Home » Modeling » UML2 » Stereotypes parameters
Stereotypes parameters [message #477972] Sat, 15 November 2008 10:58 Go to next message
Mauro is currently offline MauroFriend
Member
I defined a stereotype with a parameter of type uml::Operation
The problem is that when I apply the stereotype it seems impossible to fill
the parameter value in the property view...
Is this feature supported by the uml editor?
thanks
Mauro
Re: Stereotypes parameters [message #477973 is a reply to message #477972] Sat, 15 November 2008 15:15 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Mauro,
By "parameter" do you mean that the stereotype has a *property* of type
uml::Operation? (i.e., an association to the Operation metaclass)
This feature is supported by the UML editor. You should get a drop-down
list from which to select any existing operation in the resource set (if
it is a single-valued property) or a dialog from which to select
existing operations (if it is a multi-valued property).
Perhaps you can share details of the stereotype definition in your
profile (a snippet of the XMI would be most handy)? Likely we would be
able to see what the problem is ...
Christian
> thanks
> Mauro
Re: Stereotypes parameters [message #477974 is a reply to message #477973] Sun, 16 November 2008 18:32 Go to previous messageGo to next message
Member
I see... the dialog is there but it is so much larger than the screen that I
can't see anything!
It's the same under Windows and Linux...
Mauro
Re: Stereotypes parameters [message #477979 is a reply to message #477974] Mon, 17 November 2008 09:00 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn HusseyFriend
Mauro,
Do you have a large number of operations in your resource set? We have
received similar complaints in the past, but have been unable to reproduce
the problem (since the list should simply be scrollable)...
Kenn
"Mauro" <mauro@bglug.it> wrote in message
news:gfpli1$oil$1@build.eclipse.org...
> I
> can't see anything!
> Mauro
Re: Stereotypes parameters [message #477980 is a reply to message #477979] Mon, 17 November 2008 11:04 Go to previous messageGo to next message
Member
yes the list is very very long, some resources have a very long name and I
think that the size of the menu is based on the longest wich are
<Operation> Create Association (End 1 Is Navigable : Boolean, End 1
Aggregation : Aggregation Kind, End 1 Name : String, End 1 Lower : Integer,
End 1 Upper : Unlimited Natural, End 1 Type : Type, End 2 Is Navigable :
Boolean, End 2 Aggregation : Aggregation Kind, End 2 Name : String, End 2
Lower : Integer, End 2 Upper : Unlimited Natural) : Association
<Operation> Create Communication Path (End 1 Is Navigable : Boolean, End 1
End 1 Upper : Unlimited Natural, End 1 Node : Node, End 2 Is Navigable :
Lower : Integer, End 2 Upper : Unlimited Natural) : Communication Path
Mauro
Re: Stereotypes parameters [message #477982 is a reply to message #477980] Mon, 17 November 2008 14:35 Go to previous messageGo to next message
james bruck is currently offline james bruckFriend
Hi Mauro,
Please raise a defect on that with a small example to reproduce the issue
and it will be addressed.
- James.
news:gfrfn2$mnv$1@build.eclipse.org...
>> reproduce
> Integer,
> Integer,
> Mauro
Re: Stereotypes parameters [message #477983 is a reply to message #477982] Mon, 17 November 2008 19:44 Go to previous messageGo to next message
Member
I did it
Is it normal to have those operations in the resource set?
I installed just the default packages...
do you see any workaround (filtering the data somewhere?)
Mauro
Re: Stereotypes parameters [message #477988 is a reply to message #477983] Wed, 19 November 2008 15:33 Go to previous messageGo to next message
Thanks for raising the defect.
I can see the problem now... very wacky.
Below when you ask ".. is it normal to have *those* operations ..." which
operations are you referring to exactly? You can explicitly load other
resources into your resource set.
Filtering the data would be one possibility, but I really can't see why the
dialog is so large. Perhaps popping up a dialog with some filtering
criteria would be more helpful.
This is definitely an issue.
- James.
news:gfse5d$324$1@build.eclipse.org...
> I did it
> Mauro
Re: Stereotypes parameters [message #477990 is a reply to message #477988] Wed, 19 November 2008 17:00 Go to previous messageGo to next message
mauro is currently offline mauroFriend
> which operations are you referring to exactly?
the very long 2 I mentioned before:
I think they are the cause of the wide menu!!
Mauro
Re: Stereotypes parameters [message #478020 is a reply to message #477988] Tue, 25 November 2008 17:00 Go to previous message
James Bruck wrote:
> but I really can't see why the dialog is so large.
I think it's because the width of the menu is the width of the longest
contained element...
Re: Stereotypes parameters [message #627190 is a reply to message #477972] Sat, 15 November 2008 15:15 Go to previous message
Hi, Mauro,
Christian
> thanks
> Mauro
Re: Stereotypes parameters [message #627191 is a reply to message #477973] Sun, 16 November 2008 18:32 Go to previous message
Member
can't see anything!
Mauro
Re: Stereotypes parameters [message #627196 is a reply to message #477974] Mon, 17 November 2008 09:00 Go to previous message
Mauro,
Kenn
> I
> can't see anything!
> Mauro
Re: Stereotypes parameters [message #627197 is a reply to message #477979] Mon, 17 November 2008 11:04 Go to previous message
Member
Mauro
Re: Stereotypes parameters [message #627199 is a reply to message #477980] Mon, 17 November 2008 14:35 Go to previous message
Hi Mauro,
- James.
>> reproduce
> Integer,
> Integer,
> Mauro
Re: Stereotypes parameters [message #627200 is a reply to message #477982] Mon, 17 November 2008 19:44 Go to previous message
Member
I did it
Mauro
Re: Stereotypes parameters [message #627205 is a reply to message #477983] Wed, 19 November 2008 15:33 Go to previous message
- James.
> I did it
> Mauro
Re: Stereotypes parameters [message #627207 is a reply to message #477988] Wed, 19 November 2008 17:00 Go to previous message
Mauro
Re: Stereotypes parameters [message #627237 is a reply to message #477988] Tue, 25 November 2008 17:00 Go to previous message
Previous Topic:Usage of DerivedUnion or simple derived?
Next Topic:Creating a DSL / Extending UML2
Current Time: Thu Jul 09 19:09:10 GMT 2020
Powered by FUDForum. Page generated in 0.02836 seconds
