Home » Modeling » UML2 » AddStructuralFeatureValue constraint
Re: AddStructuralFeatureValue constraint [message #476903 is a reply to message #476902] |
Fri, 01 February 2008 13:02 |
Hi, Krzysztof,
This constraint doesn't make sense to me.
Firstly, the OCL expression is ill-formed: featuringClassifier is a
multi-valued feature, but type is scalar.
Second, this constraint indicates that the value written into a structural
feature must be of the type that defines the feature, but that's silly.
The value should at least be of the type *of* the feature, not the type
*featuring* the feature.
So, I would say that this is an issue for the RTF, and the constraint should
be formulated thus:
self.value.type.conformsTo(self.structuralFeature.type)
This would allow Student instances to be written into a structural feature
of type Person.
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> I found the following constraint on InputPin's value
> self.value.type = self.structuralFeature.featuringClassifier
> in the WriteStructuralFeatureAction which is used in other specialized
> actions (AddStructualFeatureValueAction). The question is, does this
> constraint allow to assign a value of a specialized type to a more
> general property type?
> Like to put a Student object in a property of Person type?
> If such an assignment is not allowed, what is the reason?
> Thanks for any suggestions,
> Krzysztof
Re: AddStructuralFeatureValue constraint [message #476904 is a reply to message #476903] |
Sat, 02 February 2008 07:14 |
Krzysztof Kaczmarski Messages: 88 Registered: July 2009 |
Member |
Thanks, Christian.
What is the procedure of correcting this problem? Is there any way I
can help?
Krzysztof
Christian W. Damus wrote:
> Hi, Krzysztof,
> be formulated thus:
> of type Person.
> Cheers,
> Christian
>> Hi All,
>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #476906 is a reply to message #476904] |
Mon, 04 February 2008 12:26 |
Hi, K,
You can start by searching the list of issues under consideration by the UML
2.2 RTF (revision task force) to see whether this problem has already been
raised (and possibly resolved):
http://www.omg.org/issues/uml2-rtf.html
If this appears to be a new issue, you can report it to OMG via the
issues-reporting form:
http://www.omg.org/technology/agreement.htm
Christian
> Thanks, Christian.
> can help?
> Cheers,
> Krzysztof
>> Hi, Krzysztof,
>> structural feature must be of the type that defines the feature, but
>> that's silly. The value should at least be of the type *of* the feature,
>> not the type *featuring* the feature.
>> should be formulated thus:
>> feature of type Person.
>> Cheers,
>> Christian
>>> Hi All,
>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #476907 is a reply to message #476906] |
Mon, 04 February 2008 12:31 |
Sorry, Krzysztof,
I don't seem to have pasted your complete name. I didn't mean to assume
such familiarity.
Christian
> Hi, K,
> UML 2.2 RTF (revision task force) to see whether this problem has already
> been raised (and possibly resolved):
> Cheers,
> Christian
>> Thanks, Christian.
>> can help?
>> Cheers,
>> Krzysztof
>>> Hi, Krzysztof,
>>> Cheers,
>>> Christian
>>>> Hi All,
>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #476908 is a reply to message #476907] |
Mon, 04 February 2008 17:51 |
james bruck Messages: 1724 Registered: July 2009 |
Hi, Krzysztof
I could raise that on your behalf if you wish.
(The OMG process might be a bit cumbersome if you want to raise only one
issue).
....special thanks to "big-C" for confirming this as an issue ... ;-)
- J.
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fo70jh$8fd$3@build.eclipse.org...
> Sorry, Krzysztof,
> such familiarity.
> Christian
>> Hi, K,
>> Cheers,
>> Christian
>>> Thanks, Christian.
>>> can help?
>>> Cheers,
>>> Krzysztof
>>>> Hi, Krzysztof,
>>>> feature,
>>>> Cheers,
>>>> Christian
>>>>> Hi All,
>>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #476909 is a reply to message #476908] |
Tue, 05 February 2008 12:59 |
Member |
Yes, it really is. How can I know all those informations about
document if they are not explicitly stated in the first page?
What should be taken for "Document #"?
James, If it is not a problem. Please fill free to rise this issue.
It would be great if Polish-Japanese Institute of Information
Technology could be present somewhere in the description.
Krzysztof
James Bruck wrote:
> Hi, Krzysztof
> issue).
> Cheers,
> - J.
>> Sorry, Krzysztof,
>> such familiarity.
>> Christian
>>> Hi, K,
>>> Cheers,
>>> Christian
>>>> Thanks, Christian.
>>>> can help?
>>>> Cheers,
>>>> Krzysztof
>>>>> Hi, Krzysztof,
>>>>> feature,
>>>>> Cheers,
>>>>> Christian
>>>>>> Hi All,
>>>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #476910 is a reply to message #476908] |
Tue, 05 February 2008 13:01 |
Member |
Oh, and I checked that there are no issues like this among already
submitted. It looks to be a new one.
KK
James Bruck wrote:
> Hi, Krzysztof
> issue).
> Cheers,
> - J.
>> Sorry, Krzysztof,
>> such familiarity.
>> Christian
>>> Hi, K,
>>> Cheers,
>>> Christian
>>>> Thanks, Christian.
>>>> can help?
>>>> Cheers,
>>>> Krzysztof
>>>>> Hi, Krzysztof,
>>>>> feature,
>>>>> Cheers,
>>>>> Christian
>>>>>> Hi All,
>>>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625981 is a reply to message #476902] |
Hi, Krzysztof,
be formulated thus:
of type Person.
Christian
> Hi All,
> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625982 is a reply to message #476903] |
Member |
Thanks, Christian.
can help?
Krzysztof
> Hi, Krzysztof,
> be formulated thus:
> of type Person.
> Cheers,
> Christian
>> Hi All,
>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625984 is a reply to message #476904] |
Hi, K,
Christian
> Thanks, Christian.
> can help?
> Cheers,
> Krzysztof
>> Hi, Krzysztof,
>> Cheers,
>> Christian
>>> Hi All,
>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625985 is a reply to message #476906] |
Sorry, Krzysztof,
such familiarity.
Christian
> Hi, K,
> Cheers,
> Christian
>> Thanks, Christian.
>> can help?
>> Cheers,
>> Krzysztof
>>> Hi, Krzysztof,
>>> Cheers,
>>> Christian
>>>> Hi All,
>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625986 is a reply to message #476907] |
Hi, Krzysztof
issue).
- J.
> Sorry, Krzysztof,
> such familiarity.
> Christian
>> Hi, K,
>> Cheers,
>> Christian
>>> Thanks, Christian.
>>> can help?
>>> Cheers,
>>> Krzysztof
>>>> Hi, Krzysztof,
>>>> feature,
>>>> Cheers,
>>>> Christian
>>>>> Hi All,
>>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625987 is a reply to message #476908] |
Member |
Krzysztof
James Bruck wrote:
> Hi, Krzysztof
> issue).
> Cheers,
> - J.
>> Sorry, Krzysztof,
>> such familiarity.
>> Christian
>>> Hi, K,
>>> Cheers,
>>> Christian
>>>> Thanks, Christian.
>>>> can help?
>>>> Cheers,
>>>> Krzysztof
>>>>> Hi, Krzysztof,
>>>>> feature,
>>>>> Cheers,
>>>>> Christian
>>>>>> Hi All,
>>>>>> Krzysztof
Re: AddStructuralFeatureValue constraint [message #625988 is a reply to message #476908] |
Member |
KK
James Bruck wrote:
> Hi, Krzysztof
> issue).
> Cheers,
> - J.
>> Sorry, Krzysztof,
>> such familiarity.
>> Christian
>>> Hi, K,
>>> Cheers,
>>> Christian
>>>> Thanks, Christian.
>>>> can help?
>>>> Cheers,
>>>> Krzysztof
>>>>> Hi, Krzysztof,
>>>>> feature,
>>>>> Cheers,
>>>>> Christian
>>>>>> Hi All,
>>>>>> Krzysztof
Current Time: Thu Apr 25 07:15:21 GMT 2024
Powered by FUDForum. Page generated in 0.04179 seconds
