How to save UML2 model as XMI (standalone) [message #476832] |
Mon, 07 January 2008 23:33 |
Originally posted by: jlansing.spawar.navy.mil
When I save my Model (from a standalone Java app) I don't get the top level
xmi:XMI element. Instead, the uml:Model element is at the top level.
I've tried using both .xmi and .uml extensions. (Interesting differences
result, but this isn't one of them).
My code is this:
public void save(Model model, String pathName) {
URI uri = URI.createURI("file:///" + pathName.replace('\\', '/'));
ResourceSetImpl resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(Ecore2XMLResource.FILE_EXTENSION,
Ecore2XMLResource.Factory.INSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(XMI2UMLResource.FILE_EXTENSION,
XMI2UMLResource.Factory.INSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
Resource resource = resourceSet.createResource(uri);
resource.getContents().add(model);
try {
resource.save(null);
} catch (IOException e) {
e.printStackTrace();
Obviously I've tried to mash together all the examples in the documentation
and what I've found in this newsgroup, but I'm still not getting it.
Re: How to save UML2 model as XMI (standalone) [message #476833 is a reply to message #476832] |
Tue, 08 January 2008 14:13 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Jeff,
Note that the 'XMI' pseudo element is optional in XMI - it's only really
needed if there is more than one "real" root in the document. If you are
using the UML resource implementation, I assume what's happening is your
resource only contains one root (the model), and so the 'XMI' element is not
required...
Kenn
"Jeff Lansing" <jlansing@spawar.navy.mil> wrote in message
news:flucsb$76l$1@build.eclipse.org...
> level xmi:XMI element. Instead, the uml:Model element is at the top level.
> My code is this:
> try {
> documentation and what I've found in this newsgroup, but I'm still not
> getting it.
Re: How to save UML2 model as XMI (standalone) [message #625857 is a reply to message #476832] |
Jeff,
required...
Kenn
> My code is this:
> try {
> getting it.
FUDForum. Page generated in 0.03061 seconds
