Home » Modeling » UML2 » Propagating stereotypes for all components
Propagating stereotypes for all components [message #476917] Fri, 08 February 2008 09:54 Go to next message
Originally posted by: antti.evesti.vtt.fi
Is it possible to define and connect a UML profile to the component diagram,
i.e. component element, in a way that propagates all stereotypes from the
profile for all the components inside the diagram? Now, I have to connect a
stereotype separately for each component and this is laborious task if there
is dozens components.
I mentioned following statement from the UML superstructure
A profile should be able to specialize the semantics of standard UML
metamodel elements. For example, in a model with the profile "Java model,"
generalization of classes should be able to be restricted to single
inheritance without having to explicitly assign a stereotype
Re: Propagating stereotypes for all components [message #476918 is a reply to message #476917] Fri, 08 February 2008 14:34 Go to previous messageGo to next message
james bruck is currently offline james bruckFriend
Hi Antti,
When you create your uml::Extension, you can set the isRequired() to true.
Later, when the profile is applied, all required stereotypes will also be
applied.
In this way, you would not have to apply each Stereotype individually.
I'm not sure if this is exactly what you were looking for.
- James.
"Antti Evesti" <antti.evesti@vtt.fi> wrote in message
news:foh8su$frl$1@build.eclipse.org...
> Hello,
> diagram, i.e. component element, in a way that propagates all stereotypes
> from the profile for all the components inside the diagram? Now, I have to
> connect a stereotype separately for each component and this is laborious
> task if there is dozens components.
Re: Propagating stereotypes for all components [message #476924 is a reply to message #476918] Mon, 11 February 2008 08:31 Go to previous message
Thanks! That was exactly what I meant.
Antti
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fohpak$qd0$2@build.eclipse.org...
> Hi Antti,
> applied.
> Cheers,
> - James.
>> Hello,
>> to connect a stereotype separately for each component and this is
>> laborious task if there is dozens components.
>> model," generalization of classes should be able to be restricted to
>> single inheritance without having to explicitly assign a stereotype
Re: Propagating stereotypes for all components [message #625996 is a reply to message #476917] Fri, 08 February 2008 14:34 Go to previous message
Hi Antti,
applied.
- James.
> Hello,
Re: Propagating stereotypes for all components [message #626023 is a reply to message #476918] Mon, 11 February 2008 08:31 Go to previous message
Antti
> Hi Antti,
> applied.
> Cheers,
> - James.
>> Hello,
Previous Topic:how to find out the type of element in a package
Next Topic:Re: uml2 file format
Current Time: Sat Sep 24 20:04:01 GMT 2022
Powered by FUDForum. Page generated in 0.03738 seconds
