Home » Eclipse Projects » Platform - User Assistance (UA) » Basic Eclipse UA questions
Basic Eclipse UA questions [message #475663] |
Fri, 26 June 2009 21:03 |
Erlend Leganger Messages: 2 Registered: July 2009 |
I apologize for the newbie questions, but I'm trying to get to know
Eclipse UA with the intent to use it to provide help for a standard
(non-Eclipse) application. I have searched a bit, but haven't found the
answers I need.
I have come so far that I have created two help books, they are stored in
eclipse/plugins/mydoc.ops and /mydoc.tech respectively. When I then start
the InfoCenter and point my web browser at localhost:8080/help/index.jsp,
I see the books Workbench User Guide, Java development user guide,
Platform Plug-in Developer Guide, JDT Plug-in Developer Guide, Plug-in
Development Environment Guide and then finally my two books MyDoc - Ops
and MyDoc - Tech.
And now for the questions:
- How can I control which books are displayed in the navigation pane? I
want to show my books only and not include the Eclipse specific books.
- How can I control the order of the books in the navigation pane?
- Can I change the initial URL from localhost:8080/help/index.jsp to for
example localhost:8080/mydoc/index.jsp?
- Is it possible to get an automatic redirect from localhost:8080 to the
correct URL? If I go to localhost:8080 now, I get an 404 telling me that
no context is matched.
My configuration is Eclipse 3.4.2 on Windows7, slimmed down for Help
purposes using the procedure in
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_setup_standalone.htm.
I suspect I need to work with the files in the plugins directory, so I
have included a complete list of the files at
http://pastebin.com/m58290423 (it's 800+ lines long).
Again sorry for the noob questions, hope you can help.
- Erlend Leganger
Use HELP_DATA to both hide and set ordering for books in nav frame [message #475666 is a reply to message #475663] |
Sat, 27 June 2009 21:39 |
Lee Anne Kowalski Messages: 54 Registered: July 2009 |
Member |
Hi Erlend,
No worries about newbie questions, that's what this group is for!
To hide and to set ordering for the books in the nav frame, use the
HELP_DATA customization preference.
Descriptions of the customization preferences available for the help
system is located here:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_setup_preferences.htm
And details about the HELP_DATA file format are here:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_setup_help_data.htm
For an infocenter, you'd set the plugin_customization parameter to point
to a plugin_customization.ini file, and in that file is where you set
the different customization parameters such as HELP_DATA, banner, etc.
Depending on which way you prefer, you can specify the
plugin_customization parameter on the startup command for the
infocenter, like:
-plugincustomization plugin_customization.ini
or in the plugin.xml file for your "product plug-in", like:
<plugin>
<extension id="myIC" point="org.eclipse.core.runtime.products">
<product name="%name" application="">
<property name="preferenceCustomization" value="plugin_customization.ini" />
</product>
</extension>
And the plugin_customization.ini file would have a line like:
org.eclipse.help/HELP_DATA=helpdata.xml
to point to your helpdata.xml file.
On your other questions about the URL format, I'll have to leave that
for someone else to answer.
Hope this helps,
Lee Anne
> answers I need.
> in eclipse/plugins/mydoc.ops and /mydoc.tech respectively. When I then
> start the InfoCenter and point my web browser at
> localhost:8080/help/index.jsp, I see the books Workbench User Guide,
> Java development user guide, Platform Plug-in Developer Guide, JDT
> Plug-in Developer Guide, Plug-in Development Environment Guide and then
> finally my two books MyDoc - Ops and MyDoc - Tech.
> - Erlend Leganger
Use HELP_DATA to both hide and set ordering for books in nav frame [message #623425 is a reply to message #475663] |
Member |
Hi Erlend,
infocenter, like:
<plugin>
</product>
</extension>
Hope this helps,
Lee Anne
> answers I need.
> - Erlend Leganger
Current Time: Tue Mar 19 11:23:20 GMT 2024
Powered by FUDForum. Page generated in 0.02080 seconds
