Re: EMF and UML2 M5 install issue [message #477126 is a reply to message #477080] |
Tue, 25 March 2008 20:57 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Dave,
Any luck with the integration builds? I've been told that this
incompatibilty issue was resolved both on the update site and in the M5
downloads... If this still isn't the case, please let us know.
Kenn
"Dave Carlson" <dcarlson@xmlmodeling.com> wrote in message
news:fr8ss5$46j$1@build.eclipse.org...
>I discovered this problem by downloading all M5 builds for UML, EMF, GMF,
>EMFT, etc. I did not mix M and I builds.
> I had tried to create the same environment using Ganymede update site, and
> the EMF/UML conflict did not arise. I had what appeared to be a complete
> set of features, but during development I could not view sources for any
> EMF components, and couldn't find a way to get this via Ganymede update.
> So I started over and rebuilt my environment by downloading all M5 zips
> without using the update site. Maybe I should try the same using a
> coordinated set of I builds.
> I realize that this is a temporary situation.
> Dave
> "James Bruck" <jbruck@ca.ibm.com> wrote in message
> news:fr8mit$rn7$2@build.eclipse.org...
>> There were some issues around the M5 build.
>> 1. Right after M5 the version numbers for EMF and UML changed. If you
>> were to mix an 'I' build after M5 of EMF with a UML M5 then they would be
>> incompatible.
>> 2. There have been numerous issues with the Ganymede update site.
>> Problems with mirroring etc. In the inital testing phase I had to
>> resort to testing bits from local servers since Ganymede was
>> inaccessible.
>> Getting all the bits from the UML download site for M5 should be your
>> best bet. Please give that a try.
>> I will double check the Ganymede download site once more to try and
>> reproduce your issue.
Re: EMF and UML2 M5 install issue [message #477136 is a reply to message #477126] |
Wed, 26 March 2008 14:01 |
Dave Carlson Messages: 402 Registered: July 2009 |
Kenn,
I have not tried the I-builds and am working with M5 (and a few projects
from CVS). I'll try to allocate some time to test this.
Dave
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> wrote in message
news:fsbov8$a4h$1@build.eclipse.org...
> Dave,
> Kenn
>> and the EMF/UML conflict did not arise. I had what appeared to be a
>> complete set of features, but during development I could not view sources
>> for any EMF components, and couldn't find a way to get this via Ganymede
>> update. So I started over and rebuilt my environment by downloading all
>> M5 zips without using the update site. Maybe I should try the same using
>> a coordinated set of I builds.
Re: EMF and UML2 M5 install issue [message #626261 is a reply to message #477080] |
Dave,
Kenn
> Dave
>> incompatible.
>> inaccessible.
Re: EMF and UML2 M5 install issue [message #626270 is a reply to message #477126] |
Kenn,
Dave
> Dave,
> Kenn
FUDForum. Page generated in 0.03881 seconds
