Home » Modeling » UML2 » Ordering in Sequence Diagram
Ordering in Sequence Diagram [message #477470] |
Tue, 03 June 2008 10:10 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hi all,
i have specified a Sequence Diagram with some Messages and Execution
Specifications, etc., manually with the UML tree editor. My problem is:
Where is the sequence of the messages, which are being send, specified?
Currently it is so, that I have defined two messages a and b, were a occurs
before b. Now i've inserted a third message c, which should be placed before
the occurence of a. But that message c is physically represented in the XMI
after b. So, how does the "diagram" knows that c should be occure before a,
even if it was later added?
In the UML Superstructure there is a General Ordering, but i think, this is
not the correct element to define the implicit sequence of messages?
Any help will be appreciated.
Thx
Timothy
Re: Ordering in Sequence Diagram [message #477474 is a reply to message #477470] |
Tue, 03 June 2008 10:55 |
Okay,
the questions was answered. I'm wondering, that there is no semantical
ordering of messages, but a physical one. The actual ordering of messages
are derived from the physical representation of their corresponfig
OccurenceSpecifications in the XMI. I can't image, that this is the best
solution?
Are there other opinios outthere?
Timothy
"Timothy Marc" <timothymarc@freenet.de> schrieb im Newsbeitrag
news:g2359p$o7e$1@build.eclipse.org...
> Hi all,
> occurs before b. Now i've inserted a third message c, which should be
> placed before the occurence of a. But that message c is physically
> represented in the XMI after b. So, how does the "diagram" knows that c
> should be occure before a, even if it was later added?
> is not the correct element to define the implicit sequence of messages?
> Thx
> Timothy
Re: Ordering in Sequence Diagram [message #477483 is a reply to message #477474] |
Wed, 04 June 2008 04:05 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Timothy, this is my understanding:
1 - a message has a send and receive events, which are MessageEnds.
2 - MessageEnd is abstract. One of the concrete subclasses (the one that
seems to be interesting in the context of sequence diagrams) is
MessageOccurrenceSpecification.
3 - a MessageOccurrenceSpecification is a subclass of
OccurenceSpecification, which can participate in a GeneralOrdering. From:
http://download.eclipse.org/modeling/mdt/uml2/javadoc/2.2.0/ org/eclipse/uml2/uml/GeneralOrdering.html
"A general ordering represents a binary relation between two occurrence
specifications, to describe that one occurrence specification must occur
before the other in a valid trace. This mechanism provides the ability
to define partial orders of occurrence cpecifications that may otherwise
not have a specified order."
Hope this helps. Never done anything in that area, so I might be
completely off here.
Rafael
http://abstratt.com/textuml/
Timothy Marc wrote:
> Okay,
> solution?
> Timothy
>> Hi all,
>> Thx
>> Timothy
Re: Ordering in Sequence Diagram [message #477486 is a reply to message #477483] |
Wed, 04 June 2008 12:34 |
Dear Rafael,
of course, i've read the spec before. The main purpose of GeneralOrdering is
for partial ordering of Events, which are commonly not ordered (e.g. for
asynchronous messaging). The GeneralOrdering object is not to be intendend
to order the message occurences.
It is so that the physically appearance of the occurences (physically means,
the order of appearance in the XMI) defines the ordering of message and
execution occurences.
I was wondering conerning that mechanism, even if it is very simple to
understand. But this way implies a semantical dependency between the storage
and the interpretation of a sequence diagram.
Timothy
"Rafael Chaves" <rafael@abstratt.com> schrieb im Newsbeitrag
news:g254aa$p6h$1@build.eclipse.org...
> before the other in a valid trace. This mechanism provides the ability to
> define partial orders of occurrence cpecifications that may otherwise not
> Cheers,
> Rafael
> Timothy Marc wrote:
>> Okay,
>> solution?
>> Timothy
>>> Hi all,
>>> Thx
>>> Timothy
Re: Ordering in Sequence Diagram [message #626656 is a reply to message #477470] |
Okay,
solution?
Timothy
> Hi all,
> Thx
> Timothy
Re: Ordering in Sequence Diagram [message #626665 is a reply to message #477474] |
Rafael
Timothy Marc wrote:
> Okay,
> solution?
> Timothy
>> Hi all,
>> Thx
>> Timothy
Re: Ordering in Sequence Diagram [message #626668 is a reply to message #477483] |
Dear Rafael,
Timothy
> Cheers,
> Rafael
> Timothy Marc wrote:
>> Okay,
>> solution?
>> Timothy
>>> Hi all,
>>> Thx
>>> Timothy
Current Time: Fri Apr 19 05:59:40 GMT 2024
Powered by FUDForum. Page generated in 0.01971 seconds
