Re: [EMF] Loading UML Magicdraw models [message #477792] |
Tue, 07 October 2008 19:37 |
Ed Merks Messages: 33141 Registered: July 2009 |
Waldemar,
It's best to ask on the UML2 newsgroup because I don't have a clue about
how profile magic works. I've added it to the "to" list of the reply,
so no need to repost.
Waldemar Neto wrote:
> I need load UML models exported from MagicDraw. To load these models i
> configure UML environment as said in the section Programmatic
> Migration in the article:
> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
> Well, but when a run my program these exception is throwed:
> rs.emf4atl.ASMEMFModel.loadASMEMFModel(ASMEMFModel.java:365)
> at
> org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:222)
> at
> br.edu.gmf.udt.m2m.atl.ATLExecutor.createASMMetamodel(ATLExe cutor.java:235)
> at
> br.edu.gmf.udt.m2m.atl.ATLExecutor.initInputModels(ATLExecut or.java:288)
> at
> br.edu.gmf.udt.m2m.atl.ATLExecutor.makeTransformation(ATLExe cutor.java:256)
> at
> br.edu.gmf.udt.m2m.atl.ATLExecutor.executeTransformations(AT LExecutor.java:335)
> at br.edu.gmf.udt.AbsExecutor.generateTests(AbsExecutor.java:28 )
> at br.edu.gmf.udt.UDTExecutor.main(UDTExecutor.java:53)
> Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
> with uri 'http:///_zrN_0SUoEdmNXYQzyImvfA.profile.uml2' not found.
> ( file:///C:/Users/Netuh/Desktop/eclipse%20Place/workspace/UDT 2/IN,
> 18218, 99)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2566)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2398)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1276)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1445)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1010)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:992)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:501)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:179)
> at
> com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(XMLNSDocumentScannerImpl.java:377)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(XMLDocumentFragmentSca nnerImpl.java:2747)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(XMLDocumentScannerImpl.java:648)
> at
> com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(XMLNSDocumentScannerImpl.java:140)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 510)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1205)
> at
> com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(SAXParserImpl.java:522)
> at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
> at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
> .. 10 more
> Any idea is very helpful.
> Thanks in advance,
> Waldemar Neto
> PS: sorry if my question was a crossing question, because i usaing the
> plugin ATL for load these models.
Ed Merks
Re: [EMF] Loading UML Magicdraw models [message #477795 is a reply to message #477792] |
Tue, 07 October 2008 22:01 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Waldemar ,
I'm no expert with MagicDraw but it is my understanding that they do not use
the opensource UML2 API and their serialization may (probably) be
incompatible.
see: http://wiki.eclipse.org/MDT-UML2-Tool-Compatibility
You will have to somehow convert their format to the .uml format before the
tips in the migration guide can help. The code in that guide indicate how
to open up models serialized with the .uml format.
Can you provide a snippet of the model you are trying to open from
MagicDraw.
- James.
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gcgdp3$udi$1@build.eclipse.org...
> Waldemar,
> how profile magic works. I've added it to the "to" list of the reply, so
> no need to repost.
>> Hi,
>> configure UML environment as said in the section Programmatic Migration
>> in the article:
>> at
>> at
>> at
>> at
>> at
>> ( file:///C:/Users/Netuh/Desktop/eclipse%20Place/workspace/UDT 2/IN, 18218,
>> 99)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .. 10 more
>> Thanks in advance,
>> Waldemar Neto
Re: [EMF] Loading UML Magicdraw models [message #626994 is a reply to message #477792] |
Hi Waldemar ,
incompatible.
MagicDraw.
- James.
> Waldemar,
> no need to repost.
>> Hi,
>> in the article:
>> at
>> at
>> at
>> at
>> at
>> 99)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .. 10 more
>> Thanks in advance,
>> Waldemar Neto
FUDForum. Page generated in 0.03616 seconds
