Home » Modeling » UML2 » Import and Export from/to Enterprise Architect?
Re: Import and Export from/to Enterprise Architect? [message #477637 is a reply to message #477634] |
Mon, 28 July 2008 14:25 |
Dave Carlson Messages: 402 Registered: July 2009 |
Volker,
I did some testing a few months ago with XMI exported from EA (latest
release at that time). Unfortunately, their XMI export had many bugs and
fundamental errors in XMI/UML representation, so I had to give up until they
improv their compliance with the XMI and UML metamodel specs.
You must use the XMI 2.1, UML 2.1 options exporting from EA, as these are
the versions used by UML2.
Dave Carlson
"Volker Wegert" <mail@volker-wegert.de> wrote in message
news:m2zlo7awro.fsf@gideon.home.volker-wegert.de...
> Hello everyone,
> I'd like to apologize for the cross post first - I'm not sure where this
> question should be discussed.
> I'd like to export some parts of a model from Enterprise Architect, load
> them using UML2, perform some changes and then re-import them into EA. I
> already know http://uml2ea.blogspot.com/, but from besides this being an
> unidirectional export, it seems to alter the structure and remove the
> GUIDs that EA relies upon for importing. On the other hand, EA offers
> quite a lot of combinations that can be used when exporting and
> importing XMI files, and I'm getting various errors when importing these
> files - mostly some unresolved references.
> Has anyone around here already tried this and maybe even got this
> working?
> Thanks in advance
> Volker
> * Volker Wegert * http://www.volker-wegert.de/contact *
> The computer revolution is over. The computers won.
Re: Import and Export from/to Enterprise Architect? [message #477646 is a reply to message #477634] |
Wed, 30 July 2008 21:52 |
Originally posted by: jlansing.spawar.navy.mil
Volker,
I have tried something like this and got it working. In my case I do it as a
standalone app.
I use the components4oaw ea_uml2exporter for the direction ea -> uml2. This
is cumbersome and requires some oaw libs.
It uses the ea Java api to talk to ea.
I use the same api to go the other way. The GUIDS are not necessary, only
data values, and some way to link things together for generalizations,
associations, etc.
Jeff
> Hello everyone,
> working?
> Thanks in advance
> Volker
Re: Import and Export from/to Enterprise Architect? [message #626828 is a reply to message #477634] |
Volker,
Dave Carlson
> Hello everyone,
> working?
> Thanks in advance
> Volker
Re: Import and Export from/to Enterprise Architect? [message #626837 is a reply to message #477634] |
Volker,
standalone app.
associations, etc.
Jeff
> Hello everyone,
> working?
> Thanks in advance
> Volker
Current Time: Thu Apr 25 06:07:52 GMT 2024
Powered by FUDForum. Page generated in 0.03757 seconds
