Home » Modeling » UML2 » UML2 3.0.0 metamodel now has unnamed associations
UML2 3.0.0 metamodel now has unnamed associations [message #477814] |
Sat, 11 October 2008 16:56 |
Originally posted by: cdamus.zeligsoft.com
In adopting the UML2 3.0.0 changes in the OCL project, I tripped across
a difference from the patch on Bug 232332 that I had previously tested.
There are now assocations in the UML.metamodel.uml model, such as the
new DecisionNode::decisionInputFlow, that are unnamed. Previously,
these would have (I assumed computed) names like
"A_decisionInputFlow_decisionNode."
Is this a bug? I clearly had a bug in the OCL parser, that would NPE on
these in the syntax-completion algorithm, but I am thinking that
probably these new associations should be consistent with all those that
came before.
Christian
Re: UML2 3.0.0 metamodel now has unnamed associations [message #477820 is a reply to message #477814] |
Tue, 14 October 2008 14:46 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Christian,
I will look into this today.
- James.
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:gcqlsr$nrg$1@build.eclipse.org...
> In adopting the UML2 3.0.0 changes in the OCL project, I tripped across a
> There are now assocations in the UML.metamodel.uml model, such as the new
> DecisionNode::decisionInputFlow, that are unnamed. Previously, these
> these in the syntax-completion algorithm, but I am thinking that probably
> these new associations should be consistent with all those that came
> before.
> Christian
Re: UML2 3.0.0 metamodel now has unnamed associations [message #477821 is a reply to message #477820] |
Tue, 14 October 2008 17:00 |
Thanks, James,
I took a closer look at the UML metamodel using the OCL console:
Evaluating:
Association.allInstances()->select(name.oclIsUndefined())
Results:
<Association> A_result_writeStructuralFeatureAction
<Association> A_result_clearStructuralFeatureAction
<Association> A_object_startObjectBehaviorAction
<Association> A_decisionInputFlow_decisionNode
As you can see, there are four null-named associations. The label
provider kindly computes names for us.
Christian
James Bruck wrote:
> Hi Christian,
> Cheers,
> - James.
>> Hi,
>> before.
>> Thanks,
>> Christian
Re: UML2 3.0.0 metamodel now has unnamed associations [message #477822 is a reply to message #477820] |
Tue, 14 October 2008 17:30 |
Hi Christian
The 4 offending associations can be tracked back to the original
Superstructure.uml. These are their id's
_0TsdIBk7Ed2AFo75-uQLRQ
_OPUWUCG7Ed2y9aVPK_72RA
_ijq7oBk8Ed2AFo75-uQLRQ
_wv1fYBk8Ed2AFo75-uQLRQ
That correspond to:
I will update and regenerate.
Thanks for finding those missing names.
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:gd2b9p$ohs$1@build.eclipse.org...
> Hi Christian,
> Cheers,
> - James.
>> Hi,
>> before.
>> Thanks,
>> Christian
Re: UML2 3.0.0 metamodel now has unnamed associations [message #627024 is a reply to message #477814] |
Hi Christian,
- James.
> before.
> Christian
Re: UML2 3.0.0 metamodel now has unnamed associations [message #627025 is a reply to message #477820] |
Thanks, James,
Evaluating:
Results:
Christian
James Bruck wrote:
> Hi Christian,
> Cheers,
> - James.
>> Hi,
>> before.
>> Thanks,
>> Christian
Re: UML2 3.0.0 metamodel now has unnamed associations [message #627026 is a reply to message #477820] |
Hi Christian
That correspond to:
- James.
> Hi Christian,
> Cheers,
> - James.
>> Hi,
>> before.
>> Thanks,
>> Christian
Current Time: Thu Apr 25 10:29:52 GMT 2024
Powered by FUDForum. Page generated in 0.04014 seconds
