Borland Together 2006 [message #475131] |
Tue, 14 August 2007 14:18 |
Amongst our diverse range of UML tools is Together 2006 release 2.
This appears to be based on the Eclipse UML2 tools.
What I am looking to is to examine & change the properties of the
underlying EMF model.
Does anyone know how this can be achieved wrt Together or indeed if
there is a UML2 standard way which should work assuming that together is
fully based on the UML2 code?
TIA
Adam
Re: Borland Together 2006 [message #475132 is a reply to message #475131] |
Tue, 14 August 2007 15:14 |
Originally posted by: Elena.Alekseeva.borland.com
Together is _not_ based on Eclipse UML2 tools. uml2 package is used there
for XMI interchange only.
You can use Together EMF API for getting access to Tg model - the EMF model
that can be obtained via API is syncronized with Tg model. You can find the
short API reference in Help, Reference/MDA/EMF API for Together Models
"AdamF" <user@domain.invalid> wrote in message
news:f9sdj9$890$1@build.eclipse.org...
> Does anyone know how this can be achieved wrt Together or indeed if there
> is a UML2 standard way which should work assuming that together is fully
> TIA
> Adam
Re: Borland Together 2006 [message #475133 is a reply to message #475132] |
Wed, 15 August 2007 06:59 |
>> TIA
>> Adam
Thanks.
Adam
Re: Borland Together 2006 [message #624414 is a reply to message #475131] |
> TIA
> Adam
Re: Borland Together 2006 [message #624415 is a reply to message #475132] |
>> TIA
>> Adam
Thanks.
Adam
FUDForum. Page generated in 0.02632 seconds
