Home » Modeling » UML2 » Importing Superstructure.uml to Rational Software Architect
Re: Importing Superstructure.uml to Rational Software Architect [message #477933 is a reply to message #477931] |
Wed, 05 November 2008 21:00 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Longer term, we will be producing diagrams for the source models using
tooling available at Eclipse, i.e. UML2 Tools and/or Papyrus.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:gesg96$c4e$1@build.eclipse.org...
> Hi Marco,
> The .emx files were recently removed for UML2 3.0.0 since they were out of
> date and one needed RSA (non-opensource) to modify them.
> There are efforts at the OMG to possibly provide an education licsense for
> RSA. The models should be updated soon and an appropriate home will be
> found for them.
> Cheers,
> - James.
> "Marco Mosconi" <mosconi@cs.tu-berlin.de> wrote in message
> news:gerurk$jig$1@build.eclipse.org...
>> Hector,
>> the .uml files usually contain only "semantic" model elements and no
>> visualization information. There are RSA-versions (.emx) of the UML
>> metamodel, which include many diagrams. You can find them in the Eclipse
>> UML2 CVS:
>> :pserver:anonymous@dev.eclipse.org:/cvsroot/modeling
>> org.eclipse.mdt/org.eclipse.uml2/plugins/org.eclipse.uml2.um l/model
>> Marco
>> Hector M Chavez schrieb:
>>> Hi,
>>> I was trying to visualize the UML superstructure and imported the file
>>> "Superstructure.uml" to RSA but I can only see model elements (packages,
>>> relationships, classes, etc.) does anyone know if there is a way I can
>>> actually see the class diagram. The UML I'm using is the version 2.2.1.
>>> Thanks for your help.
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477938 is a reply to message #477933] |
Thu, 06 November 2008 10:57 |
Marco Mosconi Messages: 63 Registered: July 2009 |
Member |
.... or MST, I guess (hope) ;-)
Personally I think it's still a long way for the open source modeling
tools to get mature enough for serious use. At least when it comes to
tooling details. But it's the right path to follow and perhaps Papyrus
is a good starting point.
Marco
> Kenn
>> Hi Marco,
>> found for them.
>> Cheers,
>> - James.
>>> Hector,
>>> UML2 CVS:
>>> Marco
>>>> Hi,
>>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #477942 is a reply to message #477938] |
Thu, 06 November 2008 16:41 |
Marco,
All that's required is a developer community willing/able to make it happen.
For example, Ed was able to replace the antiquated Rose models for EMF
metamodels with diagrams created using Ecore Tools in less than a year after
that component was created...
Kenn
news:geuij6$a68$1@build.eclipse.org...
> tooling details. But it's the right path to follow and perhaps Papyrus is
> Marco
>> Kenn
>>> Hi Marco,
>>> of date and one needed RSA (non-opensource) to modify them.
>>> for RSA. The models should be updated soon and an appropriate home will
>>> be found for them.
>>> Cheers,
>>> - James.
>>>> Hector,
>>>> Eclipse UML2 CVS:
>>>> Marco
>>>>> Hi,
>>>>> (packages, relationships, classes, etc.) does anyone know if there is
>>>>> a way I can actually see the class diagram. The UML I'm using is the
>>>>> version 2.2.1. Thanks for your help.
>>>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627137 is a reply to message #477925] |
Wed, 05 November 2008 11:08 |
Member |
Hector,
UML2 CVS:
Marco
> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627142 is a reply to message #477931] |
Kenn
> Hi Marco,
> found for them.
> Cheers,
> - James.
>> Hector,
>> UML2 CVS:
>> Marco
>>> Hi,
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627146 is a reply to message #477931] |
Thu, 06 November 2008 10:49 |
Member |
Hi James,
That's bad news ... I can't imagine how to analyse/navigate the UML
metamodel without RSA ;-)
> found for them.
That would be great. Please notify when it is available again.
Marco
> Cheers,
> - James.
>> Hector,
>> UML2 CVS:
>> Marco
>>> Hi,
>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627147 is a reply to message #477933] |
Member |
Marco
> Kenn
>> Hi Marco,
>> found for them.
>> Cheers,
>> - James.
>>> Hector,
>>> UML2 CVS:
>>> Marco
>>>> Hi,
>>>> Hector
Re: Importing Superstructure.uml to Rational Software Architect [message #627151 is a reply to message #477938] |
Marco,
Kenn
> Marco
>> Kenn
>>> Hi Marco,
>>> be found for them.
>>> Cheers,
>>> - James.
>>>> Hector,
>>>> Eclipse UML2 CVS:
>>>> Marco
>>>>> Hi,
>>>>> Hector
Current Time: Thu Apr 25 23:35:41 GMT 2024
Powered by FUDForum. Page generated in 0.04384 seconds
