Reverse engineering tool [message #475316] |
Mon, 08 September 2008 15:17 |
Originally posted by: jmcq.cs.nuim.ie
Can anyone recommend a tool that reverse engineers UML class diagrams
from Java code and presents the class diagram as a .uml file.
Jacqui
Re: Reverse engineering tool [message #476322 is a reply to message #475316] |
Mon, 16 February 2009 07:56 |
Originally posted by: berenger.dulac.mnhn.fr
--------------010704070400090401000801
There is also coffea.sourceforge.net which is in alpha stage and allows
you to reverse engineer a class diagram from source code and also to
browse the source code through a class diagram...
The only problem currently is the use with big projects : with more than
hundred files with this plugin it is safer to reverse engineer not the
whole project but package after package.
Hope this can help,
B
Re: Reverse engineering tool [message #623604 is a reply to message #475316] |
Hope this can help,
B
FUDForum. Page generated in 0.04772 seconds
