Re: Initial Model Object [message #476316 is a reply to message #476312] |
Wed, 11 February 2009 11:43 |
Tatiana Fesenko Messages: 530 Registered: July 2009 |
Hi John,
> ...I want to have one model per project with multiple packages.
> Should I create a Model then create multiple packages in the Class
> Diagram or should I create one Model and multiple Packages?
John, I think you can get a more comprehensive answer when to use a Model,
and when to use a Package in UML2 newsgroup.
Although a Model and a Package hold slightly different functionality, the
diagram editor process them the same way. From the point of view of diagram
editor there is no difference what to create - a Model or a Package. Top-level
_Model_ with inner packages will work fine, top-level _Package_ with inner
packages will work fine as well.
> When I do choose Model and Initialize a/the Class Diagram, the icon I
> see in the top-left corner of the diagram is labelled Package. Is that
> a bug?
Yes, it is, in accordance with the specification a model should have '<<model>>'
label on the top. Feel free to submit a bug.
Best wishes,
Tanya.
Re: Initial Model Object [message #623598 is a reply to message #476312] |
Hi John,
> a bug?
Best wishes,
Tanya.
FUDForum. Page generated in 0.03248 seconds
