Home » Modeling » UML2 » Coupling operations with activities, state machines and actions
Re: Coupling operations with activities, state machines and actions [message #477807 is a reply to message #477806] |
Fri, 10 October 2008 16:24 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Nick,
Operations can have one or more behaviors (BehavioralFeature#method,
opposite is Behavior#specification). An activity is a kind of behavior.
> For instance, http://www.omg.org/docs/ad/07-08-02.pdf shows an activity
> diagram and a matching java method.
What section of the spec are you referring to?
Rafael
Nick Betteridge wrote:
> Hi
> I'm new to uml2 and modeling, so I hope I don't sound as though I've
> really missed the point.
> I'm trying to understand how to map activities and state machines to
> operations in uml2. I've gone through the tutorials on creating models,
> packages, classes, attributes and operations. Now I would like to take
> this further and create activities and state machines (with the states
> containing actions).
> Does anyone know of a simple tutorial which demonstrates how to do this
> with uml2?
> diagram and a matching java method. I really would like to create this
> model in uml2 and then parse though the model and create the source.
> Am I on the right track here?!
> Thanks in advance for any input.
> Nick
Re: Coupling operations with activities, state machines and actions [message #477810 is a reply to message #477807] |
Fri, 10 October 2008 19:55 |
Btw, a StateMachine is also a Behavior.
Rafael Chaves wrote:
> Nick,
> Cheers,
> Rafael
>> Hi
>> models, packages, classes, attributes and operations. Now I would like
>> to take this further and create activities and state machines (with
>> the states containing actions).
>> this with uml2?
>> activity diagram and a matching java method. I really would like to
>> create this model in uml2 and then parse though the model and create
>> the source.
>> Nick
Re: Coupling operations with activities, state machines and actions [message #477816 is a reply to message #477807] |
Mon, 13 October 2008 16:44 |
Nick Betteridge Messages: 6 Registered: July 2009 |
Hi Rafael
Thanks for replying. The section of the spec (Concrete Syntax for a UML
Action Language) was the appendix - a simple java method and the
corresponding activity diagram. I can see how to generate the class and
the operation, and also generate the activity with CallBehaviourActions.
So, from what you are saying, all I have to do is create the activity
and do a getMethods().add()?
ie:
class ListUtils {
boolean sameSizeLists(List listOne, List listTwo) {
if (listOne.size() == listTwo.size())
return true;
return false;
Class class = package_.createOwnedClass("ListUtils", isAbstract);
Operation op = class.createOwnedOperation("sameSizeLists", pNames,
pTypes, returnType);
Activity activity = (Activity)
class.createOwnedBehavior("sameSizeLists",
UMLPackage.eINSTANCE.getActivity());
CallBehaviorAction cba0 = (CallBehaviorAction)
activity.createNode(null,UMLPackage.eINSTANCE.getCallBehavio rAction());
.... add actions, nodes etc
op.getMethods().add(activity);
..... and then when it comes to traversing the model (for code
generation), look at the methods assigned to the operation and choose
the most appropriate?
Thanks again
Cheers
Nick
> Nick,
> Cheers,
> Rafael
>> Hi
>> this with uml2?
>> the source.
>> Nick
Re: Coupling operations with activities, state machines and actions [message #477817 is a reply to message #477816] |
Mon, 13 October 2008 17:58 |
Hi Nick,
What I actually do is activity.setSpecification(op), but it doesn't
matter as Behavior#specification and BehavioralFeature#methods are
opposite ends.
I really don't understand the use case for operations with multiple
methods. If it doesn't make sense in your case, you could enforce a rule
that did not allow that. I have to somehow constrain UML features once
in a while, as some of them seem unnecessary for the concrete case at
hand, or have to choose one possible interpretation or even invent
something because the specification is vague/incomplete.
Another thing you should do is to create parameter nodes, one for each
parameter in the 'specification' (i.e. your operation) of the activity
being built. They provide the means for data getting in and out of your
activity.
Good luck,
Rafael
> Hi Rafael
> ie:
> class ListUtils {
> return true;
> return false;
> Thanks again
> Cheers
> Nick
>> Nick,
>> activity
>> Cheers,
>> Rafael
>>> Hi
>>> like to take this further and create activities and state machines
>>> (with the states containing actions).
>>> this with uml2?
>>> the source.
>>> Nick
Re: Coupling operations with activities, state machines and actions [message #627005 is a reply to message #477806] |
Nick,
Rafael
> Hi
> with uml2?
> Nick
Re: Coupling operations with activities, state machines and actions [message #627007 is a reply to message #477807] |
> Nick,
> Cheers,
> Rafael
>> Hi
>> this with uml2?
>> the source.
>> Nick
Re: Coupling operations with activities, state machines and actions [message #627013 is a reply to message #477807] |
Hi Rafael
ie:
class ListUtils {
return true;
return false;
Thanks again
Cheers
Nick
> Nick,
> Cheers,
> Rafael
>> Hi
>> this with uml2?
>> the source.
>> Nick
Re: Coupling operations with activities, state machines and actions [message #627014 is a reply to message #477816] |
Hi Nick,
opposite ends.
activity.
Good luck,
Rafael
> Hi Rafael
> ie:
> class ListUtils {
> return true;
> return false;
> Thanks again
> Cheers
> Nick
>> Nick,
>> activity
>> Cheers,
>> Rafael
>>> Hi
>>> this with uml2?
>>> the source.
>>> Nick
Current Time: Sat Apr 20 03:09:43 GMT 2024
Powered by FUDForum. Page generated in 0.03127 seconds
