Home » Modeling » UML2 » Standalone Project?
Re: Standalone Project? [message #477350 is a reply to message #477348] |
Mon, 05 May 2008 13:10 |
Günther Falk Messages: 39 Registered: July 2009 |
Member |
Hi Ed,
Yes, this was my first try with this configuration.
This does also not work.
This thing is hopeless, really.
I'm using uml2 in version 2.1.1 and EMF 2.3.2 downloaded last week.
Perhaps these releases don't work with each other, I don't know.
something scary happens every time.
Bye Günther
PS: Have a look at the other threads, there is an example code and model.
Ed Merks schrieb:
> Günther
> You've looked at this too?
> < http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F>
> Günther Falk wrote:
>> Hi Rafael,
>> thanks for the reply
>> Rafael Chaves schrieb:
>>> I take you are referring to the UML2 FAQ? The EMF FAQ has several
>>> questions around using EMF in standalone Java applications, you
>>> should read it too:
>> Thanks I read it and I added some line, but finally it does not work ;(
>>> > Something essential is
>>> > missing and the application does not do very well.
>>> Could you provide more details?
>> When I load the .uml file, it does not recognize a profile application
>> node.
>> When I load it from a URI ( which finally is the same as above) which
>> I got it from the Classloader.getResource() it recognizes the profile
>> application, but then it has problems with the stereotypes (I have a
>> hole thread with problems committed on this problem).
>> I see that the .eResource() returns null for the uml type but it
>> should not.
>> I have no idea and I'm finally switching to a plugin project.
>> Hope in future releases this would be better!!!!!
>> Günther
>>> Cheers,
>>> Rafael
>>> Günther Falk wrote:
>>>> Hi,
>>>> Has anyone ever tried to do a standalone application with UML2?
>>>> I tried but the information is not sufficient. Something essential
>>>> is missing and the application does not do very well.
>>>> The examples are also only plugins.
>>>> Could anyone give a real Howto for a standalone application please?
>>>> Thanks for every reply.
>>>> Günther
>>>> PS: Yes, I read the FAQ!
Re: Standalone Project? [message #477354 is a reply to message #477350] |
Mon, 05 May 2008 14:18 |
Ed Merks Messages: 33136 Registered: July 2009 |
Günther,
Perhaps there are missing magical incantations. The beauty of OSGi is
that it allows us to support registrations to configure the environment
declaratively. When running standalone, none of that is available and
all registrations must be done the old and rotten way. If you
described/showed exactly what you tried and described the details of
what's failing, someone can help you. And then you could update the
wiki with your experience so the next person doesn't have to discover
the same issues.
Günther Falk wrote:
> Hi Ed,
> Bye Günther
> Ed Merks schrieb:
>> Günther
>> Günther Falk wrote:
>>> Hi Rafael,
>>>> should read it too:
>>> application node.
>>> which I got it from the Classloader.getResource() it recognizes the
>>> profile application, but then it has problems with the stereotypes
>>> (I have a hole thread with problems committed on this problem).
>>> should not.
>>> Günther
>>>> Cheers,
>>>> Rafael
>>>> Günther Falk wrote:
>>>>> Hi,
>>>>> Günther
Ed Merks
Re: Standalone Project? [message #626528 is a reply to message #477348] |
Member |
Hi Ed,
Bye Günther
Ed Merks schrieb:
> Günther
> Günther Falk wrote:
>> Hi Rafael,
>>> should read it too:
>> node.
>> should not.
>> Günther
>>> Cheers,
>>> Rafael
>>> Günther Falk wrote:
>>>> Hi,
>>>> Günther
Re: Standalone Project? [message #626533 is a reply to message #477350] |
Günther,
the same issues.
Günther Falk wrote:
> Hi Ed,
> Bye Günther
> Ed Merks schrieb:
>> Günther
>> Günther Falk wrote:
>>> Hi Rafael,
>>>> should read it too:
>>> application node.
>>> should not.
>>> Günther
>>>> Cheers,
>>>> Rafael
>>>> Günther Falk wrote:
>>>>> Hi,
>>>>> Günther
Ed Merks
Current Time: Thu Apr 18 23:30:01 GMT 2024
Powered by FUDForum. Page generated in 0.02021 seconds
