Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Flash player plugin for safari embedded in SWT
Flash player plugin for safari embedded in SWT [message #476970] Thu, 06 August 2009 03:11 Go to next message
Originally posted by: yochrislam.gmail.com
Hello everyone,
we are developing a eclipse SWT app with a browser widget for mac.
we found that the embedded browser cannot access any flash content as if
Flash Player is not installed.
As I know SWT use safari as the rendering engine on mac and I tried to
open site with flash content with a standalone safari and it works fine.
So I am sure I have flash player for safari installed.
My environment is
Mac OS X (10.5.7)
Safari 4.0.1
Flash Player 10
JVM 1.6
Eclipse SWT 3.5 cocoa x86_64
Does anyone has a hint?
Any input is appreciated. Thank you.
Re: Flash player plugin for safari embedded in SWT [message #481841 is a reply to message #476970] Mon, 24 August 2009 14:02 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
Hi Chris, sorry for the late reply,
I've just tried this, and it looks like this fails on OSX when using 64-bit
but works for 32-bit. So a workaround you can use, assuming that you don't
require Java 6, is to use eclipse's 32-bit cocoa release instead.
I haven't looked into why this difference happens yet, but my guess is that
the Flash player cannot run as a 64-bit plug-in. It may work in stand-alone
Safari if Safari is not actually launching as a 64-bit app, but when 64-bit
eclipse embeds Safari it has to be running in 64-bit mode to match. I've
logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=287440 as a reminder to
investigate this.
Grant
"Chris Lam" <yochrislam@gmail.com> wrote in message
news:3ab3c68e6442221bddae96ac733ca072$1@www.eclipse.org...
> Hello everyone,
> My environment is
> Mac OS X (10.5.7)
> Safari 4.0.1
> Flash Player 10
> JVM 1.6
Re: Flash player plugin for safari embedded in SWT [message #481901 is a reply to message #481841] Mon, 24 August 2009 16:47 Go to previous messageGo to next message
thanks Grant.
seems we have no luck as we require JVM6 for our project.
lets try to take a step back..
is it possible to run 32bit SWT on JVM6 for mac?
I tried before and I got a "cannot load 32-bit swt libraries on 64-bit
jvm" error
is there something I can work around for this?
cheers,
Chris Lam
Re: Flash player plugin for safari embedded in SWT [message #481924 is a reply to message #481901] Mon, 24 August 2009 17:49 Go to previous messageGo to next message
Unfortunately you need to be running 64-bit in order to use Apple's 1.6 JVM,
so I don't think there's a workaround opportunity here. However according
to https://bugs.eclipse.org/bugs/show_bug.cgi?id=276564#c26 eclipse launches
with OpenJDK, so you could try this instead of Apple's JVM if you're feeling
adventurous (I'm assuming it's available in a 32-bit flavour, but have never
tried).
If I investigate and find anything more then I'll update the bug report, so
you should CC yourself to it. But at this point I don't think it's an swt
bug because the Browser has no role in the launching of plug-ins.
Grant
news:def6319f008784d6886f59325e26bc82$1@www.eclipse.org...
> thanks Grant.
> jvm" error
> cheers,
> Chris Lam
Re: Flash player plugin for safari embedded in SWT [message #482128 is a reply to message #481924] Tue, 25 August 2009 13:03 Go to previous message
FYI: How timely: http://java.dzone.com/news/32-bit-java-6-mac-os-x-snow
"Grant Gayed" <grant_gayed@ca.ibm.com> wrote in message
news:h6ujrp$149$1@build.eclipse.org...
JVM,
launches
feeling
never
> tried).
so
> Grant
> > thanks Grant.
> > jvm" error
> > cheers,
> > Chris Lam
Previous Topic:libswt-motif-3452.so : Bad Magic Number
Next Topic:CDateTime invalid time entry
Current Time: Wed Jan 29 04:21:05 GMT 2020
Powered by FUDForum. Page generated in 0.01615 seconds
