Home » Modeling » UML2 » xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ?
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #476895 is a reply to message #476894] |
Tue, 29 January 2008 14:56 |
Rene Ladan Messages: 51 Registered: July 2009 |
Member |
James Bruck wrote:
> Hi Rene,
> Downgrading from UML 2.0 to UML 1.3 is not supported by this opensource
> project so if you need this capability you will have to extract the
> information yourself.
Ok ...
> Keep in mind that the UML metamodel has changed quite dramatically between
> those versions. If you intend to do this migration I would expect there to
> be a loss of data.
I expect some data loss too, but not all data is important for the task at hand.
> Also have a look at
> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 1_Migration_Guide/guide.html
> in addition to the one you found
> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
> Cheers,
> - James.
> "Rene Ladan" <r.c.ladan@tue.nl> wrote in message
> news:fnmrqq$qa$1@build.eclipse.org...
>> Hi,
>> is it possible to use EMF / UML2 to downgrade an UML 2.0/2.1 model
>> serialized as XMI 2.1 to a UML 1.3 model serialized as XMI 1.1 ?
>> The original model consists of an XMI, UML, and EMX file.
>> I can correctly load the XMI file and show the XMI version using
>> getXMIVersion().
>> Unfortunately, setXMIVersion() only seems to change the XMI version field,
>> it doens't instruct EMF/UML2 to write XMI 1.1 ...
>> I stumbled over
>> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html#_Migration
>> but that seems more appropriate for UML 2.0 -> UML 2.1.1 conversions?
>> An alternative would be to write an XSLT script which extracts/converts
>> the part I need.
>> Thanks,
>> Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #625951 is a reply to message #476894] |
Member |
James Bruck wrote:
> Hi Rene,
Ok ...
> be a loss of data.
> Also have a look at
> Cheers,
> - James.
>> Hi,
>> getXMIVersion().
>> I stumbled over
>> the part I need.
>> Thanks,
>> Rene
Current Time: Sat Apr 20 01:11:53 GMT 2024
Powered by FUDForum. Page generated in 0.03172 seconds
