Home » Modeling » UML2 » Convert UML2 2.x to 1.x
Convert UML2 2.x to 1.x [message #477798] Wed, 08 October 2008 09:44 Go to next message
Joachim is currently offline JoachimFriend
Is it possible to convert an UML2 2.x file into an UML2 1.x file
programmatically?
I tried to apply
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
the other way round, but failed.
The URI is e.g. still
"pathmap://UML_METAMODELS/UML.metamodel.uml#_0" instead of the expected
" pathmap://UML2_METAMODELS/UML2.metamodel.uml2#_m8qbA686EdiEh 75YJ_3n8g".
Also the stereotype application is also done in the new way, e.g.
<Myprofil:Mystereotype xmi:id="Component_9358733739517_2"
base_Component="Component_9358733739517"/>
instead of the old way
<eAnnotations xmi:id="_7Nrw4pRXEd2rI5P6VK0UBQ"
source="appliedStereotypes">
<contents xmi:type="Myprofil:Mystereotype"
xmi:id="_7Nrw45RXEd2rI5P6VK0UBQ"/>
</eAnnotations>
Re: Convert UML2 2.x to 1.x [message #477799 is a reply to message #477798] Wed, 08 October 2008 14:09 Go to previous message
james bruck is currently offline james bruckFriend
Hi Joachim,
Unfortunately, the backward migration is not implemented. It would
definitely be possible however. You could look at the
UML22UMLResourceHandler for some idea of the work involved ... the bulk of
the work would probably have to go into the preSave() of the resource
handler as opposed to the post load.
Keep in mind that the preSave and postLoad would not be entirely
symmetrical.
And yes, as you pointed out, the way the stereotypes and profiles were
serialized and used also changed.
- James.
"Joachim Back" <j.back@mid.de> wrote in message
news:gchvei$n3i$1@build.eclipse.org...
> programmatically?
> I tried to apply
> </eAnnotations>
Re: Convert UML2 2.x to 1.x [message #626998 is a reply to message #477798] Wed, 08 October 2008 14:09 Go to previous message
Hi Joachim,
symmetrical.
- James.
> programmatically?
> I tried to apply
> </eAnnotations>
Previous Topic:Convert UML2 2.x to 1.x
Next Topic:[Announce] MDT UML2 3.0.0 I200810071911 is available
Current Time: Sat Oct 01 08:42:03 GMT 2022
Powered by FUDForum. Page generated in 0.01762 seconds
