Home » Modeling » UML2 » Support for multi-language documentation
Support for multi-language documentation [message #477649] |
Thu, 31 July 2008 03:51 |
Francis Gavino Messages: 57 Registered: July 2009 |
Member |
I'm using RSA as my UML tool, and I need to be able to define descriptions
of some UML elements (E.g., a UML Class) in different languages. There's
only one documentation property for a given element, and to be able to
enter the descriptions I have to use delimiters of some sort, with the
language/locale code as the key. This is not a user friendly way and is
prone to mistyping the language code. There has to be a better way of
doing this...
First thing I tried, is I defined a UML Class in my profile, that contains
2 attributes: 1) language code (enumeration), and 2) description text.
Then I set this as the type for my Stereotype property. It works, but the
support for this type of structure is not nice. Adding a new description
using the Properties view is a pain, and I have trouble getting the values
programmatically because I get a DynamicEObjectImpl and I don't know how
to get the actual values. :( Anyone has a better idea? Will there be
built-in support for this in the future?
Francis
Re: Support for multi-language documentation [message #477650 is a reply to message #477649] |
Thu, 31 July 2008 13:20 |
Originally posted by: cdamus.zeligsoft.com
Hi, Francis,
I can't speak for RSA, but the MDT UML2 API provides a
UML2Util::getString(...) API that will retrieve a localized string from
the *.properties file accompanying the Resource that contains the
contextual element passed to the getString(...) operation.
This is used in the implementation of the NamedElement::getLabel() API
for localized names, but works with any old string key in the
*.properties file. Just be sure to match the *.properties file name
with the file name of your model (without the extension).
You could, then, simply implement the Eclipse PDE convention of
%key
as the text of your documentation field, strip off the % sign, and look
up the key in the *.properties file using getString.
HTH,
Christian
Francis wrote:
> descriptions of some UML elements (E.g., a UML Class) in different
> languages. There's only one documentation property for a given element,
> and to be able to enter the descriptions I have to use delimiters of
> some sort, with the language/locale code as the key. This is not a user
> friendly way and is prone to mistyping the language code. There has to
> be a better way of doing this...
> contains 2 attributes: 1) language code (enumeration), and 2)
> description text. Then I set this as the type for my Stereotype
> property. It works, but the support for this type of structure is not
> nice. Adding a new description using the Properties view is a pain, and
> I have trouble getting the values programmatically because I get a
> DynamicEObjectImpl and I don't know how to get the actual values. :(
> Anyone has a better idea? Will there be built-in support for this in the
> future?
> Francis
Re: Support for multi-language documentation [message #477651 is a reply to message #477650] |
Thu, 31 July 2008 14:06 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Francis,
Unfortunately, the UML2Util.getString(...) with the localize parameter set
to true will not always work for RSA.
RSA uses GMF style pathmaps that map pathmap schema to the exact location of
the resource. The UML2Util.getString uses UML2Util.getResourceBundle that
expects the pathmap schema to be mapped to a platform schema when the given
URI is normalized. This will not work for RSA. RSA uses the MSL layer
that is capable of performing the translations. I would recommend using API
provided by RSA's MSL layer to obtain reliable translations.
In fact, looking at the UML2Util.getResourceBundle() it would seem that
getting translated strings, for some of the standard stereotypes for
example, would not work with a standalone opensource UML application since
we would use URI conververter to map pathmap schemas to exact jar locations
on the disk.
HTH
- James.
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:g6se6p$10g$1@build.eclipse.org...
> Hi, Francis,
> This is used in the implementation of the NamedElement::getLabel() API for
> localized names, but works with any old string key in the *.properties
> file. Just be sure to match the *.properties file name with the file name
> %key
> as the text of your documentation field, strip off the % sign, and look up
> HTH,
> Christian
> Francis wrote:
>> Hi,
>> and to be able to enter the descriptions I have to use delimiters of some
>> friendly way and is prone to mistyping the language code. There has to be
>> contains 2 attributes: 1) language code (enumeration), and 2) description
>> text. Then I set this as the type for my Stereotype property. It works,
>> but the support for this type of structure is not nice. Adding a new
>> description using the Properties view is a pain, and I have trouble
>> getting the values programmatically because I get a DynamicEObjectImpl
>> and I don't know how to get the actual values. :( Anyone has a better
>> idea? Will there be built-in support for this in the future?
>> Thanks,
>> Francis
Re: Support for multi-language documentation [message #477657 is a reply to message #477651] |
Wed, 06 August 2008 04:16 |
Member |
Thank you James and Christian for your inputs. I apologize for indirectly
asking for an opinion for RSA. I'll just work with the support team about
it.
I guess if there's no built-in support in RSx for that, I have to create a
custom way of doing it (and maybe create a nice properties view editor to
support it).
Going back to one of my technical problems, how do I resolve the
DynamicEObjectImpl class when I try to get the value of the stereotype
property whose type is a UML Class (and then I also need to get the values
of the class attributes)? Can someone point me to the right direction?
Thanks.
/Francis
James Bruck wrote:
> Hi Francis,
> on the disk.
> HTH
> - James.
>> Hi, Francis,
>> %key
>> HTH,
>> Christian
>> Francis wrote:
>>> Hi,
>>> Thanks,
>>> Francis
Re: Support for multi-language documentation [message #477661 is a reply to message #477657] |
Thu, 07 August 2008 14:30 |
Hi Francis,
I believe you are looking for UMLUtil.getStereotype() or
UMLUtil.getBaseElement().
Pass in the stereotype application (DynamicEObject) as the parameter.
From the corresponding UML element, you can navigate to the values and
attributes.
If you are trying to get and set stereotype values, have a look at the
getting started article for profiles from the wiki page.
HTH.
- James.
"Francis" <fgavino@gmail.com> wrote in message
news:22cb30f9ac7190dd5f47eff920c568c5$1@www.eclipse.org...
> it.
> support it).
> Thanks.
> /Francis
> James Bruck wrote:
>> Hi Francis,
>> set to true will not always work for RSA.
>> of the resource. The UML2Util.getString uses UML2Util.getResourceBundle
>> that expects the pathmap schema to be mapped to a platform schema when
>> the given URI is normalized. This will not work for RSA. RSA uses the
>> MSL layer that is capable of performing the translations. I would
>> recommend using API provided by RSA's MSL layer to obtain reliable
>> translations.
>> since we would use URI conververter to map pathmap schemas to exact jar
>> locations on the disk.
>> HTH
>> - James.
>>> Hi, Francis,
>>> %key
>>> HTH,
>>> Christian
>>> Francis wrote:
>>>> Hi,
>>>> the future?
>>>> Thanks,
>>>> Francis
Re: Support for multi-language documentation [message #626841 is a reply to message #477649] |
Hi, Francis,
%key
HTH,
Christian
Francis wrote:
> future?
> Francis
Re: Support for multi-language documentation [message #626842 is a reply to message #477650] |
Hi Francis,
on the disk.
HTH
- James.
> Hi, Francis,
> %key
> HTH,
> Christian
> Francis wrote:
>> Hi,
>> Thanks,
>> Francis
Re: Support for multi-language documentation [message #626849 is a reply to message #477651] |
Member |
it.
support it).
Thanks.
/Francis
James Bruck wrote:
> Hi Francis,
> on the disk.
> HTH
> - James.
>> Hi, Francis,
>> %key
>> HTH,
>> Christian
>> Francis wrote:
>>> Hi,
>>> Thanks,
>>> Francis
Re: Support for multi-language documentation [message #626853 is a reply to message #477657] |
Hi Francis,
attributes.
HTH.
- James.
> it.
> support it).
> Thanks.
> /Francis
> James Bruck wrote:
>> Hi Francis,
>> translations.
>> HTH
>> - James.
>>> Hi, Francis,
>>> %key
>>> HTH,
>>> Christian
>>> Francis wrote:
>>>> Hi,
>>>> the future?
>>>> Thanks,
>>>> Francis
Current Time: Thu Apr 25 16:36:01 GMT 2024
Powered by FUDForum. Page generated in 0.04475 seconds
