Home » Modeling » UML2 » Re: XMI Parser
Re: XMI Parser [message #477309] |
Thu, 01 May 2008 11:58 |
Ed Merks Messages: 33140 Registered: July 2009 |
--------------030100080004050309000608
Naeem,
Comments below.
Khan wrote:
> hallo every one,
> I am intermediate level Java programmer. I have to parse the XMI 2.0
> to check the classes, its attributes, data types and relations among
> classes (Class diagram converted from UML2 into XMI). I am trying
> since 2 months. First I followed a book called Mastering XMI with
> Netbeans. It was not good enough. Then I came to EMF and Ecore. I like
> to have clear example where I can access my XMI and grab every object
> in it. Could any one help me out to make my concept clear with some
> examples.
> I am also trying to get any tutorial about this. But didnt find any.
There is a common misconception that you can just throw an XMI
serialization at a system and out will pop well formed model. Of course
this misconception is aided by the fact that this is generally how it's
supposed to work. The misconception part is that you can throw any old
XMI serialized instance at the system with the expectation that nice a
model will pop out. In reality the system must effectively know the
model that corresponds to each namespace mentioned in the XMI
serialization and if it doesn't know that model in intimate detail, the
XMI is just so much meaningless syntax.
Given you have a UML2 serialization, it's best to ask on the UML2
newsgroup how to read it; I've added that group to the "to" list of the
reply. Of course starting with the documentation at their website would
be best:
<http://www.eclipse.org/modeling/mdt/?project=uml2>
http://wiki.eclipse.org/index.php/MDT-UML2
> Your help definitely will bring me out from this problem.
> Best Regards,
> Naeem Khan
<html>
<head>
http-equiv="Content-Type">
</head>
Naeem,<br>
<br>
Comments below.<br>
<br>
<br>
Khan wrote:
<blockquote
cite="mid:06d44eb0c2099cb2bffcd74b6636103f$1@www.eclipse.org"
type="cite">hallo every one,
<br>
<br>
I am intermediate level Java programmer. I have to parse the XMI 2.0 to
classes (Class diagram converted from UML2 into XMI). I am trying since
2 months. First I followed a book called Mastering XMI with Netbeans.
It was not good enough. Then I came to EMF and Ecore. I like to have
clear example where I can access my XMI and grab every object in it.
Could any one help me out to make my concept clear with some examples. <br>
<br>
</blockquote>
Ed Merks
Re: XMI Parser [message #477310 is a reply to message #477309] |
Thu, 01 May 2008 14:21 |
Originally posted by: naeemkhans79.hotmail.com
Thank you for your answer. But I might have wrong conception about reading
XMI files. I have already asked help in UML2 Newsgroup, as you recommend
me. Could you please give me any idea how would you do this task.
Further more, I dont have to generate any UML model. I have already
exported XMI file which I have to parse. How can I do this??
regards,
Khan
Re: XMI Parser [message #477315 is a reply to message #477311] |
Thu, 01 May 2008 20:45 |
thanks for giving time. Basically, I am Using EclipseUML 3.3.2 and it is
based on UML 2.0 which is completable with XMI 2.0. If you have any Idea
what should better to use then please let me know. What I did is, I just
made Ecore Model and then opened it with Text Editor, copy the XMI Code
and saved with notepad with XMI Extension. I guess It is damn what I
did??? :-) But your recommendation are really welcome.
Khan
Re: XMI Parser [message #477319 is a reply to message #477316] |
Fri, 02 May 2008 09:28 |
ja sure, below you can see the code of copied file as XMI from Ecore Model.
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="myFactory">
<eClassifiers xsi:type="ecore:EClass" name="Customer">
<eOperations name="getCstID" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EBigInteger"/>
<eOperations name="getCustomerStatus" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CstID"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CustomerStatus"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
</eClassifiers>
</ecore:EPackage>
I like to parse this file and grab the object like Class Customer, Its
Properties and data types, and relations. What I have written the code in
java is you see here.
package src;
import org.eclipse.emf.common.util.TreeIterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
public class parser {
public static void main(String[] args){
// create resource set and resource
try{
ResourceSet resourceSet = new ResourceSetImpl();
// Register XML resource factory
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xmi",
new XMIResourceFactoryImpl());
URI uri =
org.eclipse.emf.common.util.URI.createURI("C:/EcoreCustomer.XMI ");
Resource resource = resourceSet.createResource(uri);
TreeIterator ti = resource.getAllContents();
while (ti.hasNext()){
System.out.println(ti.getClass().getSimpleName());
}// end of try
catch (NullPointerException e){
e.getStackTrace();
Am I doing in the right thing to grab the XMI file saved on C: drive???
please help me out.
Khan
Re: XMI Parser [message #477328 is a reply to message #477321] |
Fri, 02 May 2008 15:17 |
Ed Merks,
If I change the suffix in lower case would it work, will I be able to read
XMI??? As you said, it is totally unrelated for UML instance. Well Merks,
I only have to write a java class where I can read stored Xmi file,
supposedly I have already converted XMI file saved some where on my
computer. In this case, am I going right???
Re: XMI Parser [message #477335 is a reply to message #477333] |
Fri, 02 May 2008 16:22 |
where can i find EMF tutorials and how can I generate Test Code?? can you
send me a link of that tutorial???
Re: XMI Parser [message #477338 is a reply to message #477336] |
Sun, 04 May 2008 16:38 |
hi Ed Merks,
I am back to you after having detail EMF tutorial and your fantastic
online demostration of EMF round trip. Ecore to Java and back to it.
Well, EMF it very cool thing to facilitate modeling and programing world.
I can now create Ecore model based on any UML class diagram. and then What
I understood is to generate EMF Model which is called *.genmodel to
generate java codes.
I saw in your presentation project architecture which you created as Empty
EMF Project. It provides you Model folder and META-INF folder and other
two things I have seen (Plug-in Dependencies, and JRE System Library) that
I dont get any, when I create any Empty EMF Project.
But code generator I have seen. I will also generate code in my case
depending upon what I have made UML Class diagram. SO far it is fine, and
I uderstood. But later I need to parse the generated classes. Could you
please guide me how can i do this???
Khan
Re: XMI Parser [message #477340 is a reply to message #477339] |
Sun, 04 May 2008 17:45 |
of course, that was not in tutorial but I have seen similar example in
your live demonstration (uploaded at eclipse.org) that generates *.tests
folders. But please recommend me how can I parse UML model which is
generated as classes by *.genmodel (generate options).
Re: XMI Parser [message #477341 is a reply to message #477340] |
Sun, 04 May 2008 20:45 |
Khan,
I'm not sure if you mean instances of UML itself or just a model for
which you happened to use UML as the way to define it. If the former,
the using the generated example is good, if the latter, then using the
documentation from the UML website is good.
> *.tests folders. But please recommend me how can I parse UML model
> which is generated as classes by *.genmodel (generate options).
Ed Merks
Re: XMI Parser [message #626470 is a reply to message #477309] |
regards,
Khan
Re: XMI Parser [message #626476 is a reply to message #477311] |
Khan
Re: XMI Parser [message #626480 is a reply to message #477316] |
</eClassifiers>
</ecore:EPackage>
package src;
try{
URI uri =
}// end of try
e.getStackTrace();
please help me out.
Khan
Re: XMI Parser [message #626482 is a reply to message #477319] |
Fri, 02 May 2008 11:00 |
Khan,
Now the example seems completely unrelated to a serialized UML
instance. You're also using an upper case fix suffix, although you
registered a lower case one. And you're using a OS-dependent file
system path as if it were a URI. If you're just working with a simple
EMF model, I'd suggest you follow one of our tutorials, and invoke
"Generate Test Code" in the generator. That will produce a *.tests
project with an XyzExample.java that illustrates what you need to do to
read and write instances of that model in a stand-alone program.
> Model.
> xmlns:xmi="http://www.omg.org/XMI"
> name="CustomerStatus" eType="ecore:EDataType
> </eClassifiers>
> </ecore:EPackage>
> code in java is you see here.
> package src;
> // create resource set and resource try{
> URI uri =
> }// end of try
> e.getStackTrace();
> drive??? please help me out.
> Khan
Ed Merks
Re: XMI Parser [message #626489 is a reply to message #477321] |
Ed Merks,
Re: XMI Parser [message #626510 is a reply to message #477328] |
Fri, 02 May 2008 16:03 |
Khan,
If you follow the EMF tutorial using your Ecore model and do what I
suggested to generate the example, that will provide you a working
example of what you need specific to your model. That's the best I can
offer.
Khan wrote:
> Ed Merks,
> read XMI??? As you said, it is totally unrelated for UML instance.
> Well Merks, I only have to write a java class where I can read stored
> Xmi file, supposedly I have already converted XMI file saved some
> where on my computer. In this case, am I going right???
Ed Merks
Re: XMI Parser [message #626513 is a reply to message #477333] |
Re: XMI Parser [message #626514 is a reply to message #477335] |
Fri, 02 May 2008 16:30 |
--------------010907050800000600000201
Khan,
Have a look at the tutorials on this page
http://www.eclipse.org/modeling/emf/docs/
These tutorials describe how to use the Generator to "Generate Model
Code". You'll see "Generate Test Code" on the same popup menu.
> you send me a link of that tutorial???
<html>
<head>
</head>
Khan,<br>
<br>
Have a look at the tutorials on this page<br>
<blockquote><a href="http://www.eclipse.org/modeling/emf/docs/">http://www.eclipse.org/modeling/emf/docs/</a><br>
</blockquote>
Code".
Ed Merks
Re: XMI Parser [message #626516 is a reply to message #477336] |
hi Ed Merks,
Khan
Re: XMI Parser [message #626517 is a reply to message #477338] |
Sun, 04 May 2008 17:06 |
Khan,
So you've invoked Generate Test Code and you have a *.tests project with
an XyzExample? This wasn't shown in the tutorials...
An empty project is useful for if you want to build your modeling from
annotated Javadoc or want to create an Ecore model directly. Once you
generate code into that project, the plugin.xml should be generated and
the MANFIEST.MF will be updated.
Khan wrote:
> hi Ed Merks,
> world. I can now create Ecore model based on any UML class diagram.
> and then What I understood is to generate EMF Model which is called
> *.genmodel to generate java codes.
> Empty EMF Project. It provides you Model folder and META-INF folder
> and other two things I have seen (Plug-in Dependencies, and JRE System
> Library) that I dont get any, when I create any Empty EMF Project.
> and I uderstood. But later I need to parse the generated classes.
> Could you please guide me how can i do this???
> Regards,
> Khan
Ed Merks
Re: XMI Parser [message #626518 is a reply to message #477339] |
Re: XMI Parser [message #626519 is a reply to message #477340] |
Khan,
Ed Merks
Current Time: Tue Apr 23 16:55:54 GMT 2024
Powered by FUDForum. Page generated in 0.05431 seconds
