enable design time only css external resource in page designer [message #476037] |
Tue, 21 October 2008 21:57 |
Originally posted by: Eclipsian.eclipsian.oti
External css can be enabled by link tag as normal HTML. But for custom
components, their default css resources are packed in jar file and they
can be accessed in component renderer. So even there is no link tag in
faces page to define external css, the renderers have problem to render
component in runtime. But for Web Page Designer, they cannot be resolved
unless you have link tag and have those css resources copied in web
root. If I create a plugin bundled with those css resources, how can I
manipulate design time dom via an (?) extension point. Or if there is
better solution?
Thanks ahead.
Re: enable design time only css external resource in page designer [message #476038 is a reply to message #476037] |
Tue, 21 October 2008 21:59 |
sorry!
typo:
> So even there is no link tag in faces page to define external css,
the > renderers have <no> problem to render component in runtime.
> better solution?
> Thanks ahead.
Re: enable design time only css external resource in page designer [message #476039 is a reply to message #476037] |
Thu, 23 October 2008 17:55 |
Ian Trimble Messages: 137 Registered: July 2009 |
Eclipsian (if that is, in fact, your real name :) ),
We're currently looking at requirements for supporting "skinning" (such as
Trinidad allows) at design-time. One requirement will be the ability to
somehow register one or more stylesheets and image sets (i.e. "skins"),
and ultimately select any one at any time. This feature will need to
provide some method to specify design-time CSS, which may be the solution
your are looking for. But, I suspect you're looking for an
already-existing solution, and frankly, I can't see one right now. If you
do find a solution, please share your experience here - it may just be
what is required for skinning support.
- Ian
> better solution?
> Thanks ahead.
Re: enable design time only css external resource in page designer [message #618567 is a reply to message #476037] |
sorry!
typo:
> better solution?
> Thanks ahead.
Re: enable design time only css external resource in page designer [message #618568 is a reply to message #476037] |
- Ian
> better solution?
> Thanks ahead.
FUDForum. Page generated in 0.04180 seconds
