sn9 r+T4U/8ACwv2
RbL4gfsWab+yppE+ueI7f9o7SPGP7bX7J3/BMrxT8Ivgd4u+BfwW/Z7+LF7q nw/PxN/bF1Lx
18Rfiv4D+JP7Q/x20i61vxF4C+En7OXxgh8P+ANE1f8AR/Vf+Ccn7Ht5BdRe HPhl4g+ENzce
INP1+31v9nH4zfHP9l7xVoMGm/Br4KfACHwR4Q8X/s5/Er4XeKfBPwfuvhT+ zd8APD2r/A3w
hrGh/BrXdR+DPw18Y634E1Dxt4O0PxHZnh//AIJyfse+E/Cq+BfCvwy8QeGv BKfB/wCGPwVT
wd4f+M3xz0bwquifBPTvhxo/wZ+JK+HtO+JVtpC/tP8Awj0j4OfCLS/hj+2U LMftceAtO+Ff
w4sfCvxt0m28D+GItLAOf+AX7Tf7Qn7VH7LHxq8aeCvgN/wz/wDtNeEv+Fj+ APhn4d/aL8Hf
tMeEvgT4r+Kdp8OtG8XfC/xrYz/Gf4A/sr/tNeK/2f5ta8ZeHPCnxE8R3v7P Hwv8Rw+MfCXx
d8LeALLxbovhnwv8RfGX5wal+394m/YzdNR/aU8e/wDBR/xP4k8JeINc+JPx Z+BP7TOl/wDB
Lm3+IXh39njwr+wZ/wAFMP2kfD/jbwde/sOfCJ/hT488P/GHxT+xR8SPCmne BtR/aD+Hnxb0
H4mfBrwf4i8Qa54A+Deqat4Y/aM/Z/wB+zF8Ivhh8LPGvwh8FWnxA0zw/wDE j/hI5/H/AIwv
fjZ8bPEHx28Zax4o8OWfg688XeJP2mfEfxC1f9o3V/iBpHgzSPDngzwV8Rb3 4qS+O/h34O8G
eAPCngDxF4a8P/D/AMFadoPj+lf8E5P2PbOC1i8R/DLxB8Xrm38Qahr9xrf7 R3xm+Of7UPir
XoNS+DXxr+AE3gjxf4v/AGjPiV8UfFPjb4P2vwp/aR+P/h7SPgb4v1jXPg1o Wo/Gb4leMdE8
Caf428Y654jvAD5A8Uf8FE/20PBf7Q/h/wDZF8Q/sY/swH9oPxz4g+Adt4Fj 0b9vL4rah8Gr
rwr8avhJ/wAFIfiveaz4s+Il9/wT00jxt4b8QeFLb/gnD4x0a28M6P8AB7xh p3iOf4l+GbyX
xZ4ej0bVLefn/jd/wWVtfgz8ItB+LZ+A/wDwm/8Awr3/AIaVn/bK+HvgPVv2 jviZ47+BGj/s
n/Gz4k/AH4k+LvAk3wS/Y2+Lnw/1f4f+PPiB8Af2io/2e/iL+2X49/4J+eBP ilo/wzbUtb8R
fD3+y/jVb/Av1/8AZB/4JcaJ8B/iZqXx7+OvxY8QftGfHaDxB8NdV8BeKLnx l+1xdeFfh3B8
J/h7+1L8NfC11o1h+1b+2X+2r8Vr/wAQX/hb9tX9o/Q/E2n6n8bpvg1Lp3iP wnq/hH4KeC/i
T4f8R/Ebxz7B8TP+CX/7FnxZ8OeKPCfij4dfEDR/D/j7/hc8HxM0/wCF/wC0 l+078Ef+Fu6P
+0B8U/ih8a/ih4R+M918GPjH4BvfjJ8P9S+Jvxv+M/ibwv8ADr4oXPi3wJ8N f+Ft/EzRvhn4
d8IeH/HfijStUAPAP2YP21/2jr/WPBHhz45eAfh/4n8JfHf/AIKf/t/fsdfB T4qeHfindR+O
7XwJ+z347/4KZ+M9KvPiL8IbX9n/AMH+EvDH/CvvCX7Gvgj4I+EbfQPir8Rd Y+JWj6/P8WfH
fifw54t0bUPCnjHn9M/4K6ajN4g/azvtU/ZZ8QQ/Bv8AYn+D/wC0p8e/jx8U tD+LXhXVtRt/
h7+zn+1B/wAFKf2YT4c8DfD3VvD/AIZ1fxV8YPihq/8AwT/sfHXgnwxeap4e +Gem+FfHvxJs
/HXxn8J+JPhP8NtH/aU+3/Ef7CP7M/if/hP/ALV4X+IGh/8ACwviBZ/Fif8A 4QP4/wD7Qnwz
/wCFdfFNP+E1/wCEi+Jf7PX/AArr4p+Fv+GW/iB8UP8AhZnxN/4Xv4y/Zs/4 VR4j/aE/4WZ8
SP8AheWpfEL/AIT7xd/bJ8Iv2Cv2Tvgl4c+InhPwX8Kf7X8P/F/4f33wt+Le n/Fnx18Sfj5/
wtXwJq/xT/aL+NfiDQviXdfHXxj8R73x7/wlXxN/az/aH8TeMtT8V3Or6x4y /wCFl6lo3inU
NX8P6R4a0rRQDz/9hj9sn4k/tWf8LR0r4pfsyfED9n/xB8N/+EJ1Cz1nUvA/ 7WPh/wCFnjrR
/Hf/AAl1tb6Z4N8Tfti/sefsNfE3X/iB4MvfA+oXXxL0LQvgprHgTwv4c8Z/ CfUNM+KXiXxB
4t8T+E/AH3/XgHwL/Zi+EX7Ov/CU3Pw6tPiBqfiDxr/YkHinx78YvjZ8bP2j finrOj+F/wC1
5PCnhG6+Lf7Q/wAQvil8TV+H/hC98SeLtZ8H/DqDxZF4E8J+I/HXxC8TeHfD umeIPiB401LX
ff6ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACvHd
b/5OA+GX/ZHfjn/6mv7O9exV47rf/JwHwy/7I78c/wD1Nf2d6a3+UvyYHRfE r4beHPil4bPh
7xAb6yntL2LWfDXibRJbe08UeC/E9rbXdrYeKfC2oXdpf2trqtpbX19YXNrq FhqegeItB1LW
vCPi7RfEPg7xD4g8P6p5t+zr+zzoHwI8L3cE8PgzxB8SPEPiPx94m8cfE3w9 8P7LwPqni278
dfEDxD45FneRtrHinXn03QIdZsvDulW+r+LddlTTdC04/aI1jit7fi7j43eI /DPxu+I9n4on
vLr4V+Gb6z8JrYaB4Yude1jQ9XufAfw28a6T4hNhoNheeKtXs9SuvFPijQtd TToNcksn/wCE
IubTQdM0q08aeIxqfC/9oW+8Razd2XjvTLfQNG8R+MfEmlfDbXhouv8AhkPp 1v4r1PQfB+h+
NNH8TyNquj+IPF2lWml6x4c1q4g0rS/EGp6z/wAIhLo3hzxCPClv488apwxk tTPaPFE8rws8
+w+XVctpZpyS9usDiK1CvOi0mqdSUalCDpVqlOdfDU5Yilh6tKjisTCt3xzT MIZdUymOKqrL
quJp4ueFvHkdelCrThJSt7SMXGrNzpRmqVWap1KkJ1KNKUPafil8J/hZ8cfA mu/C341/DT4f
/GD4ZeKP7M/4Sb4dfFLwb4c+IHgTxF/Ymsaf4i0b+3fCPizTdX8P6v8A2R4g 0jStd0z+0NPu
PsGsaZp+p2vlXtlbTxc/8Nv2evgF8GtO8E6P8IPgd8H/AIU6R8NPD/jnwn8O dL+G3w08F+Bt
O8AeFfif4q0Px18SvDPgmx8L6Lpdt4V8P/EPxt4Y8NeMfHOjaFFYad4t8VeH tD8Q6/bahq+k
2F5b9T428bJ4MTw3HH4b8Q+K9T8V+IX8NaNo3hp/DkV9NfReHPEPiq4lluPF XiHwxpFvaW+k
eGNUlkkl1RZnmWCCCCZ5vlqR/FPwLD4Ws/F/iHxFpPgrSbrVtS8OTN401bR/ D32HxTomo6to
+ueGbi8utQOk3WraTq2g63YynSdS1LTr7+yrq/0bUNT0nyNQm9V1IJuLkk4q 7voktL+89NOa
N1e65lfdHDyt2aV76K2r+7fp2PItS/Yi/Yv1nxV8JPHWsfsifswat42+APh/ wF4T+BPjHUvg
F8Kb7xV8FfCvwr1GTWPhh4Z+EniG68Jy6v8ADjw/8ONXll1TwFo3g680bTvB +oySX3h62065
dpT3/wAOP2evgF8HPFXxO8dfCL4HfB/4V+NvjZ4gXxZ8ZvGPw4+GngvwP4q+ LnipNR8Qawni
b4neIfDGi6Xq/j3xAur+LPFWqLrPiq81bUV1HxL4gvhci51nUZbnT8efFbwp 4Eu9E0S71nw9
N4t8QeIfAujaX4PufEem6b4jvrHxn430nwdJrdhpMpn1O/tNIS91HVXFvYtD dpot7atd2YSe
7tes0bxd4U8RX2t6X4f8T+Htd1Pw1diw8R6do2tabqd94fvjNd24stbtLK5n uNKuzcWF9ALa
/jgmM1ldxbN9tMqCnBycFKPMrXV9dbu3raLbW6WrSTQcrtezt3+7/Na9TyHw B+yd+yx8KPin
41+Onwt/Zp/Z/wDhr8bfiV/wkf8AwsX4xeAPg38OvB3xT8ff8Jj4js/GHi7/ AITX4heHfDmn
eLfFX/CVeLdO0/xT4j/t3V7/APtzxHYWet6n9q1O1gukPDv7J37LHhDWPiL4 i8J/s0/s/wDh
fxB8YPiB4R+LHxb13w78G/h1omsfFH4p/D/x3P8AFLwF8S/iLqem+HLa98bf EDwT8Tbm5+Iv
hHxl4mn1PxH4b8d3E/i7RtSsvEEsmoN7/RViPANE/ZO/ZY8M/wDC9P8AhHP2 af2f/D//AA1B
/a//AA0v/Ynwb+HWlf8ADRH/AAkH/CU/29/wvT7B4ct/+Ft/23/wnHjX+1/+ E/8A+Eg/tL/h
MPFP2zzv+Eg1b7WaZ+yd+yxonjv4W/FLRv2af2f9I+JvwO+H+n/Cf4KfEXTP g38OrDx38H/h
ZpGj674d0r4afC3xda+HIvEHw/8Ah/pnh/xR4m0LT/BvhPUNI8OWWj+Itd0y 202Ky1fUILj3
+igAooooAKKKKACiiql/f2OlWN7qmqXtppumabaXN/qOo39zDZ2NhY2cL3F3 e3t3cPHb2tpa
28ck9zczyRwwQxvLK6orMDbcD5r039iL9i/RvFXxb8daP+yJ+zBpPjb4/eH/ AB74T+O3jHTf
gF8KbHxV8avCvxU1GPWPif4Z+LfiG18Jxav8R/D/AMR9Xii1Tx7o3jG81nTv GGoxx33iG21G
5RZR3/h/9nr4BeE/Cq+BfCvwO+D/AIa8Ep4g+GPixPB3h/4aeC9G8Kr4q+Ce nfDjR/gz4mXw
9p2i22kL4g+EekfBz4RaX8MdZFmNR8Bad8K/hxY+FbnSbbwP4Yi0tmo/GS00 HTbnxF4o8DeN
/CPg2C78O20fjLxO3gjSNIlh8UeK9B8K6Xf3emT+Nj4t8O2iHxBBruqJ4u8N eHr7RNFsNTXW
LKy1y3i0S41tf+K3hTTdN0290TWfD3im41TxD4D0a3sNK8R6bLNJY+NvFfw9 8PtrcP2Q373F
ppWmfEvwt4jISEQ3ljrWgA3dpb+INOvmz9rTs25JcseZppp8utmk0m0+V2aT vbS5XLLRWvd2
0s9dNG1ot1e+x1tt4T8K2firWfHVn4Z8P2vjbxH4f8M+E/EPjG20bToPFWu+ FfBeo+LNY8He
GdZ8QxWy6vqnh/wnq/j3x1qnhnRr68n07QdR8aeLL7S7a1ufEesS3ngHwU/Y i/Yv/Zr8Vah4
6/Zz/ZE/Zg+APjbVvD914T1Txj8FPgF8KfhX4q1LwrfajpWsX3hnUPEPgXwn oOr3nh+81fQt
D1S60a4vJNOuNR0bSr6a2e506zlh+iYdc0u413UfDUN1v1vSdJ0XXNQsvIuF +z6X4hvNfsNH
uvtLQraS/bLvwxrkXkQTyXFv9h8y6hgiubN7jk/C/wAStC8XXGgWelWmrLd6 14Tu/Fd/a3MF
mLjwb9j1Sy0N/DXjeC2v7mXw94sk1t9f0eHRpll36p4E8e6eblbvwxewmueK aXMrttLW92mo
tadVJpPs99mKz7ba/Jq9/u/rU9Crx345/wDIlaJ/2WL9nf8A9aA+GVexV478 c/8AkStE/wCy
xfs7/wDrQHwyq47r1X5iPYq+FPH/AO0z8QdPi0W3s/DXgXw94R8RfF7xv8Id Z+MXh74i6j8S
bXwRLovxm0T4U+FUtdI8OfCXX9Ih+JnjGE+NbK/0nx1c6X8Pvgt8V/Dul+Af HviHxjqGoPo1
x1/x00bUvGnxw+DfgFPE3jzQ9DvvhV8evF9/ZeB/iH48+Hj6jq3hfxf+ztou j3WpXvgDxJ4Z
1HUV02z8a67FaWt7eT2UbancS/ZjP5Useb8T9I1zwh4Qt01/xn8QvGPhbxZ8 W/CfgzxD4W8U
r8H9b0fWPDf7Qv7Snwr0G68Iaz/bvwW1e71LwT4R8Ma34g+Gmj6LJcxatqHw x8Y+J9L1nxJe
eOrbwF8RvAW2bcP4vNOH54DKc0hl2d57halPLsbOnV/4TqrxWJwVKX7qtCdV YmrR5KsqcsLi
MPCcJ4TE0a9q9Hhw2bU8LmNetjMJOrl2VVoPExjKM3i4fVsPiqq5ZUmqXsad dOCbrwrTjJVa
Tp2hU9N/Zg+N0P7Q3wa8NfFC2bQL231SfVtHbxD4QudSn8FeKdS8MalceHfE er+EYvEVnpPj
HTdItfFGm634eudH8Z6DouvaTr2h6zYRLr+gwaJ4x8ScD+zR+3d+zP8Atc/2 T/wpLxR8QLr/
AISf4f2HxY8B/wDC0PgB+0J+z3/wtX4WX/8AYO74l/Bj/hoT4WfC7/hdPw/0 n/hL/A3/AAlH
jL4Uf8Jj4c8If8LF+Gf/AAlWpaN/wsrwJ/wkP0r4M8NXnhLQU0W/8XeKfHN0 NW8S6q/iLxk+
gvrsqeIvEur+IYNJP/CM6B4Z0WLSPDMGqReGfDNtbaNBNaeGtH0i1v7nU9Rh u9Uvf56/gV/w
Tr/bs+FX7IHwk8AXHxU+IHir49av/wAEgPEH7Dvwi8R+LvHHwd+Gmsf8Et/2 hPGn7P8A4avf
F0fh3xr+zV4I8E3vxZ/Z/wDFnxN+DnwB8FQfEqG9+PP7THwB8d/AP4deI/h7 qnxf8C/H342e
P/g55uAwtfA4LCYLE5hUzbEYXD0qFfM6tKFCePq0oKE8XKhCMVR9vJOoqbTl CMlGc6k1KcvT
rVYVqtStToLCwqzlOGGjJzVCMndUudt83InyuSfK2m4qMbJf0fV4/wDA/wCN fhX4/eC9a8de
DtP8QabpGhfGD9oX4KXlv4mtdOs9Rk8Vfs1/H34l/s5+OtQtodL1XWbZ/D+r eNvhX4h1Twnd
S3kOo33hW80a+1jStB1e4vtD07+eL4Wf8E4PG/w+8HNd2H7Hn7QHjL9mWH9o D4VeNfjZ/wAE
9vjof+CR/g3/AIaP8OeFPgT+114Bvr3wt+yd+xf4Z+CX/BObU/7M+Mvxt/ZS +MGt+P8A9oj4
9TfFP4lf8Mr6RNceHPCmtfsr/su2fxm+f1/4JQ/tFeItL8J/2j+zj+0B8KPC Un/DSdr+yd8F
fgX4k/4JZeHP+GAfGPxG/wCCjv7ePx98OfELxT8R/jJ4M/aa1P8AY4/tL4Jf HT9kT+xPjF/w
Sb/4Wp8dvBX/AAojV/7V8H6/4t+Bv7NOjan1mR/S98K/2qfCvxd8VeK9J8Nf Dr4wQ+CdG+MH
jP4EeEvjNc+EdO1b4Z/Ez4mfCjUfi94Y+OGl6Mng/wAReKPiJ8NPD/wZ+Inw N8f/AAs8TeP/
ANo74ffA/wCHvjT4hJ4T0X4K+KfipbfEHwJqPiL6fr+YL9p3/glj8XfEf7IH x
Re: UML middleweight extension:making unnessecary elements invisible [message #627256 is a reply to message #478038] |
Hi Deepak,
custom solution.
- James.
> Hello,
> With regards,
> Deepak
Re: UML middleweight extension:making unnessecary elements invisible [message #627257 is a reply to message #478039] |
Member |
Hi James,
Deepak
> Hi Deepak,
> custom solution.
> - James.
>> Hello,
>> With regards,
>> Deepak
Current Time: Mon Jan 18 02:14:31 GMT 2021
Powered by FUDForum. Page generated in 0.03643 seconds
