Getting stereotype's property values. [message #476913] |
Thu, 07 February 2008 13:36 |
Originally posted by: antti.evesti.vtt.fi
I have connected a stereotype for a component element. Now I try to get
properties and their values from that stereotype, how I should do this?
Following code gives properties' names correctly, but I cannot find a way to
getting values for these properties. I suppose this is quite trivial task.
However, I cannot find a suitable method for this task.
Antti
<------------------ CODE ----------------------------------->
private void getStereotypes(Component component) {
System.out.println("** Getting stereotypes for " +
component.getLabel());
EList<Stereotype> e = component.getAppliedStereotypes();
for(Stereotype s : e) {
System.out.println(s.getLabel());
EList<Property> el = s.getAttributes();
for(Property p : el) {
System.out.println(p.getLabel());
Re: Getting stereotype's property values. [message #476916 is a reply to message #476915] |
Fri, 08 February 2008 06:41 |
Thanks James!
Article gives an idea, that what I made wrong.
I called property.getValue(stereotype, property.getName()), instead of
component.getValue(stereotype, property.getName()).
BR,
Antti
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fof5c5$ge8$2@build.eclipse.org...
> Hi Antti,
> Have a look at:
> http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
> Cheers,
> - James
> "Antti Evesti" <antti.evesti@vtt.fi> wrote in message
> news:fof1gu$f31$1@build.eclipse.org...
>> Hi
>> to getting values for these properties. I suppose this is quite trivial
>> task. However, I cannot find a suitable method for this task.
>> Thanks,
>> Antti
Re: Getting stereotype's property values. [message #625994 is a reply to message #476915] |
Thanks James!
BR,
Antti
> Hi Antti,
> Have a look at:
> Cheers,
> - James
>> Hi
>> Thanks,
>> Antti
FUDForum. Page generated in 0.03055 seconds
