Home » Eclipse Projects » JavaServer Faces » How metadata files generated
How metadata files generated [message #475992] |
Wed, 16 July 2008 21:49 |
Originally posted by: Eclipsian.eclipsian.oti
In order to integrate custom components into Eclipse, a set of metadata
files are required such as metadata for tag creation, content
assistance, attributes list and quick editors. I wonder how the
attributes metadata for Sun RI components and Trinidad are generated?
Manually? Is there such a kind of tool available? Generate metadata for
attribute sheet is tidious.
Thx
Re: How metadata files generated [message #475995 is a reply to message #475994] |
Thu, 17 July 2008 21:44 |
Yury Kats wrote:
> On 7/16/2008 7:18 PM, Gerry Kessler wrote:
>> As you have discovered, there is no editor to simplify the creation, or
>> modification, of a tag library metadata file. However, Yury Kats of IBM
>> has made a utility available that will generate a starting point metadata
>> file of all of the tag and attribute entities. You will find it attached
>> to: https://bugs.eclipse.org/bugs/show_bug.cgi?id=181674.
> Keep in mind, it's over a year old now and hasn't been updated since.
Yes. It was for WTP 2.0 not WTP 3.0.
It helps but not a lot. I wonder if it is possible to do some more work
based on EMF code in current jst.jsf.core
Re: How metadata files generated [message #475997 is a reply to message #475995] |
Sat, 19 July 2008 00:20 |
Yury Kats Messages: 104 Registered: July 2009 |
Has metadata changed that much between 2.0 and 3.0? I don't think it has.
The tool would give you a skeleton XML that at the very least contains
all tags and all attributes. You can certainly get the same from the EMF model.
I was also creating actual metadata for many common attributes (id, value, rendered,
action, width etc etc). You won't get from the EMF model.
Re: How metadata files generated [message #618322 is a reply to message #475994] |
Re: How metadata files generated [message #618324 is a reply to message #475995] |
Current Time: Wed Apr 24 16:56:14 GMT 2024
Powered by FUDForum. Page generated in 0.03907 seconds
