Re: infocenter search database [message #475255 is a reply to message #475253] |
Mon, 16 March 2009 19:41 |
David Kyle Messages: 125 Registered: July 2009 |
Only 41 minutes after reporting the bug, the problem is fixed and targeted
for 3.5 M7 (May 1st, 2009). Thanks Chris!
David
"David Kyle" <davidk@kelman.com> wrote in message
news:gpeosd$4pb$1@build.eclipse.org...
> Chris,
> I've entered it as https://bugs.eclipse.org/bugs/show_bug.cgi?id=268623.
> David
> "Chris Goldthorpe" <cgold@us.ibm.com> wrote in message
> news:gpc43e$nej$1@build.eclipse.org...
>>I misspoke. I had forgotten that I had implemented this a while ago but it
>>looks as though it is not implemented for xhtml files or files with a
>>doctype of xhtml. That was an oversight. David can you file a bug report
>>for this?
>> Chris
>> Lee Anne Kowalski wrote:
>>> Hi Chris,
>>> I'm not sure what this statement implies:
>>> > The keywords meta tag is ignored for html and xhtml files.
>>> Isn't usage of the keywords meta tag in HTML files covered under this
>>> Bugzilla (marked Fixed):
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=223860
>>> Is that meta tag only being ignored for XHTML files (vs HTML files)?
>>> Thanks in advance,
>>> Lee Anne
>>> Chris Goldthorpe wrote:
>>>> The keywords meta tag is ignored for html and xhtml files. It may be
>>>> that for xml files the entire content of the file is added to the
>>>> search index. We have considered adding them to the search index.
>>>> David Kyle wrote:
>>>>> I have a small problem that I don't fully understand. I have an
>>>>> infocenter which is working except that the meta keywords are not
>>>>> being included in the search database.
>>>>> The keywords 'ooga' and 'booga' in the following text is not put into
>>>>> <?xml version="1.0" encoding="UTF-8"?><!DOCTYPE html PUBLIC
>>>>> "-//W3C//DTD XHTML 1.0 Transitional//EN"
>>>>> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
>>>>> <html lang="en-us" xml:lang="en-us">
>>>>> <head>
>>>>> <meta content="ooga, booga" name="keywords" />
>>>>> </head>
>>>>> <body>
>>>>> </body>
>>>>> </html>
>>>>> If I remove the DOCTYPE information then the keywords are placed in
>>>>> <head>
>>>>> </head>
>>>>> <body>
>>>>> </body>
>>>>> </html>
>>>>> Are 'keywords' not supported with xhtml?
>>>>> Thanks,
>>>>> David
Re: infocenter search database [message #623252 is a reply to message #475253] |
David
> Chris,
> David
>>for this?
>> Chris
>>> Hi Chris,
>>> Thanks in advance,
>>> Lee Anne
>>>>> <head>
>>>>> </head>
>>>>> <body>
>>>>> </body>
>>>>> </html>
>>>>> <head>
>>>>> </head>
>>>>> <body>
>>>>> </body>
>>>>> </html>
>>>>> Thanks,
>>>>> David
FUDForum. Page generated in 0.04004 seconds
