Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter Search Scope
Infocenter Search Scope [message #475474] Tue, 07 April 2009 12:30 Go to next message
Could someone explain how help search scope in an Infocenter is meant to
work? This is the behavior I see:
1. When the infocenter is displayed, I click the Search Scope: link.
2. I define a search scope.
3. When I perform the search, Eclipse seems to ignore the scope settings,
and when I return to the Search Scope, I find that the scope I defined was
not saved.
If I delete cookies from my browser, and repeat the above, the same thing
happens, BUT, the Search Scope: link changes to Advanced Search. Clicking
on Advanced Search displays a dialog that allows me to restrict the scope
of the search.
So, is this behavior normal? Is the Search Scope: link meant to work in an
Infocenter? If not, is there a way to make the Advanced Search link
displayed by default? Perhaps my browser or more likely the Infocenter is
configured incorrectly, but I'm finding this confusing. Thanks in advance,
-Tom
Re: Infocenter Search Scope [message #475479 is a reply to message #475474] Thu, 09 April 2009 17:22 Go to previous messageGo to next message
Search scope should work from an infocenter if you allow cookies to be
written.
T. Proulx wrote:
> settings, and when I return to the Search Scope, I find that the scope I
> defined was not saved.
> thing happens, BUT, the Search Scope: link changes to Advanced Search.
> Clicking on Advanced Search displays a dialog that allows me to restrict
> the scope of the search.
> an Infocenter? If not, is there a way to make the Advanced Search link
> is configured incorrectly, but I'm finding this confusing. Thanks in
> advance,
> -Tom
Re: Infocenter Search Scope [message #475483 is a reply to message #475479] Tue, 14 April 2009 10:56 Go to previous messageGo to next message
Hi Chris,
My browser is set up to accept cookies. However, the behavior I described
remains (search scopes have no effect and are not saved). Do you have any
suggestions as to what else I can try? Thanks,
-Tom
Re: Infocenter Search Scope [message #475484 is a reply to message #475483] Tue, 14 April 2009 12:39 Go to previous message
The problems definitely seems to be related to the storing and
retrieving of cookies, but I'm not sure exactly how. In an infocenter
the help system stores any state variables such as working sets in a
cookie. If it cannot write cookies it will bring up a different search
dialog. Form the symptoms it appears that the help system has determined
that it can write data to a cookie in the search scope dialog, however
when the search scope dialog returns the cookie information is not read.
There is a limit to the amount of information that the help system will
store in a cookie and if your scope ends up containing too many
subtopics it will not get saved.
You could look at the area on disk where the cookies are stored and see
if any data has been saved. Also you could try with the smallest
possible search scope which only has one subtopic selected and see if
the problem remains.
T. Proulx wrote:
> Hi Chris,
> described remains (search scopes have no effect and are not saved). Do
> you have any suggestions as to what else I can try? Thanks,
> -Tom
Re: Infocenter Search Scope [message #623327 is a reply to message #475474] Thu, 09 April 2009 17:22 Go to previous message
written.
T. Proulx wrote:
> advance,
> -Tom
Re: Infocenter Search Scope [message #623331 is a reply to message #475479] Tue, 14 April 2009 10:56 Go to previous message
Hi Chris,
-Tom
Re: Infocenter Search Scope [message #623332 is a reply to message #475483] Tue, 14 April 2009 12:39 Go to previous message
T. Proulx wrote:
> Hi Chris,
> -Tom
Previous Topic:JA KO Extended character Infocenter Help issue
Next Topic:A handler conflict occurred. This may disable some commands.
Current Time: Fri Jul 18 20:00:06 EDT 2025
Powered by FUDForum. Page generated in 0.07595 seconds
