Home » Modeling » UML2 » definecustomoperations in UMLEnvironment
definecustomoperations in UMLEnvironment [message #476753] Thu, 13 December 2007 08:33 Go to next message
charfi asma is currently offline charfi asmaFriend
Member
I have this code to define neuw EOperation (the class extend
EcoreEnvironment) and I want to do the same but to define a new Operation
(org.eclipse.uml2.uml.Operation), so my class extend UMLEnvironment instead
the code referred to the class that extend EcoreEnvironment
private void defineCustomOperations() {
EOperation nbligne;
nbligne = EcoreFactory.eINSTANCE.createEOperation();
nbligne.setName("nbligne");
nbligne.setEType(getOCLStandardLibrary().getString());
EAnnotation annotation = EcoreFactory.eINSTANCE.createEAnnotation();
annotation.setSource("MyEnvironment");
nbligne.getEAnnotations().add(annotation);
addOperation(getOCLStandardLibrary().getString(), nbligne);
when I try to define a new UML operation I write this:(I chaged to UML but I
can not find UMLFactory.eINSTANCE.createAnnotation())
Operation nbligne;
nbligne= UMLFactory.eINSTANCE.createOperation();
nbligne.setType(getOCLStandardLibrary().getString());
nbligne.setIsQuery(true);
addOperation(getOCLStandardLibrary().getString(), regexMatch); }
The question is, what is the equivalent of EAnnotation in UML, how to
annotate operation using UML?
thank you very much.
asma
Re: definecustomoperations in UMLEnvironment [message #476754 is a reply to message #476753] Wed, 12 December 2007 23:48 Go to previous messageGo to next message
Charfi,
UML's Element extends EModelElement, so I think you can annotate it
exactly the same way.
charfi asma wrote:
> EOperation nbligne;
> Operation nbligne;
> asma
Ed Merks
Re: definecustomoperations in UMLEnvironment [message #476756 is a reply to message #476754] Thu, 13 December 2007 19:39 Go to previous message
Member
when I write EAnnotation annotation =
UMLFactory.eINSTANCE.createEAnnotation();
it did not work. there is no createEAnnotation() methode in UMLFactory.
did you mean I should import org.eclipse.emf.ecore.EcoreFactory;and use it
instead of UMLFactory in all my classes?
If yes, I write EAnnotation annotation =
EcoreFactory.eINSTANCE.createEAnnotation(); but I still have problem in
callOperation.
this method is not executed.
before, I have this error "Cannot call operation (regexMatch) because it is
not a query" and Christian Damus sugest to add Operation::setIsQuery(true)
and it reseolved the first problem (operation is not a query).
thank you!
"Ed Merks" <merks@ca.ibm.com> a
Re: definecustomoperations in UMLEnvironment [message #476757 is a reply to message #476756] Thu, 13 December 2007 14:32 Go to previous message
Hi, Asma,
Yes, you can use the EcoreFactory to create an annotation, but the UML2 API
also provides a factory method on its elements. See
Element::createAnnotation(source : String) : EAnnotation
Christian
charfi asma wrote:
> callOperation.
> is not a query" and Christian Damus sugest to add
> Operation::setIsQuery(true) and it reseolved the first problem (operation
> is not a query).
> thank you!
-----8<-----
Re: definecustomoperations in UMLEnvironment [message #625727 is a reply to message #476753] Wed, 12 December 2007 23:48 Go to previous message
Charfi,
charfi asma wrote:
> EOperation nbligne;
> Operation nbligne;
> asma
Ed Merks
Re: definecustomoperations in UMLEnvironment [message #625728 is a reply to message #476754] Thu, 13 December 2007 19:39 Go to previous message
Member
callOperation.
thank you!
Re: definecustomoperations in UMLEnvironment [message #625729 is a reply to message #476756] Thu, 13 December 2007 14:32 Go to previous message
Hi, Asma,
Christian
charfi asma wrote:
> callOperation.
> is not a query).
> thank you!
-----8<-----
Previous Topic:definecustomoperations in UMLEnvironment
Next Topic:A question about the code
Current Time: Fri Dec 08 07:25:41 GMT 2023
Powered by FUDForum. Page generated in 0.02126 seconds
