Home » Eclipse Projects » JavaServer Faces » 2.0.1RC1 JSF semantics validator performance
Re: 2.0.1RC1 JSF semantics validator performance [message #475078 is a reply to message #475076] |
Tue, 11 September 2007 13:48 |
Yury Kats Messages: 104 Registered: July 2009 |
On 9/11/2007 5:11 AM, Vadim Dmitriev wrote:
> Hi!
> Just installed WTP 2.0.1RC1 and noticed, that JSF Semantics validator
> performance degraded about 15-20 times. Is such a performance drop to be
> expected in FR of 2.0.1?
> Searched bugzilla and haven't found any fixed/opened bugs related to jsf
> validator mechanism. Sorry, if I panic too early, but I consider RC's as
> bug fixing stage when no new features are added. And since jsf validator
> was rather fast in previous 2.0.1 builds, I think it is something
> intentionally changed :)
I don't if there were any changes recently, but was it ever fast, really?
Maybe you were testing with different JSPs? The more complex the JSP,
the slower it gets, especially when there are many EL expressions.
This bug has been open for a while now, and just deferred to 3.0:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163890
Re: 2.0.1RC1 JSF semantics validator performance [message #475080 is a reply to message #475078] |
Tue, 11 September 2007 16:42 |
Vadim Dmitriev Messages: 74 Registered: July 2009 |
Member |
Thanks for reply, Yury.
I was testing on project, that is almost complete and now it is in
testing stage so JSPs are mainly stay unchanged for a long time. It
consist of relatively 250 JSPs and with even 3 weeks-old WTP2.0.1 build
validated in 4 minutes topmost (the same for 2.0 release). With 2.0.1RC1
estimated completion time is about 40 or so minutes. It looks like
validation algorithm changed and i don't have nor time neither i have
will to check validation sources myself to see whether it is true :)
Well, maybe it worth to wait for RC2.
Best regards.
Re: 2.0.1RC1 JSF semantics validator performance [message #475081 is a reply to message #475080] |
Tue, 11 September 2007 17:54 |
Cameron Bateman Messages: 481 Registered: July 2009 |
I am seeing significant degradation on the variable resolver stress test:
Report for performance test: Stress Variable Resolver
Number of iterations: 100000
Max: 2,469,061,850, Max Index: 0
Min: 2,793,092, Min Index: 71,326
Avg: 3,793,538, StdDev: 8,415,462.297, StdDev Ignore Max/Min: 3,169,308.624
Compared with:
Max: 2,812,605,233, Max Index: 0
Min: 156,444, Min Index: 77,049
Avg: 257,688, StdDev: 8,915,112.194, StdDev Ignore Max/Min: 621,480.648
In the 2.0 pre-release baseline using Matthias' type info caching
mechanism. The property resolver may have degraded slightly too, but it
looks like by only about 10% which could be within the natural variance of
the test.
If this is a serious issue for you in 2.0 please escalate the bug:
by ramping the severity. Also, if you could run the StressTest test case
(use -Xmx256M -XX:PermSize=256M) in org.eclipse.jst.jsf.validation.el and
paste your console output to the bug, that would help too.
--Cam
Re: 2.0.1RC1 JSF semantics validator performance [message #614417 is a reply to message #475076] |
> Hi!
Re: 2.0.1RC1 JSF semantics validator performance [message #614418 is a reply to message #475078] |
Member |
Best regards.
Re: 2.0.1RC1 JSF semantics validator performance [message #614421 is a reply to message #475080] |
Compared with:
the test.
--Cam
Current Time: Sat Apr 20 01:15:16 GMT 2024
Powered by FUDForum. Page generated in 0.03916 seconds
