Home » Eclipse Projects » Platform - User Assistance (UA) » Please confirm allowable link_to path structures using PLUGINS_ROOT
Please confirm allowable link_to path structures using PLUGINS_ROOT [message #475569] Tue, 26 May 2009 11:37 Go to next message
Would someone on the Eclipse UA team please confirm which of the
following are supposed to work when specified in the link_to attribute?
And which one you would consider is a "best practice"?
Given a doc plug-in with:
pluginID = edition1_1
toc file = edition1_1.xml
anchorID in edition1_1.xml = comps
Trying to anchor into that anchorID using link_to, I see the following
behaviors:
link_to="/../edition1_1/edition1_1.xml#comps Works in Eclipse 3.4.1
link_to="/edition1_1/edition1_1.xml#comps Works
link_to="../edition1_1/edition1_1.xml#comps Works (this is also
in the help doc example in ua_help_content_nested.htm topic)
link_to="PLUGINS_ROOT/edition1_1/edition1_1.xml#comps Works
link_to="/PLUGINS_ROOT/edition1_1/edition1_1.xml#comps Does Not work
Now, the help topic on Content Extensions
( http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_dynamic_extensions.htm)
says that the format of the 'path" attribute is:
/pluginID/path/file.xml#elementID
So, is it a bug that link_to="/PLUGINS_ROOT/<pluginID>/<tocfile>#anchorID"
does not work?
Or is PLUGINS_ROOT not useful for contributing into an anchor?
Is the best practice to use the path attribute format? For example:
link_to="/pluginID/path/file.xml#anchorID"
Thanks in advance!
--Lee Anne
Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #475603 is a reply to message #475569] Wed, 27 May 2009 18:59 Go to previous messageGo to next message
> does not work?
It really is not necessary to specify PLUGINS_ROOT when contributing to
an anchor. The support for PLUGINS_ROOT is only there to allow the TOC
contributions to use the same format as is used for hrefs. I suppose
that if we are going to support PLUGINS_ROOT we should also support
/PLUGINS_ROOT and you could file a bug on that.
Thanks! (was Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #475606 is a reply to message #475603] Fri, 29 May 2009 16:38 Go to previous message
Hi Chris,
Thanks for that confirmation about anchor contributions and PLUGINS_ROOT.
I was using a tool that kept inserting a slash into the path that I
typed for my link_to, and that was messing things up when I included
PLUGINS_ROOT in the path, and I could't figure out why having that slash
made such a difference in that case. :-)
Thanks again!
--Lee Anne
> > does not work?
Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #623378 is a reply to message #475569] Wed, 27 May 2009 18:59 Go to previous message
> does not work?
Thanks! (was Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #623380 is a reply to message #475603] Fri, 29 May 2009 16:38 Go to previous message
Hi Chris,
Thanks again!
--Lee Anne
> > does not work?
Previous Topic:Force Welcome page for product to open docked?
Next Topic:Link to a file outside the plugins folder
Current Time: Thu Jun 19 00:33:26 EDT 2025
Powered by FUDForum. Page generated in 0.06153 seconds
